  3. Transmit LED always lit on gateway?
16 Posts 4 Posters 7.7k Views 2 Watching
  • TD22057T
    TD22057T
    TD22057
    I'm wiring up 3 LED's to mount on my gateway case (TX, RX, ERROR) using the standard pins for an MQTT gateway (Pins 9, 8, 7 respectively). When I power on the gateway, it starts fine but the transmit LED is always lit (and the other two stay off). One of the comments in the sketch says pin 9 is the on board LED pin. Is that what's causing the problem? I'm assuming the transmit LED shouldn't be on all the time right?
      Which version of the MySensors library?
      • TD22057T
        TD22057T
        TD22057
        Sorry - v1.5 of mysensors. Running on an Uno w/ Ethernet shield.
          wrote on last edited by hek
          Hmm.. there has been some work done to incorporate the LED blinking into the MySensors library (enable it in MyConfig.h)..
          But as no-one maintains the MQTT gateway any longer (@Damme where are you? :) ) I guess the blink functionality is a bit messed up right now as the sketch itself seems to fiddle with the leds itself. You can most probably just remove the led-stuff from the sketch ino file and enable the feature WITH_LEDS_BLINKING in MyConfig.
          Read more about how to set the LED pins in the constructor here:
          http://www.mysensors.org/download/sensor_api_15#the-full-api
          • TD22057T
            TD22057T
            TD22057
            OK - I'll work on it and send a pull request when I'm done. The ethernet and serial code seems pretty clear wrt the LED's so I'll just use that as a template.
            • TD22057T
              TD22057T
              TD22057
              FYI - I removed all the LED pin handling from the MQTT gateway and changed the blink calls to go through the gateway. Reloading and I get the TX and RX lights continuously lit. So I thought I must be missing something so I build the plain ethernet gateway w/ LED support and I get the same thing - TX and RX lights are lit with nothing happening.
              So either my wiring is screwed up or something is wrong w/ the 1.5 LED code. I'm going to start looking into that and if I find anything I'll open a github issue and get a fix submitted.
              • TD22057T
                TD22057T
                TD22057
                @hek I think this might be a documentation problem in the web site. The code sets the LED pins to OUTPUT and LOW for off, HIGH for on. The web site (http://www.mysensors.org/build/advanced_gateway) says:
                "Each LED is connected by its anode (long leg) to +5V. The cathode (short leg) is connected through a resistor to one of the following digital pins of the Arduino"
                At least the way I read the code, it should say something like:
                "Each LED is connected by its anode (long leg) to the digital pin. The cathode (short leg) is connected through a resistor to ground."
                Does that sound right?
                  The documentations for this has not been updated in long time (should at least mention WITH_LEDS_BLINKING now!). I will update.
                  I'm confused now, do you mean that the behaviour changed with this pull request?
                  https://github.com/mysensors/Arduino/pull/109/files
                  Or has this been wrong for a longer period? It would be quite easy to have a MY_INVERSE_LEDS-define option in MyConfig to help people decide how to wire this themselves.
                  TD22057T 1 Reply Last reply
                  • TD22057T
                    TD22057T
                    TD22057
                    I'm not sure when it changed (or if it was wrong the whole time) - just that it didn't work for me with the mqtt gateway or the ethernet gateway. I will set up a pull request to update the MqttGateway to use WITH_LEDS_BLINKING. I don't think there is any reason to have it different than the other gateways. The code is trivial - I'm just waiting on some sensor nodes so I can properly test it.
                      Great, thanks...
                      • K
                        K
                        kugel9
                        Hello There,
                        I have the same problem in the serial gateway and the version 1.5, that all 3 LEDs burn.
                        In version 1.4 the SerialGateway everything is ok.
                          TD22057T
                          TD22057T
                          TD22057
                          @hek FYI - here's the commit that reversed the LED pins 23 days ago. The note doesn't say why it was done. https://github.com/mysensors/Arduino/commit/4abaa6ded34d22e3f3dd98d33d3d12450a537706#diff-957e773aa509ae0ea23a62fad74212a4
                            We better ping @blacey on this who might enlighten us when back from vacation. :)
                            • G
                              G
                              Gambituk
                              wrote on last edited by Gambituk
                              I've been using a version of the mqtt gateway for about 6 months, i setup the LED's like it shows in the advanced build, and they all (3) run with on all the time, and off when activated, i assumed at the time that this was by design, and it's quite nice to have a clear visual indication that things are all ok, with the occasional blink when there is a message received. i quite like it now. my file was compiled with version 1.4.1 modified library. but i believe it was the same behavior with 1.4 also.
                              Just incase it helps.
                                Ok, good to know. We could perhaps have the "MY_INVERSE_LEDS" option to make it easy to switch between the two behaviours.
                                  Ok, patched the inversed behaviour and fixed the new config option.
                                  https://github.com/mysensors/Arduino/commit/cb83bfbdb3ed32ef57040cff9954b390ec9a2528
