  3. $8 Lamp (Outlet) "Smart Plug" Module
109 Posts 34 Posters 121.1k Views 13 Watching
  • D
    DanielD
    @andriej
    I have a raspberry, but I think use only arudino.
    • petewillP
      petewillP
      petewill
      @DanielD said:
      therefore I try make a device similar to vera :/
      Could you help me?
      Unfortunately I don't know how to do that. The best thing I can suggest is to use one of the existing controllers. If you already have a raspberry pi there is free software for it. Try one of those. That way you don't have to recreate anything.
      • D
        DanielD
        @petewill
        Hmm,
        Okay, but I think I don't understand is how I will do the communication between getway ethernet and another device.
        • petewillP
          petewillP
          petewill
          You probably want to check out this: http://www.mysensors.org/about/ and this: http://www.openhab.org/
          It will will take some learning and I suggest you start out small. See if you can get OpenHab up and running first. When you understand that you can start using MySensors. I had my Vera for a few months before I started learning MySensors. It was helpful to learn the controller before MySensors.
          • A
            almj
            Thank you very much for detailed description!
            But I cannot understand how to send commands from OpenHab to turn relay on and off. Please direct me.
            After a long time I can finally get the messages from sensors via serial connection, but not the other way.
            Cheers!
            petewillP 1 Reply Last reply
            • A almj
              Cheers!
              petewillP
              petewillP
              petewill
              @almj I use Vera as my controller so I'm not sure how to set up OpenHab. I know there are some instructions for setting it up here on the forum. If you're still stuck you may get better responses by posting to a new topic. Sorry I can't be more help.
              • B
                B
                bytedeez
                Is it really that difficult or expensive to get old chargers?
                I found 10 for $10.99 on ebay.
                :stuck_out_tongue:
                • B bytedeez
                  :stuck_out_tongue:
                  petewillP
                  petewillP
                  petewill
                  @bytedeez Nah, it's not that hard or expensive. It's always nice to get them free when you can though :)
                  • D
                    Douglas
                    Which is connected to the relay in the diagram???
                    Douglas (Brasil)
                    • D Douglas
                      Douglas (Brasil)
                      petewillP
                      petewillP
                      petewill
                      @Douglas I just used the standard wiring from the build page here: http://www.mysensors.org/build/relay
                      • sundberg84S
                        sundberg84S
                        #41
                        Hi @petewill!
                        I made this :) Great video :+1:
                        I think i get bad reception or something because it works the first 5-6 times and then nothing...
                        In the end you describe an cat5 wire added as antenna because of bad reception.
                        Do you remove the plastic/shielding so its just copper?
                        Im afraid to short anything out with a long uncovered antenna if thats the case...
                        and if i hear you right its 3,28 inches which should be 33,31200 millimeters on the antenna?
                        • sundberg84S sundberg84
                          Hi @petewill!
                          petewillP
                          petewillP
                          petewill
                          @sundberg84 said:
                          Hi @petewill!
                          This could also be a power or a wiring issue. But, the antenna is an easy modification so it wouldn't hurt to try this first. Another test is to move the device closer to your gateway. If it still stops after 5-6 times then it probably isn't communication issues.
                          No, I left the shielding on the wire. Sorry, I should have specified that.
                          I think 3.28 inches is 83.312 millimeters (at least that's what google says it is).
                          H 1 Reply Last reply
                          • AWIA
                            AWIA
                            AWI
                            I have these lockups all the time and have not been able to get rid of them. I tried:
                            • separated power supplies
                            • capacitors
                            • shielding
                            Most probably (in my case) is the spike introduced by the coil of the relay. This somehow puts the radio in a sleep (or half dead) state. By moving away from mechanical to triac (ssd) 'relays' I was finaly able to solve it. If you find a solution please post.
                            • sundberg84S
                              sundberg84S
                              #44
                              @AWI Hmm, ok... will give it a try and report back if i find anything...
                              It seems to be both range and spikes? The sensor works great without anything connected to 240v out but as soon as i connect anything like a lamp it fails within 5 on/off. Also when i move it close to the gw but then atleast it works without any 240v connected.
                              The SSD relays, is that something like this?
                              http://www.ebay.com/itm/1pcs-5V-DC-1-Channel-Solid-State-Relay-Board-module-High-Level-fuse-for-arduino-/191563980850?pt=LH_DefaultDomain_2&hash=item2c9a1a6032
                              Any downsides with SSR relays?
                              AWIA 1 Reply Last reply
                                AWIA
                                AWIA
                                AWI
                                @sundberg84 I have never found these before. Sounds like an interesting option. Made myself boards like these
                                The 'downside' of these is that there can be a leak voltage when the output is left open.
                                • sundberg84S
                                  sundberg84S
                                  @AWI Your link didnt work (typo)
                                  Ill give these a try and let post if they are any good.
                                  • AWIA AWI
                                    • capacitors
                                    • shielding
                                    petewillP
                                    petewillP
                                    petewill
                                    • capacitors
                                    • shielding
                                    Strange. I have been using mine for months without any issues. It is triggered by motion in my family room so it is used every day multiple times. Were you powering the relay from the Arduino or directly from the 5v?
                                    • sundberg84S
                                      sundberg84S
                                      #48
                                      @petewill In my case from VCC from arduino. I try to change incoming to raw and see if that makes any differens.
                                        petewillP
                                        petewillP
                                        petewill
                                        Yeah, let me know. It's been a while, so I don't remember what project I had issues with, but I had issues with power when I was using the Arduino 5V. I always try to pull power from the source (not Arduino) whenever I can now. Hopefully this will help your issue.
                                        • sundberg84S
                                          sundberg84S
                                          Now the relay powers up, and i can switch (led turns on) but no click/coil activation so no 240v power out. Changed the relay but same result. I have 5v relay vcc and 5v on in but nothing... strange.
                                          Moshe LivneM petewillP 2 Replies Last reply
