  2. Announcements
  3. Sensebender Micro
Sensebender Micro
584 Posts 84 Posters 658.9k Views 35 Watching
  • G
    G
    gloob
    I have the FTDI headers on the opposite site and I also get this transmission errors.
    I ordered a new batch of NRF24L01+ modules and will check if the problem still exists.
      mvader
      I have my FTDI headers on the other side as well and have no transmission errors.
      I am using genuine NRF+ radios though.
      could be the fakes causing a problem
      • tbowmoT
        tbowmoT
        tbowmo
        I have a male connector on my FTDI thingie, so I just put it in the mounting holes on the micro, and hold it to one of the sides, so it makes contact.
        • T
          tlund
          wrote on last edited by tlund
          #200
          @tbowmo
          I tried uploading the sensebender sketch using 1.0.5-r2 with board config "pro mini 328 3.3V 8MHz". The si7021 doesn't work in this configuration, but I managed to get a sleep current of ~6.8uA
          I can provide the binary output from the two IDE versions if someone can give me an indication where to find the build binaries.
          • tbowmoT
            tbowmoT
            tbowmo
            @tlund
            I think it's better if we can get the intermediate asm file from the compiler chain. Will look at it tomorrow evening (I have closed my computer down for the evening today)
            • G gbfromhb
              @mvader
              mvader
              @gbfromhb said:
              @mvader
              I just wanted to follow up and say thanks for the link/info
              i was able to get that working.
              surprised that they just don't offer a 3v pin.. it works great the way that link shows
              Thanks again!
              • 5546dug5
                5546dug5
                5546dug
                Has anybody built a box for the standard Sensebender Micro with 2 AA batteries yet.
                I would like to get the .stl files if so
                Thanks Doug
                SparkmanS 1 Reply Last reply
                • 5546dug5 5546dug
                  Thanks Doug
                  SparkmanS
                  SparkmanS
                  Sparkman
                  Thanks Doug
                  Hi Doug,
                  @ServiceXP has posted this one: http://forum.mysensors.org/topic/1566/mysensors-sensebender-micro-3dp-case
                  Al
                  • K
                    K
                    Kurtsejr
                    Has anyone been able to "Include" it to VERA UI7, My Sensebender borad is working fine according to the output from the Arduino terminal window - it request a node id, but will not "include". I'm using the default code already installed in Sensebender Micro board.
                    /Kurt
                      Yes, it works in UI7. Are you using the correct Vera-branch?
                      K 1 Reply Last reply
                      • G
                        G
                        gloob
                        wrote on last edited by gloob
                        #207
                        If somebody is looking for some Sensebenders. They are in sale currently for only 14$
                        http://imall.itead.cc/mysensors-micro.html
                        Edit:
                        I thought I had paid 17$ but they were initially sold for 14$. Sorry.
                        • F
                          F
                          Fabien
                          I just order 4 new sensebender, NRF24L01+ (normal and PA+LNA), and Iboard for the gateway. Shiiping is quite expensive (about 31 $)
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            @Fabien
                            Did you choose DHL as shipping option?
                            • sowardS
                              sowardS
                              soward
                              I just tried to order something from them and for some reason DHL is now the only available ( US ) shipping option, and it's quite expensive. The sensorbenders I ordered last month were ~$6 shipping, the other components I looked at today via DHL (similar size) were $46, so might be worth holding off a bit until they restore the air-mail option.
                                $46 in shipping is a bit hefty. I'll check what's up with their air mail shipping.
                                sowardS 1 Reply Last reply
                                  sowardS
                                  sowardS
                                  soward
                                  @hek I have seen it happen once before with them -- wait a few hours, or at most a day and it'll be corrected if history repeats...
                                  • F
                                    F
                                    Fabien
                                    My last order have cheap shipping costs. But this time I buy lot of things, and shipping price is probably higher du to the weight.
                                    • G gloob
                                      Edit:
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @gloob You fell for the oldest marketing trick in the world. I also missed a heartbeat when pressing on the clearance banner and seeing sensebender there!!!
                                      • tbowmoT
                                        tbowmoT
                                        tbowmo
                                        @Moshe-Livne @gloob
                                        The sensebender is shown under the "new stuff" banner :)
                                        (At least in the email I got from Itead :))
                                          @tbowmo or @hek: Could you point me to the right Mysensors bootloader directory please? Is it this one https://github.com/mysensors/Arduino/tree/master/MYSBootloader ? I think yes, but I have seen others links, so I am not sure. I would like to add and test some ulpnode functionalities and would like to start with the right bootloader.
