  3. PhoneyTV for Vera is Here!
34 Posts 6 Posters 31.5k Views 3 Watching
  • stofakillerS stofakiller
    @BulldogLowell
    Okay, now i better understand, because in the schematics the J1 is connected to pin 3 and i didnt get it to work, but also the D1 you use is Blue, but in the sketch the first one you use is white ;-) So now i got the 6 diodes connected, what about the other 6? :-) are the connected parallel? (whites, red greens etc)
    Regards Jan
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    @stofakiller said:
    @BulldogLowell
    Regards Jan
    Sorry about the schematic, I actually recall thinking that would come back to haunt me. I'll fix it to make it easier for the next guy :)
    Yes, I put two LEDs on each 'channel' wired in parallel. This way, you can power all 12 LEDs with the arduino, no problem.
    Six channels with two LEDs each.
    Blue1
    Blue2
    White1
    White2
    Red
    Green
    I arranged them in this 4 x 3 matrix attached and used more space between the rows for a square-ish (that isn't a real word!) arrangement.
    FYI, I'll probably get to adding a pushbutton to turn it on/off. I'll post that if I can get to it.
    I also wanted to look at using SoftPWM.h and move some LEDs to the analogue side for even more variation in brightness.
    Finally, I want random go-dark dips (turning all LEDs off for a moment) and I didn't want to do it using delays, I will get that in there too.
    • BulldogLowellB
      BulldogLowellB
      BulldogLowell
      I have an updated version attached to:
      Add a pushbutton to control it locally (I am using an interrupt on Digital Pin 2, which is not in use presently, so you can disconnect your radio connection to pin 2)
      Improved the dark dips of light, again trying to make it even more realistic.
      cleaned up the code to make it (a lot) simpler; I eliminated the generic relay 'stuff' and made is single use, basically.
      Now you can leave it plugged in and turn it off if you are occupying the room... and no longer have to worry about plugging it back in :)
      PhoneyTV_V2.ino
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        Completed upgrade to version 1.4, removing Relay capability.
        PhoneyTV update attached:
        PhoneyTV_V3.1_MySensors_V1.4.1.ino
        • 5546dug5
          5546dug5
          5546dug
          Hi @BulldogLowell
          get work am in the middle of working the hardware
          I cant seem to download the V2 or V3.1 versions I get the reply as is is the pic
          • 5546dug5
            5546dug5
            5546dug
            When I create this file it states only ashii characters allowed and asks meto delete the file
              Rename it to something shorter and try again.
              • 5546dug5
                5546dug5
                5546dug
                Once again @hek you have come to the rescue.
                Back to planning the phoney, I think this is a terrific app hats off to @BulldogLowell
                • 5546dug5
                  5546dug5
                  5546dug
                  @BulldogLowell In the final stage of boxing this unit I like it and sure will use it in the coming months.
                  Question is when it was included to vera she made the node and then created the light node for it complete with on and off buttons, are they supposed to work or ignore these and use the local interrupt on d2 but would be cool to control this remotely with vera or in a scene.
                  Great project!
                  • 5546dug5 5546dug
                    Great project!
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    you will be able to turn on/off at the controller and with the (quite optional) attached button!
                    do you need it to work just by the button, and no controller? that is an easy mod if that is your use case.
                    • 5546dug5
                      5546dug5
                      5546dug
                      @BulldogLowell , In a perfect world I would like to control Phoney TV over vera/my sensors.
                      right now I can use RST to drop the lights for a few secs only, but that is a physical action .
                      I did look at phoney tv 2.0 and see the pin was changed to pinbutton and declared as an output?
                      There was a relay in this sketch, or is the vera switch node to be therelay ? I see when you push button it changes the state of the lights but I think not the power to the nano.
                      I guessing my guesses are wrong.
                      Enough guessing from an old guy!
                      • 5546dug5 5546dug
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        @5546dug
                        Actually, the arduino never turns "off." Rather, cycling the "power" merely stops the output to the blinking/fading LEDs.
                        I'm not clear on your question... are you trying to use PhoneyTV without a controller at all?
                        anyways, you want the latest version above: PhoneyTV_V3.1_MySensors_V1.4.1.ino, i think
                        • 5546dug5
                          5546dug5
                          5546dug
                          @BulldogLowell yes I have v3.1 So I was wrong -at least consistent!
                          I have Vera controller and at the moment My Sensors serial GW is connected ,
                          The vera dashboard shows node for light on and off and that is really what I want. To start the lights remotely , I think using the reset locally (d2 to gnd?) may work but only if we are there
                          • 5546dug5
                            5546dug5
                            5546dug
                            Should also tell you I use ui5 in my veras case it makes a difference and I can toggle the switch off and on in my Device page but no Phoney TV changes.
                            • 5546dug5 5546dug
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              then you are there...
                              is it working?
                              • 5546dug5
                                5546dug5
                                5546dug
                                no it is not
                                • 5546dug5
                                  5546dug5
                                  5546dug
                                  @BulldogLowell I see in v3.1 pin d2 is called ' button pin' and is an' input' and 'pullup'
                                  (understand it is for the pushbutton use but even then it is only for a few sec. in my setup.)
                                  Also there is d13 defined as for the relay and used with the radio could that be an issue?
                                  How is the controller/GW telling the Phoney TV to change states? Do I need to run a wire from d2 (?) to gnd/vcc to create an interupt?
                                  I don't really need the button, but I will leave it there
                                  • 5546dug5
                                    5546dug5
                                    5546dug
                                    @BulldogLowell Just noticed your post is v3.1 lib 1.4.1 and I have lib 1.4
                                    That might be why I can't control from Vera ....then there is that d2 interrupt connection.
                                    • 5546dug5 5546dug
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      @5546dug
                                      hmmm, looking at the code I posted I see why you have a problem.
                                      Try this:
                                       * PhoneyTV v3.1.1
                                       * This Sketch illuminates 6 sets of LED's in a random fashion as to mimic the
                                       * light eminating from a television.  It is intended to make an empty home,
                                       * or an empty section of a home, appear to be occupied by someone watching
                                       * TV.  As an alternative to a real television left on, this uses less than 1%
                                       * of the electrical energy.
                                       * With the use of the MySensors plugin and gateway, PhoneyTV is intended to
                                       * be used with a controller (e.g. Vera or Raspberry PI).
                                       * Sketch does not use any delays to create the random blinking as a way to
                                       * assure that communication back to the gateway is as unaffected as possible.
                                       * You can adjust the length of the blink interval and its "twitchyness" by
                                       * modifying the random number generators, if you prefer more/less 'motion' in
                                       * in your unit.  The lines are highlighted in the code, play around to create the
                                       * random effect you like.
                                       * Sketch takes advantage of available PWM on pins 3, 5 & 6 using the white/blue LEDs
                                       * to allow fluctuations in the intensity of the light, enhancing the PhoneyTV's
                                       * realistic light effects.
                                       * Created 12-APR-2014
                                       * Free for distrubution
                                       * Credit should be given to MySensors.org for their base code for relay control
                                       * and for the radio configuration.  Thanks Guys.
                                       * 29-May-2014
                                       * Version 2:  Simplified the code, removing all redundant relay setup from original
                                       * code.  Added an on/off momentary pushputton option to be set up on pin 2.  Inproved
                                       * the dark dips for longer duration (can be configured) at intervals.
                                       * 6-Jun-2015
                                       * Version 3.1
                                       * Updated for MySensors V1.4.1
                                       * Contributed by Jim (BulldogLowell@gmail.com) Inspired by Josh >> Deltanu1142@gmail.com
                                      #define SKETCH_NAME "PhoneyTV"
                                      #define SKETCH_VERSION "3.1.1"
                                      #define RADIO_RESET_DELAY_TIME 20
                                      #define BUTTON_PIN  2  // Arduino Digital I/O pin number for button
                                      #define CHILD_ID 1   //
                                      #define RADIO_ID 5  //AUTO
                                      #define DEBUG_ON
                                      #ifdef DEBUG_ON
                                      byte ledPin3 =  3;      // White using PWM
                                      byte ledPin4 =  4;      // Red
                                      byte ledPin5 =  5;      // Blue using PWM
                                      byte ledPin6 =  6;      // Blue using PWM
                                      byte ledPin7 =  7;      // Green
                                      byte ledPin8 =  8;      // White (No PWM)
                                      Bounce debouncer = Bounce();
                                      byte oldValue = 0;
                                      boolean state = false;
                                      boolean oldState = false;
                                      int dipInterval = 10;
                                      int darkTime = 250;
                                      unsigned long currentDipTime;
                                      unsigned long dipStartTime;
                                      unsigned long currentMillis;
                                      byte ledState = LOW;
                                      unsigned long previousMillis = 0UL;
                                      byte led = 5;
                                      unsigned long interval = 2000UL;
                                      int twitch = 50;
                                      int dipCount = 0;
                                      int analogLevel = 100;
                                      boolean timeToDip = false;
                                      boolean gotAck=false;
                                        SERIAL_START(115200);
                                        pinMode(ledPin3, OUTPUT);
                                        pinMode(ledPin4, OUTPUT);
                                        pinMode(ledPin5, OUTPUT);
                                        pinMode(ledPin6, OUTPUT);
                                        pinMode(ledPin7, OUTPUT);
                                        pinMode(ledPin8, OUTPUT);
                                        pinMode(BUTTON_PIN, INPUT_PULLUP);
                                        debouncer.attach(BUTTON_PIN);
                                        debouncer.interval(50);
                                        gw.begin(incomingMessage, RADIO_ID, true, 0);  // configured as a repeating node!!
                                        gw.wait(RADIO_RESET_DELAY_TIME);
                                        gw.present(CHILD_ID, S_LIGHT);
                                        while(!gw.send(msg.set(state), false))
                                        debouncer.update();
                                        byte value = debouncer.read();
                                        if (value != oldValue && value == 0)
                                          state = !state;
                                          while(!gotAck)
                                            gw.send(msg.set(state), true);
                                          gotAck = false;
                                          DEBUG_PRINT(F("State Changed to:"));
                                          DEBUG_PRINTLN(state? F("PhoneyTV ON") : F("PhoneyTV OFF"));
                                        oldValue = value;
                                        if (state)
                                          if (timeToDip == false)
                                            currentMillis = millis();
                                            if (currentMillis - previousMillis > interval)
                                              interval = random(750, 4001); //Adjusts the interval for more/less frequent random light changes
                                              twitch = random(40, 100); // Twitch provides motion effect but can be a bit much if too high
                                              dipCount = dipCount++;
                                            if (currentMillis - previousMillis < twitch)
                                              led = random(3, 9);
                                              analogLevel = random(50, 255); // set the range of the 3 pwm leds
                                              ledState = !ledState;
                                              switch (led) //for the three PWM pins
                                                case 3:
                                                  pwmWrite();
                                                case 5:
                                                  pwmWrite();
                                                case 6:
                                                  pwmWrite();
                                                default:
                                                  digitalWrite(led, ledState);
                                              if (dipCount > dipInterval)
                                                timeToDip = true;
                                                dipCount = 0;
                                                dipStartTime = millis();
                                                darkTime = random(50, 150);
                                                dipInterval = random(5, 250); // cycles of flicker
                                            DEBUG_PRINTLN(F("Dip Time"));
                                            currentDipTime = millis();
                                            if (currentDipTime - dipStartTime < darkTime)
                                              for (int i = 3; i < 9; i++)
                                                digitalWrite(i, LOW);
                                              timeToDip = false;
                                          if (state != oldState)
                                        oldState = state;
                                      void incomingMessage(const MyMessage &message)
                                        if (message.isAck())
                                          gotAck = true;
                                        if (message.type == V_LIGHT)
                                          state = message.getBool();
                                          DEBUG_PRINT(F("Incoming change for sensor... New State = "));
                                          DEBUG_PRINTLN(state? F("ON") : F("OFF"));
                                      void pwmWrite()
                                        if (ledState == HIGH)
                                          analogWrite(led, analogLevel);
                                          digitalWrite(led, LOW);
                                      • 5546dug5
                                        5546dug5
                                        5546dug
                                        @BulldogLowell Thanks
                                        I will try. 3.1.1 when I get home
                                        • 5546dug5
                                          5546dug5
                                          5546dug
                                          @BulldogLowell
                                          here is screen shot of error codeArduino: 1.6.5 (Windows 8.1), Board: "Arduino Nano, ATmega328"
                                          Using library MySensors in folder: C:\Users\Carolyn & Doug\Documents\Arduino\libraries\MySensors (legacy)
                                          Using library SPI in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
                                          Using library Bounce2 in folder: C:\Users\Carolyn & Doug\Documents\Arduino\libraries\Bounce2 (legacy)
                                          C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs -IC:\Users\Carolyn & Doug\Documents\Arduino\libraries\MySensors -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI -IC:\Users\Carolyn & Doug\Documents\Arduino\libraries\Bounce2 C:\Users\CAROLY~1\AppData\Local\Temp\build5063782765207672318.tmp\phoney_tv_july_20_3.1.1.cpp -o C:\Users\CAROLY~1\AppData\Local\Temp\build5063782765207672318.tmp\phoney_tv_july_20_3.1.1.cpp.o
                                          phoney_tv_july_20_3.1.1.ino: In function 'void setup()':
                                          phoney_tv_july_20_3.1.1.ino:111:6: error: 'class MySensor' has no member named 'wait'
                                          phoney_tv_july_20_3.1.1.ino:113:6: error: 'class MySensor' has no member named 'wait'
                                          phoney_tv_july_20_3.1.1.ino:116:8: error: 'class MySensor' has no member named 'wait'
                                          phoney_tv_july_20_3.1.1.ino:118:6: error: 'class MySensor' has no member named 'wait'
                                          phoney_tv_july_20_3.1.1.ino: In function 'void loop()':
                                          phoney_tv_july_20_3.1.1.ino:133:10: error: 'class MySensor' has no member named 'wait'
