  3. Washing machine state sensor
32 Posts 10 Posters 24.8k Views 7 Watching
  • Moshe LivneM Moshe Livne
    @ServiceXp I was thinking of having the logic in the arduino. should be simple, no? current drawn - in cycle. no current for 5 min - cycle ended. what am i missing?
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    I think it depends on your washers efficiency and the cycles you use. My washer is one of those HE machines that using adaptive cycle routines with-in the select load type. Creates a wattage watching nightmare. Couple that with Vera's instability, I just gave up and took a more direct approach.
    RJ_Make
    • RJ_MakeR RJ_Make
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @ServiceXp
      I like this project, but since my washer and dryer have LEDs which indicate that cycle is complete too, I was thinking to optically sense that cycle was complete if I cannot get to the electronics easily (and maybe even void my warrantee). I'm going to try to find a very small sensor, perhaps.
      My real issue is how to get my wife excited about increasing our laundry efficiency ;)
        Tried the washer thing a year back...
        But it quickly got down-voted by my wife after some innocent "bugs" in the watt-algorithm. I was forced to stop the Sonos speakers to announce "Tvätten är klar" ( <-- Swedish) several times during the wash cycle.
        Hope to build enough confident to give it another try. But I suspect we got one of these eco-washers...
        • DidiD
          DidiD
          Didi
          I bought one this year and my wife is really happy with it ;-)
          • K
            K
            kalle
            Maybe a vibration sensor do the trick ;-)
            like this one or similar: http://www.dfrobot.com/index.php?route=product/product&product_id=79#.VYM0i6O0N8E
              @ServiceXp
              Moshe LivneM
              Moshe LivneM
              Moshe Livne
              @BulldogLowell @ServiceXp Bosch in their infinite wisdom made the LED integral part of the start/stop button, putting a bit of a damper on optically sensing it. So far the 2 sound sensors I have are so bad that unless you do something really drastic like nuclear explosion they are very stoic about environmental beeps. they are ok for sensing knocks. now, I am not trying to sense Watt or try to profile the current use, as this is hopeless (my washing machine is also too smart for her own good). I am just going to watch for current draw above the "zero" over 5 min period. I think it would be safe enough but will not know until I get the sensors.....
              @kalle - got the vibration sensor in the mail yesterday! great minds, etc. but it is more complicated as while doing hot wash there are lengthy waits for the water to heat up.
              my plan is to use one of these powerboard things (http://www.mitre10.co.nz/shop/electrical_hardware/cords_powerboards/hpm_surge_protector_powerboard_6_way_106033/) and block the last two and use the space for the arduino and sensor to measure current on the last socket. I have excellent RCDs installed :-)
              @hek - I use discreet notification using google hangouts....
                mvdarend
                @kalle, I actually tried the vibration sensor (based on this design) but I could only get it to perform properly by pressing a button to tell the Arduino that the cycle had started, which made it useless for when I wanted the machine to delay the start.
                I tried checking for vibrations as a trigger for 'Machine start' but it would trigger when loading the machine, and again when unloading... basically that was useless.
                @Moshe-Livne, I wanted to try sensing electricity usage, but when profiling the machine I found that when 'off' it was still consuming almost 5 watts, which is not a major problem if you define that as a threshold, but our machine sometimes just sits there doing nothing as far as I can see during the cycle. I was worried it would be a bit of a 'hit and miss' affair as @hek experienced.
                @ServiceXp, I looked at your solution also when browsing the forums and almost went that way. But I didn;t want to open my machine, I know that my wife would not be happy about that. And with three small kids I can't afford to take my time about it, we need the machine every day :)
                Prateek GuptaP Moshe LivneM 2 Replies Last reply
                • M mvdarend
                  Prateek GuptaP
                  Prateek GuptaP
                  Prateek Gupta
                  @mvdarend hey I just stumbled across this post. I would like to draw your attention to something called as Power signature analysis.
                  There are some automation systems using it, such as neurio.io
                  I am still intrigued by it. Any electrical engineers here?
                  • M mvdarend
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @mvdarend you are a ray of sunshine, aren't you? I think power profiling is the way to go. although the washing machine will sit around doing nothing for a while (especially during pre-wash) I think it is still safe to say that there will be spikes of usage when heating, spinning, etc
                    I am not too fussy about catching the machine the minute it finished so even 30 min with nothing over the threshold will be fine for me. I tend to leave the washing for DAYS in the machine :disappointed:
                    I now have 3 different vibration sensors. They do work for an extent but as you said - the number of false positives is a pain.
                    @Prateek-Gupta I think that is a bit of over solving a washing machine problem :-)
                    Prateek GuptaP 1 Reply Last reply
                      Prateek GuptaP
                      Prateek GuptaP
                      Prateek Gupta
                      @Moshe-Livne Yes, I agree. But then this could be applied to a numerous electrical appliances across your home. Almost, all the devices have a unique power signature down to different operating modes.
                        mvdarend
                        Created a custom widget in HomeGenie and set it up to send PushBullet notifications. After running for a week I've noticed a few small problems.
                        • If I leave the door open and the sun shines on the sensor, it's status changes to 'Running'. Increasing the threshold doesn't help so I'll need to protect the sensor from outside elements better. *
                        • The LED on the machine also flashes just before it goes into running mode. I think I'll go with an extra status depending on the previous one (Off -> Flashing = 'stand by', Running -> flashing = 'Idle') or something like that.
                        • My 3D printer is ordered and on its way, so I'll be able to create a custom holder. You guys are killing my finances :)
                        • M mvdarend
                          Moshe LivneM
                          Moshe LivneM
                          Moshe Livne
                          @mvdarend While waiting for the current sensor (and also discovering that new powerboards have one way screws! evil people!), I have re-checked my vibration sensors. i am using this one http://www.aliexpress.com/item/1pc-lot-SW-420-Normally-Closed-Alarm-Vibration-Sensor-Module-Vibration-Switch-30512/32259757483.html which is better than the others i think.
                          currently I am just monitoring 5 minute periods and if there is a vibration during this time I mark it as "active". my theory (that I can't check as I ran out of laundry) is that 3 periods of vibrations signal that a cycle is in progress. a period of quite means the cycle has finished. will post final results the minute the kids will produce enough dirty cloths.
                            mvdarend
                            wrote on last edited by mvdarend
                            #23
                            @Moshe-Livne How is it working so far, have you been able to test it?
                            • M mvdarend
                              Moshe LivneM
                              Moshe LivneM
                              Moshe Livne
                              @mvdarend so far so good. have added a bit of logic to my sketch and need another load to test it :-)
                              this is the current sketch:
                              // Washing machine finished sketch
                              #define CHILD_ID 3
                              #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
                              #define SAMPLING_PERIOD 600000
                              int oldValue=-1;
                              unsigned long period_start = millis();
                              int state = -1;
                                gw.begin();
                               // Setup the button
                                pinMode(BUTTON_PIN,INPUT);
                                // Activate internal pull-up
                                gw.present(CHILD_ID, S_DOOR);
                              void report_state(int state)
                              	  	Serial.print("reporting state: ");
                              		Serial.println(state);
                              	    gw.send(msg.set(state));
                              int prev_state = -1;
                              int prev_state_length = 0;
                                // Get the update value
                                int value = digitalRead(BUTTON_PIN);
                                if (value == 1) {// 0 means vibration detected
                                	state = 1;
                                	Serial.println("setting state to 1");
                                Serial.println(millis()-period_start);
                                if (millis() - period_start > SAMPLING_PERIOD) {
                                  if (state != prev_state) {
                                		if (state == 1 && prev_state_length > 2) { //a vibration period after long period of quit means a cycle started
                                	    	report_state(state);
                              	    	prev_state_length = 1;
                                		} else if (state == 0 && prev_state_length > 2){ //a long quite period after a cycle means cycle finished
                              	prev_state = state;
                                  state = 0;
                                delay(100);
                              will refine it once i verify it works through all the different cycles - this is not even a tested version, just to give you an idea about how it works. looks promising so far.
                              • Moshe LivneM
                                Moshe LivneM
                                Moshe Livne
                                found some flaws in the logic - updated and checking - do not use the code above
                                  BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  #26
                                  @Moshe-Livne
                                  I think you can make this easier...
                                  It looks like you are looking for two motion events in the past two minutes to indicate washer is on?
                                  something like this (untested)
                                  #define CHILD_ID 3
                                  #define SAMPLING_PERIOD 600000UL
                                  unsigned long motionTime;
                                  unsigned long lastMotionTime = millis();
                                  boolean lastSensorState = false;
                                  boolean lastWasherState = false;
                                    gw.begin();
                                    pinMode(BUTTON_PIN, INPUT_PULLUP);
                                    boolean sensorState = digitalRead(BUTTON_PIN);// Get the updated sensor value
                                    if (sensorState != lastSensorState && lastSensorState == true) //detect state change from true to false
                                      lastMotionTime = motionTime; //cascade time back
                                      motionTime = millis();
                                    lastSensorState = sensorState;
                                    boolean washerState = (motionTime - lastMotionTime < SAMPLING_PERIOD && motionTime - millis() < SAMPLING_PERIOD);
                                    if (washerState != lastWasherState)
                                      gw.send(msg.set(washerState));
                                    lastWasherState = washerState;
                                    @Moshe-Livne
                                    #define CHILD_ID 3
                                      gw.begin();
                                    Moshe LivneM
                                    Moshe LivneM
                                    Moshe Livne
                                    @BulldogLowell It is slightly more complicated (but not much). the machine can idle for 5-10 min (well, not really idle, but idle enough so no vibrations will be felt). so, the current logic marks 5 minute periods. a vibration period marks the beginning of the cycle and 2 or 3 (yet to be determined) periods of quite marks end of cycle.
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      #28
                                      @Moshe-Livne
                                      so if no vibration is sensed in the past five (configurable) minutes machine is OFF, otherwise machine is ON?
                                      likewise you want to indicate Washing when two vibrations are sensed in less than two or three (configurable) minutes?
                                      yes?
                                        @Moshe-Livne
                                        #define CHILD_ID 3
                                          gw.begin();
                                        Moshe LivneM
                                        Moshe LivneM
                                        Moshe Livne
                                        @BulldogLowell re-reading your code, it would work well. the reason I made the "periods" was more to help me debug the scenario as I didn't want to sift through zillions of on/off.
                                        • BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          #30
                                          yeah, that is why it is important to just print() when there are state changes... added configuration and debug:
                                          #define CHILD_ID 3
                                          #define ONE_MINUTE 600000UL
                                            gw.begin();
                                            boolean washerState = ((motionTime - lastMotionTime < ONE_MINUTE * 2) && (motionTime - millis() < ONE_MINUTE * 5));
                                              Serial.print(F("Washer is "));
                                              Serial.println(washerState? F("ON") : F("OFF"));
                                            lastWasherState = sensorState;
