  3. Leaf Wetness
Leaf Wetness
45 Posts 9 Posters 39.2k Views 3 Watching
  • elisavetgrigE
    elisavetgrigE
    elisavetgrig
    Hey,
    I am a newbie (in the forum) and in the arduino/sensors development. I bought the Leaf Wetness from cooking-hacks.com. Can I connected it to my Arduino via Analog input? Is it easy?
    SparkmanS 1 Reply Last reply
    • elisavetgrigE elisavetgrig
      Hey,
      SparkmanS
      SparkmanS
      Sparkman
      @elisavetgrig Welcome to the forum. The answer is yes to both questions. Given that the sensor is a resistive element, you need to build a voltage divider. Google "voltage divider" Arduino and you'll find lots of examples.
      Al
      • FotoFieberF
        FotoFieberF
        FotoFieber
        Measuring the current with DC doesn't seem to be the ideal solution:
        thread
        • FotoFieberF FotoFieber
          thread
          SparkmanS
          SparkmanS
          Sparkman
          @FotoFieber That thread is regarding soil moisture measurements which is different than leaf wetness. For soil, capacitive is the best way to go IMHO.
          Al
          • FotoFieberF
            FotoFieberF
            FotoFieber
            AC Statement ☺
            • elisavetgrigE
              elisavetgrigE
              elisavetgrig
              ok...Thank you... I will try the "voltage divider" and I will see what will happen!
              • elisavetgrigE
                elisavetgrigE
                elisavetgrig
                wrote on last edited by elisavetgrig
                #29
                • elisavetgrigE
                  elisavetgrigE
                  elisavetgrig
                  Did you mean something like the figure above? Or I only need to connect one resistor to one wire and the other wire to another pin in the Arduino?
                    SparkmanS
                    SparkmanS
                    Sparkman
                    @elisavetgrig You're missing the connections to a voltage source and ground. You also only need one resistor as the wetness sensor is the 2nd resistor in the voltage divider circuit. Take a look at this: http://homepage.cs.uri.edu/faculty/hamel/workshops/as220-sept-09/sensors-voltage-dividers.html.
                    Al
                    • elisavetgrigE
                      elisavetgrigE
                      elisavetgrig
                      You are right! I thought that I missing something... always there are Data connection, VCC connection and GND.. and I had only one! I made another dummy scheme... Is that better?leaf wetness.jpg
                        SparkmanS
                        SparkmanS
                        Sparkman
                        @elisavetgrig Take a look at the second diagram of the link I posted. Right now you show the GND pin connected to the Analog pin and Vcc is also connected to the same spot, so that's not going to work.
                        Al
                        • elisavetgrigE
                          elisavetgrigE
                          elisavetgrig
                          I based in the second diagram... i think that I understand it... resistorss-leaf wet.png
                            SparkmanS
                            SparkmanS
                            Sparkman
                            @elisavetgrig As I mentioned a few posts ago and how it's shown in the diagram on that link, is that you only need one resistor. The leaf wetness sensor becomes the other resistor in the circuit. In your last diagram, you have both the terminals of the wetness sensor connected to ground. Think of the wetness sensor as a resistor, with each of the terminals representing one leg of a regular resistor.
                            Al
                            • elisavetgrigE
                              elisavetgrigE
                              elisavetgrig
                              OK... So I need only one resister... I think that "Scheme 2" is closer to the solution... images ofs.jpg
                              • 5546dug5
                                5546dug5
                                5546dug
                                @epierre how is the gold plating holding out on the sensor?
                                Is there pitting and would you'd recommend this over the style in the store?
                                How is the battery life with this setup?
                                • epierreE
                                  epierreE
                                  epierre
                                  gold plating is a must have for outdoor.
                                  I am now regarding to have something more robust in time , I'm waiting for a light with movement with solar pannel to modify it for it.
                                  z-wave - Vera -> Domoticz
                                  • AWIA
                                    AWIA
                                    AWI
                                    wrote on last edited by AWI
                                    #39
                                    In the case described there is a constant battery drain when there is "wetness" (moisture) on the sensor. This also implies an electrolytic process which takes care of eroding your sensor. No matter if you use gold plating or not.
                                    To avoid both you can supply the sensor during measurement only -and- reverse te polarity each time.
                                    An example ketch which takes care of measuring three moisture sensors which relies on this principle.
                                    (the actual measurement is in the "ReadMoistureValues()" routine)
                                     PROJECT: MySensors / Floor moisture sensor - measures moisture
                                     PROGRAMMER: AWI
                                     DATE: june 7, 2015/ last update: june 9, 2015
                                     FILE: AWI_FloorMoisture.ino
                                     LICENSE: Public domain
                                     Hardware: tbd .- ATmega328p board w/ NRF24l01
                                    	and MySensors 1.4
                                    	(later: Temp & Humidity - HTU21)
                                    Special:
                                    	program with Arduino Pro 3.3V 8Mhz
                                    SUMMARY:
                                    	Moisture by analog read a polarity switching voltage divider between (high/ low)
                                     Remarks:
                                    	Fixed node-id
                                    #include <Wire.h> 								// I2C
                                    #define batteryVoltagePin A0
                                    #define MoistureHighPin 3
                                    #define MoistureLowPin 4
                                    #define Moisture1ReadPin A1
                                    #define Moisture2ReadPin A2
                                    #define Moisture3ReadPin A3
                                    #define BuzzerPin 5
                                    #define LedPin 6
                                    // MySensors Child ID's
                                    #define MOISTURE1_CHILD_ID 5					// Moisture 1
                                    #define MOISTURE2_CHILD_ID 6					// Moisture 2
                                    #define MOISTURE3_CHILD_ID 7					// Moisture 3
                                    // #define MOISTURE4_CHILD_ID 8					// Moisture 4
                                    // MySensors messages
                                    MyMessage moisturePercentageMsg1(MOISTURE1_CHILD_ID, V_HUM);	// Percentage
                                    MyMessage moisturePercentageMsg2(MOISTURE2_CHILD_ID, V_HUM);	// Percentage
                                    MyMessage moisturePercentageMsg3(MOISTURE3_CHILD_ID, V_HUM);	// Percentage
                                    // MySensors instantiate
                                    MySensor gw(9,10); 								// board, 3.3v (pin default 9,10)
                                    // Reference values for ADC and Battery measurements
                                    const float VccMin        = 1.0*3.5;    // Minimum expected Vcc level, in Volts. Example for 1 rechargeable lithium-ion.
                                    const float VccMax        = 1.0*4.2;    // Maximum expected Vcc level, in Volts.
                                    float VccReference = 3.3 ;				// voltage reference for measurement (=vcc)
                                    unsigned long SLEEP_TIME = 60000;  		//  10 sec sleep time between reads (seconds * 1000 milliseconds)
                                    // **** class for Moisture measurement *****
                                    // attaches an analog input to a data structure for measurements
                                    // 			measures % of full scale voltage and scales the range of actual values
                                    // 			stores current/ min & max values for the sensor
                                    class MoistureSense
                                    public:
                                    	// Create an instance of MoistureSense and initialize (digital & input pin and reference values)
                                      MoistureSense(uint8_t ReadPin, int LowValue, int HighValue) ; 		// attach to pin and init
                                      void ReadHigh();								// Read moisture if positive
                                      void ReadLow();								// Read moisture with polarity inverted
                                      // average the low/ high readings ang get the moisture percent value
                                      uint8_t MoisturePercent();
                                      void ResetMinMax();							// reset min & max values
                                    protected:
                                      uint8_t _ReadPin ; 							// Hardware Analog Pin number
                                      int _CurMoisture, _MaxMoisture, _MinMoisture, _Low, _High, _HighValue, _LowValue ;
                                      uint8_t _curState;
                                    // to create an instance of MoistureSense and initialize (input pin and reference values)
                                    MoistureSense::MoistureSense(uint8_t ReadPin, int LowValue, int HighValue) {		// attach to pins and init
                                    	_ReadPin = ReadPin;
                                    	_LowValue = LowValue;
                                    	_HighValue = HighValue;
                                    	_CurMoisture = _MaxMoisture = _MinMoisture = NULL ;	// min & max in percent
                                    void MoistureSense::ReadHigh()
                                     // Read moisture with high polarity (in relation to Gnd)
                                    	_High = analogRead(_ReadPin);
                                    void MoistureSense::ReadLow()
                                     // Read moisture with low polarity (in relation to Vcc)
                                    	_Low = 1024 - analogRead(_ReadPin);
                                    void MoistureSense::ResetMinMax()
                                     // Reset min & max values
                                    	_MinMoisture = _MaxMoisture = _CurMoisture;
                                    uint8_t MoistureSense::MoisturePercent()
                                    	uint8_t reading = constrain(map((_Low + _High)/2, _LowValue, _HighValue, 0, 100),0,100);	// average map to the 0-100% range
                                    	_MinMoisture = min(reading, _MinMoisture);	// set min and max values
                                    	_MaxMoisture = max(reading, _MaxMoisture);
                                    // Instantiate moisture sensor objects
                                    MoistureSense Moisture1(Moisture1ReadPin, 0, 1024);
                                    MoistureSense Moisture2(Moisture2ReadPin, 0, 1024);
                                    MoistureSense Moisture3(Moisture3ReadPin, 0, 1024);
                                    void setup(){
                                      	// MySensors setup (baud 115200)
                                    	gw.begin(NULL, 21);  // fixed node 21, (final: connected to repeater 3 (living))"
                                    	gw.sendSketchInfo("AWI FloorMoisture 21", "1.0");
                                    	gw.present(MOISTURE1_CHILD_ID, S_HUM);			// Present Moisture sensors as humidity
                                    	gw.present(MOISTURE2_CHILD_ID, S_HUM);			// Present Moisture sensors as humidity
                                    	gw.present(MOISTURE3_CHILD_ID, S_HUM);			// Present Moisture sensors as humidity
                                    	Serial.print("AWI Moisture Started ");
                                    	pinMode(BuzzerPin,OUTPUT);						// Setup intermittent buzzer & light
                                    	pinMode(LedPin,OUTPUT);
                                    void loop(){
                                    	Serial.println("Moisture Percentages");
                                    	ReadMoistureValues();
                                    	gw.send(moisturePercentageMsg1.set(Moisture1.MoisturePercent())); // MySensors Send (V)
                                    	gw.send(moisturePercentageMsg2.set(Moisture2.MoisturePercent())); // MySensors Send (V)
                                    	gw.send(moisturePercentageMsg3.set(Moisture3.MoisturePercent())); // MySensors Send (V)
                                    	gw.sendBatteryLevel(batteryPercentage());
                                    	// show local alarm if moisture > 20%
                                    	if ((Moisture1.MoisturePercent()>20) || (Moisture2.MoisturePercent()>20) ||
                                    		(Moisture3.MoisturePercent()>20) || (batteryPercentage() < 10))
                                    		MoistureAlarm();
                                    	gw.sleep(SLEEP_TIME);							// low power for sleep time
                                    unsigned ReadMoistureValues()
                                    // read all moisturevalues
                                    	pinMode(MoistureLowPin, OUTPUT);				// first set all pins to measurement(non floating) mode
                                    	pinMode(MoistureHighPin, OUTPUT);
                                    	digitalWrite(MoistureLowPin, LOW); 				// Set polarity on voltage divider high and read the values
                                    	digitalWrite(MoistureHighPin, HIGH); delayMicroseconds(100);
                                    	Moisture1.ReadLow(); delayMicroseconds(100);
                                    	Moisture2.ReadLow(); delayMicroseconds(100);
                                    	Moisture3.ReadLow(); delayMicroseconds(100);
                                    	digitalWrite(MoistureLowPin, HIGH);				// reverse polarity on voltage divider and read values
                                    	digitalWrite(MoistureHighPin, LOW); delayMicroseconds(100);
                                    	Moisture1.ReadHigh(); delayMicroseconds(100);
                                    	Moisture2.ReadHigh(); delayMicroseconds(100);
                                    	Moisture3.ReadHigh(); delayMicroseconds(100);
                                    	pinMode(MoistureLowPin, INPUT);					// reset pins to floating, to avoid power leakage
                                    	pinMode(MoistureHighPin, INPUT);
                                    	Serial.print("Moist1: ");
                                    	Serial.print(Moisture1.MoisturePercent());
                                    	Serial.print(" , Moist2: ");
                                    	Serial.print(Moisture2.MoisturePercent());
                                    	Serial.print(" , Moist3: ");
                                    	Serial.print(Moisture3.MoisturePercent());
                                    	Serial.println();
                                    unsigned MoistureAlarm()
                                    // If moisturelevel to high, sound & show local alarm
                                    	delay(100);										// sound & light for 100ms, uses a lot of power, so no no need for power down
                                    // get Battery Voltage & charge current
                                    // assumes a balanced voltage divider on Battery and uses the Vcc as reference (3.3V in this case)
                                    // Parameters:
                                    // - VccMin = minimum battery voltage
                                    // - VccMax = maximum battery voltage
                                    // - VccReference = reference voltage for ADC
                                    uint8_t batteryPercentage()
                                    	float batteryVoltage = ((float)analogRead(batteryVoltagePin)* VccReference/1024) * 2;	// actual voltage is double
                                    	Serial.print("Batt: ");
                                    	Serial.print(batteryVoltage);
                                    	Serial.print("V ; ");
                                    	return(constrain(map(batteryVoltage, VccMin, VccMax, 0, 100),0,100));	// and map to the 0-100% range
                                      This is a great idea to get less erosion!
                                      • epierreE
                                        epierreE
                                        epierre
                                        @AWI your sketch has 3 sensors ? do you use a special wiring or you just get through high and low ?
                                        The sketch on soil humidity does this but with two pins to make kind of AC current, but it needs also some gypsum to protect the electrodes.
                                        . Leaf wetness is not immersed by nature hopefully ;-)
                                        AWIA 1 Reply Last reply
                                        • epierreE epierre
                                          AWIA
                                          AWIA
                                          AWI
                                          #42
                                          @epierre It has 3 sensors with copper wiring. It switches the polarity of the voltage divider (1 Mohm in series with the "sensor") and measures the voltage over the sensor. Actualy it is a moisture alarm for a sensitive wooden floor.
                                          and I learned something today :smirk:
                                          "Gypsum is a soft sulfate mineral composed of calcium sulfate dihydrate, with the chemical formula CaSO4·2H2O"
