  3. Which are the *best* NRF24L01+ modules?
310 Posts 42 Posters 345.7k Views 37 Watching
  • Z
    Z
    Zeph
    Agreed. If the module takes more power during transmit because it's putting out more RF, we might be able to back it off by using less than the maximum power settings, or use it in applications where it more rarely transmits.
    But if it uses too much sleep current, it's a bad option for battery power.
    • Z Zeph
      #149
      Exactly! You said it better than I did.
        For further comparison, here are the measurements taken on the red module from earlier in the thread:
        Again, just eyeballing it, that looks like, what, maybe 23ma? Acually more than the blob module, it would seem.
        AWIA
        AWIA
        AWI
        @NeverDie It should be possible to get some better (noiseless) measurements on the rigol scope.... at least if I look at what HARI is measuring on the ESP8266 current...
          #151
          I hooked up the uCurrent inline with the Itead NRF24L01+ module, measured using a Fluke 87V multimeter, and I got these measurements:
          Powered Down (Sleep): 0.6uA
          Standby: 22.6uA
          I'm satisfied that these are within error tolerances for the expected results.
          Prior to that, I tested the blob module and seemed to get bizarre results. I'm going to go back and re-test now that I'm reasonably confident the test setup and measurements are working right.
          I'm using an Arduino Uno. This was the test code I used:
          /* Adapted by NeverDie on 8/11/2015 to facilitate uCurrent measurements.
           Copyright (C) 2011 J. Coliz <maniacbug@ymail.com>
           TMRh20 2014 - Updates to the library allow sleeping both in TX and RX modes:
                TX Mode: The radio can be powered down (.9uA current) and the Arduino slept using the watchdog timer
                RX Mode: The radio can be left in standby mode (22uA current) and the Arduino slept using an interrupt pin
           * Example RF Radio Ping Pair which Sleeps between Sends
           * This is an example of how to use the RF24 class to create a battery-
           * efficient system.  It is just like the GettingStarted_CallResponse example, but the
           * ping node powers down the radio and sleeps the MCU after every
           * ping/pong cycle, and the receiver sleeps between payloads.
           * Write this sketch to two different nodes,
           * connect the role_pin to ground on one.  The ping node sends the current
           * time to the pong node, which responds by sending the value back.  The ping
           * node can then see how long the whole cycle took.
          #include <avr/sleep.h>
          #include <avr/power.h>
          #include "nRF24L01.h"
          #include "RF24.h"
          #include "printf.h"
          // Set up nRF24L01 radio on SPI bus plus pins 7 & 8
          RF24 radio(7,8);
          // sets the role of this unit in hardware.  Connect to GND to be the 'pong' receiver
          // Leave open to be the 'ping' transmitter
          const int role_pin = 5;
          const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };   // Radio pipe addresses for the 2 nodes to communicate.
          // Role management
          // Set up role.  This sketch uses the same software for all the nodes
          // in this system.  Doing so greatly simplifies testing.  The hardware itself specifies
          // which node it is.
          // The various roles supported by this sketch
          typedef enum { role_ping_out = 1, role_pong_back } role_e;
          // The debug-friendly names of those roles
          const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
          // The role of the current running sketch
          role_e role;
          void setup(){
            // set up the role pin
            pinMode(role_pin, INPUT);
            digitalWrite(role_pin,HIGH);
            delay(20); // Just to get a solid reading on the role pin
            // read the address pin, establish our role
            if ( digitalRead(role_pin) )
              role = role_ping_out;
              role = role_pong_back;
            Serial.begin(57600);
            printf_begin();
            printf("\n\rRF24/examples/pingpair_sleepy/\n\r");
            printf("ROLE: %s\n\r",role_friendly_name[role]);
            radio.begin();
            // Open pipes to other nodes for communication
            // This simple sketch opens two pipes for these two nodes to communicate
            // back and forth.
            // Open 'our' pipe for writing
            // Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
            if ( role == role_ping_out ) {
              radio.openWritingPipe(pipes[0]);
              radio.openReadingPipe(1,pipes[1]);
              radio.openWritingPipe(pipes[1]);
              radio.openReadingPipe(1,pipes[0]);
            // Dump the configuration of the rf unit for debugging
            radio.printDetails();
          void loop(){
            radio.powerDown();              // NOTE: The radio MUST be powered back up again manually
            delay(5000);
            radio.powerUp();                // Power up the radio after sleeping
            delay(5000);
            #152
            Yup, same as before. The measurements on the blob module are:
            -43.3ua and -42.8ua.
            I'm not sure which is standby current and which is sleep current. I definitely was not expecting a negative current. There's not much difference in magnitude between the two currents.
            So, I tried it on a different blob module:
            -43.5ua and -42.9ua.
            Essentially the same results.
            Truly bizarre. What's going on? I'm powering the Uno through a roughly 9V battery pack of Eneloop batteries via its barrel jack, as with the earlier measurement of the Itead module, whose measurements not only met expected value, but they were positive currents, not negative ones.
            Here's the red module:
            Powered Down (Sleep): 1.6uA
            Standby: 13.9uA
            Here's an Addicore module from Amazon:
            Powered Down (Sleep): 1.8uA
            Standyby: 16.3uA
            It's a very simple test. I'd say anyone can do these measurements, provided they have a good way to measure microamps.
            • rvendrameR
              rvendrameR
              rvendrame
              So the blob module is so good that it is charging your batteries ;-)
              ESP8266 GW + mySensors 2.3.2
              Alexa / Google Home
              • rvendrameR rvendrame
                I'm measuring the current between the Uno 3.3 Female header pin and the Vcc pin on the RF module.
                • rvendrameR
                  rvendrameR
                  rvendrame
                  Now talking seriously, maybe the some current is leaking through the other pins (MISO, CE, CS, etc), from arduino to radio? That would could an negative VCC flow I think...
                  Alexa / Google Home
                    It must be that. I wonder how it would measure if I were to use 3.3v on the datapins rather than the 5v the Uno uses.
                    • rvendrameR
                      rvendrameR
                      rvendrame
                      In theory it would require a logic level converter
                      But for sure the atmega is tolerant between 3.3V and 5V. And probably the converter would introduce an error in the u-measurement, I guess.
                      Alexa / Google Home
                        #158
                        I plugged a blob module into the RFToy, which is effectively an 8Mhz Mini Pro running at 3.3v, and used a jig similar to the one before (just no resistor) to route the module Vcc current into the uCurrent.
                        This time it is powered through the USB port, and the voltage is downshifted from there.
                        New measurements for the blob module:
                        Powered Down (Sleep): 3.3uA
                        Standby: 67.2uA
                        For comparison, I plugged the Itead module (Nordic tracecode 1301CL) into the same apparatus, and this time I got
                        Standby: 22.8uA
                        which, within measurement error, I would call the same as when it was hooked up to the Uno.
                          #159
                          @Zeph: For the NRF24L01+ modules, I now have good enough current measurements that I wanted to get, so I'll be holding off on doing further measurements, at least for now. I want to try the RFM69HW for comparison, but that is outside the scope of this thread.
                            #160
                            BTW, using just my Fluke 87V multimeter set on the uA setting, the measurements I get are:
                            Fluke 87V Itead Module Measurements:
                            Powered Down(Sleep): 0.5uA
                            Standby: 22.5uA
                            and
                            Fluke 87V Blob Module Meaasurements:
                            Powwred Down(Sleep): 3.0uA
                            Standby: 56uA
                            and
                            Fluke 87V Addicore module from Amazon Measurements:
                            Powered Down: 1.2uA
                            Standby: 18.2uA
                            So, although a bit different than the uCurrent measurements, they seem good enough for separating out the fakes that I have from the genuine article (which at this point the evidence suggests is what the chip in the Itead module is).
                            So, good news! Maybe all you need is a DMM with decent uA measurements. If I'd had this information at the very beginning of this thread, it would have saved me a lot of frustration and doubt. Now everyone can be empowered. :smile: The next time you buy modules, you can now easily test them right away and send them back if they're fake! :smile: :smile: :smile:
                            hekH 1 Reply Last reply
                              Standby: 22.5uA
                              and
                              Standby: 56uA
                              and
                              Powered Down: 1.2uA
                              Standby: 18.2uA
                              I told you in the fifth post :punch: ;)
                                @hek said:
                                Where exactly did you read it anyway?
                                  Just a lucky guess.
                                    Just a lucky guess.
                                    #164
                                    @hek said:
                                    Just a lucky guess.
                                    What??? You were BS'ing me about reading it? :punch: :astonished:
                                    @hek said:
                                    You should also compare the power consumption. From what I have read the genuine Nordic module has much better characteristics.
                                      @NeverDie said:
                                      You were BS'ing me then?
                                      Hmm.. no.. but I cannot for my mind recollect where I could have read it. So it might just have been a creation of my (weird) mind. :)
                                        #166
                                        All's well that ends well. :smile:
                                          #167
                                          BTW, I just now measured this surface mount module using the uCurrent, and it measures out at
                                          Powered Down (Sleep): 0.7uA
                                          Standyby: 22.7uA
                                          Therefore, I deem it genuine. I got it at ICStation two or three months ago:
                                          http://www.icstation.com/nrf24l01-rfid-wireless-transmission-module-2dbm-p-4620.html
                                          It would help a lot if others here, when you measure your module, would post your measurements and where you got it from, and when. That way we can all benefit from the network effect and make better purchases and possibly avoid bad purchases also.
