  3. My Ugly ESP GW Prototype
34 Posts 18 Posters 20.3k Views 8 Watching
  • tekkaT tekka
    @hek said:
    Waiting with interest on results from the community members trying to port MySensors library running natively on ESP.
    I'm running the GW sketch (and repeater node) natively on the ESP8266 - however, the porting needs some additional work on EEPROM handling and pointer addressing. Also, a stable power supply is important (>3.1V with ESP8266 and NRF24 attached, no peaks). Will post more as porting progresses.
    Mickey
    Do you porting it to Arduino environment or using the native esp sdk ?
      A Former User
      Would also be interested to have MySensors on ESP8266 "native" (without Arduino) using the Arduino IDE. This is what you are planning to do ?
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        I'll donate a Photon to someone who can port the ethernet gateway over to Particle!!!
        @hek ?? WE SHOULD BE ABLE TO ADD A LOT OF FUNCTIONALITY WITH THIS LITTLE POWERHOUSE
        128KB RAM
        120MHZ
        • epierreE
          epierreE
          epierre
          I already have one, thanx !
          guy, I had the same idea, and the photon is a beast (when you make it work for I was an alpha alpha tester...)
          z-wave - Vera -> Domoticz
          • epierreE
            epierreE
            epierre
            @BulldogLowell someone already ported the nrf24l library here: https://community.particle.io/t/request-answered-nrf24l01-library/2286
              Have you guys seen this? http://www.seeedstudio.com/depot/EMW3165-CortexM4-based-WiFi-SoC-Module-p-2488.html
              The specs seem almost the same as the Photon's, but it's less than half the price. And, it's in stock.
              I'm open minded. Is there a reason to prefer the Photon?
              • tbowmoT
                tbowmoT
                tbowmo
                Looks interesting. However, it's probably a bit more complicated to use for newcommers, as it's not arduino compatible (not yet anyways).
                • tbowmoT tbowmo
                  #22
                  @tbowmo said:
                  Good point. Also, the Photon already has header pins soldered on, and not having that means extra work.
                  I think I'm persuaded that, at least for now, the Photon can justify its higher price.
                  What's the best board to dock it into? Or is it simply roll-you-own with female headers on some prototyping board?
                  Sparkfun will have a Photon redboard, but at $39.95....
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    Is Photon compatible with Arduino? (the build eco system). That is one of the key elements of mysensors at the moment, and what makes it accessible for newcommers.
                    If not then everything needs to be ported to another build system..
                    BulldogLowellB NeverDieN 2 Replies Last reply
                    • tbowmoT tbowmo
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      It is "Arduino-like" for sure, but a little different in that it's implementation is still developing. I've done a few projects with Photon, including (vera controlled) LED projects and sensors. There are some differences so you may find it rough at first (particularly with the availability of Libraries).
                      Probably a great add-on to your sensor network if you are more experienced with Arduino.
                      Like MySensors, they have a terrific forum!
                      PS, comparable to the EMW3165, the P1 version of photon is $10
                      • tbowmoT tbowmo
                        @tbowmo said:
                        Glad you brought this up.
                        • rvendrameR
                          rvendrameR
                          rvendrame
                          Would mind to share your sketch for the ESP8266 + WiFi+GW + nRF24 ? If I understood correctly --- the ESP can run the mySensors GW + regular Wi-fi, replacing the arduino? Any other downside than the EEPROM ?
                          ESP8266 GW + mySensors 2.3.2
                          Alexa / Google Home
                          tekkaT 1 Reply Last reply
                          • rvendrameR rvendrame
                            tekkaT
                            tekkaT
                            tekka
                            @rvendrame yes, ESP8266 + nRF24L01 = GW. However, build is currently unstable and WIP.
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              @tekka, ok got it. I just managed to run my serial GW on my media-player computer (using a serial to ethernet program), so I now I finally have my kind of ethernet GW. Thanks!
                              Alexa / Google Home
                              barduinoB 1 Reply Last reply
                                barduinoB
                                barduinoB
                                barduino
                                @rvendrame said:
                                @tekka, ok got it. ... so I now I finally have my kind of ethernet GW. Thanks!
                                NodeJS?
                                • rvendrameR
                                  rvendrameR
                                  rvendrame
                                  @barduino , I have Vera as controller. And I have a old mac mini which is my media player / nas / voip / etc... I just installed the .99c TCP2Serial on it, and plugged my serial gateway. It is working like a charm.
                                  Alexa / Google Home
                                  • Daniel OliveiraD
                                    Daniel OliveiraD
                                    Daniel Oliveira
                                    Hi @hek and everyone,
                                    I'm starting to get really interested in knowing more about these ESP8266 litle things but after some "googling" I still didn't figured out one thing. I already saw some projects to use an ESP alone as a GW (with a RF24 module attached) but is it not possible to have a MySensor's network of only ESPs?
                                    One ESP as GE and multiple others as sensor nodes? Why?
                                    Thank you all in advance,
                                    Daniel
                                    MySensors rules my home :)
                                      Most probably possible once someone get library running on it.
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @Daniel-Oliveira
                                        If you were to make a sensor network only with ESP8266, you don't need mysensors (as I see it). It has network capabilities by itself (wifi), so you could actually just connect them to your existing wifi network (or create a new one with an old router).
                                        One thing though, they probably will use more current, compared to nrf24 / rfm69. Unless you can power up/down the module. But then you'll have latency time when connecting to the wifi, before sending the actual sensor values.
                                        But besides that, it should be possible to make some sort of sensor network with the ESP only..
                                        • Lucas FiggL
                                          Lucas FiggL
                                          Lucas Figg
                                          Does anyone have any working examples of Sensebender Micro working with a Photon? I have all the parts but finding it difficult to unravel all GW libs and so on. I just want to use my sensebender with a Onewire waterproof temp sensor and for it to report back to the Photon every 5 minutes or so.
                                          12.5k
