  3. Freedomotic
  4. Freedomotic
Freedomotic
Scheduled Pinned Locked Moved Freedomotic
automationserialgatewaycontroller
72 Posts 15 Posters 55.6k Views 4 Watching
  • freedomoticF
    freedomoticF
    freedomotic
    Of course @virgus1970 , I need all possible testers.
    I'm updating the plugin to start testing. For now you can install Freedomotic on your raspberry and try it. The plugin works with the upcoming version 5.6 you can download from http://teamcity.codebetter.com/guestAuth/repository/download/bt1177/.lastSuccessful/freedomotic-5.6.0-{build.number}.zip
    Freedomotic Iot & Smart Spaces framework
    http://www.freedomotic.com
    • V
      V
      virgus1970
      Ok. I'm going to start next week & will keep You up to date
      • freedomoticF
        freedomoticF
        freedomotic
        Hi, in attachment the new development version. You need to download freedomotic from the previous link (teamcity), extract the plugin zip to freedomotic_root/plugins/devices folder and then modify your serial port name in mysensors-manifest.xml.
        Start Freedomotic and double click on Mysensors icon.
        mysensors.zip
        barduinoB 1 Reply Last reply
        • freedomoticF freedomotic
          mysensors.zip
          barduinoB
          barduinoB
          barduino
          @freedomotic
          When you say you dont have hardware for testing, what do you mean?
          Do you have ate least 2 Arduinos?
          Im working on a way to simulate sensors, still alpha and not tested (im travelling) but so far it should be capable of simulating 12 sensors.
          Would this work for you?
          • freedomoticF
            freedomoticF
            freedomotic
            @barduino
            Now I have only an Arduino Uno and no radio transceiver and sensors.
            I made some tests sending "fake" serial protocol strings via software.
            • freedomoticF
              freedomoticF
              freedomotic
              @barduino
              any news about your simulator?
                @barduino
                barduinoB
                barduinoB
                barduino
                @freedomotic
                Actually yes.
                I did a major refactor recently (here) and in a last minute update it ended up on the development branch of the 1.5 library, here
                This is intented to be used with at least 2 arduinos, a normal gateway and a fake sensors arduino mocking signals. It should support all the 24 sensors from lib 1.4.1.
                Not sure how you could take this and adapt to your situation since i'm using the MySensors library and it wont run without the radios.
                • freedomoticF
                  freedomoticF
                  freedomotic
                  @barduino
                  My plugin is based on serial protocol so I need to generate some "serial" strings as the gateway does. Now I'm using a serial data port emulator to write manually these strings. If I read your fake frames from serial (without using a gateway) maybe I could solve the problem
                    The MySensors project could perhaps support you by donating a couple of radios and arduino boards so you can make the necessary tests properly. Please contact me.
                    • freedomoticF
                      freedomoticF
                      freedomotic
                      Hi @hek
                      thanks for your offer.
                      • freedomoticF
                        freedomoticF
                        freedomotic
                        a new version of our plugin is available on the marketplace.
                        More info on http://freedomotic.com/content/plugins/mysensors
                        • freedomoticF
                          freedomoticF
                          freedomotic
                          Hi all
                          finally the first Release Candidate version of Commander is available.
                          You can download it from http://sourceforge.net/projects/freedomotic/files/freedomotic-commander-5.6.0-rc1.zip/download
                          We ask your help: try it and share your feedback here or filling out the form at https://goo.gl/CC65By
                          Share your experience about Freedomotic: only 5 minutes of time to answer our survey at https://goo.gl/Iq8C6e
                          Thanks in advance
                          • freedomoticF
                            freedomoticF
                            freedomotic
                            Hi
                            we are looking for Swedish translators for our project. If you want to give us a hand please reply.
                            • freedomoticF
                              freedomoticF
                              freedomotic
                              Hi all
                              Freedomotic 5.6 Commander RC2 is out and can be downloaded from
                              http://sourceforge.net/projects/freedomotic/files/freedomotic-commander-5.6.0-rc2.zip/download
                              We fixed some bugs and in particular included the first draft of a web client.
                              After starting Freedomotic go to http://localhost:8090 in your browser and digit admin/admin as username/password.
                              You can access from another pc in your network by changing in the previous URL "localhost" with the ip of the machine running Freedomotic.
                              The web client doesn't have all features included in the java frontend but they can run at the same time.
                              If you want to use only the web client please remove the folder "frontend-java" under plugins/devices.
                              We need your help in different areas:
                              • testing (not all browsers are 100% html5-compatible)
                              • functionality
                              • usability/UX
                              • graphics/layout
                              So report your comments/issues on https://goo.gl/CC65By
                              If you want to contribute take a look at the source code https://github.com/freedomotic and at our tracking system http://freedomotic.myjetbrains.com/youtrack/issues
                              Stay tuned!
                              • freedomoticF
                                freedomoticF
                                freedomotic
                                Hi all,
                                we moved our issues tracker to github.
                                Take a look at https://github.com/freedomotic/freedomotic/issues
                                freedomoticF 1 Reply Last reply
                                  Hi all,
                                  freedomoticF
                                  freedomoticF
                                  freedomotic
                                  Hello
                                  in this video https://youtu.be/G98U2Q3cCVc you can see our Telegram bot plugin in action.
                                  We need your feedback to improve it.
                                  • freedomoticF
                                    freedomoticF
                                    freedomotic
                                    Hi all
                                    Freedomotic 5.6 Commander RC4 is out and can be downloaded from https://sourceforge.net/projects/freedomotic/files/latest/download?source=recommended
                                    We fixed some bugs and introduced new functionalities.
                                    If you want to contribute take a look at the source code https://github.com/freedomotic and https://github.com/freedomotic/freedomotic/issues
                                    Stay tuned!
                                    • freedomoticF
                                      freedomoticF
                                      freedomotic
                                      Hi all
                                      we are working on a new web client for our domotic framework.
                                      Here some screenshots
                                      It's a WIP so we need any help to complete it.
                                      The code is available at https://github.com/freedomotic/fd-vue-webapp/
