  3. Pulse Powermeter
Pulse Powermeter
13 Posts 7 Posters 5.6k Views 2 Watching
  • FrancoisF
    FrancoisF
    Francois
    Hi I just complete and compile the pulse power-meter on lib 1.4.1 and I don't get any values back from the sensor. The pulse sensor is wire as per the instruction what can the problem be here?
    Here is the info from the serial port:
    send: 21-21-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,st=ok:Energy Meter
    send: 21-21-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    send: 21-21-0-0 s=1,c=0,t=13,pt=0,l=5,sg=0,st=ok:1.4.1
    send: 21-21-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    • Ø
      Ø
      Øyvind A. Espnes
      wrote on last edited by Øyvind A. Espnes
      I seem to have the same problem. Did you find any answer to this?
      I get this reply from the serialmonitor:
      send: 9-9-0-0 s=1,c-9-0-0 s=1,c=2,t=24,pt=0,l=0,st=ok:
      sensor started, id 9
      send: 9-9-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
      send: 9-9-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
      read: 0-0-9 s=255,c=3,t=6,pt=0,l=1:M
      send: 9-9-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Energy Meter
      send: 9-9-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
      send: 9-9-0-0 s=1,c=0,t=13,pt=0,l=0,st=ok:
      send: 9-9-0-0 s=1,c=2,t=24,pt=0,l=0,st=ok:
        Looks like the sensor is requesting last known pulse count from the controller. Do you have anything answering this request?
        https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/EnergyMeterPulseSensor/EnergyMeterPulseSensor.ino#L46
        • Ø
          Ø
          Øyvind A. Espnes
          No. Where do i insert this?
            What controller are you using?
            • Ø
              Ø
              Øyvind A. Espnes
              Domoticz
                Sorry, I'm not using Domoticz myself... So I'm not sure where you fill in your pulse count in the GUI (VAR1). You should probably also check that Domoticz support requesting of VAR1-5.
                • Ø
                  Ø
                  Øyvind A. Espnes
                  Ok, so the sensor is requesting a number to continue the count? And there is no way to bay-pass this and insert my own?
                    wrote on last edited by hek
                    Yes, you could hard-code the current pulsecount in the sketch. But then it will revert back to this value every time the sensor loses power and restart.
                      Moshe LivneM
                      Moshe LivneM
                      Moshe Livne
                      @hek You can't access these from the UI. He would have to write a sketch that sets this var. Not big deal but awkward. would have been nice if the VAR1-5 could be accessed.
                      • SweebeeS
                        SweebeeS
                        Sweebee
                        You could also save the value every time in the eeprom, so when the sensor loses power it can recover the value.
                        • T
                          TommySharp
                          Would it not be the MySensors gateway that should respond with the last pulse count?
                          • epierreE
                            epierreE
                            epierre
                            @Tommy-Sharp the gateway is like the RFXTRX, it has no memory by design.
                            z-wave - Vera -> Domoticz
