  3. MQTT Gateway - Stuck on "Started!"
29 Posts 6 Posters 17.0k Views 3 Watching
  • siodS
    siodS
    siod
    @Zed Could you test if Ethernet Gateway Sketch is working just like it´s working in my setup?
    still learning...
    • Z
      Z
      Zed
      I have already done that. Although the Ethernet module works correctly (I've checked that with a simple Ethernet sketch) either the Ethernet or the MQTT gateway seems to work. The only message I get on the serial monitor is something like started, yet I cannot ping the gateway.
      • siodS
        siodS
        siod
        You should try the UIPEthernet library for Ethernet.
        still learning...
        Z 1 Reply Last reply
        • siodS siod
          Z
          Z
          Zed
          @siod I am using the W5100 Ethernet module so there is no need to change the library. Funny thing...I just compiled bot MQTT and Ethernet GW without any problems. They seem to work and I finally can ping them.:bowtie:
          The only thing that I changed is that now I use an official Arduino UNO and not the pro minis. I will try the circuit with the mini again and I will update my post.
          • siodS
            siodS
            siod
            wrote on last edited by siod
            W5100, sure, should have read your first post again. No need for the UIPEthernet library, of course.
            Ok, thanks for the hint, as I am using a nano testing with an uno could be an option. Will wait for your updated post first...
            still learning...
            • siodS siod
              Z
              Z
              Zed
              wrote on last edited by Zed
              @siod I tried again with an unofficial Arduino UNO R3. None of the gateways is working. I get the same symptoms with the pro minis (which are also unofficial boards from China).
              • Could someone comment of the official/unofficial board issue?
              • I suppose it could be useful to start a compatibility list for the gateways.
              UPDATE: I attach a picture with the two boards that do not work correctly with the Ethernet and the MQTT gateway sketch. I managed to compile and upload the sketches to the boards without any problem. In the serial monitor I get the proper message showing that the GW has started, however I cannot ping it.
              UPDATE 2: I removed the photos that I have posted earlier since all the boards seem to work correctly. See post below.
              • siodS
                siodS
                siod
                OK great testing. I will test as soon as possible and will post my results here. We'll get it to work! ;)
                still learning...
                  Weird. Bad decoupling is the only thing that comes into mind. It contains the same MCU...
                    Z
                    Z
                    Zed
                    @hek I am pretty sure that this is not the case. I have a quite decent power supply. Attached is a picture of my stone age 10MHz oscilloscope. Although old with some tilt issues (I have to fix that) it is quite enough for identifying a poor power supply. As you can see there are no decoupling issues.
                    UPDATE: Finally, after experimenting for more than a week, the gateway seems to work even with the unofficial Arduino boards! Unfortunately I don't know what the problem was. I would blame the power supply but the gw now works with all boards and with three different power supplies (bench power supply, PC usb port and cell phone chargers), including those (cell charger, desktop usb port and laptop usb port) I was using before.
                    In case i find what the problem was I will post it here. Of course I now have to get the gw working with one of the software controllers, probably with Domoticz.
                    Thanks for your contributions!
                    • siodS
                      siodS
                      siod
                      mmh, that´s very strange. Did you change anything in your code? I can´t test right now but will give you more info the next days.
                      still learning...
                      • siodS siod
                        Z
                        Z
                        Zed
                        @siod No, I did not change anything. The only thing that I can think of is that the supply voltage (~3.3V) could be marginally enough and due the consumption of the cheap regulators that the unofficial boards have.
                        • siodS
                          siodS
                          siod
                          Uploaded sketch on my original Arduino Uno, made same connections, did not change anything in the code:
                          • Serial Monitor is showing nothing -.-
                          edit: can I use an Uno using the same code for the nano? :suspect:
                          edit2: Testing Nano again. Unconnected Ethernet module from nano, still only geting "Started!" message. Uploaded Ethernet Gateway Sketch and everything is fine again. -> So it must have to do sth. with the code. :hurtrealbad:
                          edit3: Now tested different nanos, still the same problem with every Nano. Holy, I don´t have any more ideas...:finnadie:
                          edit4: I shit bricks...I downloaded the whole MySensors Library again, installed it and uploaded the sketch again: IT WORKS ! ! ! :feelsgood:
                          Some file must have been missing...WTF. Well, thanks anyway guys, have fun with your sensors. :godmode:
                          still learning...
                          • Z
                            Z
                            Zed
                            Not as tidy as other gateways, yet its something. I got bored and didn't open holes for LEDs. I'll do it after I am sure that it works. For the moment I am able to ping it successfully. I am thinking now that an Arduino nano is more appropriate for a GW. The USB port can be used to monitor and reflash the gateway.
                            PS. I am pretty sure now that the power supply was the problem. The AC to DC unit that I was using (12V) could provide just 0.5 Amps an probably this is not enough for all the components to work properly. Has anyone measured what is the max current required from such a GW?
                            • rvendrameR
                              rvendrameR
                              rvendrame
                              @Zed , the antenna-version of nRF officially consumes up to 115mA (cheap clones can easily drawn more). The w5100 running at 100Mbps may consume ~140mA. That still leave some room for your arduino. Have you measured the DC adapter with full load on it?
                              ESP8266 GW + mySensors 2.3.2
                              Alexa / Google Home
                              • rvendrameR rvendrame
                                Z
                                Z
                                Zed
                                @rvendrame No, I have not measured the DC adapter with full load on it. I will do it in the following days and I will report my findings.
                                • Z
                                  Z
                                  Zed
                                  #23
                                  I still have some trouble... Although this seems like a Domoticz question, I'll post it here because I think that the problem is related to my Ethernet GW and not to Domoticz.
                                  So, I upgraded my GW to mySensors 1.5 and I made a Temperature/Humidity sensor as it is described here using a DHT22. On the serial monitor I get:
                                  find parent
                                  send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
                                  sensor started, id=255, parent=255, distance=255
                                  find parent
                                  find parent
                                  find parent
                                  find parent
                                  find parent
                                  T: 31.00
                                  find parent
                                  H: 44.40
                                  I don't really understand the message (could someone explain a little bit), however I suppose that the sensor works. Then, on the serial monitor of the ethernet gateway I get:
                                  On Domoticz I have added the Ethernet GW to the hardware list. However when I open the web interface i see the following:
                                  and in the log I get:
                                  2015-08-03 17:03:45.650 Domoticz V2.2657 (c)2012-2015 GizMoCuz
                                  2015-08-03 17:03:45.758 Sunrise: 06:31:00 SunSet:20:31:00
                                  2015-08-03 17:03:45.763 Active notification subsystems: (0/8)
                                  2015-08-03 17:03:46.164 Webserver started on port: 8008
                                  2015-08-03 17:03:46.171 Webserver started on port: 443
                                  2015-08-03 17:03:46.172 Hardware Monitor: Started
                                  2015-08-03 17:03:48.509 Incoming connection from: 127.0.0.1
                                  2015-08-03 17:03:49.837 Incoming connection from: 192.168.1.14
                                  2015-08-03 17:03:50.191 MySensors: connected to: 192.168.1.152:5003
                                  Questions:
                                  • Does the GW message mean that the GW is not working properly?
                                  • I've set the IP of the GW to be 192.168.1.152 and Port 5003. Does this mean that the same port has to be free on the server side?
                                  • What is the inclusion button. Do I have to add it to the GW?
                                  So, any suggestions for troubleshooting? :bowtie:
                                  PS: Configuration summary
                                  Arduino IDE: 1.6.5
                                  OS: Mac OS X Yosemite 10.10.4 (for the sketches) and Windows 10 for Domoticz
                                  MySensor Library: 1.5
                                  hekH 1 Reply Last reply
                                    Looks like GW has started correctly but no messages seems to reach the gateway from the node. The node is broadcasting a find-parent-request with no answer from the gateway.
                                    Hard to say what the problem is.. Have you changed any channels settings in MyConfig.h before compiling gateway/node?
                                      Z
                                      Z
                                      Zed
                                      #25
                                      @hek No, I didn't change anything. Should I?
                                      I am experimenting now with MYSController. I send a version request to the gateway and I get a proper reply.
                                      8/3/2015 20:18:04	TX	0;0;3;0;2;
                                      8/3/2015 20:18:04	RX	0;0;3;0;2;1.5
                                      (If I ask for the sketch name or version I do not get a reply)
                                      I am suspecting that the radio module of the gateway may not work properly. Is there a way to check this without de-soldering the module and replacing it by another one?
                                      • Z Zed
                                        find parent
                                        find parent
                                        find parent
                                        find parent
                                        find parent
                                        find parent
                                        T: 31.00
                                        find parent
                                        H: 44.40
                                        Questions:
                                        Arduino IDE: 1.6.5
                                        @Zed
                                        You might have the same problem described here:
                                        http://forum.mysensors.org/topic/1736/release-1-5-and-ethernet-gateway
                                        Seems like you have to send something from gateway before you can receive anything.. A bug.
                                          @Zed
                                          Z
                                          Z
                                          Zed
                                          #27
                                          @hek Probably this is not the case. I downgraded everything to 1.4.1. Now on the sensor serial monitor I get:
                                          req node id
                                          send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
                                          req node id
                                          req node id
                                          req node id
                                          T: 31.30
                                          req node id
                                          send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
                                          H: 38.50
                                          req node id
                                          T: 31.20
                                          req node id
                                          H: 39.70
                                          If understand it correctly the sensor still is not able to get an ID from the GW. Probably I will make a serial gateway in the following days for testing.
