  3. Pulse Powermeter
Pulse Powermeter
13 Posts 7 Posters 5.7k Views 2 Watching
  • Ø
    Ø
    Øyvind A. Espnes
    No. Where do i insert this?
      What controller are you using?
      • Ø
        Ø
        Øyvind A. Espnes
        Domoticz
          Sorry, I'm not using Domoticz myself... So I'm not sure where you fill in your pulse count in the GUI (VAR1). You should probably also check that Domoticz support requesting of VAR1-5.
          • Ø
            Ø
            Øyvind A. Espnes
            Ok, so the sensor is requesting a number to continue the count? And there is no way to bay-pass this and insert my own?
              wrote on last edited by hek
              Yes, you could hard-code the current pulsecount in the sketch. But then it will revert back to this value every time the sensor loses power and restart.
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @hek You can't access these from the UI. He would have to write a sketch that sets this var. Not big deal but awkward. would have been nice if the VAR1-5 could be accessed.
                • SweebeeS
                  SweebeeS
                  Sweebee
                  You could also save the value every time in the eeprom, so when the sensor loses power it can recover the value.
                  • T
                    TommySharp
                    Would it not be the MySensors gateway that should respond with the last pulse count?
                    • epierreE
                      epierreE
                      epierre
                      @Tommy-Sharp the gateway is like the RFXTRX, it has no memory by design.
                      z-wave - Vera -> Domoticz
