  3. Pulse Powermeter
Pulse Powermeter
13 Posts 7 Posters 5.7k Views 2 Watching
  • Ø
    Ø
    Øyvind A. Espnes
    wrote on last edited by Øyvind A. Espnes
    I seem to have the same problem. Did you find any answer to this?
    I get this reply from the serialmonitor:
    send: 9-9-0-0 s=1,c-9-0-0 s=1,c=2,t=24,pt=0,l=0,st=ok:
    sensor started, id 9
    send: 9-9-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
    send: 9-9-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    read: 0-0-9 s=255,c=3,t=6,pt=0,l=1:M
    send: 9-9-0-0 s=255,c=3,t=11,pt=0,l=12,st=ok:Energy Meter
    send: 9-9-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
    send: 9-9-0-0 s=1,c=0,t=13,pt=0,l=0,st=ok:
    send: 9-9-0-0 s=1,c=2,t=24,pt=0,l=0,st=ok:
      Looks like the sensor is requesting last known pulse count from the controller. Do you have anything answering this request?
      https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/examples/EnergyMeterPulseSensor/EnergyMeterPulseSensor.ino#L46
      • Ø
        Ø
        Øyvind A. Espnes
        No. Where do i insert this?
          What controller are you using?
          • Ø
            Ø
            Øyvind A. Espnes
            Domoticz
              Sorry, I'm not using Domoticz myself... So I'm not sure where you fill in your pulse count in the GUI (VAR1). You should probably also check that Domoticz support requesting of VAR1-5.
              • Ø
                Ø
                Øyvind A. Espnes
                Ok, so the sensor is requesting a number to continue the count? And there is no way to bay-pass this and insert my own?
                  wrote on last edited by hek
                  Yes, you could hard-code the current pulsecount in the sketch. But then it will revert back to this value every time the sensor loses power and restart.
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @hek You can't access these from the UI. He would have to write a sketch that sets this var. Not big deal but awkward. would have been nice if the VAR1-5 could be accessed.
                    • SweebeeS
                      SweebeeS
                      Sweebee
                      You could also save the value every time in the eeprom, so when the sensor loses power it can recover the value.
                      • T
                        TommySharp
                        Would it not be the MySensors gateway that should respond with the last pulse count?
                        • epierreE
                          epierreE
                          epierre
                          @Tommy-Sharp the gateway is like the RFXTRX, it has no memory by design.
                          z-wave - Vera -> Domoticz
