  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 330.8k Views 52 Watching
  • T treb0r
    @BulldogLowell
    I am afraid that Domoticz doesn't have such advanced options of configuration of devices. Or maybe I am wrong? Is there any chance to bypass the V_VAR1 variables?
    Moshe LivneM
    Moshe LivneM
    Moshe Livne
    @treb0r This thread seems to imply that V_VAR1 etc are supported. I guess @AWI can say more about that.
    • Moshe LivneM Moshe Livne
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      thanks for your help, @Moshe-Livne
      Do you know if Domoticz supports returning Unix timestamp using requestTime()?
        Moshe LivneM
        Moshe LivneM
        Moshe Livne
        @BulldogLowell Sorry, I don't know.
        • T treb0r
          @BulldogLowell
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          thanks @Moshe-Livne
          @treb0r said:
          @BulldogLowell
          @treb0r,
          If you can find out if V_VAR1 & V_VAR2 can work you can try that. Otherwise we can hard code the watering times by zone into the programming.
          If requestTime() isn't supported, we can attach a Real Time Clock (RTC) device to gain back the clock functionality.
          You can then use the Domoticz devices to start the ALL_ZONE sequence or individual zones...
          Let me know what you would like to do and I can modify the program for you.
            thanks @Moshe-Livne
            @treb0r said:
            @BulldogLowell
            @treb0r,
            treb0r
            @BulldogLowell
            requestTime() seems not be supported. A have rtc ds3231 or ds1307. They can use the same commands and libraries. If you would change the code that would perfect :) As you proposed you would also include in the code the timers for zones, instead of requesting them from Domoticz. As I understand these timers are only for manuals starts (via button) right?
            BulldogLowellB 2 Replies Last reply
            • T treb0r
              @BulldogLowell
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @treb0r said:
              @BulldogLowell
              Well, those times will be used when you activate the device using the Domoticz on/off controls (or activate using 'scene' in Domotocz.
              Give me a day or so and I will try to code for you.
              • T treb0r
                @BulldogLowell
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @treb0r
                Would you like to try this, untested.
                Just to see if the RTC is working...
                MySprinkler for MySensors
                Arduino Multi-Zone Sprinkler Control
                June 30, 2015
                *** Version 2.0nsr //MODIFIED FOR NO SHIFT REGISTER
                * LED status indicator
                PARTS LIST:
                * Relays (8 channel)
                * NRF24L01 Radio
                * Arduino (I used a Pro Mini)
                * Capacitors (10uf and .1uf)
                * 3.3v voltage regulator
                * Resistors (270 & 10K)
                * Female Dupont Cables
                * LED
                * Push button
                * Shift Register (SN74HC595)
                * 18 gauge wire (for relay)
                INSTRUCTIONS:
                  on the serial monitor.
                #include <DS1307RTC.h>
                #include <Time.h>
                #include <LiquidCrystal.h>
                #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
                #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
                #define SKETCH_VERSION "2.0nsr"
                #define CHILD_ID_SPRINKLER 0
                #define ACTIVE_LOW // comment out this line if your relays are active high
                #ifdef ACTIVE_LOW
                #define ALL_VALVES_OFF 0xFFFF
                #define ALL_VALVES_OFF 0U
                #ifdef DEBUG_ON
                typedef enum {
                SprinklerStates;
                SprinklerStates lastState;
                const int relayPin[NUMBER_OF_VALVES] = {5, 6, 7, 8}; //<<<<<<<<<<<<<<<<<<< YOUR DIGITAL PINS HERE
                byte menuState = 0;
                unsigned long menuTimer;
                byte countDownTime = 10;
                int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 1, 1, 1, 1}; //minutes
                int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 2, 2, 2, 2};
                int valveNumber;
                int lastValve;
                unsigned long startMillis;
                const int ledPin = 4;
                const int waterButtonPin = 3;
                boolean buttonPushed = false;
                boolean showTime = true;
                boolean clockUpdating = false;
                boolean recentUpdate = true;
                const char *verboseDayOfWeek[] = {
                  /*"Null",*/ "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
                String valveNickName[17] = {
                time_t lastTimeRun = 0;
                /*Setup Shift Register...<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< COMMENTED OUT THIS BIT
                const int latchPin = 8;
                const int clockPin = 4;
                const int dataPin  = 7;
                LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                  SERIAL_START(115200);
                  pinMode(ledPin, OUTPUT);
                  attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                  digitalWrite (ledPin, HIGH);
                  updateRelays(ALL_VALVES_OFF);
                  //delay(5000);
                  lcd.clear();
                  lcd.backlight();
                  lcd.createChar(0, clock);
                  lcd.createChar(1, raindrop);
                  // RTC setup
                  setSyncProvider(RTC.get);   // the function to get the time from the RTC
                  if(timeStatus()!= timeSet)
                     Serial.println("Unable to sync with the RTC");
                     Serial.println("RTC has set the system time");
                  delay(500);
                  if (gw.loadState(0) == 0xFF); // EEPROM flag
                    for (int i = 0; i < 4 ; i++)
                      lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                  gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                    gw.present(i, S_LIGHT);
                  digitalWrite (ledPin, LOW);
                  DEBUG_PRINTLN(F("Ready..."));
                  lcd.clear();
                    pinMode(relayPin[i], OUTPUT);
                    lcd.print(F(" Updating  "));
                    lcd.setCursor(0, 1);
                    lcd.print(i);
                    boolean flashIcon = false;
                    DEBUG_PRINT(i);
                    DEBUG_PRINTLN(F(" Data..."));
                    while (gw.process() == false)
                      lcd.setCursor(15, 0);
                      flashIcon = !flashIcon;
                      gw.request(i, V_VAR1);
                      delay(100);
                      gw.request(i, V_VAR2);
                      delay(100);
                      gw.request(i, V_VAR3);
                      delay(100);
                  lcd.clear();
                  updateDisplay();
                  goGetValveTimes();
                  if (buttonPushed)
                    menuTimer = millis();
                      state = ZONE_SELECT_MENU;
                      menuState = 0;
                      menuState++;
                        menuState = 0;
                    slowToggleLED ();
                    if (state != lastState)
                        delay(50);
                        gw.send(msg1valve.setSensor(i).set(false), false);
                      lcd.clear();
                      lcd.setCursor(0, 0);
                      delay(2000);
                      lastValve = -1;
                    if (lastValve != valveNumber)
                          gw.send(msg1valve.setSensor(i).set(true), false);
                    lastValve = valveNumber;
                    fastToggleLed();
                      valveNumber = 1;
                      startMillis = millis();
                      valveNumber++;
                        state = CYCLE_COMPLETE;
                        lastValve = -1;
                        lastTimeRun = now();
                        DEBUG_PRINT(F("State = "));
                        DEBUG_PRINTLN(state);
                    fastToggleLed();
                      DEBUG_PRINT(F("Zone: "));
                      DEBUG_PRINTLN(valveNumber);
                      fastToggleLed();
                  else if (state = ZONE_SELECT_MENU)
                    displayMenu();
                  lastState = state;
                void displayMenu(void)
                  static int lastSecond;
                    lcd.clear();
                    lcd.print(F("Starting"));
                    lcd.print(F("."));
                    Serial.print(".");
                  lastSecond = thisSecond;
                    if (menuState == 0)
                      valveNumber = 1;
                      state = RUN_ALL_ZONES;
                      valveNumber = menuState;
                      state = RUN_SINGLE_ZONE;
                  lastMenuState = menuState;
                void updateRelays(int value)
                  for (byte i = 0; i < NUMBER_OF_VALVES; i++)
                    digitalWrite(relayPin[i], bitRead(value, i));
                    buttonPushed = true;
                void fastToggleLed()
                    fastLedTimer = millis ();
                void slowToggleLED ()
                    slowLedTimer = millis ();
                  boolean zoneTimeUpdate = false;
                  if (message.isAck())
                    if (message.sensor == i)
                      if (message.type == V_LIGHT)
                        if (switchState == 0)
                          if (i == 0)
                            valveNumber = 1;
                            valveNumber = i;
                            DEBUG_PRINTLN(i);
                        DEBUG_PRINT(i);
                        DEBUG_PRINT(F(" = "));
                        DEBUG_PRINTLN(variable1);
                          allZoneTime[i] = variable1;
                          zoneTimeUpdate = true;
                        DEBUG_PRINT(i);
                        DEBUG_PRINTLN(variable2);
                          valveSoloTime[i] = variable2;
                        if (newMessage.length() == 0)
                          DEBUG_PRINTLN(i);
                        if (newMessage.length() > 16)
                          newMessage.substring(0, 16);
                        valveNickName[i] = "";
                        DEBUG_PRINT(F("Recieved new name for zone "));
                        DEBUG_PRINT(i);
                        DEBUG_PRINT(F(" and it is now called: "));
                  if (zoneTimeUpdate)
                      if (i != 0)
                        DEBUG_PRINT(F("Zone "));
                        DEBUG_PRINT(i);
                        DEBUG_PRINTLN(allZoneTime[i]);
                    recentUpdate = false;
                void updateDisplay()
                  static boolean displayToggle = false;
                    switch (state) {
                      case STAND_BY_ALL_OFF:
                        fastClear();
                        if (displayToggle)
                          if (clockUpdating)
                            lcd.write(byte(0));
                          lcd.print(hourFormat12());
                          lcd.print(minute());
                          lcd.print(month());
                          lcd.print(day());
                          lcd.print(F("/"));
                          lcd.print(year() % 100);
                          if (clockUpdating)
                            lcd.write(byte(0));
                          lcd.print(verboseDayOfWeek[weekday(lastTimeRun)]);
                          lcd.setCursor(11, 1);
                          lcd.print(day(lastTimeRun));
                      case RUN_SINGLE_ZONE:
                        fastClear();
                        if (displayToggle)
                          lcd.print(F(" Zone:"));
                          lcd.print(valveNumber);
                          lcd.print(F(" Active"));
                            lcd.print("min");
                            lcd.print("sec  ");
                      case RUN_ALL_ZONES:
                        fastClear();
                        if (displayToggle)
                          lcd.print(F(" Active "));
                          lcd.print("min");
                          lcd.print("sec  ");
                      case CYCLE_COMPLETE:
                        if (displayToggle)
                          int totalTimeRan = 0;
                          lcd.print(totalTimeRan);
                          lcd.print(" Minutes   ");
                    lastUpdateTime = millis();
                  lastDisplayState = state;
                void fastClear()
                  if (gw.loadState(0) != 0xFF)
                    gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                  for (int i = 1; i < 5; i++)
                    gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                void goGetValveTimes()
                  static byte valveIndex = 1;
                  if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                    DEBUG_PRINTLN(F("Calling for Valve Data..."));
                    lcd.write(byte(1)); //lcd.write(1);
                    gw.request(valveIndex, V_VAR1);
                    gw.request(valveIndex, V_VAR2);
                    gw.request(valveIndex, V_VAR3);
                    valveUpdateTime = millis();
                    valveIndex++;
                    if (valveIndex > NUMBER_OF_VALVES + 1)
                      valveIndex = 1;
                  @treb0r
                  June 30, 2015
                  PARTS LIST:
                  * NRF24L01 Radio
                  * LED
                  * Push button
                  INSTRUCTIONS:
                  #include <Time.h>
                  #ifdef ACTIVE_LOW
                  #ifdef DEBUG_ON
                  typedef enum {
                  SprinklerStates;
                  byte menuState = 0;
                  int valveNumber;
                  int lastValve;
                    //delay(5000);
                    lcd.clear();
                    lcd.backlight();
                    // RTC setup
                    delay(500);
                    lcd.clear();
                      lcd.print(i);
                      DEBUG_PRINT(i);
                        delay(100);
                        delay(100);
                        delay(100);
                    lcd.clear();
                    updateDisplay();
                    goGetValveTimes();
                    if (buttonPushed)
                        menuState = 0;
                        menuState++;
                          menuState = 0;
                      slowToggleLED ();
                          delay(50);
                        lcd.clear();
                        delay(2000);
                        lastValve = -1;
                      fastToggleLed();
                        valveNumber = 1;
                        valveNumber++;
                          lastValve = -1;
                      fastToggleLed();
                        fastToggleLed();
                      displayMenu();
                    lastState = state;
                      lcd.clear();
                      lcd.print(F("."));
                      Serial.print(".");
                      if (menuState == 0)
                        valveNumber = 1;
                            if (i == 0)
                              valveNumber = 1;
                              valveNumber = i;
                              DEBUG_PRINTLN(i);
                          DEBUG_PRINT(i);
                          DEBUG_PRINT(i);
                            DEBUG_PRINTLN(i);
                          DEBUG_PRINT(i);
                    if (zoneTimeUpdate)
                        if (i != 0)
                          DEBUG_PRINT(i);
                      switch (state) {
                          fastClear();
                          if (displayToggle)
                            if (clockUpdating)
                              lcd.write(byte(0));
                            lcd.print(month());
                            lcd.print(day());
                            lcd.print(F("/"));
                            if (clockUpdating)
                              lcd.write(byte(0));
                          fastClear();
                          if (displayToggle)
                              lcd.print("min");
                              lcd.print("sec  ");
                        case RUN_ALL_ZONES:
                          fastClear();
                          if (displayToggle)
                            lcd.print("min");
                            lcd.print("sec  ");
                          if (displayToggle)
                  void fastClear()
                      valveIndex++;
                        valveIndex = 1;
                  treb0r
                  @BulldogLowell
                  HI
                  Thanks for the post. On LCD there is no info about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
                  So I cant check if the RTC is working
                  treb0r
                  • T treb0r
                    @BulldogLowell
                    HI
                    treb0r
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @treb0r
                    did you get your RTC connected and tested?
                      @treb0r
                      treb0r
                      @BulldogLowell
                      Yes, RTC is connected and tested with different sketches (just to check if RTC work correctly). Works ok.
                      With your correctes projects, as above mentioned: On LCD there is no info neither about Time Synchronisation, nor about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
                      treb0r
                      • BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        Yes, since clock no longer needs to call server for time, synchronizing is not necessary.
                        You should post serial output or show a video.
                        Did you find out if Domoticz supports V_VAR1?
                          treb0r
                          @BulldogLowell
                          OK, I will post the video. If I will manage I will also post serial output
                          treb0r
                          • T treb0r
                            @BulldogLowell
                            treb0r
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @treb0r @BulldogLowel I had a chance to play a little bit with VAR1 this weekend. I verified that if you declare MyMessage var(CHILD_ID, V_VAR1); you can set it with gw.send(var.set("hello")); and request its value from the gateway using gw.request(CHILD_ID, V_VAR1);. you will get the answer in the incoming message handler under the V_VAR1 message
                               if (message.type==V_VAR1) {
                               	 Serial.println("got var1 answer");
                            However I still didn't manage to find how to access or show these values on the domoticz. their site crashed so couldn't ask this in the forum
                            • epierreE
                              epierreE
                              epierre
                              @Moshe-Livne Domoticz (as of today) doesn't support V_VARx ...
                              z-wave - Vera -> Domoticz
                              • epierreE epierre
                                Moshe LivneM
                                Moshe LivneM
                                Moshe Livne
                                @epierre it does but in a strange way. The vars are not display vars. They are stored in the db and can be fetched and set only by the sensor. Tried it, it works....
                                • epierreE
                                  epierreE
                                  epierre
                                  @Moshe-Livne this is not what @GizMoCuz said in a post... strange...
                                  • epierreE epierre
                                    Moshe LivneM
                                    Moshe LivneM
                                    Moshe Livne
                                    @epierre can you please link to the post?
                                    • epierreE
                                      epierreE
                                      epierre
                                      here it is:
                                      http://www.domoticz.com/forum/viewtopic.php?f=42&t=7187&p=48366&hilit=v_var#p48366
                                      • epierreE epierre
                                        here it is:
                                        Moshe LivneM
                                        Moshe LivneM
                                        Moshe Livne
                                        @epierre He meant in the sense that it does not display or use it for anything. he said there "it is used to store/retrieve variables". The thread was about the option to show the vars as part of the sensor output. for storing and retrieving, it works.... verified.... I might get annoyed enough to add to the code that the lua script can also retrieve these vars and then it would be sweet.....
                                        • epierreE
                                          epierreE
                                          epierre
                                          ok good although it was not explicit... now I'll have to go back to him about water meter that heavily use V_VARs but is recognized.... as a power meter...
