  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 333.4k Views 52 Watching
  • epierreE
    epierreE
    epierre
    here it is:
    http://www.domoticz.com/forum/viewtopic.php?f=42&t=7187&p=48366&hilit=v_var#p48366
    z-wave - Vera -> Domoticz
    • epierreE epierre
      here it is:
      Moshe LivneM
      Moshe LivneM
      Moshe Livne
      @epierre He meant in the sense that it does not display or use it for anything. he said there "it is used to store/retrieve variables". The thread was about the option to show the vars as part of the sensor output. for storing and retrieving, it works.... verified.... I might get annoyed enough to add to the code that the lua script can also retrieve these vars and then it would be sweet.....
      • epierreE
        epierreE
        epierre
        ok good although it was not explicit... now I'll have to go back to him about water meter that heavily use V_VARs but is recognized.... as a power meter...
          moffen666
          Hello
          And thx for a nice forum, I did build the irrigation controller and tried to connect it to Domoticz. Everything just seems fine, LCD works, push button works and I can turn on the irrigation from Domoticz and it shows in the LCD.
          But the problem is that it doesn't switch the relays on, it just says "no valve time" and then go watering cycle complete.
          Any suggestions on what the problem might be...... Domoticz?
          Regards
          • M moffen666
            Hello
            Regards
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @moffen666
            I don't have Domoticz but I suspect that the callback isn't functioning.
            try populating the array with the desired times for each sequence. replace this:
            int allZoneTime [NUMBER_OF_VALVES + 1];
            int valveSoloTime [NUMBER_OF_VALVES + 1];
            with something like this:
            int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 10, 10, 10, 5,<... how many valves you have with zero in the first position>} ;
            int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 5, 5, 5, 5,<... how many valves you have with zero in the first position>};
            This will load in the times that the program uses as your 'default' values. Then, you can check with Domoticz experts on getting the V_VAR variables working.
            fusion_manF 1 Reply Last reply
              moffen666
              Thx Bulldog
              I will check asap and get back with the result.
              Regards
                moffen666
                Hi
                I tried the code but it didn't compile, and I'm not good enough to be sure whats wrong.
                I did try change the code and I did get it to compile, but I don't know if I got it right. You can see the lame attempt below the colored line.
                upload-956d60c8-6d6d-44b7-abdb-015f701c65dc
                • M moffen666
                  Hi
                  BulldogLowellB
                  BulldogLowellB
                  BulldogLowell
                  #95
                  @moffen666
                  Clearly you understand that you are to put the times for each of the valve zones, led by a zero into the array, and not copy my verbatim instructions...
                  How many valves do you have? You need that many (plus one) integer numbers separated by commas...
                  Example 8 valves:
                  ...= {0,5,5,5,5,5,5,5,5};
                  You've commented out the wrong lines.
                    moffen666
                    Thx for the quick answer
                    I use 4 valves atm, I tried your suggestion but it seems it wont work for me.
                    upload-edb305b1-3dc3-4afd-ae02-e2e779452d18
                    Regards
                      moffen666
                      The inserted values in the array works from start, but it looks like the irrigation controller immediately starts to request valve data from the controller for variable1 and 2. As we cant set variable1 and 2 in Domoticz I guess it returns 0 and overwrite the inserted values in the arrays...or is it anything else happening?
                      Initialising...
                      Turning All Valves Off...
                      Unable to sync with the RTC
                      Checking EEPROM for stored date:
                      Retreiving last run time from EEPROM...
                      send: 7-7-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                      send: 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                      read: 0-0-7 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      sensor started, id=7, parent=0, distance=1
                      send: 7-7-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:MySprinkler
                      send: 7-7-0-0 s=255,c=3,t=12,pt=0,l=6,sg=0,st=ok:2.0nsr
                      send: 7-7-0-0 s=0,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                      send: 7-7-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                      send: 7-7-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                      send: 7-7-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                      send: 7-7-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                      Sensor Presentation Complete
                      Ready...
                      Calling for Valve 0 Data...
                      send: 7-7-0-0 s=0,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=0,c=2,t=24,pt=0,l=0,sg=0:
                      Recieved variable1 valve:0 = 0
                      send: 7-7-0-0 s=0,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=0,c=2,t=25,pt=0,l=0,sg=0:
                      Recieved variable2 valve:0 = 0
                      send: 7-7-0-0 s=0,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=0,c=2,t=26,pt=0,l=0,sg=0:
                      No Name Recieved for zone 0
                      Calling for Valve 1 Data...
                      send: 7-7-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=1,c=2,t=24,pt=0,l=0,sg=0:
                      Recieved variable1 valve:1 = 0
                      New Zone Times Recieved...
                      Zone 1 individual time: 1 group time: 0
                      Zone 2 individual time: 1 group time: 1
                      Zone 3 individual time: 1 group time: 1
                      Zone 4 individual time: 1 group time: 1
                      send: 7-7-0-0 s=1,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=1,c=2,t=25,pt=0,l=0,sg=0:
                      Recieved variable2 valve:1 = 0
                      Zone 1 individual time: 0 group time: 0
                      send: 7-7-0-0 s=1,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=1,c=2,t=26,pt=0,l=0,sg=0:
                      No Name Recieved for zone 1
                      Calling for Valve 2 Data...
                      send: 7-7-0-0 s=2,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=2,c=2,t=24,pt=0,l=0,sg=0:
                      Recieved variable1 valve:2 = 0
                      Zone 2 individual time: 1 group time: 0
                      send: 7-7-0-0 s=2,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=2,c=2,t=25,pt=0,l=0,sg=0:
                      Recieved variable2 valve:2 = 0
                      Zone 2 individual time: 0 group time: 0
                      send: 7-7-0-0 s=2,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=2,c=2,t=26,pt=0,l=0,sg=0:
                      No Name Recieved for zone 2
                      Calling for Valve 3 Data...
                      send: 7-7-0-0 s=3,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=3,c=2,t=24,pt=0,l=0,sg=0:
                      Recieved variable1 valve:3 = 0
                      Zone 3 individual time: 1 group time: 0
                      send: 7-7-0-0 s=3,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=3,c=2,t=25,pt=0,l=0,sg=0:
                      Recieved variable2 valve:3 = 0
                      Zone 3 individual time: 0 group time: 0
                      send: 7-7-0-0 s=3,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=3,c=2,t=26,pt=0,l=0,sg=0:
                      No Name Recieved for zone 3
                      Calling for Valve 4 Data...
                      send: 7-7-0-0 s=4,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=4,c=2,t=24,pt=0,l=0,sg=0:
                      Recieved variable1 valve:4 = 0
                      Zone 4 individual time: 1 group time: 0
                      send: 7-7-0-0 s=4,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=4,c=2,t=25,pt=0,l=0,sg=0:
                      Recieved variable2 valve:4 = 0
                      Zone 4 individual time: 0 group time: 0
                      send: 7-7-0-0 s=4,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                      read: 0-0-7 s=4,c=2,t=26,pt=0,l=0,sg=0:
                      No Name Recieved for zone 4
                      • M moffen666
                        Initialising...
                        Ready...
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        @moffen666
                        try commenting out this in setup():
                            pinMode(relayPin[i], OUTPUT);
                            lcd.print(F(" Updating  "));
                            lcd.setCursor(0, 1);
                            lcd.print(i);
                            boolean flashIcon = false;
                            DEBUG_PRINT(i);
                            DEBUG_PRINTLN(F(" Data..."));
                            while (gw.process() == false)
                              lcd.setCursor(15, 0);
                              flashIcon = !flashIcon;
                              gw.request(i, V_VAR1);
                              delay(100);
                              gw.request(i, V_VAR2);
                              delay(100);
                              gw.request(i, V_VAR3);
                              delay(100);
                        and this in loop():
                        //goGetValveTimes();
                        That will disable those callbacks and you should be OK with a HardCoded time table for the valves and valve names.
                          moffen666
                          Thx Bulldog for all the help, everything seems to be working as it should now.
                          Keep up the good work :+1:
                          Updated code for Domoticz.
                          MySprinkler for MySensors
                          Arduino Multi-Zone Sprinkler Control
                          May 31, 2015
                          *** Version 2.0
                          * LED status indicator
                          PARTS LIST:
                          * Relays (8 channel)
                          * NRF24L01 Radio
                          * Arduino (I used a Pro Mini)
                          * Capacitors (10uf and .1uf)
                          * 3.3v voltage regulator
                          * Resistors (270 & 10K)
                          * Female Dupont Cables
                          * LED
                          * Push button
                          * Shift Register (SN74HC595)
                          * 18 gauge wire (for relay)
                          INSTRUCTIONS:
                            on the serial monitor.
                          #include <Time.h>
                          #include <LiquidCrystal.h>
                          #define NUMBER_OF_VALVES 4  // Change this to set your valve count up to 16.
                          #define RADIO_ID AUTO  // Change this to fix your Radio ID or use Auto
                          #define SKETCH_NAME "MySprinkler Domoticz"
                          #define SKETCH_VERSION "2.0"
                          #define CHILD_ID_SPRINKLER 0
                          //#define ACTIVE_LOW // comment out this line if your relays are active high
                          #ifdef ACTIVE_LOW
                          #define ALL_VALVES_OFF 0xFFFF
                          #define ALL_VALVES_OFF 0U
                          #ifdef DEBUG_ON
                          typedef enum {
                          SprinklerStates;
                          SprinklerStates lastState;
                          byte menuState = 0;
                          unsigned long menuTimer;
                          byte countDownTime = 10;
                          int allZoneTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};     // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
                          int valveSoloTime [NUMBER_OF_VALVES + 1]= {0, 1, 1, 1, 1};   // Insert values in min, 0 = all zone (always 0) this is a 4 chan relay
                          int valveNumber;
                          int lastValve;
                          unsigned long startMillis;
                          const int ledPin = 5;
                          const int waterButtonPin = 3;
                          boolean buttonPushed = false;
                          boolean showTime = true;
                          boolean clockUpdating = false;
                          boolean recentUpdate = true;
                          const char *dayOfWeek[] = {
                          String valveNickName[17] = {
                          time_t lastTimeRun = 0;
                          //Setup Shift Register...
                          const int latchPin = 8;
                          const int clockPin = 4;
                          const int dataPin  = 7;
                          LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address to 0x27
                            SERIAL_START(115200);
                            pinMode(latchPin, OUTPUT);
                            pinMode(clockPin, OUTPUT);
                            pinMode(dataPin, OUTPUT);
                            pinMode(ledPin, OUTPUT);
                            attachInterrupt(1, PushButton, RISING); //May need to change for your Arduino model
                            digitalWrite (ledPin, HIGH);
                            updateRelays(ALL_VALVES_OFF);
                            //delay(5000);
                            lcd.clear();
                            lcd.backlight();
                            lcd.createChar(0, clock);
                            lcd.createChar(1, raindrop);
                            delay(500);
                            if (gw.loadState(0) == 0xFF); // EEPROM flag
                              for (int i = 0; i < 4 ; i++)
                                lastTimeRun = lastTimeRun | gw.loadState(i + 1); // assemble 4 bytes into an ussigned long epoch timestamp
                            gw.begin(getVariables, RADIO_ID, false); // Change 'false' to 'true' to create a Radio repeating node
                              gw.present(i, S_LIGHT);
                            digitalWrite (ledPin, LOW);
                            DEBUG_PRINTLN(F("Ready..."));
                            lcd.setCursor(0, 0);
                            lcd.write(byte(0));
                            int clockCounter = 0;
                              gw.requestTime(receiveTime);
                              delay(1000);
                              lcd.print(".");
                              clockCounter++;
                              if (clockCounter > 16)
                                lcd.clear();
                                delay(2000);
                            lcd.clear();
                              lcd.print(i);
                              DEBUG_PRINT(i);
                                delay(100);
                                delay(100);
                                delay(100);
                            lcd.clear();
                            updateClock();
                            updateDisplay();
                            if (buttonPushed)
                              menuTimer = millis();
                                state = ZONE_SELECT_MENU;
                                menuState = 0;
                                menuState++;
                                  menuState = 0;
                              slowToggleLED ();
                              if (state != lastState)
                                  delay(50);
                                  gw.send(msg1valve.setSensor(i).set(false), false);
                                lcd.clear();
                                lcd.setCursor(0,0);
                                lcd.setCursor(0,1);
                                delay(2000);
                                lastValve = -1;
                              if (lastValve != valveNumber)
                                    gw.send(msg1valve.setSensor(i).set(true), false);
                              lastValve = valveNumber;
                              fastToggleLed();
                                valveNumber = 1;
                                startMillis = millis();
                                valveNumber++;
                                  state = CYCLE_COMPLETE;
                                  lastValve = -1;
                                  lastTimeRun = now();
                                  DEBUG_PRINT(F("State = "));
                                  DEBUG_PRINTLN(state);
                              fastToggleLed();
                                DEBUG_PRINT(F("Zone: "));
                                DEBUG_PRINTLN(valveNumber);
                                fastToggleLed();
                            else if (state = ZONE_SELECT_MENU)
                              displayMenu();
                            lastState = state;
                          void displayMenu(void)
                            static int lastSecond;
                              lcd.clear();
                              lcd.print(F("Starting"));
                              lcd.print(F("."));
                              Serial.print(".");
                            lastSecond = thisSecond;
                              if (menuState == 0)
                                valveNumber = 1;
                                state = RUN_ALL_ZONES;
                                valveNumber = menuState;
                                state = RUN_SINGLE_ZONE;
                            lastMenuState = menuState;
                          void updateRelays(int value)
                            digitalWrite(latchPin, LOW);
                            digitalWrite(latchPin, HIGH);
                              buttonPushed = true;
                          void fastToggleLed()
                              fastLedTimer = millis ();
                          void slowToggleLED ()
                              slowLedTimer = millis ();
                            boolean zoneTimeUpdate = false;
                            if (message.isAck())
                              if (message.sensor == i)
                                if (message.type == V_LIGHT)
                                  if (switchState == 0)
                                    if (i == 0)
                                      valveNumber = 1;
                                      valveNumber = i;
                                      DEBUG_PRINTLN(i);
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINT(F(" = "));
                                  DEBUG_PRINTLN(variable1);
                                    allZoneTime[i] = variable1;
                                    zoneTimeUpdate = true;
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINTLN(variable2);
                                    valveSoloTime[i] = variable2;
                                  if (newMessage.length() == 0)
                                    DEBUG_PRINTLN(i);
                                  if (newMessage.length() > 16)
                                    newMessage.substring(0, 16);
                                  valveNickName[i] = "";
                                  DEBUG_PRINT(F("Recieved new name for zone "));
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINT(F(" and it is now called: "));
                            if (zoneTimeUpdate)
                                if (i != 0)
                                  DEBUG_PRINT(F("Zone "));
                                  DEBUG_PRINT(i);
                                  DEBUG_PRINTLN(allZoneTime[i]);
                              recentUpdate = false;
                          void updateDisplay()
                            static boolean displayToggle = false;
                              switch (state) {
                                case STAND_BY_ALL_OFF:
                                  fastClear();
                                  if (displayToggle)
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                    lcd.print(hourFormat12());
                                    lcd.print(minute());
                                    lcd.print(month());
                                    lcd.print(day());
                                    lcd.print(F("/"));
                                    lcd.print(year() % 100);
                                    if (clockUpdating)
                                      lcd.write(byte(0));
                                    lcd.setCursor(11, 1);
                                    lcd.print(day(lastTimeRun));
                                case RUN_SINGLE_ZONE:
                                  fastClear();
                                  if (displayToggle)
                                    lcd.print(F(" Zone:"));
                                    lcd.print(valveNumber);
                                    lcd.print(F(" Active"));
                                      lcd.print("min");
                                      lcd.print("sec  ");
                                case RUN_ALL_ZONES:
                                  fastClear();
                                  if (displayToggle)
                                    lcd.print(F(" Active "));
                                    lcd.print("min");
                                    lcd.print("sec  ");
                                case CYCLE_COMPLETE:
                                  if (displayToggle)
                                    int totalTimeRan = 0;
                                    lcd.print(totalTimeRan);
                                    lcd.print(" Minutes   ");
                              lastUpdateTime = millis();
                            lastDisplayState = state;
                            int lastSecond = second();
                            int lastMinute = minute();
                            int lastHour = hour();
                            setTime(newTime);
                              DEBUG_PRINT(hourFormat12());
                              DEBUG_PRINT(minute());
                              DEBUG_PRINT(month());
                              DEBUG_PRINT(F("/"));
                              DEBUG_PRINT(day());
                              DEBUG_PRINTLN(year());
                              showTime = false;
                          void fastClear()
                          void updateClock()
                              lcd.write(byte(0));
                              clockUpdating = true;
                              lastVeraGetTime = millis();
                            if (gw.loadState(0) != 0xFF)
                              gw.saveState(0, 0xFF); // EEPROM flag for last date saved stored in EEPROM (location zero)
                            for (int i = 1; i < 5; i++)
                              gw.saveState(5 - i, byte(theDate >> 8 * (i - 1))); // store epoch datestamp in 4 bytes of EEPROM starting in location one
                          void goGetValveTimes()
                            static byte valveIndex = 1;
                            if (millis() - valveUpdateTime >= 300000UL / NUMBER_OF_VALVES)// update each valve once every 5 mins (distributes the traffic)
                              DEBUG_PRINTLN(F("Calling for Valve Data..."));
                              lcd.write(byte(1)); //lcd.write(1);
                              gw.request(valveIndex, V_VAR1);
                              gw.request(valveIndex, V_VAR2);
                              gw.request(valveIndex, V_VAR3);
                              valveUpdateTime = millis();
                              valveIndex++;
                              if (valveIndex > NUMBER_OF_VALVES + 1)
                                valveIndex = 1;
                          • petewillP
                            petewillP
                            petewill
                            Hey Everyone,
                            I just made a follow up video to this irrigation controller that shows my logic I'm using to save water. It's pretty specific to my environment but hopefully you can use some of the ideas to save water in your environment. I have attached the logic I used in my PLEG device.
                            Pete
                            PLEG Irrigation.pdf
                            https://youtu.be/_voDZH2EBgw
                            • epierreE
                              epierreE
                              epierre
                              looking at the project, I'm wondering why you propose 3.3V only, is this for the shift register and the screen ? Why not stay in 5V ?
                              petewillP 1 Reply Last reply
                              • epierreE epierre
                                petewillP
                                petewillP
                                petewill
                                @epierre Where did you see that I don't remember? Perhaps for the NRF radio?
                                • epierreE
                                  epierreE
                                  epierre
                                  @petewill it is here: http://www.mysensors.org/build/irrigation
                                  it is hard to know the BOM from the page, so I was wondering why you would neeed the powering adaptation if you input 5V
                                  • epierreE epierre
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    @epierre
                                    If you watch the video, you can see he's using the voltage regulator to supply power to the radio.
                                    Are you getting ready to build?
                                    epierreE 1 Reply Last reply
                                      @epierre
                                      epierreE
                                      epierreE
                                      epierre
                                      @BulldogLowell said:
                                      @epierre
                                      I've ordered the 8 switch, I have soil moisture, leaf moisture, ground humidity, rain gauge and found some evapotranspiration algorithm so I have all inputs and now need to have outputs in parallel of my rainbird scheduler (too dumb...)
                                      So I'm ready to build as you say ;-)
                                        Added your project to the main site togeter with @petewill excellent new video.
                                        https://youtu.be/l4GPRTsuHkI
                                        C
                                        C
                                        charlybrown
                                        Excellent project.
                                        Can you help me with the android code, to send instrucctions from my cell phone to Arduino? like on-off light , bomb, etc.
                                        thanks for your time!
                                        best regards.
                                        • C
                                          C
                                          charlybrown
                                          Excellent work. I need help with android code. Anybody can help me with this?
                                          thanks
