  3. Leaf Wetness
Leaf Wetness
45 Posts 9 Posters 38.6k Views 3 Watching
  • elisavetgrigE
    elisavetgrigE
    elisavetgrig
    wrote on last edited by elisavetgrig
    #29
    • elisavetgrigE
      elisavetgrigE
      elisavetgrig
      Did you mean something like the figure above? Or I only need to connect one resistor to one wire and the other wire to another pin in the Arduino?
      SparkmanS 1 Reply Last reply
      • elisavetgrigE elisavetgrig
        SparkmanS
        SparkmanS
        Sparkman
        @elisavetgrig You're missing the connections to a voltage source and ground. You also only need one resistor as the wetness sensor is the 2nd resistor in the voltage divider circuit. Take a look at this: http://homepage.cs.uri.edu/faculty/hamel/workshops/as220-sept-09/sensors-voltage-dividers.html.
        Al
        • elisavetgrigE
          elisavetgrigE
          elisavetgrig
          You are right! I thought that I missing something... always there are Data connection, VCC connection and GND.. and I had only one! I made another dummy scheme... Is that better?leaf wetness.jpg
            SparkmanS
            SparkmanS
            Sparkman
            @elisavetgrig Take a look at the second diagram of the link I posted. Right now you show the GND pin connected to the Analog pin and Vcc is also connected to the same spot, so that's not going to work.
            Al
            • elisavetgrigE
              elisavetgrigE
              elisavetgrig
              I based in the second diagram... i think that I understand it... resistorss-leaf wet.png
                SparkmanS
                SparkmanS
                Sparkman
                @elisavetgrig As I mentioned a few posts ago and how it's shown in the diagram on that link, is that you only need one resistor. The leaf wetness sensor becomes the other resistor in the circuit. In your last diagram, you have both the terminals of the wetness sensor connected to ground. Think of the wetness sensor as a resistor, with each of the terminals representing one leg of a regular resistor.
                Al
                • elisavetgrigE
                  elisavetgrigE
                  elisavetgrig
                  OK... So I need only one resister... I think that "Scheme 2" is closer to the solution... images ofs.jpg
                  • 5546dug5
                    5546dug5
                    5546dug
                    @epierre how is the gold plating holding out on the sensor?
                    Is there pitting and would you'd recommend this over the style in the store?
                    How is the battery life with this setup?
                    • epierreE
                      epierreE
                      epierre
                      gold plating is a must have for outdoor.
                      I am now regarding to have something more robust in time , I'm waiting for a light with movement with solar pannel to modify it for it.
                      z-wave - Vera -> Domoticz
                      • AWIA
                        AWIA
                        AWI
                        wrote on last edited by AWI
                        #39
                        In the case described there is a constant battery drain when there is "wetness" (moisture) on the sensor. This also implies an electrolytic process which takes care of eroding your sensor. No matter if you use gold plating or not.
                        To avoid both you can supply the sensor during measurement only -and- reverse te polarity each time.
                        An example ketch which takes care of measuring three moisture sensors which relies on this principle.
                        (the actual measurement is in the "ReadMoistureValues()" routine)
                         PROJECT: MySensors / Floor moisture sensor - measures moisture
                         PROGRAMMER: AWI
                         DATE: june 7, 2015/ last update: june 9, 2015
                         FILE: AWI_FloorMoisture.ino
                         LICENSE: Public domain
                         Hardware: tbd .- ATmega328p board w/ NRF24l01
                        	and MySensors 1.4
                        	(later: Temp & Humidity - HTU21)
                        Special:
                        	program with Arduino Pro 3.3V 8Mhz
                        SUMMARY:
                        	Moisture by analog read a polarity switching voltage divider between (high/ low)
                         Remarks:
                        	Fixed node-id
                        #include <Wire.h> 								// I2C
                        #define batteryVoltagePin A0
                        #define MoistureHighPin 3
                        #define MoistureLowPin 4
                        #define Moisture1ReadPin A1
                        #define Moisture2ReadPin A2
                        #define Moisture3ReadPin A3
                        #define BuzzerPin 5
                        #define LedPin 6
                        // MySensors Child ID's
                        #define MOISTURE1_CHILD_ID 5					// Moisture 1
                        #define MOISTURE2_CHILD_ID 6					// Moisture 2
                        #define MOISTURE3_CHILD_ID 7					// Moisture 3
                        // #define MOISTURE4_CHILD_ID 8					// Moisture 4
                        // MySensors messages
                        MyMessage moisturePercentageMsg1(MOISTURE1_CHILD_ID, V_HUM);	// Percentage
                        MyMessage moisturePercentageMsg2(MOISTURE2_CHILD_ID, V_HUM);	// Percentage
                        MyMessage moisturePercentageMsg3(MOISTURE3_CHILD_ID, V_HUM);	// Percentage
                        // MySensors instantiate
                        MySensor gw(9,10); 								// board, 3.3v (pin default 9,10)
                        // Reference values for ADC and Battery measurements
                        const float VccMin        = 1.0*3.5;    // Minimum expected Vcc level, in Volts. Example for 1 rechargeable lithium-ion.
                        const float VccMax        = 1.0*4.2;    // Maximum expected Vcc level, in Volts.
                        float VccReference = 3.3 ;				// voltage reference for measurement (=vcc)
                        unsigned long SLEEP_TIME = 60000;  		//  10 sec sleep time between reads (seconds * 1000 milliseconds)
                        // **** class for Moisture measurement *****
                        // attaches an analog input to a data structure for measurements
                        // 			measures % of full scale voltage and scales the range of actual values
                        // 			stores current/ min & max values for the sensor
                        class MoistureSense
                        public:
                        	// Create an instance of MoistureSense and initialize (digital & input pin and reference values)
                          MoistureSense(uint8_t ReadPin, int LowValue, int HighValue) ; 		// attach to pin and init
                          void ReadHigh();								// Read moisture if positive
                          void ReadLow();								// Read moisture with polarity inverted
                          // average the low/ high readings ang get the moisture percent value
                          uint8_t MoisturePercent();
                          void ResetMinMax();							// reset min & max values
                        protected:
                          uint8_t _ReadPin ; 							// Hardware Analog Pin number
                          int _CurMoisture, _MaxMoisture, _MinMoisture, _Low, _High, _HighValue, _LowValue ;
                          uint8_t _curState;
                        // to create an instance of MoistureSense and initialize (input pin and reference values)
                        MoistureSense::MoistureSense(uint8_t ReadPin, int LowValue, int HighValue) {		// attach to pins and init
                        	_ReadPin = ReadPin;
                        	_LowValue = LowValue;
                        	_HighValue = HighValue;
                        	_CurMoisture = _MaxMoisture = _MinMoisture = NULL ;	// min & max in percent
                        void MoistureSense::ReadHigh()
                         // Read moisture with high polarity (in relation to Gnd)
                        	_High = analogRead(_ReadPin);
                        void MoistureSense::ReadLow()
                         // Read moisture with low polarity (in relation to Vcc)
                        	_Low = 1024 - analogRead(_ReadPin);
                        void MoistureSense::ResetMinMax()
                         // Reset min & max values
                        	_MinMoisture = _MaxMoisture = _CurMoisture;
                        uint8_t MoistureSense::MoisturePercent()
                        	uint8_t reading = constrain(map((_Low + _High)/2, _LowValue, _HighValue, 0, 100),0,100);	// average map to the 0-100% range
                        	_MinMoisture = min(reading, _MinMoisture);	// set min and max values
                        	_MaxMoisture = max(reading, _MaxMoisture);
                        // Instantiate moisture sensor objects
                        MoistureSense Moisture1(Moisture1ReadPin, 0, 1024);
                        MoistureSense Moisture2(Moisture2ReadPin, 0, 1024);
                        MoistureSense Moisture3(Moisture3ReadPin, 0, 1024);
                        void setup(){
                          	// MySensors setup (baud 115200)
                        	gw.begin(NULL, 21);  // fixed node 21, (final: connected to repeater 3 (living))"
                        	gw.sendSketchInfo("AWI FloorMoisture 21", "1.0");
                        	gw.present(MOISTURE1_CHILD_ID, S_HUM);			// Present Moisture sensors as humidity
                        	gw.present(MOISTURE2_CHILD_ID, S_HUM);			// Present Moisture sensors as humidity
                        	gw.present(MOISTURE3_CHILD_ID, S_HUM);			// Present Moisture sensors as humidity
                        	Serial.print("AWI Moisture Started ");
                        	pinMode(BuzzerPin,OUTPUT);						// Setup intermittent buzzer & light
                        	pinMode(LedPin,OUTPUT);
                        void loop(){
                        	Serial.println("Moisture Percentages");
                        	ReadMoistureValues();
                        	gw.send(moisturePercentageMsg1.set(Moisture1.MoisturePercent())); // MySensors Send (V)
                        	gw.send(moisturePercentageMsg2.set(Moisture2.MoisturePercent())); // MySensors Send (V)
                        	gw.send(moisturePercentageMsg3.set(Moisture3.MoisturePercent())); // MySensors Send (V)
                        	gw.sendBatteryLevel(batteryPercentage());
                        	// show local alarm if moisture > 20%
                        	if ((Moisture1.MoisturePercent()>20) || (Moisture2.MoisturePercent()>20) ||
                        		(Moisture3.MoisturePercent()>20) || (batteryPercentage() < 10))
                        		MoistureAlarm();
                        	gw.sleep(SLEEP_TIME);							// low power for sleep time
                        unsigned ReadMoistureValues()
                        // read all moisturevalues
                        	pinMode(MoistureLowPin, OUTPUT);				// first set all pins to measurement(non floating) mode
                        	pinMode(MoistureHighPin, OUTPUT);
                        	digitalWrite(MoistureLowPin, LOW); 				// Set polarity on voltage divider high and read the values
                        	digitalWrite(MoistureHighPin, HIGH); delayMicroseconds(100);
                        	Moisture1.ReadLow(); delayMicroseconds(100);
                        	Moisture2.ReadLow(); delayMicroseconds(100);
                        	Moisture3.ReadLow(); delayMicroseconds(100);
                        	digitalWrite(MoistureLowPin, HIGH);				// reverse polarity on voltage divider and read values
                        	digitalWrite(MoistureHighPin, LOW); delayMicroseconds(100);
                        	Moisture1.ReadHigh(); delayMicroseconds(100);
                        	Moisture2.ReadHigh(); delayMicroseconds(100);
                        	Moisture3.ReadHigh(); delayMicroseconds(100);
                        	pinMode(MoistureLowPin, INPUT);					// reset pins to floating, to avoid power leakage
                        	pinMode(MoistureHighPin, INPUT);
                        	Serial.print("Moist1: ");
                        	Serial.print(Moisture1.MoisturePercent());
                        	Serial.print(" , Moist2: ");
                        	Serial.print(Moisture2.MoisturePercent());
                        	Serial.print(" , Moist3: ");
                        	Serial.print(Moisture3.MoisturePercent());
                        	Serial.println();
                        unsigned MoistureAlarm()
                        // If moisturelevel to high, sound & show local alarm
                        	delay(100);										// sound & light for 100ms, uses a lot of power, so no no need for power down
                        // get Battery Voltage & charge current
                        // assumes a balanced voltage divider on Battery and uses the Vcc as reference (3.3V in this case)
                        // Parameters:
                        // - VccMin = minimum battery voltage
                        // - VccMax = maximum battery voltage
                        // - VccReference = reference voltage for ADC
                        uint8_t batteryPercentage()
                        	float batteryVoltage = ((float)analogRead(batteryVoltagePin)* VccReference/1024) * 2;	// actual voltage is double
                        	Serial.print("Batt: ");
                        	Serial.print(batteryVoltage);
                        	Serial.print("V ; ");
                        	return(constrain(map(batteryVoltage, VccMin, VccMax, 0, 100),0,100));	// and map to the 0-100% range
                          This is a great idea to get less erosion!
                          • epierreE
                            epierreE
                            epierre
                            @AWI your sketch has 3 sensors ? do you use a special wiring or you just get through high and low ?
                            The sketch on soil humidity does this but with two pins to make kind of AC current, but it needs also some gypsum to protect the electrodes.
                            . Leaf wetness is not immersed by nature hopefully ;-)
                            AWIA 1 Reply Last reply
                            • epierreE epierre
                              AWIA
                              AWIA
                              AWI
                              #42
                              @epierre It has 3 sensors with copper wiring. It switches the polarity of the voltage divider (1 Mohm in series with the "sensor") and measures the voltage over the sensor. Actualy it is a moisture alarm for a sensitive wooden floor.
                              and I learned something today :smirk:
                              "Gypsum is a soft sulfate mineral composed of calcium sulfate dihydrate, with the chemical formula CaSO4·2H2O"
                              • epierreE
                                epierreE
                                epierre
                                @AWI You can call it also "Plaster of Paris" ;-)
                                When immersed you need to protect it whatever you do : http://vanderleevineyard.com/1/category/vinduino/1.html
                                • epierreE
                                  epierreE
                                  epierre
                                  @awi going back to you above sketch, what is your wiring ?
                                  • epierreE
                                    epierreE
                                    epierre
                                    #45
                                    I guess it is the same as Vinduino :
                                    with their test code:
                                    // This program tests 3 soil sensor inputs and prints bias caused by galvanic effects
                                    // Copyright (C) 2015, Reinier van der Lee
                                    // www.vanderleevineyard.com
                                    // This program is free software: you can redistribute it and/or modify
                                    // it under the terms of the GNU General Public License as published by
                                    // the Free Software Foundation, either version 3 of the License, or
                                    // any later version.
                                    // This program is distributed in the hope that it will be useful,
                                    // but WITHOUT ANY WARRANTY; without even the implied warranty of
                                    // MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
                                    // GNU General Public License for more details.
                                    #include <math.h>       // Conversion equation from resistance to %
                                    // Setting up format for reading 3 soil sensors
                                    #define NUM_READS 10    // Number of sensor reads for filtering
                                    long buffer[NUM_READS];
                                    int index;
                                    typedef struct {        // Structure to be used in percentage and resistance values matrix to be filtered (have to be in pairs)
                                      int moisture;
                                      long resistance;
                                    } values;
                                    const long knownResistor = 1500;  // Constant value of known resistor in Ohms
                                    int supplyVoltage;                // Measured supply voltage
                                    int sensorVoltage;                // Measured sensor voltage
                                    values valueOf[NUM_READS];        // Calculated moisture percentages and resistances to be sorted and filtered
                                    int i;                            // Simple index variable
                                      // initialize serial communications at 9600 bps:
                                      // initialize the digital pins as an output.
                                      // Pin 6,7 is for sensor 1
                                      pinMode(6, OUTPUT);
                                      pinMode(7, OUTPUT);
                                    measure(1,6,7,1);
                                    Serial.print ("\t");
                                    Serial.println (average());
                                    long read1 = average();
                                    measure(1,7,6,0);
                                    long read2= average();
                                    long sensor1 = (read1 + read2)/2;
                                    Serial.print ("resistance bias =" );
                                    Serial.println (read1-read2);
                                    Serial.print ("sensor bias compensated value = ");
                                    Serial.println (sensor1);
                                    Serial.println ();
                                     delay (3000);
                                    void measure (int sensor, int phase_b, int phase_a, int analog_input)
                                      // read sensor, filter, and calculate resistance value
                                      // Noise filter: median filter
                                      for (i=0; i<NUM_READS; i++) {
                                        // Read 1 pair of voltage values
                                        digitalWrite(phase_a, HIGH);                 // set the voltage supply on
                                        delayMicroseconds(25);
                                        supplyVoltage = analogRead(analog_input);   // read the supply voltage
                                        digitalWrite(phase_a, LOW);                  // set the voltage supply off
                                        delay(1);
                                        digitalWrite(phase_b, HIGH);                 // set the voltage supply on
                                        sensorVoltage = analogRead(analog_input);   // read the sensor voltage
                                        digitalWrite(phase_b, LOW);                  // set the voltage supply off
                                        // Calculate resistance
                                        // the 0.5 add-term is used to round to the nearest integer
                                        // Tip: no need to transform 0-1023 voltage value to 0-5 range, due to following fraction
                                        long resistance = (knownResistor * (supplyVoltage - sensorVoltage ) / sensorVoltage)-457 ;
                                        delay(1);
                                        addReading(resistance);
                                        Serial.print (resistance);
                                    // Averaging algorithm
                                    void addReading(long resistance){
                                      buffer[index] = resistance;
                                      index++;
                                      if (index >= NUM_READS) index = 0;
                                    long average(){
                                      long sum = 0;
                                      for (int i = 0; i < NUM_READS; i++){
                                        sum += buffer[i];
                                      return (long)(sum / NUM_READS);
                                    and my hall of fame and shame of sensors I've tried :
