  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 514.7k Views 73 Watching
  • tekkaT tekka
    @robosensor said:
    The MYSBootloader.hex file you are flashing has a wrong file size (=32722 bytes) in your post:
    avrdude: reading input file "C:\Program Files (x86)\Arduino\hardware\arduino\avr/bootloaders/MySensors/MYSBootloader.hex"
    MYSBootloader 1.1 should have ~2kb
    From your log I assume, that you flashed the sketch instead of the bootloader.
    Please pay attention to steps 3 and 13 from the step-by-step manual.
    N
    N
    NewFolk
    @tekka
    Hello, could you help me with uploading bootloader. I stuck on Step 5 step-by-step manual and get error
    Arduino: 1.6.4 (Mac OS X), Плата"ATmega328 16Mhz MYSBootloader"
    avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
    I`m using 16Mhz pro mini clone and FTDI232
    tekkaT 1 Reply Last reply
    • tekkaT tekka
      R
      R
      robosensor
      wrote on last edited by robosensor
      #129
      @tekka I have googled for [avrdude bootloader "bytes of flash written"] and found many answers about big upload size for bootloader (> 32000 bytes). It seems that big size is the way it should be.
      I have solved problem. I must power up node with newly burned bootloader but without sensor node firmware and upload firmware using MYSController
      Incorrect way is: burn bootloader, burn sensor node firmware, powerup sensor.
      Thank you for great software! :)
      • N NewFolk
        @tekka
        tekkaT
        tekkaT
        tekka
        @NewFolk You'll need e.g. USBasp or ArduinoISP to flash a new bootloader. If you have a spare Arduino and FTDI232, follow this tutorial to program a new bootloader using the Arduino IDE.
        Good luck! :)
        • R robosensor
          tekkaT
          tekkaT
          tekka
          @robosensor Yes, the sensor firmware is uploaded OTA via MYSController.
            mvader
            wrote on last edited by mvader
            #132
            Hi - I need some clarification.
            I have mysensors connected to my vera lite (working)
            I bought 3 of the sensebender micro boards and got them talking with the gateway (working)
            loaded up myscontroller it's running and see the gateway and all 3 nodes.
            yay!
            the issue is the sensors are reporting in C instead of F, so i modified the sketch, compiled it, found the hex file (66k)
            and moved it to the correct folder per instructions.
            when i says "assign FW" nothing happens.
            am i understanding correctly that "firmware" is just a compiled sketch?
            if i need to make changes to my device, is this the correct way?
            modify sketch - > compile -> move hex to myscontroller folder - > edit firmware_config file -> right click assign fw -> pick new firmware
            is that correct?
            nothing is happening for me when i do that..
            please clarify.
            thanks!
            edit: file size says 66k in win7
            but in the compiler it says
            Sketch uses 23,724 bytes (77%) of program storage space. Maximum is 30,720 bytes.
            Global variables use 822 bytes (40%) of dynamic memory, leaving 1,226 bytes for local variables. Maximum is 2,048 bytes.
            the file i grabbed was SensebenderMicro.cpp.hex
            • M mvader
              yay!
              is that correct?
              please clarify.
              thanks!
              tekkaT
              tekkaT
              tekka
              is that correct?
              For OTA updates you need to burn the MYSBootloader (instructions here). Once done, assign FW, reboot node and wait until FW is transferred.
              Yup, because the .hex file is not binary but a hex (hence the suffix) format with headers and checksums.
              • tekkaT tekka
                is that correct?
                mvader
                #134
                is that correct?
                I thought i read those sensebender boards were going to come pre-burned with the MYSBootloader from the mfg? that why you wouldn't need a programmer. i'll check with those folks..
                edit: i found where they said it was pre-programmed..
                @hek said:
                Yes, FTDI, ISCP or over-the-air updates.
                It comes pre-programmed with MySensors variant of the DualOptiboot-bootloader.
                https://github.com/mysensors/DualOptiboot
                Which can take advantage of the extra flash memory to do a safe over-the-air firmware update.
                • M mvader
                  is that correct?
                  mvader
                  • G
                    G
                    gigaguy
                    wrote on last edited by gigaguy
                    #136
                    I have a some questions. Couldnt find answer anywhere.
                    If I am using an arduino connected to the serial port on a Raspberry pi (w/openhab) How do I assign fw, reboot, etc?
                    Do I need to disconnect the GW and use windows temporarily to reboot, update fw? or can I have 2 GW's?
                    I updated my nano with the MYS bootloader, and after I power it on, it never shows up in MYSController.
                    • F
                      F
                      Fredrik Carlsson
                      @tekka Hey, it seems like the downloadlink is broken. Can you check?
                      • n3roN
                        n3roN
                        n3ro
                        i dont understand how to use this...
                        Can somebody explain it?
                        pimatic + MySensors + Homeduino + z-way
                        https://github.com/n3roGit/MySensors_n3ro
                        • F Fredrik Carlsson
                          tekkaT
                          tekkaT
                          tekka
                          wrote on last edited by tekka
                          #139
                          @Fredrik-Carlsson link works for me (https://goo.gl/48Yn6y)
                          • F
                            F
                            Fredrik Carlsson
                            Yes I tried now again an now it works. Maybe something temporary with Dropbox yesterday
                            • C
                              C
                              cdr
                              It is possible to burn the bootloader to an Arduino Uno right? (if not please skip below and I will rtfm some more)
                              Could anyone please explain me what I am doing wrong here? I use avrdudess (http://blog.zakkemble.co.uk/avrdudess-a-gui-for-avrdude/) to program the bootloader.hex (also tried the supplied method) but no dice;
                              Writing the bootloader seems to work;
                              Detected 1e950f = ATmega328P
                              MYSBootloader.hex: 2.002 / 32.768 Bytes (6,11%)
                              avrdude.exe: set SCK frequency to 1500000 Hz
                              avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
                              avrdude.exe: AVR device initialized and ready to accept instructions
                              avrdude.exe: Device signature = 0x1e950f
                              avrdude.exe: erasing chip
                              avrdude.exe: reading input file "C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex"
                              avrdude.exe: input file C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex auto detected as Intel Hex
                              avrdude.exe: writing flash (32722 bytes):
                              avrdude.exe: 32722 bytes of flash written
                              avrdude.exe: verifying flash memory against C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex:
                              avrdude.exe: load data flash data from input file C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex:
                              avrdude.exe: input file C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex contains 32722 bytes
                              avrdude.exe: reading on-chip flash data:
                              avrdude.exe: verifying ...
                              avrdude.exe: 32722 bytes of flash verified
                              However tech life wouldn't be techlife without days of endless debugging
                              Setting the extended fuse fails verification
                              avrdude.exe: reading input file "0xF7"
                              avrdude.exe: writing lfuse (1 bytes):
                              avrdude.exe: 1 bytes of lfuse written
                              avrdude.exe: verifying lfuse memory against 0xF7:
                              avrdude.exe: load data lfuse data from input file 0xF7:
                              avrdude.exe: input file 0xF7 contains 1 bytes
                              avrdude.exe: reading on-chip lfuse data:
                              avrdude.exe: 1 bytes of lfuse verified
                              avrdude.exe: reading input file "0xDA"
                              avrdude.exe: writing hfuse (1 bytes):
                              avrdude.exe: 1 bytes of hfuse written
                              avrdude.exe: verifying hfuse memory against 0xDA:
                              avrdude.exe: load data hfuse data from input file 0xDA:
                              avrdude.exe: input file 0xDA contains 1 bytes
                              avrdude.exe: reading on-chip hfuse data:
                              avrdude.exe: 1 bytes of hfuse verified
                              avrdude.exe: reading input file "0xFE"
                              avrdude.exe: writing efuse (1 bytes):
                              Writing |  ***failed;
                              ################################################## | 100% 0.03s
                              avrdude.exe: 1 bytes of efuse written
                              avrdude.exe: verifying efuse memory against 0xFE:
                              avrdude.exe: load data efuse data from input file 0xFE:
                              avrdude.exe: input file 0xFE contains 1 bytes
                              avrdude.exe: reading on-chip efuse data:
                              avrdude.exe: verification error, first mismatch at byte 0x0000
                                           0x06 != 0xfe
                              avrdude.exe: verification error; content mismatch
                              avrdude.exe done.  Thank you.
                              This last error is giving me headaches, why the "first mismatch at byte 0x0000 0x06 != 0xfe" error?
                              Really hope someone can enlighten me...
                              • C cdr
                                             0x06 != 0xfe
                                tekkaT
                                tekkaT
                                tekka
                                @cdr the efuse only uses the lower 3 bits: with AVRDude set 0x06, with AVRStudio set 0xFE. You can verify this with the fuse calculator.
                                • F
                                  F
                                  Fabien
                                  I try to uplaod sketch via OTA but it doesn''t work.
                                  I have sensebender with stock bootloader. Gateway is connect to an ODROID C1 with ser2net and i connect to ser2net. I can see all incoming traffic for my sensors.
                                  I upload sensebender default sketch from dev branch using MySensors dev branch too.
                                  I tell MYSController sensors is battery powered.
                                  I try with the two provided example but nothing happen in log or anything else
                                  • F Fabien
                                    mvader
                                    #144
                                    check in the sensebender announcement thread. I had the same question. Hek responded with what needed to be done to make it work.
                                    I didn't get a chance to try his solutions yet to see if it works. if you do, post and let us know.
                                    edit: here
                                    http://forum.mysensors.org/topic/1345/sensebender-micro/139
                                    • D
                                      Dirk_H
                                      @Fabien
                                      I dont understand what you mean by "I told MysController" that the node is battery powered. It should find that out automatically I think. Anyway I'm pretty sure that I read somewhere that battery powered sensors cant be updated OTA. (If it relly is battery powered). I think I read a define somewhere that disables the firmware low level commands in the MySensors Library if the Node is battery powered.
                                        No there isn't. But battery powered sensors most likely sleep most of the time so they won't receive any update command. And a fw updates over-the-air would probably drain batteries pretty quick.
                                        • C
                                          C
                                          cdr
                                          @tekka I feel really, really, REALLY stupid;
                                          I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
                                          D'OH
                                          Thanks for your patience and help, everything is working now and I'm really happy!
                                          :+1:
                                          N petewillP 2 Replies Last reply
