  3. Transmit LED always lit on gateway?
16 Posts 4 Posters 7.4k Views 2 Watching
  • T Offline
    T Offline
    TD22057
    I'm wiring up 3 LED's to mount on my gateway case (TX, RX, ERROR) using the standard pins for an MQTT gateway (Pins 9, 8, 7 respectively). When I power on the gateway, it starts fine but the transmit LED is always lit (and the other two stay off). One of the comments in the sketch says pin 9 is the on board LED pin. Is that what's causing the problem? I'm assuming the transmit LED shouldn't be on all the time right?
    • H Offline
      H Offline
      Which version of the MySensors library?
      • T Offline
        T Offline
        TD22057
        Sorry - v1.5 of mysensors. Running on an Uno w/ Ethernet shield.
        • H Offline
          H Offline
          wrote on last edited by hek
          Hmm.. there has been some work done to incorporate the LED blinking into the MySensors library (enable it in MyConfig.h)..
          But as no-one maintains the MQTT gateway any longer (@Damme where are you? :) ) I guess the blink functionality is a bit messed up right now as the sketch itself seems to fiddle with the leds itself. You can most probably just remove the led-stuff from the sketch ino file and enable the feature WITH_LEDS_BLINKING in MyConfig.
          Read more about how to set the LED pins in the constructor here:
          http://www.mysensors.org/download/sensor_api_15#the-full-api
          • T Offline
            T Offline
            TD22057
            OK - I'll work on it and send a pull request when I'm done. The ethernet and serial code seems pretty clear wrt the LED's so I'll just use that as a template.
            • T Offline
              T Offline
              TD22057
              FYI - I removed all the LED pin handling from the MQTT gateway and changed the blink calls to go through the gateway. Reloading and I get the TX and RX lights continuously lit. So I thought I must be missing something so I build the plain ethernet gateway w/ LED support and I get the same thing - TX and RX lights are lit with nothing happening.
              So either my wiring is screwed up or something is wrong w/ the 1.5 LED code. I'm going to start looking into that and if I find anything I'll open a github issue and get a fix submitted.
              • T Offline
                T Offline
                TD22057
                @hek I think this might be a documentation problem in the web site. The code sets the LED pins to OUTPUT and LOW for off, HIGH for on. The web site (http://www.mysensors.org/build/advanced_gateway) says:
                "Each LED is connected by its anode (long leg) to +5V. The cathode (short leg) is connected through a resistor to one of the following digital pins of the Arduino"
                At least the way I read the code, it should say something like:
                "Each LED is connected by its anode (long leg) to the digital pin. The cathode (short leg) is connected through a resistor to ground."
                Does that sound right?
                • H Offline
                  H Offline
                  The documentations for this has not been updated in long time (should at least mention WITH_LEDS_BLINKING now!). I will update.
                  I'm confused now, do you mean that the behaviour changed with this pull request?
                  https://github.com/mysensors/Arduino/pull/109/files
                  Or has this been wrong for a longer period? It would be quite easy to have a MY_INVERSE_LEDS-define option in MyConfig to help people decide how to wire this themselves.
                  • T Offline
                    T Offline
                    TD22057
                    I'm not sure when it changed (or if it was wrong the whole time) - just that it didn't work for me with the mqtt gateway or the ethernet gateway. I will set up a pull request to update the MqttGateway to use WITH_LEDS_BLINKING. I don't think there is any reason to have it different than the other gateways. The code is trivial - I'm just waiting on some sensor nodes so I can properly test it.
                    • H Offline
                      H Offline
                      Great, thanks...
                      • K Offline
                        K Offline
                        kugel9
                        Hello There,
                        I have the same problem in the serial gateway and the version 1.5, that all 3 LEDs burn.
                        In version 1.4 the SerialGateway everything is ok.
                        • H hek
                          T Offline
                          T Offline
                          TD22057
                          @hek FYI - here's the commit that reversed the LED pins 23 days ago. The note doesn't say why it was done. https://github.com/mysensors/Arduino/commit/4abaa6ded34d22e3f3dd98d33d3d12450a537706#diff-957e773aa509ae0ea23a62fad74212a4
                          • H Offline
                            H Offline
                            We better ping @blacey on this who might enlighten us when back from vacation. :)
                            • G Offline
                              G Offline
                              Gambituk
                              wrote on last edited by Gambituk
                              I've been using a version of the mqtt gateway for about 6 months, i setup the LED's like it shows in the advanced build, and they all (3) run with on all the time, and off when activated, i assumed at the time that this was by design, and it's quite nice to have a clear visual indication that things are all ok, with the occasional blink when there is a message received. i quite like it now. my file was compiled with version 1.4.1 modified library. but i believe it was the same behavior with 1.4 also.
                              Just incase it helps.
                              • H Offline
                                H Offline
                                Ok, good to know. We could perhaps have the "MY_INVERSE_LEDS" option to make it easy to switch between the two behaviours.
                                • H Offline
                                  H Offline
                                  Ok, patched the inversed behaviour and fixed the new config option.
                                  https://github.com/mysensors/Arduino/commit/cb83bfbdb3ed32ef57040cff9954b390ec9a2528
                                  12.1k
