  3. Irrigation Controller (up to 16 valves with Shift Registers)
371 Posts 56 Posters 330.8k Views 52 Watching
  • T treb0r
    @BulldogLowell
    HI
    Thanks for the post. On LCD there is no info about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
    So I cant check if the RTC is working
    treb0r
    BulldogLowellB
    BulldogLowellB
    BulldogLowell
    @treb0r
    did you get your RTC connected and tested?
      @treb0r
      treb0r
      @BulldogLowell
      Yes, RTC is connected and tested with different sketches (just to check if RTC work correctly). Works ok.
      With your correctes projects, as above mentioned: On LCD there is no info neither about Time Synchronisation, nor about Time Synchronisation fail. It stops, as previously on info: Updating Valve : 0
      treb0r
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        Yes, since clock no longer needs to call server for time, synchronizing is not necessary.
        You should post serial output or show a video.
        Did you find out if Domoticz supports V_VAR1?
          treb0r
          @BulldogLowell
          OK, I will post the video. If I will manage I will also post serial output
          treb0r
          • T treb0r
            @BulldogLowell
            treb0r
            Moshe LivneM
            Moshe LivneM
            Moshe Livne
            @treb0r @BulldogLowel I had a chance to play a little bit with VAR1 this weekend. I verified that if you declare MyMessage var(CHILD_ID, V_VAR1); you can set it with gw.send(var.set("hello")); and request its value from the gateway using gw.request(CHILD_ID, V_VAR1);. you will get the answer in the incoming message handler under the V_VAR1 message
               if (message.type==V_VAR1) {
               	 Serial.println("got var1 answer");
            However I still didn't manage to find how to access or show these values on the domoticz. their site crashed so couldn't ask this in the forum
            • epierreE
              epierreE
              epierre
              @Moshe-Livne Domoticz (as of today) doesn't support V_VARx ...
              z-wave - Vera -> Domoticz
              • epierreE epierre
                Moshe LivneM
                Moshe LivneM
                Moshe Livne
                @epierre it does but in a strange way. The vars are not display vars. They are stored in the db and can be fetched and set only by the sensor. Tried it, it works....
                • epierreE
                  epierreE
                  epierre
                  @Moshe-Livne this is not what @GizMoCuz said in a post... strange...
                  • epierreE epierre
                    Moshe LivneM
                    Moshe LivneM
                    Moshe Livne
                    @epierre can you please link to the post?
                    • epierreE
                      epierreE
                      epierre
                      here it is:
                      http://www.domoticz.com/forum/viewtopic.php?f=42&t=7187&p=48366&hilit=v_var#p48366
                      • epierreE epierre
                        here it is:
                        Moshe LivneM
                        Moshe LivneM
                        Moshe Livne
                        @epierre He meant in the sense that it does not display or use it for anything. he said there "it is used to store/retrieve variables". The thread was about the option to show the vars as part of the sensor output. for storing and retrieving, it works.... verified.... I might get annoyed enough to add to the code that the lua script can also retrieve these vars and then it would be sweet.....
                        • epierreE
                          epierreE
                          epierre
                          ok good although it was not explicit... now I'll have to go back to him about water meter that heavily use V_VARs but is recognized.... as a power meter...
                            moffen666
                            Hello
                            And thx for a nice forum, I did build the irrigation controller and tried to connect it to Domoticz. Everything just seems fine, LCD works, push button works and I can turn on the irrigation from Domoticz and it shows in the LCD.
                            But the problem is that it doesn't switch the relays on, it just says "no valve time" and then go watering cycle complete.
                            Any suggestions on what the problem might be...... Domoticz?
                            Regards
                            • M moffen666
                              Hello
                              Regards
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              @moffen666
                              I don't have Domoticz but I suspect that the callback isn't functioning.
                              try populating the array with the desired times for each sequence. replace this:
                              int allZoneTime [NUMBER_OF_VALVES + 1];
                              int valveSoloTime [NUMBER_OF_VALVES + 1];
                              with something like this:
                              int allZoneTime [NUMBER_OF_VALVES + 1] = {0, 10, 10, 10, 5,<... how many valves you have with zero in the first position>} ;
                              int valveSoloTime [NUMBER_OF_VALVES + 1] = {0, 5, 5, 5, 5,<... how many valves you have with zero in the first position>};
                              This will load in the times that the program uses as your 'default' values. Then, you can check with Domoticz experts on getting the V_VAR variables working.
                              fusion_manF 1 Reply Last reply
                                moffen666
                                Thx Bulldog
                                I will check asap and get back with the result.
                                Regards
                                  moffen666
                                  Hi
                                  I tried the code but it didn't compile, and I'm not good enough to be sure whats wrong.
                                  I did try change the code and I did get it to compile, but I don't know if I got it right. You can see the lame attempt below the colored line.
                                  upload-956d60c8-6d6d-44b7-abdb-015f701c65dc
                                  • M moffen666
                                    Hi
                                    BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    #95
                                    @moffen666
                                    Clearly you understand that you are to put the times for each of the valve zones, led by a zero into the array, and not copy my verbatim instructions...
                                    How many valves do you have? You need that many (plus one) integer numbers separated by commas...
                                    Example 8 valves:
                                    ...= {0,5,5,5,5,5,5,5,5};
                                    You've commented out the wrong lines.
                                      moffen666
                                      Thx for the quick answer
                                      I use 4 valves atm, I tried your suggestion but it seems it wont work for me.
                                      upload-edb305b1-3dc3-4afd-ae02-e2e779452d18
                                      Regards
                                        moffen666
                                        The inserted values in the array works from start, but it looks like the irrigation controller immediately starts to request valve data from the controller for variable1 and 2. As we cant set variable1 and 2 in Domoticz I guess it returns 0 and overwrite the inserted values in the arrays...or is it anything else happening?
                                        Initialising...
                                        Turning All Valves Off...
                                        Unable to sync with the RTC
                                        Checking EEPROM for stored date:
                                        Retreiving last run time from EEPROM...
                                        send: 7-7-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                                        send: 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                        read: 0-0-7 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                        sensor started, id=7, parent=0, distance=1
                                        send: 7-7-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:MySprinkler
                                        send: 7-7-0-0 s=255,c=3,t=12,pt=0,l=6,sg=0,st=ok:2.0nsr
                                        send: 7-7-0-0 s=0,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                        send: 7-7-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                        send: 7-7-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                        send: 7-7-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                        send: 7-7-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                                        Sensor Presentation Complete
                                        Ready...
                                        Calling for Valve 0 Data...
                                        send: 7-7-0-0 s=0,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=0,c=2,t=24,pt=0,l=0,sg=0:
                                        Recieved variable1 valve:0 = 0
                                        send: 7-7-0-0 s=0,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=0,c=2,t=25,pt=0,l=0,sg=0:
                                        Recieved variable2 valve:0 = 0
                                        send: 7-7-0-0 s=0,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=0,c=2,t=26,pt=0,l=0,sg=0:
                                        No Name Recieved for zone 0
                                        Calling for Valve 1 Data...
                                        send: 7-7-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=1,c=2,t=24,pt=0,l=0,sg=0:
                                        Recieved variable1 valve:1 = 0
                                        New Zone Times Recieved...
                                        Zone 1 individual time: 1 group time: 0
                                        Zone 2 individual time: 1 group time: 1
                                        Zone 3 individual time: 1 group time: 1
                                        Zone 4 individual time: 1 group time: 1
                                        send: 7-7-0-0 s=1,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=1,c=2,t=25,pt=0,l=0,sg=0:
                                        Recieved variable2 valve:1 = 0
                                        Zone 1 individual time: 0 group time: 0
                                        send: 7-7-0-0 s=1,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=1,c=2,t=26,pt=0,l=0,sg=0:
                                        No Name Recieved for zone 1
                                        Calling for Valve 2 Data...
                                        send: 7-7-0-0 s=2,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=2,c=2,t=24,pt=0,l=0,sg=0:
                                        Recieved variable1 valve:2 = 0
                                        Zone 2 individual time: 1 group time: 0
                                        send: 7-7-0-0 s=2,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=2,c=2,t=25,pt=0,l=0,sg=0:
                                        Recieved variable2 valve:2 = 0
                                        Zone 2 individual time: 0 group time: 0
                                        send: 7-7-0-0 s=2,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=2,c=2,t=26,pt=0,l=0,sg=0:
                                        No Name Recieved for zone 2
                                        Calling for Valve 3 Data...
                                        send: 7-7-0-0 s=3,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=3,c=2,t=24,pt=0,l=0,sg=0:
                                        Recieved variable1 valve:3 = 0
                                        Zone 3 individual time: 1 group time: 0
                                        send: 7-7-0-0 s=3,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=3,c=2,t=25,pt=0,l=0,sg=0:
                                        Recieved variable2 valve:3 = 0
                                        Zone 3 individual time: 0 group time: 0
                                        send: 7-7-0-0 s=3,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=3,c=2,t=26,pt=0,l=0,sg=0:
                                        No Name Recieved for zone 3
                                        Calling for Valve 4 Data...
                                        send: 7-7-0-0 s=4,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=4,c=2,t=24,pt=0,l=0,sg=0:
                                        Recieved variable1 valve:4 = 0
                                        Zone 4 individual time: 1 group time: 0
                                        send: 7-7-0-0 s=4,c=2,t=25,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=4,c=2,t=25,pt=0,l=0,sg=0:
                                        Recieved variable2 valve:4 = 0
                                        Zone 4 individual time: 0 group time: 0
                                        send: 7-7-0-0 s=4,c=2,t=26,pt=0,l=0,sg=0,st=ok:
                                        read: 0-0-7 s=4,c=2,t=26,pt=0,l=0,sg=0:
                                        No Name Recieved for zone 4
                                        • M moffen666
                                          Initialising...
                                          Ready...
                                          BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          @moffen666
                                          try commenting out this in setup():
                                              pinMode(relayPin[i], OUTPUT);
                                              lcd.print(F(" Updating  "));
                                              lcd.setCursor(0, 1);
                                              lcd.print(i);
                                              boolean flashIcon = false;
                                              DEBUG_PRINT(i);
                                              DEBUG_PRINTLN(F(" Data..."));
                                              while (gw.process() == false)
                                                lcd.setCursor(15, 0);
                                                flashIcon = !flashIcon;
                                                gw.request(i, V_VAR1);
                                                delay(100);
                                                gw.request(i, V_VAR2);
                                                delay(100);
                                                gw.request(i, V_VAR3);
                                                delay(100);
                                          and this in loop():
                                          //goGetValveTimes();
                                          That will disable those callbacks and you should be OK with a HardCoded time table for the valves and valve names.
