  3. My Ugly ESP GW Prototype
34 Posts 18 Posters 20.3k Views 8 Watching
    Ok, had to toss something together for the ESP gw development.
    Not pretty, but hopefully it'll work.
    RJ_MakeR
    RJ_MakeR
    RJ_Make
    @hek Ugly???? That right there is a thing of beauty in my world... :stuck_out_tongue:
    RJ_Make
      @hek: very interesting. I will follow your work too.
      Do you know Huzzah esp8266, I think yes. Because pcb board is opensource and it is easier to use than china breadboard. But maybe you received it with esp on it? Otherwise it could help if you have more chips.
      See you soon.
        @scalz said:
        Huzzah esp8266
        Yes, Huzzah seems nice. But I bought a couple of these (which includes an esp-07):
        http://www.ebay.com/itm/141656822263?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
        • H
          H
          hitosnap
          All ESP stuff info http://tech.scargill.net/ ESP12E or ESP13 .
          • DidiD
            DidiD
            Didi
            I knowMr Scargills techblog very long and it´s really good ;-)
            • tbowmoT
              tbowmoT
              tbowmo
              @hek
              Do you have some more details on that level converter thingie that you've used between the arduino, and the ESP8266?
                I used this one:
                http://www.ebay.com/itm/181572335264?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                  I used this one:
                  Moshe LivneM
                  Moshe LivneM
                  Moshe Livne
                  @hek what is the thing the nrf is sitting on? what is the esp for? and if this is ugly, you should see some of my stuff.... it is almost neat....
                  hekH 1 Reply Last reply
                  • Moshe LivneM Moshe Livne
                    wrote on last edited by hek
                    @Moshe-Livne
                    Te radio is sitting on a (slightly modified) NRF-socket adapter plate as I didn't have any AMS step downs laying around.
                    http://www.ebay.com/itm/Socket-Adapter-plate-Board-for-8Pin-NRF24L01-Wireless-Transceive-module-51-/200960749614?pt=LH_DefaultDomain_0&hash=item2eca31b02e
                    The ESP is there to create a wireless connection to the controller (PoC).
                      @Fabien
                      Yes, I know it can be programmed directly which could be a good option for (none battery) sensor nodes. It is still somewhat more complicated to get started using ESP modules (compared to Arduino). Waiting with interest on results from the community members trying to port MySensors library running natively on ESP.
                      But anyhow, the gateway @tbowmo is designing will running on a ATMega1284 and communicate through serial AT-commands to ESP, so I'd better start developing that code as well. :)
                      Regarding ESP inputs being 5V tolerant.. When googling around I'm getting mixed results regarding this. Better safe than sorry.
                      tekkaT
                      tekkaT
                      tekka
                      I'm running the GW sketch (and repeater node) natively on the ESP8266 - however, the porting needs some additional work on EEPROM handling and pointer addressing. Also, a stable power supply is important (>3.1V with ESP8266 and NRF24 attached, no peaks). Will post more as porting progresses.
                      • tekkaT tekka
                        Mickey
                        Do you porting it to Arduino environment or using the native esp sdk ?
                          A Former User
                          Would also be interested to have MySensors on ESP8266 "native" (without Arduino) using the Arduino IDE. This is what you are planning to do ?
                          • BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            I'll donate a Photon to someone who can port the ethernet gateway over to Particle!!!
                            @hek ?? WE SHOULD BE ABLE TO ADD A LOT OF FUNCTIONALITY WITH THIS LITTLE POWERHOUSE
                            128KB RAM
                            120MHZ
                            • epierreE
                              epierreE
                              epierre
                              I already have one, thanx !
                              guy, I had the same idea, and the photon is a beast (when you make it work for I was an alpha alpha tester...)
                              z-wave - Vera -> Domoticz
                              • epierreE
                                epierreE
                                epierre
                                @BulldogLowell someone already ported the nrf24l library here: https://community.particle.io/t/request-answered-nrf24l01-library/2286
                                  Have you guys seen this? http://www.seeedstudio.com/depot/EMW3165-CortexM4-based-WiFi-SoC-Module-p-2488.html
                                  The specs seem almost the same as the Photon's, but it's less than half the price. And, it's in stock.
                                  I'm open minded. Is there a reason to prefer the Photon?
                                  • tbowmoT
                                    tbowmoT
                                    tbowmo
                                    Looks interesting. However, it's probably a bit more complicated to use for newcommers, as it's not arduino compatible (not yet anyways).
                                    • tbowmoT tbowmo
                                      #22
                                      @tbowmo said:
                                      Good point. Also, the Photon already has header pins soldered on, and not having that means extra work.
                                      I think I'm persuaded that, at least for now, the Photon can justify its higher price.
                                      What's the best board to dock it into? Or is it simply roll-you-own with female headers on some prototyping board?
                                      Sparkfun will have a Photon redboard, but at $39.95....
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        Is Photon compatible with Arduino? (the build eco system). That is one of the key elements of mysensors at the moment, and what makes it accessible for newcommers.
                                        If not then everything needs to be ported to another build system..
                                        BulldogLowellB NeverDieN 2 Replies Last reply
                                        • tbowmoT tbowmo
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          It is "Arduino-like" for sure, but a little different in that it's implementation is still developing. I've done a few projects with Photon, including (vera controlled) LED projects and sensors. There are some differences so you may find it rough at first (particularly with the availability of Libraries).
                                          Probably a great add-on to your sensor network if you are more experienced with Arduino.
                                          Like MySensors, they have a terrific forum!
                                          PS, comparable to the EMW3165, the P1 version of photon is $10
                                          12.5k
