  2. Announcements
  3. 1.4 Beta
1.4 Beta
1.4betahelp
129 Posts 18 Posters 123.8k Views 4 Watching
    @Damme said:
    $port->write("255;255;3;4;1\n");
    Try
    $port->write("255;255;3;0;4;1\n");
    DammeD 1 Reply Last reply
      Try
      DammeD
      DammeD
      Damme
      Code Contributor
      @hek
      Thanks, that worked. I thought I understood the message layout.. never seen that 0 before:)
      hekH 1 Reply Last reply
      • DammeD Damme
        @hek
        It's a change in the serial protocol for 1.4.
        1 = request ack back from destination node.
        0 = no ack.
        • jendrushJ
          jendrushJ
          jendrush
          wrote on last edited by jendrush
          Could you describe it better keeping in mind my problem with Relay? How the message should look like to turn on Relay? Previously message like this worked ok - 11;1;1;2;1.
          • jendrushJ jendrush
            DammeD
            DammeD
            Damme
            Code Contributor
            @jendrush I suppose it should be 11:1:1:0:2:1 then
            @hek what about C_STREAM ? Didnt find much about it.
            hekH jendrushJ 2 Replies Last reply
            • DammeD Damme
              @Damme
              It will be used for firmware updates.
              • DammeD Damme
                jendrushJ
                jendrushJ
                jendrush
                I fugured it out yesterday, but thanx!
                  @Damme
                  DammeD
                  DammeD
                  Damme
                  Code Contributor
                  wrote on last edited by Damme
                  @hek
                  I just tried to send myself a picture over the network. real ugly code but it worked.. thought if I put a small cam and someone rings on the doorbell or something.. :) (Right now I just read the data from SPI flash)
                  • DammeD Damme
                    @hek
                    @Damme
                    great
                    • MisterEM
                      MisterEM
                      MisterE
                      • DammeD
                        DammeD
                        Damme
                        Code Contributor
                        I've tried the lib for a while now and found the following:
                        Then using ack=1 the returned message is exacly the one I sent. No way of knowing if its a request or an ACK.
                        example:
                        Client sends
                        3;255;3;6;0 (Give me configuration 0 (btw, why not leave config as a byte 0-255 instead of hardcoing it? I could have plenty of uses for configuration-values.)
                        Gateway responds: 3;255;3;6;M and requests ack
                        client sends
                        3;255;3;6;M
                        my software tried to lookup config id 'M' (Not a big deal for letter, but what if its a number?)
                        maybe ACK should be some sort of incremental number in return in special message type. I dont really know what is best.
                        It would be great if GW resends the messsage automatically a couple of times (configurable) if ACK = 1.
                        I've also noticed during DEBUG enabled that the message gets overwritten by old one, i.e.
                        send: 3-3-0-0 s=255,c=0,t=18,pt=0,l=15,st=fail:1.4b1 (18848a2)
                        send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=4,st=ok:test1 (18848a2)
                        send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:2.0t1 (18848a2)
                        (message 2: test1, message 3: 2.0)
                        Edit; One more thing
                        Do I really need one gw.process(); before each gw.send(..); in the loop? I seam to loose messages if I dont do like that.
                        // gw.sleep(SLEEP_TIME); //Seems to break recieing message, loosing ~75%
                        YveauxY DammeD 2 Replies Last reply
                        • DammeD Damme
                          example:
                          Client sends
                          client sends
                          3;255;3;6;M
                          @Damme Other wireless protocols usually have a counter which is increased with each message. Returning the counter as an ack would be sufficient to correlate the ack and the original message.
                          Returning the whole message seems like overkill indeed...
                          The send-methods could e.g. return the Id counter of the message sent, and an app waiting for an ack on that message should check for this value in any ack received (using some timeout)
                          • DammeD
                            DammeD
                            Damme
                            Code Contributor
                            Additional comment on config;
                            I think it should be request config, response config messages.
                            I also think its a bit odd that the actuator reports as
                            gw.present(2, S_LIGHT);
                            but requests as
                            if (message.type==V_LIGHT) {
                            V_LIGHT != S_LIGHT (2 vs 3)
                            I think the def should follow as much as possible.
                            hope any of my thoughts are somewhat useful
                            • DammeD Damme
                              but requests as
                              @Damme there's a lot of Vera legacy in there... This forum had a discussion going on about decoupling from Vera, but I'm afraid that got lost in the crash...
                              • DammeD Damme
                                example:
                                Client sends
                                client sends
                                3;255;3;6;M
                                DammeD
                                DammeD
                                Damme
                                Code Contributor
                                me just dumb here, delay(SLEEP_TIME); works. gw.sleep puts radio in sleep I guess.
                                • DammeD Damme
                                  gw.sleep() puts both Arduino and radio to sleep.
                                  • YveauxY Yveaux
                                    That mean you might have to rememeber the original message. The idea is to have all the information necessary in the callback.
                                    In my example sketches (e.g. RelayActuator) the ack message actually changes the relay status when the ack comes back from gateway. If not full message came in you would have to keep buffers with sent messages and start matching counter-values. Much more complicated.
                                    But a message counter will probably be necessary if/when we start encrypting messages to prohibit replay attacks.
                                    @Damme
                                    I actually thought about having a bit in the message header which says if the message is an ack or not. With that implemented you would just call a msg.isAck() to determine if the incoming message is an ack message. Would that be ok?
                                    You shouldn't need to call gw.process() after each send. It is only necessary in the loop() section if you expect incoming messages or have enabled repeater mode.
                                    I don't understand what you mean with messages getting overwritten with DEBUG enabled. Could you explain it a bit more (with an example?).
                                      wrote on last edited by hek
                                      #24
                                      @Yveaux
                                      To pick up the discussions about existence or not of getTemp().
                                      A better solution would probably be to create a MySensorsATMega328-subclass of the library which contains AtMega specific stuff such as sleep() and potentially getTemp().
                                      This class should also implement the EEPROM specifics.
                                        @Damme
                                        You have to remember it anyway when you regard the message as lost after some time without an ack and you decide to send the message again. Only for a simple sensor node which sends a sensor value with ack, waits for an ack reply and then continues with the next sensor value this wouldn't be necessary. When a single node has multiple messages with ack 'in flight', you definately need message buffering.
                                        This is independent from the ack message format IMHO.
                                        I also think message buffering and retrying, when implemented, should be part of the MySensors library.
                                        This improves realiability even more than with the NRF24 ack's enabled and avoids putting the retry-burden on the clients of the library.
                                          @Damme
                                          DammeD
                                          DammeD
                                          Damme
                                          Code Contributor
                                          here is a serial output from one of my nodes
                                          repeater started, id 3
                                          send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
                                          send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=4,st=fail:test1 (18848a2)
                                          send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:2.0t1 (18848a2)
                                          send: 3-3-0-0 s=0,c=0,t=7,pt=0,l=15,st=fail:1.4b1 (18848a2)
                                          send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=15,st=fail:1.4b1 (18848a2)
                                          send: 3-3-0-0 s=2,c=0,t=3,pt=0,l=15,st=fail:1.4b1 (18848a2)
                                          send: 3-3-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:1.4b1 (18848a2)
                                          and the sketch has: gw.sendSketchInfo("test", "2.0");
                                          yes, I know they all failed, I'm using the microwave oven atm, it kills the channel 76 (usually uses 21 but forgot to change last time, works better for me here..)
