  3. SSMSG - Single file SQL MySensors Gateway
8 Posts 4 Posters 3.8k Views 1 Watching
  • D Offline
    Damme
    Code Contributor
    wrote on last edited by Damme
    This is what I've been working on, Exact purpose is still unknown, Probobly full of bugs and lacks functionallity.
    https://github.com/Damme/SSMSG
    start with no parameters and it will be running in background.
    • Requires version 1.4b
    Y 1 Reply Last reply
    • D Damme
      Y Offline
      Y Offline
      So leave it to us to figure out ;-)
      I think you want to create some middleware to send to/receive from sensor nodes without using Vera, right?
      D 1 Reply Last reply
      • Y Yveaux
        Damme
        Code Contributor
        @Yveaux :) correct, I use a small php page for controlling some lights and stuff and a cron script that reads light value and calculate if it should turn on / off lights.
        the small scripts dont need any access to the usb device, only a DB connection.
        Y ch3b7C 2 Replies Last reply
        • D Damme
          Y Offline
          Y Offline
          @Damme You might be interested in my post at http://forum.mysensors.org/topic/175/open-source-home-automation-software/19
          I experimented with MySensors and MQTT, a publish/subscribe messaging system.
          It also acts as a database, but you don't have to actively request sensor data as you can subscribe to them from e.g. the sensor nodes or a logging task. Once subscribed you simply get the data pushed when an update arrives!
          • hekH Online
            hekH Online
            Nice. Looking forward to see where it leads!
            • D Damme
              ch3b7C Offline
              ch3b7C Offline
              ch3b7
              @Damme How the gateway recieve data and send to other sensor ? like "255;255;3;0;4;2\n" because if i send directly from arduino program work, but with other program connected to serial port not work.
              • ch3b7C ch3b7
                Damme
                Code Contributor
                @ch3b7 Uhm, Might misunderstood you. You'll have to configure the serial port correctly and then send \n , if using echo you need to use echo -e -n "1;1;1;1;1;1\n"
                • ch3b7C Offline
                  ch3b7C Offline
                  ch3b7
                  @Damme said:
                  1;1;1;1;1;1\n
                  sorry im from argentina and my english is very bad xD the problem is... i can send "255;255;3;0;4;2\n" from vb.net programm to arduino gateway in COM port and then the gateway send the same command to the sensor to change de ID
                  vb.net --> arduino gw ---> sensor
                  but i think the gw dont read the incoming data
                  at now im use your script and work fine
