  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 330.8k Views 52 Watching
  • SparkmanS Sparkman
    @epierre said:
    Do you think I I could use that kind of design in parallel of a static watering controller, so I could have the basic program with the controller, and manage extras with the arduino/mysensors ?
    Inspired by @BulldogLowell's controller, I've been working on a MySensors irrigation controller that works in parallel with my RainBird Controller. I'm using a double set of relays (one 5VDC set that's controlled by the Arduino and a 24VAC set that's controlled by the 5VDC relays and the RainBird). This way I can also sense in my HA system when the valves have been opened by the RainBird controller. I have the base functionality finished and working on some additional bells and whistles. Will post some details in a separate thread later today.
    Al
    treb0r
    Regarding the Video presenting this irrigation project: is the 15 min time, which is counting down after starting the valve via pressing the button, programed somewhere in the arduino code? Or it is taken from timer set in the Vera (or Domoticz) controller?
      @treb0r said:
      Shall it be working withou any problems with Domoticz on Raspberry Pi?
      I assume so. It is using S_LIGHT, one of the most used device types. I am unsure however if Domoticz supports V_VAR1 & V_VAR2 for that device type, so you may have to check with other forum members who use Domoticz.
      treb0r
      Well, it is not working. Domoticz finds 5 switches, but on LCD there is Message: Failed Clock Synchronisation, and the Updating Valves but still 0 :/ Is the problems with V_VAR1 & V_VAR2 variables?
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        On my Vera controller (as demonstrated by @petewill ) you would edit the times under Variable1 and Variable2, which corresponds to V_VAR1 and V_VAR2 in the program.
        The video shows how to modify the values in the arduino by changing the values. I am not sure if Domoticz supports such dataflow. Does Domoticz support V_VAR1 and V_VAR2?
        does Domoticz support MySensors time function? That I do not know.
          treb0r
          @BulldogLowell
          I am afraid that Domoticz doesn't have such advanced options of configuration of devices. Or maybe I am wrong? Is there any chance to bypass the V_VAR1 variables?
          Moshe LivneM BulldogLowellB 2 Replies Last reply
          • T treb0r
            @BulldogLowell
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @treb0r This thread seems to imply that V_VAR1 etc are supported. I guess @AWI can say more about that.
            • Moshe LivneM Moshe Livne
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              thanks for your help, @Moshe-Livne
              Do you know if Domoticz supports returning Unix timestamp using requestTime()?
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @BulldogLowell Sorry, I don't know.
                • T treb0r
                  @BulldogLowell
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  thanks @Moshe-Livne
                  @treb0r said:
                  @BulldogLowell
                  @treb0r,
                  If you can find out if V_VAR1 & V_VAR2 can work you can try that. Otherwise we can hard code the watering times by zone into the programming.
                  If requestTime() isn't supported, we can attach a Real Time Clock (RTC) device to gain back the clock functionality.
                  You can then use the Domoticz devices to start the ALL_ZONE sequence or individual zones...
                  Let me know what you would like to do and I can modify the program for you.
                    thanks @Moshe-Livne
                    @treb0r said:
                    @BulldogLowell
                    @treb0r,
                    treb0r
                    @BulldogLowell
                    requestTime() seems not be supported. A have rtc ds3231 or ds1307. They can use the same commands and libraries. If you would change the code that would perfect :) As you proposed you would also include in the code the timers for zones, instead of requesting them from Domoticz. As I understand these timers are only for manuals starts (via button) right?
                    • T treb0r
                      @BulldogLowell
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @treb0r said:
                      @BulldogLowell
                      Well, those times will be used when you activate the device using the Domoticz on/off controls (or activate using 'scene' in Domotocz.
                      Give me a day or so and I will try to code for you.
                      • T treb0r
                        @BulldogLowell
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        @treb0r
                        Would you like to try this, untested.
                        Just to see if the RTC is working...
                        MySprinkler for MySensors
                        Arduino Multi-Zone Sprinkler Control
                        June 30, 2015
                        *** Version 2.0nsr //MODIFIED FOR NO SHIFT REGISTER
                        * LED status indicator
                        PARTS LIST:
                        * Relays (8 channel)
                        * NRF24L01 Radio
                        * Arduino (I used a Pro Mini)
                        * Capacitors (10uf and .1uf)
                        * 3.3v voltage regulator
                        * Resistors (270 & 10K)
                        * Female Dupont Cables
                        * LED
                        * Push button
                        * Shift Register (SN74HC595)
                        * 18 gauge wire (for relay)
                        INSTRUCTIONS:
                          on the serial monitor.
                        #include <DS1307RTC.h>
                        #include <Time.h>
                        #include <LiquidCrystal.h>
                        #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
                        #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
                        #define SKETCH_VERSION "2.0nsr"
                        #define CHILD_ID_SPRINKLER 0
                        #define ACTIVE_LOW // comment out this line if your relays are active high
                        #ifdef ACTIVE_LOW
                        #define ALL_VALVES_OFF 0xFFFF
                        #define ALL_VALVES_OFF 0U
                        #ifdef DEBUG_ON
                        typedef enum {
                        SprinklerStates;
                        SprinklerStates lastState;
                        const int relayPin[NUMBER_OF_VALVES] = {5, 6, 7, 8}; //<<<<<<<<<<<<<<<<<<< YOUR DIGITAL PINS HERE
                        byte menuState = 0;
                        unsigned long menuTimer;
                        byte countDownTime = 10;
                        int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 1, 1, 1, 1}; //minutes
                        int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 2, 2, 2, 2};
                        int valveNumber;
                        int lastValve;
                        unsigned long startMillis;
                        const int ledPin = 4;
                        const int waterButtonPin = 3;
                        boolean buttonPushed = false;
                        boolean showTime = true;
                        boolean clockUpdating = false;
                        boolean recentUpdate = true;
                        const char *verboseDayOfWeek[] = {
                          /*"Null",*/ "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
                        String valveNickName[17] = {
                        time_t lastTimeRun = 0;
                        /*Setup Shift Register...<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< COMMENTED OUT THIS BIT
                        const int latchPin = 8;
                        const int clockPin = 4;
                        const int dataPin  = 7;
                        LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                          SERIAL_START(115200);
                          pinMode(ledPin, OUTPUT);
                          attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                          digitalWrite (ledPin, HIGH);
                          updateRelays(ALL_VALVES_OFF);
                          //delay(5000);
                          lcd.clear();
                          lcd.backlight();
                          lcd.createChar(0, clock);
                          lcd.createChar(1, raindrop);
                          // RTC setup
                          setSyncProvider(RTC.get);   // the function to get the time from the RTC
                          if(timeStatus()!= timeSet)
                             Serial.println("Unable to sync with the RTC");
                             Serial.println("RTC has set the system time");
                          delay(500);
                          if (gw.loadState(0) == 0xFF); // EEPROM flag
                            for (int i = 0; i < 4 ; i++)
                              lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                          gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                            gw.present(i, S_LIGHT);
                          digitalWrite (ledPin, LOW);
                          DEBUG_PRINTLN(F("Ready..."));
                          lcd.clear();
                            pinMode(relayPin[i], OUTPUT);
                            lcd.print(F(" Updating  "));
                            lcd.setCursor(0, 1);
                            lcd.print(i);
                            boolean flashIcon = false;
                            DEBUG_PRINT(i);
                            DEBUG_PRINTLN(F(" Data..."));
                            while (gw.process() == false)
                              lcd.setCursor(15, 0);
                              flashIcon = !flashIcon;
                              gw.request(i, V_VAR1);
                              delay(100);
                              gw.request(i, V_VAR2);
                              delay(100);
                              gw.request(i, V_VAR3);
                              delay(100);
                          lcd.clear();
                          updateDisplay();
                          goGetValveTimes();
                          if (buttonPushed)
                            menuTimer = millis();
                              state = ZONE_SELECT_MENU;
                              menuState = 0;
                              menuState++;
                                menuState = 0;
                            slowToggleLED ();
                            if (state != lastState)
                                delay(50);
                                gw.send(msg1valve.setSensor(i).set(false), false);
                              lcd.clear();
                              lcd.setCursor(0, 0);
                              delay(2000);
                              lastValve = -1;
                            if (lastValve != valveNumber)
                                  gw.send(msg1valve.setSensor(i).set(true), false);
                            lastValve = valveNumber;
                            fastToggleLed();
                              valveNumber = 1;
                              startMillis = millis();
                              valveNumber++;
                                state = CYCLE_COMPLETE;
                                lastValve = -1;
                                lastTimeRun = now();
                                DEBUG_PRINT(F("State = "));
                                DEBUG_PRINTLN(state);
                            fastToggleLed();
                              DEBUG_PRINT(F("Zone: "));
                              DEBUG_PRINTLN(valveNumber);
                              fastToggleLed();
                          else if (state = ZONE_SELECT_MENU)
                            displayMenu();
                          lastState = state;
                        void displayMenu(void)
                          static int lastSecond;
                            lcd.clear();
                            lcd.print(F("Starting"));
                            lcd.print(F("."));
                            Serial.print(".");
                          lastSecond = thisSecond;
                            if (menuState == 0)
                              valveNumber = 1;
                              state = RUN_ALL_ZONES;
                              valveNumber = menuState;
                              state = RUN_SINGLE_ZONE;
                          lastMenuState = menuState;
                        void updateRelays(int value)
                          for (byte i = 0; i < NUMBER_OF_VALVES; i++)
                            digitalWrite(relayPin[i], bitRead(value, i));
                            buttonPushed = true;
                        void fastToggleLed()
                            fastLedTimer = millis ();
                        void slowToggleLED ()
                            slowLedTimer = millis ();
                          boolean zoneTimeUpdate = false;
                          if (message.isAck())
                            if (message.sensor == i)
                              if (message.type == V_LIGHT)
                                if (switchState == 0)
                                  if (i == 0)
                                    valveNumber = 1;
                                    valveNumber = i;
                                    DEBUG_PRINTLN(i);
                                DEBUG_PRINT(i);
                                DEBUG_PRINT(F(" = "));
                                DEBUG_PRINTLN(variable1);
                                  allZoneTime[i] = variable1;
                                  zoneTimeUpdate = true;
                                DEBUG_PRINT(i);
                                DEBUG_PRINTLN(variable2);
                                  valveSoloTime[i] = variable2;
                                if (newMessage.length() == 0)
                                  DEBUG_PRINTLN(i);
                                if (newMessage.length() > 16)
                                  newMessage.substring(0, 16);
                                valveNickName[i] = "";
                                DEBUG_PRINT(F("Recieved new name for zone "));
                                DEBUG_PRINT(i);
                                DEBUG_PRINT(F(" and it is now called: "));
                          if (zoneTimeUpdate)
                              if (i != 0)
                                DEBUG_PRINT(F("Zone "));
                                DEBUG_PRINT(i);
                                DEBUG_PRINTLN(allZoneTime[i]);
                            recentUpdate = false;
                        void updateDisplay()
                          static boolean displayToggle = false;
                            switch (state) {
                              case STAND_BY_ALL_OFF:
                                fastClear();
                                if (displayToggle)
                                  if (clockUpdating)
                                    lcd.write(byte(0));
                                  lcd.print(hourFormat12());
                                  lcd.print(minute());
                                  lcd.print(month());
                                  lcd.print(day());
                                  lcd.print(F("/"));
                                  lcd.print(year() % 100);
                                  if (clockUpdating)
                                    lcd.write(byte(0));
                                  lcd.print(verboseDayOfWeek[weekday(lastTimeRun)]);
                                  lcd.setCursor(11, 1);
                                  lcd.print(day(lastTimeRun));
                              case RUN_SINGLE_ZONE:
                                fastClear();
                                if (displayToggle)
                                  lcd.print(F(" Zone:"));
                                  lcd.print(valveNumber);
                                  lcd.print(F(" Active"));
                                    lcd.print("min");
                                    lcd.print("sec  ");
                              case RUN_ALL_ZONES:
                                fastClear();
                                if (displayToggle)
                                  lcd.print(F(" Active "));
                                  lcd.print("min");
                                  lcd.print("sec  ");
                              case CYCLE_COMPLETE:
                                if (displayToggle)
                                  int totalTimeRan = 0;
                                  lcd.print(totalTimeRan);
                                  lcd.print(" Minutes   ");
                            lastUpdateTime = millis();
                          lastDisplayState = state;
                        void fastClear()
                          if (gw.loadState(0) != 0xFF)
                            gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                          for (int i = 1; i < 5; i++)
                            gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                        void goGetValveTimes()
                          static byte valveIndex = 1;
                          if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                            DEBUG_PRINTLN(F("Calling for Valve Data..."));
                            lcd.write(byte(1)); //lcd.write(1);
                            gw.request(valveIndex, V_VAR1);
                            gw.request(valveIndex, V_VAR2);
                            gw.request(valveIndex, V_VAR3);
                            valveUpdateTime = millis();
                            valveIndex++;
                            if (valveIndex > NUMBER_OF_VALVES + 1)
                              valveIndex = 1;
                          @treb0r
                          June 30, 2015
                          PARTS LIST:
                          * NRF24L01 Radio
                          * LED
                          * Push button
                          INSTRUCTIONS:
                          #include <Time.h>
                          #ifdef ACTIVE_LOW
                          #ifdef DEBUG_ON
                          typedef enum {
                          SprinklerStates;
                          byte menuState = 0;
                          int valveNumber;
                          int lastValve;
                            //delay(5000);
                            lcd.clear();
                            lcd.backlight();
                            // RTC setup
                            delay(500);
                            lcd.clear();
                              lcd.print(i);
                              DEBUG_PRINT(i);
                                delay(100);
                                delay(100);
                                delay(100);
                            lcd.clear();
                            updateDisplay();
                            goGetValveTimes();
                            if (buttonPushed)
                                menuState = 0;
                                menuState++;
                                  menuState = 0;
                              slowToggleLED ();
                                  delay(50);
                                lcd.clear();
                                delay(2000);
                                lastValve = -1;
                              fastToggleLed();
                                valveNumber = 1;
                                valveNumber++;
                                  lastValve = -1;
                              fastToggleLed();
                                fastToggleLed();
                              displayMenu();
                            lastState = state;
                              lcd.clear();
                              lcd.print(F("."));
                              Serial.print(".");
                              if (menuState == 0)
                                valveNumber = 1;
                                    if (i == 0)
                                      valveNumber = 1;
                                      valveNumber = i;
                                      DEBUG_PRINTLN(i);
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINT(i);
                                    DEBUG_PRINTLN(i);
                                  DEBUG_PRINT(i);
                            if (zoneTimeUpdate)
                                if (i != 0)
                                  DEBUG_PRINT(i);
                              switch (state) {
                                  fastClear();
                                  if (displayToggle)
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                    lcd.print(month());
                                    lcd.print(day());
                                    lcd.print(F("/"));
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                  fastClear();
                                  if (displayToggle)
                                      lcd.print("min");
                                      lcd.print("sec  ");
                                case RUN_ALL_ZONES:
                                  fastClear();
                                  if (displayToggle)
                                    lcd.print("min");
                                    lcd.print("sec  ");
                                  if (displayToggle)
                          void fastClear()
                              valveIndex++;
                                valveIndex = 1;
                          treb0r
                          @BulldogLowell
                          HI
                          Thanks for the post. On LCD there is no info about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
                          So I cant check if the RTC is working
                          treb0r
                          • T treb0r
                            @BulldogLowell
                            HI
                            treb0r
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            @treb0r
                            did you get your RTC connected and tested?
                              @treb0r
                              treb0r
                              @BulldogLowell
                              Yes, RTC is connected and tested with different sketches (just to check if RTC work correctly). Works ok.
                              With your correctes projects, as above mentioned: On LCD there is no info neither about Time Synchronisation, nor about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
                              treb0r
                              • BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                Yes, since clock no longer needs to call server for time, synchronizing is not necessary.
                                You should post serial output or show a video.
                                Did you find out if Domoticz supports V_VAR1?
                                  treb0r
                                  @BulldogLowell
                                  OK, I will post the video. If I will manage I will also post serial output
                                  treb0r
                                  • T treb0r
                                    @BulldogLowell
                                    treb0r
                                    Moshe LivneM
                                    Moshe LivneM
                                    Moshe Livne
                                    @treb0r @BulldogLowel I had a chance to play a little bit with VAR1 this weekend. I verified that if you declare MyMessage var(CHILD_ID, V_VAR1); you can set it with gw.send(var.set("hello")); and request its value from the gateway using gw.request(CHILD_ID, V_VAR1);. you will get the answer in the incoming message handler under the V_VAR1 message
                                       if (message.type==V_VAR1) {
                                       	 Serial.println("got var1 answer");
                                    However I still didn't manage to find how to access or show these values on the domoticz. their site crashed so couldn't ask this in the forum
                                    • epierreE
                                      epierreE
                                      epierre
                                      @Moshe-Livne Domoticz (as of today) doesn't support V_VARx ...
                                      z-wave - Vera -> Domoticz
                                      • epierreE epierre
                                        Moshe LivneM
                                        Moshe LivneM
                                        Moshe Livne
                                        @epierre it does but in a strange way. The vars are not display vars. They are stored in the db and can be fetched and set only by the sensor. Tried it, it works....
                                        • epierreE
                                          epierreE
                                          epierre
                                          @Moshe-Livne this is not what @GizMoCuz said in a post... strange...
