  3. Which are the *best* NRF24L01+ modules?
310 Posts 42 Posters 345.7k Views 37 Watching
    I've asked for a comment from Itead.
    Thanks! Please post when you hear back.
      Also, I notice that on your genuine board, the discrete component below the chip has the value 105 (or is it 501?), whereas on mine it says 01E. That's different. Is there such a thing as an 01E?
      @NeverDie 01E is one meg ohm (table) which is the same as 105.
      Sharp notice regarding the different 1 on both IC's! :+1:
      I cannot say that yours are genuine or not. That's why I suggest we join forces and start collecting data to discover some patterns to distinguish fakes from genuine!
        wrote on last edited by hek
        This is a genuine Nordic module. Not easy to see the hole in the cross.
        Here is some misc module I bought from ebay:
        Here is an amplified module of mine.
          Have you observed any difference in the performance of the three different modules that you have? The module in the middle photo has the "1" font discrepancy noted above.
          hekH 1 Reply Last reply
            No, haven't done any scientific regression tests on them.
            • YveauxY Yveaux
              I 100% agree. That's why I'm posting as much info as I can. I hope others will do the same, as it is in our common interest.
              In my testing to date, at 1Mbps the blob modules vastly outperform the allegedly Itead modules. The question is: what can I attribute that to? I won't ever be buying anything more from Itead or any of its distributors until after this gets resolved.
                I just now opened up the third Itead module to see if it was any different. Lo and behold, it is:
                This may be the strangest chip yet. Rather than a dot above the N, it looks like a rectangle. In addition, there's some plastic nub of some kind above the R. Lastly, the "1" font seems more similar to the allegedly fake chip than the chip Hek thinks is genuine.
                So, I just now ran the ping-pong test on it, and it performs even worse than the allegedly Itead modules I photographed earlier. When ping-ponging with one of those, the percentage of lost packets is 99.92% out of 90,000 packets.
                I don't know what to make of all this, but it doesn't look good.
                  The nub almost looks like a 3d variant of the Nordics logo. Have they done this to make it harder to copy/clone?
                  Are you using the same type of chip on both ends? I imagine intercompability could be an issue when mixing different fake once or with genuine chip.
                    No. I purchased three modules from EpicTinker, and only one was like that. The other two were the same as the post I made earlier today.
                      Ok, 99.92% packet loss is extremely bad. Are you sure you're giving it enough juice?
                        Good question. What I've done so far is plug them into a couple of RFToys:
                        so they're getting as much juice as the RFToys are giving them.
                        I've been assuming that an RFToy would give them enough juice, but maybe that's a faulty assumption.
                          #23
                          OK, for easy testing, I just now ordered some socket adapters:
                          and should receive them on Tuesday. Also, instead of RFToys, I'll try driving them from Arduino Mega2560's. Does anyone here have experience to know whether the socket adapters will supply sufficient juice? I would hope so, as it would seem to be its primary function, but if anyone knows for sure one way or the other, please post.
                          Meanwhile, I may try powering the modules using bench power supplies.
                            #24
                            If worse comes to worst, I'll just move ahead using blob modules. Who knows what they are, but could it be that they're actually better than genuine Nordic NRF24L01+'s?
                              Moshe LivneM
                              Moshe LivneM
                              Moshe Livne
                              @NeverDie do you use a good power supply?
                              • Moshe LivneM Moshe Livne
                                #26
                                Define "good". :blush:
                                I've been powering through nominal 5v USB, either through a computer's USB port for the master trasceiver (so, typically 500ma peak current) or through a typical USB charger module (typically nominal 5v 1amp or better peak current) for the slave echo transceiver. I'm not sure how the RFToy steps it down to 3.3v, or what the peak current available is on an RFToy at 3.3v. It seems good enough for the blob modules, so I (perhaps erroneously) assumed it should be good enough for the alleged NRF24L01+ modules. I'm aware some people have been getting better results using 10uF capacitors. In one of the threads it was claimed that only the fake NRF24L01_modules benefit from using capacitors(?), so I haven't rushed to embrace using capacitors. However, if you think it advisable, I could certainly try that.
                                  Moshe LivneM
                                  Moshe LivneM
                                  Moshe Livne
                                  @NeverDie I do not use capacitors but I have noticed that the quality of the power supply is important but USB from a computer should have very little noise so that is not the reason.
                                  If you happen to have capacitors, would be interesting to see how they effect the results.
                                  @hek (or anyone else who knows what they are doing), as this seems to be a universal problem, why don't you start a github sketch with simple regression results that will evolve with time? we can also start a google drive spreadsheet to collect the results so we can record who we bought it from, include a photo and the results. Although the Chinese merchants can be fickle with they supply chain, at least on aliexpress you can verify beforehand with them that you are getting specific things and if you get something else you just don't pay. It is possible to establish good and reliable supply with them if they see that it brings them consistent returns and rating - I have done that with components for my LED lights. But we need a simple way of telling what we get....
                                    #28
                                    I looked just now at section 10.4 of the Nordic Semiconductor spec sheet for the NRF24L01+, and if I'm reading this right, it does make specific recommendations that may be worth repeating here:
                                    "The nRF24L01 DC supply voltage should be decoupled as close as possible to the VDD pins with high performance
                                    RF capacitors, see Table 26. on page 69. It is preferable to mount a large surface mount capacitor
                                    (for example, 4.7μF ceramic) in parallel with the smaller value capacitors. The nRF24L01 supply
                                    voltage should be filtered and routed separately from the supply voltages of any digital circuitry."
                                    I'm not sure if that's advocating the use of a large capacitor (such as a 4.7uF), or merely stating that if a large surface mount capacitor is used, then it's preferable it be mounted in parallel. I think it may be advocating. Can anyone here resolve the ambiguity? Would a 10uF capacitor commonly added by some people be relevant to this, or would it literally need to be a surface-mount component to qualify? Also, since it did specifically mention ceramic, is it important that it be ceramic rather than some other type? And if so, what type of ceramic capacitor would be best?
                                    Does supplying 3.3v from a voltage regulator right near the module, as in the adapter module I picture above, help provide a supply voltage that's separately filtered and routed, in part by putting it close to the NRF chip? I ask because it also says "Full swing digital data or control signals should not be routed close to the crystal or the power supply lines."
                                      Moshe LivneM
                                      Moshe LivneM
                                      Moshe Livne
                                      @NeverDie No expert so just regurgitating what I read here on other threads:
                                      The capacitor serves two purposes:
                                      1. give the module extra juice while transmitting
                                      2. clean and smooth the noise on the power
                                      for (1), electrolite capacitor is good enough. for (2), people here said that ceramic is much better as it has all sorts of good qualities that has 3 or 4 letters acronyms. (not an expert!)
                                      the capacitor needs to be mounted as closely to the module otherwise the legs serves as antenna for interference or something.
                                      if you have a good power supply that produce good, clean 3.3v (a battery is a good example), connecting it directly to the nrf vcc is better than taking the 3v3 from the arduino.
                                        Thanks for the good info. . Since it's better for both MySensors and Itead to have a good working relationship where such matters can be quickly resolved, for now I'm going to hold off on soldering in the event Itead (the manufacturer) wants to inspect the modules I received in the same condition that I received them. Hopefully Hek will soon post an update from Itead regarding whether the modules are genuine or not. In addition to what has already been discussed, the packaging does not exactly match what Itead has shown on their website, judging from a post by Sparkman in a different thread related to this.
                                        I ordered from one of Itead's officially designated distributors, so I hope Itead stands behind their product and what was delivered. I really do hope I haven't been Shanghaied, but if that's how it shakes out, at least I limited the damage by purchasing only 3 modules to begin with rather than the larger number I'll ultimately be ordering.
                                        • J
                                          J
                                          jerry
                                          This is Jerry from ITEAD.
                                          The Module we sell is original.
                                          Can you provide me your contact information?
                                          We will ask Nordic FAE in your country to contact you and test the module together with you.
                                          Just post the test result publicly on the forum.
