  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.1k Views 73 Watching
  • G
    G
    gigaguy
    wrote on last edited by gigaguy
    #136
    I have a some questions. Couldnt find answer anywhere.
    If I am using an arduino connected to the serial port on a Raspberry pi (w/openhab) How do I assign fw, reboot, etc?
    Do I need to disconnect the GW and use windows temporarily to reboot, update fw? or can I have 2 GW's?
    I updated my nano with the MYS bootloader, and after I power it on, it never shows up in MYSController.
    • F
      F
      Fredrik Carlsson
      @tekka Hey, it seems like the downloadlink is broken. Can you check?
      tekkaT 1 Reply Last reply
      • n3roN
        n3roN
        n3ro
        i dont understand how to use this...
        Can somebody explain it?
        pimatic + MySensors + Homeduino + z-way
        https://github.com/n3roGit/MySensors_n3ro
        • F Fredrik Carlsson
          tekkaT
          tekkaT
          tekka
          wrote on last edited by tekka
          #139
          @Fredrik-Carlsson link works for me (https://goo.gl/48Yn6y)
          • F
            F
            Fredrik Carlsson
            Yes I tried now again an now it works. Maybe something temporary with Dropbox yesterday
            • C
              C
              cdr
              It is possible to burn the bootloader to an Arduino Uno right? (if not please skip below and I will rtfm some more)
              Could anyone please explain me what I am doing wrong here? I use avrdudess (http://blog.zakkemble.co.uk/avrdudess-a-gui-for-avrdude/) to program the bootloader.hex (also tried the supplied method) but no dice;
              Writing the bootloader seems to work;
              Detected 1e950f = ATmega328P
              MYSBootloader.hex: 2.002 / 32.768 Bytes (6,11%)
              avrdude.exe: set SCK frequency to 1500000 Hz
              avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
              avrdude.exe: AVR device initialized and ready to accept instructions
              avrdude.exe: Device signature = 0x1e950f
              avrdude.exe: erasing chip
              avrdude.exe: reading input file "C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex"
              avrdude.exe: input file C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex auto detected as Intel Hex
              avrdude.exe: writing flash (32722 bytes):
              avrdude.exe: 32722 bytes of flash written
              avrdude.exe: verifying flash memory against C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex:
              avrdude.exe: load data flash data from input file C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex:
              avrdude.exe: input file C:\Users\codar\Desktop\MYSController_0_1_2_280\Bootloader\MYSBootloader.hex contains 32722 bytes
              avrdude.exe: reading on-chip flash data:
              avrdude.exe: verifying ...
              avrdude.exe: 32722 bytes of flash verified
              However tech life wouldn't be techlife without days of endless debugging
              Setting the extended fuse fails verification
              avrdude.exe: reading input file "0xF7"
              avrdude.exe: writing lfuse (1 bytes):
              avrdude.exe: 1 bytes of lfuse written
              avrdude.exe: verifying lfuse memory against 0xF7:
              avrdude.exe: load data lfuse data from input file 0xF7:
              avrdude.exe: input file 0xF7 contains 1 bytes
              avrdude.exe: reading on-chip lfuse data:
              avrdude.exe: 1 bytes of lfuse verified
              avrdude.exe: reading input file "0xDA"
              avrdude.exe: writing hfuse (1 bytes):
              avrdude.exe: 1 bytes of hfuse written
              avrdude.exe: verifying hfuse memory against 0xDA:
              avrdude.exe: load data hfuse data from input file 0xDA:
              avrdude.exe: input file 0xDA contains 1 bytes
              avrdude.exe: reading on-chip hfuse data:
              avrdude.exe: 1 bytes of hfuse verified
              avrdude.exe: reading input file "0xFE"
              avrdude.exe: writing efuse (1 bytes):
              Writing |  ***failed;
              ################################################## | 100% 0.03s
              avrdude.exe: 1 bytes of efuse written
              avrdude.exe: verifying efuse memory against 0xFE:
              avrdude.exe: load data efuse data from input file 0xFE:
              avrdude.exe: input file 0xFE contains 1 bytes
              avrdude.exe: reading on-chip efuse data:
              avrdude.exe: verification error, first mismatch at byte 0x0000
                           0x06 != 0xfe
              avrdude.exe: verification error; content mismatch
              avrdude.exe done.  Thank you.
              This last error is giving me headaches, why the "first mismatch at byte 0x0000 0x06 != 0xfe" error?
              Really hope someone can enlighten me...
              • C cdr
                             0x06 != 0xfe
                tekkaT
                tekkaT
                tekka
                @cdr the efuse only uses the lower 3 bits: with AVRDude set 0x06, with AVRStudio set 0xFE. You can verify this with the fuse calculator.
                • F
                  F
                  Fabien
                  I try to uplaod sketch via OTA but it doesn''t work.
                  I have sensebender with stock bootloader. Gateway is connect to an ODROID C1 with ser2net and i connect to ser2net. I can see all incoming traffic for my sensors.
                  I upload sensebender default sketch from dev branch using MySensors dev branch too.
                  I tell MYSController sensors is battery powered.
                  I try with the two provided example but nothing happen in log or anything else
                  • F Fabien
                    mvader
                    wrote on last edited by mvader
                    #144
                    check in the sensebender announcement thread. I had the same question. Hek responded with what needed to be done to make it work.
                    I didn't get a chance to try his solutions yet to see if it works. if you do, post and let us know.
                    edit: here
                    http://forum.mysensors.org/topic/1345/sensebender-micro/139
                    • D
                      Dirk_H
                      @Fabien
                      I dont understand what you mean by "I told MysController" that the node is battery powered. It should find that out automatically I think. Anyway I'm pretty sure that I read somewhere that battery powered sensors cant be updated OTA. (If it relly is battery powered). I think I read a define somewhere that disables the firmware low level commands in the MySensors Library if the Node is battery powered.
                        No there isn't. But battery powered sensors most likely sleep most of the time so they won't receive any update command. And a fw updates over-the-air would probably drain batteries pretty quick.
                        • C
                          C
                          cdr
                          @tekka I feel really, really, REALLY stupid;
                          I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
                          D'OH
                          Thanks for your patience and help, everything is working now and I'm really happy!
                          :+1:
                          N petewillP 2 Replies Last reply
                          • O
                            O
                            Omemanti
                            wrote on last edited by Omemanti
                            #148
                            Hi. I was wondering if someone could get the irrigation controller working with this program?
                            I'm new to this all, and so far this the easiest controller that I came across. ( got the gateway etc working with almost no effort)
                            • F
                              F
                              fitzpatrick
                              Hi, nice work. Is there any chances that you add the possibility to log the nodes information to a mysql database ?
                              • 5546dug5
                                5546dug5
                                5546dug
                                Hi @tekka
                                I am having trouble understanding the error codes on this gui.
                                It is the solar mini weather stn on proto board and it is not working properly.
                                At this minute I see that the g/w code is telling me 4-4-5-0 ,there was a node 5 in my My Sensors package and it was configured as a repeater but it is not here as it connected laptop> usb port/cord> ftdi 3.3v> 3.3 v promini.
                                As the code cannot get to and from node 5 it is a down as a st=fail
                                Is there a why to change this in your program to allow continuing debugging my sketch?
                                Am I again missing something?
                                • 5546dug5
                                  5546dug5
                                  5546dug
                                  • 5546dug5 5546dug
                                    tekkaT
                                    tekkaT
                                    tekka
                                    @5546dug the log looks like a sensor log, try connecting MYSController to the gateway...
                                    • rvendrameR
                                      rvendrameR
                                      rvendrame
                                      Hello guys, I'm trying to burn the MYSBootloader.hex into some Pro minis (clones) here, however after burning it, they get somehow 'bricked' :
                                      • I'm using my Uno "as ISP" on IDE 1.6.4
                                      • I've followed the step-by-step tutorial posted above by @tekka
                                      • My pro-minis are 5V, 16Mhz, external clock , 328p, supposedly a perfect match with 'boards.txt' info...
                                      • "Burn bootloader" ends successful, with "Done burning boot loader" message.
                                      • After that, the pro-mini pin 13 led flashes in a kind of random pattern, and it is not possible to upload any sketch, nor any kind of serial monitor on any speed.
                                      • I can revert it, by selecting the standard 'Arduino Pro or Pro Mini' board , and burn boot loader again. It makes the pro-mini gets back to live, I can upload my sketches and serial monitor it.
                                      So my questions:
                                      • I don't have extra eprom connected --- Is it mandatory? I've read somewhere that it can be disabled, but can't find the instructions anymore...
                                      • Fuse adjustments?
                                      • What else can I do in order to troubleshooting it?
                                      ESP8266 GW + mySensors 2.3.2
                                      Alexa / Google Home
                                        #154
                                        @rvendrame: it seems to be wrong fuses. MYSBootloader does not use extra eeprom. It's DualOptiboot which uses one. You need to set fuses. Then burn bootloader. For fuses you need to look in boards.txt . It should work. For setting fuses, I use usbasp. I never tried with uno.
                                        • rvendrameR
                                          rvendrameR
                                          rvendrame
                                          @scalz, thanks for the reply. BTW, did you see this?
                                          Well, with standard bootloader (working), my pro-minis have fuses as FF DA 05 (Low/High/Ext).
                                          The MYSBootloader.hex boot loader (not working) is set in boards.txt with F7 DA 06.
                                          I have played with all possible combinations (including changing values in boards.txt), no luck.
                                          Maybe I have to compile my own version of MYSBootloader? Sorry, this is all new to me...
                                          Thx again
                                          Alexa / Google Home
