  3. Freedomotic
  4. Freedomotic
Freedomotic
Scheduled Pinned Locked Moved Freedomotic
automationserialgatewaycontroller
72 Posts 15 Posters 55.5k Views 4 Watching
  • freedomoticF
    freedomoticF
    freedomotic
    Hi @BobC
    we are working on the plugin but we need some testers. Nobody is helping us now. Did you try the post attached zip file? If you want we can collaborate. Thanks
    Freedomotic Iot & Smart Spaces framework
    http://www.freedomotic.com
    • freedomoticF
      freedomoticF
      freedomotic
      We are very glad to announce that Freedomotic is on Canonical Ubuntu Snappy Official Page ("Our Partners" section). A great result for our efforts!
      http://www.ubuntu.com/things
      • Roberto BrunialtiR
        Roberto BrunialtiR
        Roberto Brunialti
        Hi, what about the mysensor plugin? I would like to try the freedomotic frontend with raspberrypi as a (serial)gateway. Are there any tutorials about?
        thanks
        • freedomoticF
          freedomoticF
          freedomotic
          Hi Roberto
          thanks for your interest. The plugin is in stand-by because I don't have any hardware for tests. I asked some help on this forum with no success. If you want we can collaborate. I tried a first draft using a fake serial connection on Windows. Let me know your idea with Raspi. Bye
          • freedomoticF
            freedomoticF
            freedomotic
            Hi @Roberto-Brunialti
            are you still interested?
              Roberto BrunialtiR
              Roberto Brunialti
              Yes, I' am. Still to understand the needs in terms of sensors, gw and so on...
              Never used before mysensor, but i've got 4 sensordend boards.
              I should be able to setup a gw with nrf+ in a raspberry 2.
              • V
                V
                virgus1970
                Hi, Freedomotic!
                I'm too interesting in testing hardware (sensors & rellays) with MySensor Plugin on Pi B+. Do You need one more tester?
                • freedomoticF
                  freedomoticF
                  freedomotic
                  Of course @virgus1970 , I need all possible testers.
                  I'm updating the plugin to start testing. For now you can install Freedomotic on your raspberry and try it. The plugin works with the upcoming version 5.6 you can download from http://teamcity.codebetter.com/guestAuth/repository/download/bt1177/.lastSuccessful/freedomotic-5.6.0-{build.number}.zip
                  • V
                    V
                    virgus1970
                    Ok. I'm going to start next week & will keep You up to date
                    • freedomoticF
                      freedomoticF
                      freedomotic
                      Hi, in attachment the new development version. You need to download freedomotic from the previous link (teamcity), extract the plugin zip to freedomotic_root/plugins/devices folder and then modify your serial port name in mysensors-manifest.xml.
                      Start Freedomotic and double click on Mysensors icon.
                      mysensors.zip
                      barduinoB 1 Reply Last reply
                      • freedomoticF freedomotic
                        mysensors.zip
                        barduinoB
                        barduinoB
                        barduino
                        @freedomotic
                        When you say you dont have hardware for testing, what do you mean?
                        Do you have ate least 2 Arduinos?
                        Im working on a way to simulate sensors, still alpha and not tested (im travelling) but so far it should be capable of simulating 12 sensors.
                        Would this work for you?
                        • freedomoticF
                          freedomoticF
                          freedomotic
                          @barduino
                          Now I have only an Arduino Uno and no radio transceiver and sensors.
                          I made some tests sending "fake" serial protocol strings via software.
                          • freedomoticF
                            freedomoticF
                            freedomotic
                            @barduino
                            any news about your simulator?
                              @barduino
                              barduinoB
                              barduinoB
                              barduino
                              @freedomotic
                              Actually yes.
                              I did a major refactor recently (here) and in a last minute update it ended up on the development branch of the 1.5 library, here
                              This is intented to be used with at least 2 arduinos, a normal gateway and a fake sensors arduino mocking signals. It should support all the 24 sensors from lib 1.4.1.
                              Not sure how you could take this and adapt to your situation since i'm using the MySensors library and it wont run without the radios.
                              • freedomoticF
                                freedomoticF
                                freedomotic
                                @barduino
                                My plugin is based on serial protocol so I need to generate some "serial" strings as the gateway does. Now I'm using a serial data port emulator to write manually these strings. If I read your fake frames from serial (without using a gateway) maybe I could solve the problem
                                  The MySensors project could perhaps support you by donating a couple of radios and arduino boards so you can make the necessary tests properly. Please contact me.
                                  • freedomoticF
                                    freedomoticF
                                    freedomotic
                                    Hi @hek
                                    thanks for your offer.
                                    • freedomoticF
                                      freedomoticF
                                      freedomotic
                                      a new version of our plugin is available on the marketplace.
                                      More info on http://freedomotic.com/content/plugins/mysensors
                                      • freedomoticF
                                        freedomoticF
                                        freedomotic
                                        Hi all
                                        finally the first Release Candidate version of Commander is available.
                                        You can download it from http://sourceforge.net/projects/freedomotic/files/freedomotic-commander-5.6.0-rc1.zip/download
                                        We ask your help: try it and share your feedback here or filling out the form at https://goo.gl/CC65By
                                        Share your experience about Freedomotic: only 5 minutes of time to answer our survey at https://goo.gl/Iq8C6e
                                        Thanks in advance
                                        • freedomoticF
                                          freedomoticF
                                          freedomotic
                                          Hi
                                          we are looking for Swedish translators for our project. If you want to give us a hand please reply.
