  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 322.6k Views 52 Watching
    thanks for your help, @Moshe-Livne
    Do you know if Domoticz supports returning Unix timestamp using requestTime()?
    Moshe LivneM
    Moshe LivneM
    Moshe Livne
    @BulldogLowell Sorry, I don't know.
    • T treb0r
      @BulldogLowell
      I am afraid that Domoticz doesn't have such advanced options of configuration of devices. Or maybe I am wrong? Is there any chance to bypass the V_VAR1 variables?
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      thanks @Moshe-Livne
      @treb0r said:
      @BulldogLowell
      @treb0r,
      If you can find out if V_VAR1 & V_VAR2 can work you can try that. Otherwise we can hard code the watering times by zone into the programming.
      If requestTime() isn't supported, we can attach a Real Time Clock (RTC) device to gain back the clock functionality.
      You can then use the Domoticz devices to start the ALL_ZONE sequence or individual zones...
      Let me know what you would like to do and I can modify the program for you.
        thanks @Moshe-Livne
        @treb0r said:
        @BulldogLowell
        @treb0r,
        treb0r
        @BulldogLowell
        requestTime() seems not be supported. A have rtc ds3231 or ds1307. They can use the same commands and libraries. If you would change the code that would perfect :) As you proposed you would also include in the code the timers for zones, instead of requesting them from Domoticz. As I understand these timers are only for manuals starts (via button) right?
        BulldogLowellB 2 Replies Last reply
        • T treb0r
          @BulldogLowell
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @treb0r said:
          @BulldogLowell
          Well, those times will be used when you activate the device using the Domoticz on/off controls (or activate using 'scene' in Domotocz.
          Give me a day or so and I will try to code for you.
          • T treb0r
            @BulldogLowell
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @treb0r
            Would you like to try this, untested.
            Just to see if the RTC is working...
            MySprinkler for MySensors
            Arduino Multi-Zone Sprinkler Control
            June 30, 2015
            *** Version 2.0nsr //MODIFIED FOR NO SHIFT REGISTER
            * LED status indicator
            PARTS LIST:
            * Relays (8 channel)
            * NRF24L01 Radio
            * Arduino (I used a Pro Mini)
            * Capacitors (10uf and .1uf)
            * 3.3v voltage regulator
            * Resistors (270 & 10K)
            * Female Dupont Cables
            * LED
            * Push button
            * Shift Register (SN74HC595)
            * 18 gauge wire (for relay)
            INSTRUCTIONS:
              on the serial monitor.
            #include <DS1307RTC.h>
            #include <Time.h>
            #include <LiquidCrystal.h>
            #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
            #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
            #define SKETCH_VERSION "2.0nsr"
            #define CHILD_ID_SPRINKLER 0
            #define ACTIVE_LOW // comment out this line if your relays are active high
            #ifdef ACTIVE_LOW
            #define ALL_VALVES_OFF 0xFFFF
            #define ALL_VALVES_OFF 0U
            #ifdef DEBUG_ON
            typedef enum {
            SprinklerStates;
            SprinklerStates lastState;
            const int relayPin[NUMBER_OF_VALVES] = {5, 6, 7, 8}; //<<<<<<<<<<<<<<<<<<< YOUR DIGITAL PINS HERE
            byte menuState = 0;
            unsigned long menuTimer;
            byte countDownTime = 10;
            int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 1, 1, 1, 1}; //minutes
            int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 2, 2, 2, 2};
            int valveNumber;
            int lastValve;
            unsigned long startMillis;
            const int ledPin = 4;
            const int waterButtonPin = 3;
            boolean buttonPushed = false;
            boolean showTime = true;
            boolean clockUpdating = false;
            boolean recentUpdate = true;
            const char *verboseDayOfWeek[] = {
              /*"Null",*/ "Sunday ", "Monday ", "Tuesday ", "Wednesday ", "Thursday ", "Friday ", "Saturday "
            String valveNickName[17] = {
            time_t lastTimeRun = 0;
            /*Setup Shift Register...<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< COMMENTED OUT THIS BIT
            const int latchPin = 8;
            const int clockPin = 4;
            const int dataPin  = 7;
            LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
              SERIAL_START(115200);
              pinMode(ledPin, OUTPUT);
              attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
              digitalWrite (ledPin, HIGH);
              updateRelays(ALL_VALVES_OFF);
              //delay(5000);
              lcd.clear();
              lcd.backlight();
              lcd.createChar(0, clock);
              lcd.createChar(1, raindrop);
              // RTC setup
              setSyncProvider(RTC.get);   // the function to get the time from the RTC
              if(timeStatus()!= timeSet)
                 Serial.println("Unable to sync with the RTC");
                 Serial.println("RTC has set the system time");
              delay(500);
              if (gw.loadState(0) == 0xFF); // EEPROM flag
                for (int i = 0; i < 4 ; i++)
                  lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
              gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                gw.present(i, S_LIGHT);
              digitalWrite (ledPin, LOW);
              DEBUG_PRINTLN(F("Ready..."));
              lcd.clear();
                pinMode(relayPin[i], OUTPUT);
                lcd.print(F(" Updating  "));
                lcd.setCursor(0, 1);
                lcd.print(i);
                boolean flashIcon = false;
                DEBUG_PRINT(i);
                DEBUG_PRINTLN(F(" Data..."));
                while (gw.process() == false)
                  lcd.setCursor(15, 0);
                  flashIcon = !flashIcon;
                  gw.request(i, V_VAR1);
                  delay(100);
                  gw.request(i, V_VAR2);
                  delay(100);
                  gw.request(i, V_VAR3);
                  delay(100);
              lcd.clear();
              updateDisplay();
              goGetValveTimes();
              if (buttonPushed)
                menuTimer = millis();
                  state = ZONE_SELECT_MENU;
                  menuState = 0;
                  menuState++;
                    menuState = 0;
                slowToggleLED ();
                if (state != lastState)
                    delay(50);
                    gw.send(msg1valve.setSensor(i).set(false), false);
                  lcd.clear();
                  lcd.setCursor(0, 0);
                  delay(2000);
                  lastValve = -1;
                if (lastValve != valveNumber)
                      gw.send(msg1valve.setSensor(i).set(true), false);
                lastValve = valveNumber;
                fastToggleLed();
                  valveNumber = 1;
                  startMillis = millis();
                  valveNumber++;
                    state = CYCLE_COMPLETE;
                    lastValve = -1;
                    lastTimeRun = now();
                    DEBUG_PRINT(F("State = "));
                    DEBUG_PRINTLN(state);
                fastToggleLed();
                  DEBUG_PRINT(F("Zone: "));
                  DEBUG_PRINTLN(valveNumber);
                  fastToggleLed();
              else if (state = ZONE_SELECT_MENU)
                displayMenu();
              lastState = state;
            void displayMenu(void)
              static int lastSecond;
                lcd.clear();
                lcd.print(F("Starting"));
                lcd.print(F("."));
                Serial.print(".");
              lastSecond = thisSecond;
                if (menuState == 0)
                  valveNumber = 1;
                  state = RUN_ALL_ZONES;
                  valveNumber = menuState;
                  state = RUN_SINGLE_ZONE;
              lastMenuState = menuState;
            void updateRelays(int value)
              for (byte i = 0; i < NUMBER_OF_VALVES; i++)
                digitalWrite(relayPin[i], bitRead(value, i));
                buttonPushed = true;
            void fastToggleLed()
                fastLedTimer = millis ();
            void slowToggleLED ()
                slowLedTimer = millis ();
              boolean zoneTimeUpdate = false;
              if (message.isAck())
                if (message.sensor == i)
                  if (message.type == V_LIGHT)
                    if (switchState == 0)
                      if (i == 0)
                        valveNumber = 1;
                        valveNumber = i;
                        DEBUG_PRINTLN(i);
                    DEBUG_PRINT(i);
                    DEBUG_PRINT(F(" = "));
                    DEBUG_PRINTLN(variable1);
                      allZoneTime[i] = variable1;
                      zoneTimeUpdate = true;
                    DEBUG_PRINT(i);
                    DEBUG_PRINTLN(variable2);
                      valveSoloTime[i] = variable2;
                    if (newMessage.length() == 0)
                      DEBUG_PRINTLN(i);
                    if (newMessage.length() > 16)
                      newMessage.substring(0, 16);
                    valveNickName[i] = "";
                    DEBUG_PRINT(F("Recieved new name for zone "));
                    DEBUG_PRINT(i);
                    DEBUG_PRINT(F(" and it is now called: "));
              if (zoneTimeUpdate)
                  if (i != 0)
                    DEBUG_PRINT(F("Zone "));
                    DEBUG_PRINT(i);
                    DEBUG_PRINTLN(allZoneTime[i]);
                recentUpdate = false;
            void updateDisplay()
              static boolean displayToggle = false;
                switch (state) {
                  case STAND_BY_ALL_OFF:
                    fastClear();
                    if (displayToggle)
                      if (clockUpdating)
                        lcd.write(byte(0));
                      lcd.print(hourFormat12());
                      lcd.print(minute());
                      lcd.print(month());
                      lcd.print(day());
                      lcd.print(F("/"));
                      lcd.print(year() % 100);
                      if (clockUpdating)
                        lcd.write(byte(0));
                      lcd.print(verboseDayOfWeek[weekday(lastTimeRun)]);
                      lcd.setCursor(11, 1);
                      lcd.print(day(lastTimeRun));
                  case RUN_SINGLE_ZONE:
                    fastClear();
                    if (displayToggle)
                      lcd.print(F(" Zone:"));
                      lcd.print(valveNumber);
                      lcd.print(F(" Active"));
                        lcd.print("min");
                        lcd.print("sec  ");
                  case RUN_ALL_ZONES:
                    fastClear();
                    if (displayToggle)
                      lcd.print(F(" Active "));
                      lcd.print("min");
                      lcd.print("sec  ");
                  case CYCLE_COMPLETE:
                    if (displayToggle)
                      int totalTimeRan = 0;
                      lcd.print(totalTimeRan);
                      lcd.print(" Minutes   ");
                lastUpdateTime = millis();
              lastDisplayState = state;
            void fastClear()
              if (gw.loadState(0) != 0xFF)
                gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
              for (int i = 1; i < 5; i++)
                gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
            void goGetValveTimes()
              static byte valveIndex = 1;
              if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                DEBUG_PRINTLN(F("Calling for Valve Data..."));
                lcd.write(byte(1)); //lcd.write(1);
                gw.request(valveIndex, V_VAR1);
                gw.request(valveIndex, V_VAR2);
                gw.request(valveIndex, V_VAR3);
                valveUpdateTime = millis();
                valveIndex++;
                if (valveIndex > NUMBER_OF_VALVES + 1)
                  valveIndex = 1;
              @treb0r
              June 30, 2015
              PARTS LIST:
              * NRF24L01 Radio
              * LED
              * Push button
              INSTRUCTIONS:
              #include <Time.h>
              #ifdef ACTIVE_LOW
              #ifdef DEBUG_ON
              typedef enum {
              SprinklerStates;
              byte menuState = 0;
              int valveNumber;
              int lastValve;
                //delay(5000);
                lcd.clear();
                lcd.backlight();
                // RTC setup
                delay(500);
                lcd.clear();
                  lcd.print(i);
                  DEBUG_PRINT(i);
                    delay(100);
                    delay(100);
                    delay(100);
                lcd.clear();
                updateDisplay();
                goGetValveTimes();
                if (buttonPushed)
                    menuState = 0;
                    menuState++;
                      menuState = 0;
                  slowToggleLED ();
                      delay(50);
                    lcd.clear();
                    delay(2000);
                    lastValve = -1;
                  fastToggleLed();
                    valveNumber = 1;
                    valveNumber++;
                      lastValve = -1;
                  fastToggleLed();
                    fastToggleLed();
                  displayMenu();
                lastState = state;
                  lcd.clear();
                  lcd.print(F("."));
                  Serial.print(".");
                  if (menuState == 0)
                    valveNumber = 1;
                        if (i == 0)
                          valveNumber = 1;
                          valveNumber = i;
                          DEBUG_PRINTLN(i);
                      DEBUG_PRINT(i);
                      DEBUG_PRINT(i);
                        DEBUG_PRINTLN(i);
                      DEBUG_PRINT(i);
                if (zoneTimeUpdate)
                    if (i != 0)
                      DEBUG_PRINT(i);
                  switch (state) {
                      fastClear();
                      if (displayToggle)
                        if (clockUpdating)
                          lcd.write(byte(0));
                        lcd.print(month());
                        lcd.print(day());
                        lcd.print(F("/"));
                        if (clockUpdating)
                          lcd.write(byte(0));
                      fastClear();
                      if (displayToggle)
                          lcd.print("min");
                          lcd.print("sec  ");
                    case RUN_ALL_ZONES:
                      fastClear();
                      if (displayToggle)
                        lcd.print("min");
                        lcd.print("sec  ");
                      if (displayToggle)
              void fastClear()
                  valveIndex++;
                    valveIndex = 1;
              treb0r
              @BulldogLowell
              HI
              Thanks for the post. On LCD there is no info about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
              So I cant check if the RTC is working
              treb0r
              • T treb0r
                @BulldogLowell
                HI
                treb0r
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @treb0r
                did you get your RTC connected and tested?
                  @treb0r
                  treb0r
                  @BulldogLowell
                  Yes, RTC is connected and tested with different sketches (just to check if RTC work correctly). Works ok.
                  With your correctes projects, as above mentioned: On LCD there is no info neither about Time Synchronisation, nor about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
                  treb0r
                  • BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    Yes, since clock no longer needs to call server for time, synchronizing is not necessary.
                    You should post serial output or show a video.
                    Did you find out if Domoticz supports V_VAR1?
                      treb0r
                      @BulldogLowell
                      OK, I will post the video. If I will manage I will also post serial output
                      treb0r
                      • T treb0r
                        @BulldogLowell
                        treb0r
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        @treb0r @BulldogLowel I had a chance to play a little bit with VAR1 this weekend. I verified that if you declare MyMessage var(CHILD_ID, V_VAR1); you can set it with gw.send(var.set("hello")); and request its value from the gateway using gw.request(CHILD_ID, V_VAR1);. you will get the answer in the incoming message handler under the V_VAR1 message
                           if (message.type==V_VAR1) {
                           	 Serial.println("got var1 answer");
                        However I still didn't manage to find how to access or show these values on the domoticz. their site crashed so couldn't ask this in the forum
                        • epierreE
                          epierreE
                          epierre
                          @Moshe-Livne Domoticz (as of today) doesn't support V_VARx ...
                          z-wave - Vera -> Domoticz
                          • epierreE epierre
                            Moshe LivneM
                            Moshe LivneM
                            Moshe Livne
                            @epierre it does but in a strange way. The vars are not display vars. They are stored in the db and can be fetched and set only by the sensor. Tried it, it works....
                            • epierreE
                              epierreE
                              epierre
                              @Moshe-Livne this is not what @GizMoCuz said in a post... strange...
                              • epierreE epierre
                                Moshe LivneM
                                Moshe LivneM
                                Moshe Livne
                                @epierre can you please link to the post?
                                • epierreE
                                  epierreE
                                  epierre
                                  here it is:
                                  http://www.domoticz.com/forum/viewtopic.php?f=42&t=7187&p=48366&hilit=v_var#p48366
                                  • epierreE epierre
                                    here it is:
                                    Moshe LivneM
                                    Moshe LivneM
                                    Moshe Livne
                                    @epierre He meant in the sense that it does not display or use it for anything. he said there "it is used to store/retrieve variables". The thread was about the option to show the vars as part of the sensor output. for storing and retrieving, it works.... verified.... I might get annoyed enough to add to the code that the lua script can also retrieve these vars and then it would be sweet.....
                                    • epierreE
                                      epierreE
                                      epierre
                                      ok good although it was not explicit... now I'll have to go back to him about water meter that heavily use V_VARs but is recognized.... as a power meter...
                                        moffen666
                                        Hello
                                        And thx for a nice forum, I did build the irrigation controller and tried to connect it to Domoticz. Everything just seems fine, LCD works, push button works and I can turn on the irrigation from Domoticz and it shows in the LCD.
                                        But the problem is that it doesn't switch the relays on, it just says "no valve time" and then go watering cycle complete.
                                        Any suggestions on what the problem might be...... Domoticz?
                                        Regards
                                        • M moffen666
                                          Hello
                                          Regards
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          @moffen666
                                          I don't have Domoticz but I suspect that the callback isn't functioning.
                                          try populating the array with the desired times for each sequence. replace this:
                                          int allZoneTime [NUMBER_OF_VALVES + 1];
                                          int valveSoloTime [NUMBER_OF_VALVES + 1];
                                          with something like this:
                                          int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 10, 10, 10, 5,<... how many valves you have with zero in the first position>} ;
                                          int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 5, 5, 5, 5,<... how many valves you have with zero in the first position>};
                                          This will load in the times that the program uses as your 'default' values. Then, you can check with Domoticz experts on getting the V_VAR variables working.
                                          fusion_manF 1 Reply Last reply
