  3. Sharing sketches between projects
21 Posts 5 Posters 10.1k Views 1 Watching
  • Z
    Z
    Zeph
    wrote on last edited by Zeph
    The so called "Arduino" language IS essentially C++.
    They do some preprocessing, so for example you don't have to predeclare your functions before you use them (they scan the file for functions and generate declarations for you, to be inserted before the C++ compiler see it). They also combine multiple .ino files together and a few other tweaks.
    In other words, if you can write sketches, you can write C++ with just a tiny bit more effort. Including making a library.
    Adapting some functions or classes that you include in your .ino file to be standalone libraries is usually very easy.
    And there is no need to learn the esoterica of C++ like templates (tho you can).
    • Z Zeph
      marceltrapmanM
      marceltrapmanM
      marceltrapman
      @Zeph Thanks, Guess I will have to put some energy in doing this...
      Fulltime Servoy Developer
        Yeah, a library is probably the easiest way of reuse code between your projects.
        • marceltrapmanM
          marceltrapmanM
          marceltrapman
          @HEK already working on it. Easier than I thought :)
            I have searched the internet but could not find any other answer than 'use a library' or 'copy files around'. So here is what I want:
            I would like to use the same code across different sketches.
            From what I understand using libraries means doing c++ which is not my main thing (Java, Servoy, Xojo, Objective C are).
            Ideally I would make one sketch. Add one or two methods that I want to use and share that sketch. Certainly while developing the methods this would be ideal.
            Possible?
            @marceltrapman If 90% of your code is identical between sensor sketches (e.g. all the MySensors stuff etc. etc) except for e.g. the code to read the sensor and send the value, a simple way could be to use #defines to conditionally compile code, e.g.
            // Compile your sketch this time with TEMP sensor, but no HUM sensor
            #define TEMP_SENSOR
            // #define HUM_SENSOR
              // ... Do all your normal stuff
              #ifdef TEMP_SENSOR
              gw.sendSensorPresentation(0, S_TEMP);
              #ifdef HUM_SENSOR
              // Not compiled in this run
              gw.sendSensorPresentation(0, S_HUM);
              // ... Again, all the regular stuff
              #ifdef TEMP_SENSOR
              gw.sendVariable(0, V_TEMP, readTemp() );
              #ifdef HUM_SENSOR
              gw.sendVariable(0, V_HUM, readHum() );
            Then, later on, when you compile your humidity sensor code, you only change the top #define's :
            // #define TEMP_SENSOR
            #define HUM_SENSOR
            Compile, flash and you've created a humidity sensor.
            • YveauxY Yveaux
              #define TEMP_SENSOR
                #ifdef TEMP_SENSOR
                #ifdef HUM_SENSOR
                #ifdef TEMP_SENSOR
                #ifdef HUM_SENSOR
              #define HUM_SENSOR
              marceltrapmanM
              marceltrapmanM
              marceltrapman
              @Yveaux Also a nice idea.
              I am not yet at a point that I know how much of my code is the same though.
              The only disadvantage I see is that it can get a bit cluttered/hard to read.
              Right now I opt for the library option.
              I have the work done already so it was not as hard as I thought :)
              The reason I wanted to do this is adding a battery check to some of my sketches.
              One simple constructor and a check method and I am good to go...
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @marceltrapman
                I like this idea and the existing MySensors library and the sketches we work with are relatively low overhead (memory usage). This means there is usually room for a bit extra...
                  @marceltrapman
                  marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  wrote on last edited by marceltrapman
                  Well, I have not yet optimised the code but I was a bit disappointed by how much overhead was added (forgot how much) but I was thinking about dropping the boot loader anyway.
                  Z 1 Reply Last reply
                    Z
                    Z
                    Zeph
                    Your library shouldn't add much overhead (and in general no more than incuding the code in each module).
                    Are you talking about the overhead of the Arduino core libraries, or the MySensors libraries, or the Arduino bootloader itself?
                    Arduino bootloaders are typically 512 bytes (Optiboot) to 2K bytes (older Arduino).
                    I think the APM may tend to use the larger boot loader. Does anybody know if it can use Optiboot or why not?
                    I think there may also be an issue with the boards.txt and the Arduino IDE; the "Arduino Pro Micro" entries may assume a large bootloader in any case (ie: reserve space for it in their memory layout). So even if one could load a 512 byte Optiboot, they might need to modify boards.txt as well. But this is a little outside my confident knowledge zone.
                    AND of course you may be going to ditch the serial bootloader entirely and program the full memory using the ICSP connector and an external programmer (instead of a USB to serial adapter) - 0K for the bootloader.
                    @moderator @marceltrapman This might be a good candidate for thread splitting - starting at the next post, there are some good messages about altering the bootloader.
                    • Z Zeph
                      Yes, it works very well! I compiled optiboot 5.0a to run at 76k8 baud, as I got problems with 115k2.
                      It's true that you need to add an entry to boards.txt, but that's not too hard.
                      When done, your new entry shows up in arduino and can be used just like any other target board.
                      Z 2 Replies Last reply
                      • YveauxY Yveaux
                        Z
                        Z
                        Zeph
                        Any tips on how to do this? (Do you have a favorite reference URL?)
                          Yes, optiboot should work fine. Uploads becomes faster and you can use watchdogs.
                          Just bought a couple of these ISPs to be able to change bootloader. Will probably add them to the shop.
                          AVR ISP programmer for Arduino bootloader
                          • Z Zeph
                            @Zeph Yeah, on my harddrive in Dutch...
                            I can give you a very short description on how I did it for Arduino Pro Mini, 3v3 @ 8MHz, though.
                            • Download https://code.google.com/p/optiboot/downloads/detail?name=optiboot-v5.0a.zip
                            • Extract to c:\Arduino_1.5.5\hardware\arduino\avr\ (rename existing optiboot dir, when required)
                            • Edit bootloaders\optiboot\Makefile to change baudrate (line 562)
                                atmega328_pro8:
                                	$(MAKE) $(CHIP) AVR_FREQ=8000000L LED_START_FLASHES=3 BAUD_RATE=76800
                            • Start cmd shell in c:\Arduino_1.5.5\hardware\arduino\avr\bootloaders\optiboot
                            • make clean
                            • make atmega328_pro8
                            • flash optiboot_atmega328_pro_8MHz.hex using your favourite ISP
                            • Fuses: Low = 0xFF, High = 0xDE, Extended = 0xFE
                            • Close any active Arduino windows.
                            • Edit c:\Arduino_1.5.5\hardware\arduino\avr\boards.txt
                            • Add (based on Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328):
                                ## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328 - Optiboot 76k8
                                pro.menu.cpu.8MHzatmega328ob=ATmega328 (3.3V, 8 MHz, Optiboot 76k8)
                                pro.menu.cpu.8MHzatmega328ob.upload.maximum_size=30720
                                pro.menu.cpu.8MHzatmega328ob.upload.maximum_data_size=2048
                                pro.menu.cpu.8MHzatmega328ob.upload.speed=76800
                                pro.menu.cpu.8MHzatmega328ob.bootloader.low_fuses=0xFF
                                pro.menu.cpu.8MHzatmega328ob.bootloader.high_fuses=0xDA
                                pro.menu.cpu.8MHzatmega328ob.bootloader.extended_fuses=0x05
                                pro.menu.cpu.8MHzatmega328ob.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                                pro.menu.cpu.8MHzatmega328ob.build.mcu=atmega328p
                                pro.menu.cpu.8MHzatmega328ob.build.f_cpu=8000000L
                            • Start Arduino IDE
                            • Select Board -> Arduino Pro or Pro Mini
                            • Select Processor -> ATmega328 (3.3V, 8 MHz, Optiboot 76k8)
                            • File->Upload
                            That's it :+1:
                            hekH Z 2 Replies Last reply
                            • YveauxY Yveaux
                                  atmega328_pro8:
                              • make clean
                              • Start Arduino IDE
                              • File->Upload
                              That's it :+1:
                              @Yveaux
                              Could you perhaps post this separately? Candidate for stickie.
                              • YveauxY Yveaux
                                    atmega328_pro8:
                                • make clean
                                • Start Arduino IDE
                                • File->Upload
                                That's it :+1:
                                Z
                                Z
                                Zeph
                                @Yveaux
                                Thanks! Very helpful.
                                There's something I've been considering for a while. I'd like a unique ID on each Arduino. A short number would be fine if I'm assigning my own.
                                My thought is that there seems to be a few unused bytes at the top of OptiBoot (not specified in the .hex, and remaining the unprogrammed FF value when read). I was thinking I could put my unique unit number there. Unlike eeprom or application flash, it would remain stable (until and unless I reflashed the boot flash). The fuses have to be programmed to make the boot flash readable by application code of course.
                                I was thinking to use about 3 bytes, with a 2 byte ID number and a checksum. The checksum doesn't have to be very robust, it's mainly just to confirm that there is indeed a unit ID there (would be all FF otherwise, or other values if fuses don't let you read it).
                                Then I could have a very tiny utility routine which allows me to ask a node which Arduino it's running on (the system corresponding to the ID would be described in a row of a Google spreadsheet so I don't misplace it)
                                I was thinking that this could be perhaps done by editing the.hex file before programming the bootloader (with some code, or by hand if neccessary - I don't have THAT many ardu's) There is a simple per row checksum in the .hex file, but I'm not aware of a overall checksum on the whole image to be adjusted.
                                How feasible / difficult does this sound? Any ideas on how to implement it?
                                • Z Zeph
                                  @Yveaux
                                  @Zeph sound feasible and useful.
                                  Google for hex file format (I know there are many variants so be careful) or tools to modify them.
                                  You could also just decode (or take the binary file generated by the linker) the hex file, change it and then convert to hex again.
                                    @Yveaux
                                    Moved it to my blog: http://yveaux.blogspot.nl/2014/07/changing-arduino-bootloader-to-optiboot.html
                                    • YveauxY Yveaux
                                      Z
                                      Z
                                      Zeph
                                      @Yveaux I was about to ask about using 31.5 KiB for application code with optiboot, but I'll put the comment on your blog instead.
                                      • YveauxY Yveaux
                                        Z
                                        Z
                                        Zeph
                                        That makes sense - 115k2 is kind of marginal anyway in terms of bit rate accuracy for async serial on the ATMega @16 MHz, and many Arduino Pro Micros have ceramic resonators with +/- 0.5% (vs more accurate crystals for the Uno). I see that 76k8 is actually a pretty good match even with an 8 MHz F_CPU. (0.2% error)
                                        I had not noticed that there was a good match for 76k8, so thanks for that indirect "tip" as well.
                                        • Z Zeph
                                          @Zeph Yeah, I know, but I didn't want to devote a whole article on baudrate calculation!
