  3. Door, Motion and Temperature Sensor
63 Posts 11 Posters 48.8k Views 4 Watching
  • C Offline
    C Offline
    CaptainZap
    wrote on last edited by CaptainZap
    Hi guys,
    It's been a few months since I last made a sensor, and I'm experiencing some issues trying to create one now. I've made a sketch, from parts from other projects and made myself a 3in1 sensor, but the problem is that I have no parent node, and I can't understand why.
    Can anyone take a look over it and correct me ?
    Note that this is meant to be a power operated sensor. Thank you :)
    //This sketch is for Door & Motion & Temp Sensor
    #include <OneWire.h>
    char sketch_name[] = "Multi Sensor";
    char sketch_ver[]  = "1.0";
    #define CLIENT_ID AUTO  // Sets MYSensors client id
    #define RADIO_CH 76  // Sets MYSensors to use Radio Channel
    #define TRIGGER	3	// used to connect motion sensor
    #define BUTTON_PIN  4 // used to connect door/window sensor
    //Temp Sensor bits
    #define ONE_WIRE_BUS 14 // Pin where dallas sensor is connected
    DallasTemperature DallasSensors(&oneWire);
    float lastTemperature ;
    #define CHILD_ID_T1 3 //CHILD ID for temp
    //Door/Window bits
    #define CHILD_ID_D1 1 //CHILD ID for door/window
    //Trigger Sensor Bits
    #define CHILD_ID_S1 2 //CHILD ID for Reed/Motion sensor
    boolean lastTripped = 0;
    Bounce debouncer = Bounce();
    int oldValue=-1;
    MyMessage msg(CHILD_ID_D1,V_TRIPPED);
    MyMessage triggerMsg(CHILD_ID_S1,V_TRIPPED);
    MyMessage tempMsg(CHILD_ID_T1,V_TEMP);
    	// Startup OneWire Temp Sensors
    	DallasSensors.begin();
    	 gw.begin(NULL, AUTO, true);
    	gw.sendSketchInfo(sketch_name, sketch_ver);
    	gw.present(CHILD_ID_D1, S_DOOR);
    	gw.present(CHILD_ID_T1, S_TEMP);
    	gw.present(CHILD_ID_S1, S_MOTION);
    	// Setup the button
            pinMode(BUTTON_PIN,INPUT);
            // Activate internal pull-up
            debouncer.attach(BUTTON_PIN);
            debouncer.interval(5);
    	// Check for motion change value
    		boolean tripped = digitalRead(TRIGGER) == HIGH;
    		if (lastTripped != tripped ) {
    			gw.send(triggerMsg.set(tripped?"1":"0")); // Send new state and request ack back
    			Serial.println("Tripped");
    			lastTripped=tripped;
                    debouncer.update();
                  // Get the update value
                    int value = debouncer.read();
                    if (value != oldValue) {
                        // Send in the new value
                         oldValue = value;
    		DallasSensors.requestTemperatures();
    		float tempC = DallasSensors.getTempCByIndex(1);
    		if (lastTemperature != tempC && tempC != -127.00) {
    			gw.send(tempMsg.set(tempC,1));
    			lastTemperature=tempC;
                            delay(30000);
    A 1 Reply Last reply
    • C CaptainZap
      Hi guys,
      //Temp Sensor bits
      //Door/Window bits
      int oldValue=-1;
      	// Setup the button
                      debouncer.update();
                           oldValue = value;
                              delay(30000);
      A Offline
      A Offline
      AWI
      @CaptainZap
      What do you mean by "have no parent node"?
      Have a look at the serial monitor (connected to the sensor Arduino).
      And you are initializing this node as a repeater.. is that what you were planning to do?
      // change to gw.begin(NULL, <fixed_node>)
      • C Offline
        C Offline
        CaptainZap
        @AWI Yes I want all my nodes to be repeaters, and that's exactly what I want to do :) However I use a Vera as my controller, and there you are supposed to have a parent node for your arduino sensor, followed by child devices for sensors/relays etc. Right now I have 3 child devices for the My Sensors plugin which isn't right.
        • M Offline
          M Offline
          m26872
          The fetching of Dallas temperature and also the delay(30000) are rather blocking code. Maybe not the cause of your problem, but not very good as a repeater node. Use a timing if-statement instead.
          C 1 Reply Last reply
          • M m26872
            C Offline
            C Offline
            CaptainZap
            @m26872 No idea how do to that, could you please help me ? :)
            • M Offline
              M Offline
              m26872
              Can't guide you in detail right now but this should give you an idea.
              • C CaptainZap
                M Offline
                M Offline
                mvdarend
                Here is an excellent article; How and why to avoid Delay()
                • M Offline
                  M Offline
                  m26872
                  wrote on last edited by m26872
                  Regarding the Vera parental node issue. I see it often but don't know what's causing this. A lot of struggle usually help. I'd try things like:
                  1. put a "delay(500);" before gw.begin and before gw.sendsketchinfo to make sure radio is fully powered and ready when initializing. Then redo the Vera inclusion. Try a few times.
                  2. If still no success. Load and run the ClearEepromConfig sketch. Reload your sketch again and continue trying inclusion in vera.
                  Perhaps you'll get a lot of ghost child nodes to delete. I use static node Ids so inclusion with cleared eeprom doesn't make the controller give me new node ids every time.
                  • C Offline
                    C Offline
                    CaptainZap
                    @mvdarend @m26872 Thanks so much for your feedback, I did apply the hints and I'll test the sketch later on today. I do have a question... does anyone know how do I upgrade my library to version 1.4.1 ? I've copied the one available from the main page, but it's version 1.4.
                    • R Offline
                      R Offline
                      robosensor
                      DallasSensors.requestTemperatures(); delays code execution up to 750ms. MySensors DS18B20 library is bit outdated, you should update library (https://github.com/milesburton/Arduino-Temperature-Control-Library) and use following code:
                      In setup:
                      	DallasSensors.setWaitForConversion(false);
                      In loop:
                      		DallasSensors.requestTemperatures(); // no delay here
                      		gw.wait(750); // insert another value for non-12-bit resolution
                      • C Offline
                        C Offline
                        CaptainZap
                        @robosensor Thank you very much for your insight... do I just download the new library and overwrite the one in the Arduino IDE install folder ?
                        I've also used your code and I'm getting errors compiling it, any hints ? I guess it could be because of the library ?
                        Arduino: 1.6.4 (Windows 8.1), Board: "Arduino Mini, ATmega328"
                        Door_Motion_Temp_rev2.ino: In function 'void getTemps()':
                        Door_Motion_Temp_rev2:115: error: 'class MySensor' has no member named 'wait'
                        Multiple libraries were found for "DallasTemperature.h"
                        Used: C:\Users***\Documents\Arduino\libraries\DallasTemperature << this is where I've copied the downloaded library
                        Not used: C:\Users***\Documents\Arduino\libraries\Arduino-Temperature-Control-Library-master
                        R 1 Reply Last reply
                        • C CaptainZap
                          R Offline
                          R Offline
                          robosensor
                          @CaptainZap yes, but update two libraries (OneWire and Dallas).
                          gw.wait() function was added 1 feb 2015: https://github.com/mysensors/Arduino/commit/d45a48d8b786656968fb4b45b049e16700dd3fd0 so you should use latest stable 1.4.* code.
                          • R robosensor
                            C Offline
                            C Offline
                            CaptainZap
                            @robosensor I don't know where to find the complete library for version 1.4.x
                            • C CaptainZap
                              R Offline
                              R Offline
                              robosensor
                              @CaptainZap
                              http://www.mysensors.org/download/ click on Download button under "1.4 - Latest Release" section, download zip archive, extract archive and check Arduino-master\libraries\MySensors\Version.h file.
                              • R robosensor
                                @CaptainZap
                                C Offline
                                C Offline
                                CaptainZap
                                @robosensor Thanks, I installed that but it's version 1.5 b1 and after using it it's giving me lots of errors :| I think there have been changes in how the code is used...
                                LE: I finally found the 1.4.1 branch and downloaded it however it's still giving me the same error about wait:
                                LLE: Just checked the cpp and there is no wait, this is the library I used :
                                https://github.com/mysensors/Arduino/tree/1.4.1
                                Can you tell me if there will be any issue if I comment that part ?
                                • C CaptainZap
                                  R Offline
                                  R Offline
                                  robosensor
                                  @CaptainZap https://github.com/mysensors/Arduino/archive/master.zip
                                  • H Offline
                                    H Offline
                                    @robosensor
                                    LOL :)
                                    • C Offline
                                      C Offline
                                      CaptainZap
                                      That was the version I was using when I first encountered the issues... anyways I'll remove arduino IDE with everything and reinstall it. Thanks.
                                      @hek I also LOL-ed :D Gotta love the helping spirit in the community you guys built.
                                      • C CaptainZap
                                        R Offline
                                        R Offline
                                        robosensor
                                        @CaptainZap also try to backup and clean C:\Users***\Documents\Arduino\ directory :)
                                        • H hek
                                          @robosensor
                                          LOL :)
                                          R Offline
                                          R Offline
                                          robosensor
                                          @hek as I said before, Dallas library is bit outdated. Is it possible to update dallas and onewire libraries? I provided links for newer versions of this libraries in this thread. I can do PR in github myself, but I don't know how to do it :) I need to read github manuals first :)
                                          requestTemperatures() is can be non-blocking in newer version of dallas library, so code can deep sleep (better for batteries) or process messages (better for repeaters and msg-receiving nodes) about 750 ms.
                                          H 1 Reply Last reply
                                          12.1k
