  3. Temperature not presented to controller
7 Posts 4 Posters 3.0k Views 2 Watching
  • Sander StolkS
    Sander StolkS
    Sander Stolk
    wrote on last edited by Sander Stolk
    Hi there,
    I've got this sketch running on a Arduino Nano with a 5V 2.1A powersupply and I cannot get the Temp presented to the gateway.
    Below is my sketch and my debug-log:
    sensor started, id 4
    send: 4-4-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
    send: 4-4-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
    read: 4-1-0 s=255,c=3,t=6,pt=1,l=1:0
    read: 0-0-4 s=255,c=3,t=6,pt=0,l=1:M
    send: 4-4-0-0 s=255,c=3,t=11,pt=0,l=8,st=ok:Whatever
    send: 4-4-0-0 s=255,c=3,t=12,pt=0,l=1,st=ok:7
    send: 4-4-0-0 s=0,c=0,t=16,pt=0,l=0,st=ok:
    send: 4-4-0-0 s=1,c=0,t=16,pt=0,l=0,st=fail:
    send: 4-4-0-0 s=2,c=0,t=16,pt=0,l=0,st=fail:
    send: 4-4-0-0 s=8,c=0,t=6,pt=0,l=0,st=fail:
    send: 4-4-0-0 s=3,c=0,t=0,pt=0,l=0,st=fail:
    send: 4-4-0-0 s=8,c=1,t=0,pt=7,l=5,st=fail:-127.0
    send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,st=fail:487
    send: 4-4-0-0 s=1,c=1,t=23,pt=2,l=2,st=fail:430
    send: 4-4-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
    read: 4-1-255 s=255,c=3,t=7,pt=0,l=0:
    read: 0-0-4 s=255,c=3,t=8,pt=1,l=1:0
    new parent=0, d=1
    send: 4-4-0-0 s=2,c=1,t=23,pt=2,l=2,st=ok:386
    send: 4-4-0-0 s=3,c=1,t=16,pt=2,l=2,st=ok:0
    send: 4-4-0-0 s=8,c=1,t=0,pt=7,l=5,st=ok:-127.0
    send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,st=fail:353
    send: 4-4-0-0 s=1,c=1,t=23,pt=2,l=2,st=fail:335
    send: 4-4-0-0 s=2,c=1,t=23,pt=2,l=2,st=fail:350
    send: 4-4-0-0 s=3,c=1,t=16,pt=2,l=2,st=fail:0
    send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,st=fail:350
    send: 4-4-0-0 s=1,c=1,t=23,pt=2,l=2,st=fail:332
    send: 4-4-0-0 s=2,c=1,t=23,pt=2,l=2,st=ok:347
    send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,st=fail:351
    send: 4-4-0-0 s=1,c=1,t=23,pt=2,l=2,st=fail:333
    send: 4-4-0-0 s=2,c=1,t=23,pt=2,l=2,st=fail:348
    send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,st=fail:349
    send: 4-4-0-0 s=1,c=1,t=23,pt=2,l=2,st=fail:331
    new parent=0, d=1
    send: 4-4-0-0 s=2,c=1,t=23,pt=2,l=2,st=ok:346
    send: 4-4-0-0 s=1,c=1,t=23,pt=2,l=2,st=fail:330
    send: 4-4-0-0 s=2,c=1,t=23,pt=2,l=2,st=fail:346
    send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,st=fail:348
    send: 4-4-0-0 s=2,c=1,t=23,pt=2,l=2,st=ok:345
    send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,st=fail:346
    send: 4-4-0-0 s=1,c=1,t=23,pt=2,l=2,st=fail:327
    send: 4-4-0-0 s=2,c=1,t=23,pt=2,l=2,st=ok:343
    new parent=0, d=1
    send: 4-4-0-0 s=2,c=1,t=23,pt=2,l=2,st=fail:343
    send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,st=fail:344
    send: 4-4-0-0 s=1,c=1,t=23,pt=2,l=2,st=fail:326
    send: 4-4-0-0 s=2,c=1,t=23,pt=2,l=2,st=ok:341
    send: 4-4-0-0 s=0,c=1,t=23,pt=2,l=2,st=fail:347
    send: 4-4-0-0 s=1,c=1,t=23,pt=2,l=2,st=fail:328
    send: 4-4-0-0 s=2,c=1,t=23,pt=2,l=2,st=fail:344
    send: 4-4-0-0 s=1,c=1,t=23,pt=2,l=2,st=fail:325
    read: 0-0-4 s=255,c=3,t=8,pt=1,l=1:0```]
    ```#include <SPI.h>
    #include <OneWire.h>
    #define LIGHT_SENSOR_ANALOG_PIN_0 0 // Wasmachine
    #define LIGHT_SENSOR_ANALOG_PIN_1 1 // Droger
    #define LIGHT_SENSOR_ANALOG_PIN_2 2 // Zon
    #define BUTTON_PIN_1 3 // Balkondeur
    #define TEMP_1 8 // Pin where dallas sensor is connected
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    OneWire oneWire(TEMP_1);
    boolean metric = true;
    MyMessage msgW(LIGHT_SENSOR_ANALOG_PIN_0,V_LIGHT_LEVEL);
    MyMessage msgD(LIGHT_SENSOR_ANALOG_PIN_1,V_LIGHT_LEVEL);
    MyMessage msgZ(LIGHT_SENSOR_ANALOG_PIN_2,V_LIGHT_LEVEL);
    MyMessage msgTemp(TEMP_1,V_TEMP);
    MyMessage msgBD(BUTTON_PIN_1,V_TRIPPED);
      gw.begin();
      // Startup OneWire
      sensors.begin();
      gw.sendSketchInfo("Whatever", "7");
      gw.present(LIGHT_SENSOR_ANALOG_PIN_0,S_LIGHT_LEVEL);
      gw.present(LIGHT_SENSOR_ANALOG_PIN_1,S_LIGHT_LEVEL);
      gw.present(LIGHT_SENSOR_ANALOG_PIN_2,S_LIGHT_LEVEL);
      gw.present(TEMP_1,S_TEMP);
      gw.present(BUTTON_PIN_1,S_DOOR);
      pinMode(BUTTON_PIN_1,INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN_1,HIGH);
      //Read temp from sensor
      float temperature = static_cast<float>(static_cast<int> (sensors.getTempCByIndex(TEMP_1) * 10.)) / 10.;
      //delay(5000);
      int lightLevel0 = analogRead(LIGHT_SENSOR_ANALOG_PIN_0);
      //delay(5000);
      int lightLevel1 = analogRead(LIGHT_SENSOR_ANALOG_PIN_1);
      //delay(5000);
      int lightLevel2 = analogRead(LIGHT_SENSOR_ANALOG_PIN_2);
      //delay(5000);
      //Serial.println(lightLevel0);
      //Serial.println(lightLevel1);
      //Serial.println(lightLevel2);
      gw.send(msgW.set(lightLevel0));
      gw.send(msgD.set(lightLevel1));
      gw.send(msgZ.set(lightLevel2));
      gw.send(msgBD.set(BUTTON_PIN_1==HIGH ? 1 : 0));
      gw.sleep(SLEEP_TIME);
    I'm using 1.4 version in combination with a Arduino Gateway Nano.
    Everything else is presented to the controller but not the temperature.
    When I build a sketch with only the temp it works but that differs from this code above.
    • rvendrameR
      rvendrameR
      rvendrame
      You might try to add a capacitor between radio's VCC/GND, if not yet. Another try is to add a gw.wait(100) after each gw.send() (this made the trick for me).
      If after that you still getting a lot of st=fails, try replacing PSU / radio.
      ESP8266 GW + mySensors 2.3.2
      Alexa / Google Home
      • Sander StolkS
        Sander StolkS
        Sander Stolk
        Cap is present and I will proceed to add a 100ms delay between those messages.
        Otherwise I will replace the radio.
        Let you know!
        • Sander StolkS
          Sander StolkS
          Sander Stolk
          Implemented the wait time but no luck
          Replaced the radio and the cap but no luck
          Checked the wires but no luck
          Next thing is checking the code because the door is working and comes after the tempsensor.
          The reading of the tempsensor says -127.0
          Is there somebody who knows what kind of error -127.0 degrees means except my bedroom is very cold :P
            https://github.com/mysensors/Arduino/blob/master/libraries/DallasTemperature/DallasTemperature.h#L57
            • Tomasz PazioT
              Tomasz PazioT
              Tomasz Pazio
              Sander, I have the same issue on my side.
              http://forum.mysensors.org/topic/1715/multiple-ds18d20-does-not-report-temperature
              • Sander StolkS
                Sander StolkS
                Sander Stolk
                Boom! Got it!
                The sketch above does not send the temp because -127.0 / disconnected however with this sketch and implemented in my sketch above and it works...
                #define ONE_WIRE_BUS 8 // Pin where dallase sensor is connected
                unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds) 30000 orig
                int numSensors=0;
                boolean receivedConfig = false;
                MyMessage msg(0,V_TEMP);
                  // Startup OneWire
                  sensors.begin();
                  // Startup and initialize MySensors library. Set callback for incoming messages.
                  //gw.begin();
                  gw.begin();
                  gw.sendSketchInfo("test temp");
                     gw.present(i, V_TEMP);
                  // Process incoming messages (like config from server)
                    float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
                    // Only send data if temperature has changed more then 1 degC and no error
                    if (int(lastTemperature[i]) != int(temperature) && temperature != -127.00) { //added integer
                      gw.send(msg.setSensor(i).set(temperature,1));
                  //gw.sleep(SLEEP_TIME);
                Same hardware, same libs and different code...
                You tell me whats wrong because I don't know it anymore...
