  3. My Ugly ESP GW Prototype
34 Posts 18 Posters 20.3k Views 8 Watching
  • F
    F
    Fabien
    Why did you need arduino ? ESP can be programmed. The only problem now is EEPROM in Mysensors library. And you don't need 5V/3.3V adapt. ESP input are 5V tolerant (see datasheet).
    Can you post shematic and ESP code (arduino compatible ?)
      @Fabien
      Yes, I know it can be programmed directly which could be a good option for (none battery) sensor nodes. It is still somewhat more complicated to get started using ESP modules (compared to Arduino). Waiting with interest on results from the community members trying to port MySensors library running natively on ESP.
      But anyhow, the gateway @tbowmo is designing will running on a ATMega1284 and communicate through serial AT-commands to ESP, so I'd better start developing that code as well. :)
      Regarding ESP inputs being 5V tolerant.. When googling around I'm getting mixed results regarding this. Better safe than sorry.
      tekkaT 1 Reply Last reply
      • F
        F
        Fabien
        On datasheet P15 : http://www.adafruit.com/datasheets/ESP8266_Specifications_English.pdf
        All digital IO pins are protected from over-voltage with a snap-back circuit connected between
        the pad and ground. The snap back voltage is typically about 6V, and the holding voltage is 5.8V.
        This provides protection from over-voltages and ESD. The output devices are also protected
        from reversed voltages with diodes.
          Ok, had to toss something together for the ESP gw development.
          Not pretty, but hopefully it'll work.
          RJ_MakeR
          RJ_MakeR
          RJ_Make
          @hek Ugly???? That right there is a thing of beauty in my world... :stuck_out_tongue:
          RJ_Make
            @hek: very interesting. I will follow your work too.
            Do you know Huzzah esp8266, I think yes. Because pcb board is opensource and it is easier to use than china breadboard. But maybe you received it with esp on it? Otherwise it could help if you have more chips.
            See you soon.
              @scalz said:
              Huzzah esp8266
              Yes, Huzzah seems nice. But I bought a couple of these (which includes an esp-07):
              http://www.ebay.com/itm/141656822263?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
              • H
                H
                hitosnap
                All ESP stuff info http://tech.scargill.net/ ESP12E or ESP13 .
                • DidiD
                  DidiD
                  Didi
                  I knowMr Scargills techblog very long and it´s really good ;-)
                  • tbowmoT
                    tbowmoT
                    tbowmo
                    @hek
                    Do you have some more details on that level converter thingie that you've used between the arduino, and the ESP8266?
                      I used this one:
                      http://www.ebay.com/itm/181572335264?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                        I used this one:
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        @hek what is the thing the nrf is sitting on? what is the esp for? and if this is ugly, you should see some of my stuff.... it is almost neat....
                        hekH 1 Reply Last reply
                        • Moshe LivneM Moshe Livne
                          wrote on last edited by hek
                          @Moshe-Livne
                          Te radio is sitting on a (slightly modified) NRF-socket adapter plate as I didn't have any AMS step downs laying around.
                          http://www.ebay.com/itm/Socket-Adapter-plate-Board-for-8Pin-NRF24L01-Wireless-Transceive-module-51-/200960749614?pt=LH_DefaultDomain_0&hash=item2eca31b02e
                          The ESP is there to create a wireless connection to the controller (PoC).
                            @Fabien
                            tekkaT
                            tekkaT
                            tekka
                            I'm running the GW sketch (and repeater node) natively on the ESP8266 - however, the porting needs some additional work on EEPROM handling and pointer addressing. Also, a stable power supply is important (>3.1V with ESP8266 and NRF24 attached, no peaks). Will post more as porting progresses.
                            • tekkaT tekka
                              Mickey
                              Do you porting it to Arduino environment or using the native esp sdk ?
                                A Former User
                                Would also be interested to have MySensors on ESP8266 "native" (without Arduino) using the Arduino IDE. This is what you are planning to do ?
                                • BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  I'll donate a Photon to someone who can port the ethernet gateway over to Particle!!!
                                  @hek ?? WE SHOULD BE ABLE TO ADD A LOT OF FUNCTIONALITY WITH THIS LITTLE POWERHOUSE
                                  128KB RAM
                                  120MHZ
                                  • epierreE
                                    epierreE
                                    epierre
                                    I already have one, thanx !
                                    guy, I had the same idea, and the photon is a beast (when you make it work for I was an alpha alpha tester...)
                                    z-wave - Vera -> Domoticz
                                    • epierreE
                                      epierreE
                                      epierre
                                      @BulldogLowell someone already ported the nrf24l library here: https://community.particle.io/t/request-answered-nrf24l01-library/2286
                                        Have you guys seen this? http://www.seeedstudio.com/depot/EMW3165-CortexM4-based-WiFi-SoC-Module-p-2488.html
                                        The specs seem almost the same as the Photon's, but it's less than half the price. And, it's in stock.
                                        I'm open minded. Is there a reason to prefer the Photon?
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          Looks interesting. However, it's probably a bit more complicated to use for newcommers, as it's not arduino compatible (not yet anyways).
                                          12.5k
