  3. PiDome
  4. Send color data to sensors
Scheduled Pinned Locked Moved PiDome
controllercolor
22 Posts 8 Posters 16.9k Views 6 Watching
  • JohnJ
    JohnJ
    John
    wrote on last edited by John
    Then to make sure there is as less data as possible over the air then this would mean to send data as: "000000" to "ffffff" (so no "#" char)
    This also has my personal preference, but want to know how the community would like it to handle it on the node side.
      wrote on last edited by hek
      Using something like:
      string hexstring = "FF3Fa0";
      int number = (int) strtol( &hexstring, NULL, 16);
      int r = number >> 16;
      int g = number >> 8 & 0xFF;
      int b = number & 0xFF;
      JohnJ 1 Reply Last reply
        JohnJ
        JohnJ
        John
        @hek
        Understood, i meant how they want to receive the data. @BulldogLowell would like to receive a long instead of an hex string (if i understood it correctly).
        That's the part i'm interested in.
        • JohnJ John
          @hek
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @John
          The 3byte message works here.
          Like I mentioned, a little function to put a bow in it.
          • A
            arendst
            wrote on last edited by arendst
            I agree on the 6 character hex text value. Who will implement this when in 1.4.2?
            I have build a RGB neopixel led strip actuator and I would like to control the colours with V_RGB.
            Thanks in advance. 😉
            • A arendst
              JohnJ
              JohnJ
              John
              @arendst
              Together with an user this is implemented in the current PiDome version available on the build server. He has posted a little tutorial on how to do this. So if you are a PiDome user: http://forum.pidome.org/viewtopic.php?id=58
              It is only available in the serial version for testing purposes.
              If all goes well, it will be extended to the MQTT version.
              [EDIT]It sends hex values which can be extracted as posted above[/EDIT]
              • A
                arendst
                @John
                Thanks for the response. I use Domoticz as controller which just started to support MySensors. It works great for V_Light and V_Dimmer but lacks RGB color support as the MySensors library lacks color support too.
                @hek
                Why not update the MySensors library with S_Color and V_RGB. That way Domoticz and other controllers can support color natively.
                hekH 1 Reply Last reply
                • A arendst
                  @John
                  @hek
                  Wanted to add this in the next major release. But if this drags out (time-wise) I might add it to the next minor as well.
                  • D
                    davy39
                    Hi guys,
                    Any news about that ?
                    Is it now possible to use domoticz's rgb module to control an rgb led strip through an arduino mysensor node ?
                    Thanks for your help.
                    • D
                      davy39
                      up !
                      Could anyone help me to configure domoticz & mysensors in order to control analog RGB led strip ?
                      D 1 Reply Last reply
                      • siklosiS
                        siklosiS
                        siklosi
                        wrote on last edited by siklosi
                        #21
                        @davy39
                        I just made RGB controller for domoticz. So if it's not to late...
                        #define RED_PIN 3
                        #define GREEN_PIN 5
                        #define BLUE_PIN 6
                        #define NODE_ID 2
                        #define CHILD_ID 0
                        #define SKETCH_NAME "RGB_STRIP"
                        #define SKETCH_VERSION "1.0.0"
                        #define NODE_REPEAT false
                        long RGB_values[3] = {0, 0, 0};
                        float dimmer;
                          pinMode(RED_PIN, OUTPUT);
                          pinMode(GREEN_PIN, OUTPUT);
                          pinMode(BLUE_PIN, OUTPUT);
                          gw.begin(incomingMessage, NODE_ID, NODE_REPEAT);
                          gw.present(CHILD_ID, S_RGB_LIGHT, "RGB Strip", false);
                          gw.request(CHILD_ID, V_RGB);
                          if (message.type == V_RGB) {
                            String hexstring = message.getString();
                            long number = (long) strtol( &hexstring[0], NULL, 16);
                            RGB_values[0] = number >> 16;
                            RGB_values[1] = number >> 8 & 0xFF;
                            RGB_values[2] = number & 0xFF;
                          if (message.type == V_DIMMER) {
                            dimmer = message.getInt();
                            analogWrite(RED_PIN, int(RGB_values[0] * (dimmer / 100)));
                            analogWrite(GREEN_PIN, int(RGB_values[1] * (dimmer / 100)));
                            analogWrite(BLUE_PIN, int(RGB_values[2] * (dimmer / 100)));
                            if (message.getInt() == 0) {
                              digitalWrite(RED_PIN, 0);
                              digitalWrite(GREEN_PIN, 0);
                              digitalWrite(BLUE_PIN, 0);
                            if (message.getInt() == 1) {
                        • D davy39
                          up !
                          Dylano
                          @davy39 said:
                          up !
                          Is this option working?
                          Or perhaps a RGBW strip...
                          Domoticz, with a lot of working hardware, include mysensors :-)
                          OpenPLI, RuneAudio, Solarmeter, etc......
                          Not a great builder of software and hardware, more a user...
                          Only i try to do my best :-(
