  3. PiDome
  4. Send color data to sensors
Scheduled Pinned Locked Moved PiDome
controllercolor
22 Posts 8 Posters 16.9k Views 6 Watching
    yup, you gotta think small!
    JohnJ
    JohnJ
    John
    wrote on last edited by John
    @BulldogLowell
    Yup, i'm spoiled.....
    I will take this option in consideration. It does depends on what users would prefer the most.
      In the next version RGB values it will be transmitted as a 3 byte binary value over the air.
      On the serial line it will probably be split into decimal json like: {red:<0-255>;green:<0-255>;blue:<0-255>}.
      If you want to add this to 1.4.1 i would suggest sending data as RGB hex string (to make survive over serial interface).
      • JohnJ
        JohnJ
        John
        Then to make sure there is as less data as possible over the air then this would mean to send data as: "000000" to "ffffff" (so no "#" char)
        This also has my personal preference, but want to know how the community would like it to handle it on the node side.
          wrote on last edited by hek
          Using something like:
          string hexstring = "FF3Fa0";
          int number = (int) strtol( &hexstring, NULL, 16);
          int r = number >> 16;
          int g = number >> 8 & 0xFF;
          int b = number & 0xFF;
          JohnJ 1 Reply Last reply
            JohnJ
            JohnJ
            John
            @hek
            Understood, i meant how they want to receive the data. @BulldogLowell would like to receive a long instead of an hex string (if i understood it correctly).
            That's the part i'm interested in.
            • JohnJ John
              @hek
              BulldogLowellB
              BulldogLowellB
              BulldogLowell
              @John
              The 3byte message works here.
              Like I mentioned, a little function to put a bow in it.
              • A
                arendst
                wrote on last edited by arendst
                I agree on the 6 character hex text value. Who will implement this when in 1.4.2?
                I have build a RGB neopixel led strip actuator and I would like to control the colours with V_RGB.
                Thanks in advance. 😉
                • A arendst
                  JohnJ
                  JohnJ
                  John
                  @arendst
                  Together with an user this is implemented in the current PiDome version available on the build server. He has posted a little tutorial on how to do this. So if you are a PiDome user: http://forum.pidome.org/viewtopic.php?id=58
                  It is only available in the serial version for testing purposes.
                  If all goes well, it will be extended to the MQTT version.
                  [EDIT]It sends hex values which can be extracted as posted above[/EDIT]
                  • A
                    arendst
                    @John
                    Thanks for the response. I use Domoticz as controller which just started to support MySensors. It works great for V_Light and V_Dimmer but lacks RGB color support as the MySensors library lacks color support too.
                    @hek
                    Why not update the MySensors library with S_Color and V_RGB. That way Domoticz and other controllers can support color natively.
                    hekH 1 Reply Last reply
                    • A arendst
                      @John
                      @hek
                      Wanted to add this in the next major release. But if this drags out (time-wise) I might add it to the next minor as well.
                      • D
                        davy39
                        Hi guys,
                        Any news about that ?
                        Is it now possible to use domoticz's rgb module to control an rgb led strip through an arduino mysensor node ?
                        Thanks for your help.
                        • D
                          davy39
                          up !
                          Could anyone help me to configure domoticz & mysensors in order to control analog RGB led strip ?
                          D 1 Reply Last reply
                          • siklosiS
                            siklosiS
                            siklosi
                            wrote on last edited by siklosi
                            #21
                            @davy39
                            I just made RGB controller for domoticz. So if it's not to late...
                            #define RED_PIN 3
                            #define GREEN_PIN 5
                            #define BLUE_PIN 6
                            #define NODE_ID 2
                            #define CHILD_ID 0
                            #define SKETCH_NAME "RGB_STRIP"
                            #define SKETCH_VERSION "1.0.0"
                            #define NODE_REPEAT false
                            long RGB_values[3] = {0, 0, 0};
                            float dimmer;
                              pinMode(RED_PIN, OUTPUT);
                              pinMode(GREEN_PIN, OUTPUT);
                              pinMode(BLUE_PIN, OUTPUT);
                              gw.begin(incomingMessage, NODE_ID, NODE_REPEAT);
                              gw.present(CHILD_ID, S_RGB_LIGHT, "RGB Strip", false);
                              gw.request(CHILD_ID, V_RGB);
                              if (message.type == V_RGB) {
                                String hexstring = message.getString();
                                long number = (long) strtol( &hexstring[0], NULL, 16);
                                RGB_values[0] = number >> 16;
                                RGB_values[1] = number >> 8 & 0xFF;
                                RGB_values[2] = number & 0xFF;
                              if (message.type == V_DIMMER) {
                                dimmer = message.getInt();
                                analogWrite(RED_PIN, int(RGB_values[0] * (dimmer / 100)));
                                analogWrite(GREEN_PIN, int(RGB_values[1] * (dimmer / 100)));
                                analogWrite(BLUE_PIN, int(RGB_values[2] * (dimmer / 100)));
                                if (message.getInt() == 0) {
                                  digitalWrite(RED_PIN, 0);
                                  digitalWrite(GREEN_PIN, 0);
                                  digitalWrite(BLUE_PIN, 0);
                                if (message.getInt() == 1) {
                            • D davy39
                              up !
                              Dylano
                              @davy39 said:
                              up !
                              Is this option working?
                              Or perhaps a RGBW strip...
                              Domoticz, with a lot of working hardware, include mysensors :-)
                              OpenPLI, RuneAudio, Solarmeter, etc......
                              Not a great builder of software and hardware, more a user...
                              Only i try to do my best :-(
