  3. Freedomotic
  4. Freedomotic
Freedomotic
Scheduled Pinned Locked Moved Freedomotic
automationserialgatewaycontroller
72 Posts 15 Posters 55.5k Views 4 Watching
  • freedomoticF
    freedomoticF
    freedomotic
    Hi Roberto
    thanks for your interest. The plugin is in stand-by because I don't have any hardware for tests. I asked some help on this forum with no success. If you want we can collaborate. I tried a first draft using a fake serial connection on Windows. Let me know your idea with Raspi. Bye
    Freedomotic Iot & Smart Spaces framework
    http://www.freedomotic.com
    • freedomoticF
      freedomoticF
      freedomotic
      Hi @Roberto-Brunialti
      are you still interested?
      • Roberto BrunialtiR
        Roberto BrunialtiR
        Roberto Brunialti
        Yes, I' am. Still to understand the needs in terms of sensors, gw and so on...
        Never used before mysensor, but i've got 4 sensordend boards.
        I should be able to setup a gw with nrf+ in a raspberry 2.
        • V
          V
          virgus1970
          Hi, Freedomotic!
          I'm too interesting in testing hardware (sensors & rellays) with MySensor Plugin on Pi B+. Do You need one more tester?
          • freedomoticF
            freedomoticF
            freedomotic
            Of course @virgus1970 , I need all possible testers.
            I'm updating the plugin to start testing. For now you can install Freedomotic on your raspberry and try it. The plugin works with the upcoming version 5.6 you can download from http://teamcity.codebetter.com/guestAuth/repository/download/bt1177/.lastSuccessful/freedomotic-5.6.0-{build.number}.zip
            • V
              V
              virgus1970
              Ok. I'm going to start next week & will keep You up to date
              • freedomoticF
                freedomoticF
                freedomotic
                Hi, in attachment the new development version. You need to download freedomotic from the previous link (teamcity), extract the plugin zip to freedomotic_root/plugins/devices folder and then modify your serial port name in mysensors-manifest.xml.
                Start Freedomotic and double click on Mysensors icon.
                mysensors.zip
                barduinoB 1 Reply Last reply
                • freedomoticF freedomotic
                  mysensors.zip
                  barduinoB
                  barduinoB
                  barduino
                  @freedomotic
                  When you say you dont have hardware for testing, what do you mean?
                  Do you have ate least 2 Arduinos?
                  Im working on a way to simulate sensors, still alpha and not tested (im travelling) but so far it should be capable of simulating 12 sensors.
                  Would this work for you?
                  • freedomoticF
                    freedomoticF
                    freedomotic
                    @barduino
                    Now I have only an Arduino Uno and no radio transceiver and sensors.
                    I made some tests sending "fake" serial protocol strings via software.
                    • freedomoticF
                      freedomoticF
                      freedomotic
                      @barduino
                      any news about your simulator?
                        @barduino
                        barduinoB
                        barduinoB
                        barduino
                        @freedomotic
                        Actually yes.
                        I did a major refactor recently (here) and in a last minute update it ended up on the development branch of the 1.5 library, here
                        This is intented to be used with at least 2 arduinos, a normal gateway and a fake sensors arduino mocking signals. It should support all the 24 sensors from lib 1.4.1.
                        Not sure how you could take this and adapt to your situation since i'm using the MySensors library and it wont run without the radios.
                        • freedomoticF
                          freedomoticF
                          freedomotic
                          @barduino
                          My plugin is based on serial protocol so I need to generate some "serial" strings as the gateway does. Now I'm using a serial data port emulator to write manually these strings. If I read your fake frames from serial (without using a gateway) maybe I could solve the problem
                            The MySensors project could perhaps support you by donating a couple of radios and arduino boards so you can make the necessary tests properly. Please contact me.
                            • freedomoticF
                              freedomoticF
                              freedomotic
                              Hi @hek
                              thanks for your offer.
                              • freedomoticF
                                freedomoticF
                                freedomotic
                                a new version of our plugin is available on the marketplace.
                                More info on http://freedomotic.com/content/plugins/mysensors
                                • freedomoticF
                                  freedomoticF
                                  freedomotic
                                  Hi all
                                  finally the first Release Candidate version of Commander is available.
                                  You can download it from http://sourceforge.net/projects/freedomotic/files/freedomotic-commander-5.6.0-rc1.zip/download
                                  We ask your help: try it and share your feedback here or filling out the form at https://goo.gl/CC65By
                                  Share your experience about Freedomotic: only 5 minutes of time to answer our survey at https://goo.gl/Iq8C6e
                                  Thanks in advance
                                  • freedomoticF
                                    freedomoticF
                                    freedomotic
                                    Hi
                                    we are looking for Swedish translators for our project. If you want to give us a hand please reply.
                                    • freedomoticF
                                      freedomoticF
                                      freedomotic
                                      Hi all
                                      Freedomotic 5.6 Commander RC2 is out and can be downloaded from
                                      http://sourceforge.net/projects/freedomotic/files/freedomotic-commander-5.6.0-rc2.zip/download
                                      We fixed some bugs and in particular included the first draft of a web client.
                                      After starting Freedomotic go to http://localhost:8090 in your browser and digit admin/admin as username/password.
                                      You can access from another pc in your network by changing in the previous URL "localhost" with the ip of the machine running Freedomotic.
                                      The web client doesn't have all features included in the java frontend but they can run at the same time.
                                      If you want to use only the web client please remove the folder "frontend-java" under plugins/devices.
                                      We need your help in different areas:
                                      • testing (not all browsers are 100% html5-compatible)
                                      • functionality
                                      • usability/UX
                                      • graphics/layout
                                      So report your comments/issues on https://goo.gl/CC65By
                                      If you want to contribute take a look at the source code https://github.com/freedomotic and at our tracking system http://freedomotic.myjetbrains.com/youtrack/issues
                                      Stay tuned!
                                      • freedomoticF
                                        freedomoticF
                                        freedomotic
                                        Hi all,
                                        we moved our issues tracker to github.
                                        Take a look at https://github.com/freedomotic/freedomotic/issues
                                        freedomoticF 1 Reply Last reply
                                          Hi all,
                                          freedomoticF
                                          freedomoticF
                                          freedomotic
                                          Hello
                                          in this video https://youtu.be/G98U2Q3cCVc you can see our Telegram bot plugin in action.
                                          We need your feedback to improve it.
