  3. Sharing sketches between projects
21 Posts 5 Posters 10.1k Views 1 Watching
    @marceltrapman
    I like this idea and the existing MySensors library and the sketches we work with are relatively low overhead (memory usage). This means there is usually room for a bit extra...
    marceltrapmanM
    marceltrapmanM
    marceltrapman
    wrote on last edited by marceltrapman
    Well, I have not yet optimised the code but I was a bit disappointed by how much overhead was added (forgot how much) but I was thinking about dropping the boot loader anyway.
    Fulltime Servoy Developer
    Z 1 Reply Last reply
      Z
      Z
      Zeph
      wrote on last edited by Zeph
      Your library shouldn't add much overhead (and in general no more than incuding the code in each module).
      Are you talking about the overhead of the Arduino core libraries, or the MySensors libraries, or the Arduino bootloader itself?
      Arduino bootloaders are typically 512 bytes (Optiboot) to 2K bytes (older Arduino).
      I think the APM may tend to use the larger boot loader. Does anybody know if it can use Optiboot or why not?
      I think there may also be an issue with the boards.txt and the Arduino IDE; the "Arduino Pro Micro" entries may assume a large bootloader in any case (ie: reserve space for it in their memory layout). So even if one could load a 512 byte Optiboot, they might need to modify boards.txt as well. But this is a little outside my confident knowledge zone.
      AND of course you may be going to ditch the serial bootloader entirely and program the full memory using the ICSP connector and an external programmer (instead of a USB to serial adapter) - 0K for the bootloader.
      @moderator @marceltrapman This might be a good candidate for thread splitting - starting at the next post, there are some good messages about altering the bootloader.
      • Z Zeph
        Yes, it works very well! I compiled optiboot 5.0a to run at 76k8 baud, as I got problems with 115k2.
        It's true that you need to add an entry to boards.txt, but that's not too hard.
        When done, your new entry shows up in arduino and can be used just like any other target board.
        Z 2 Replies Last reply
        • YveauxY Yveaux
          Z
          Z
          Zeph
          Any tips on how to do this? (Do you have a favorite reference URL?)
            Yes, optiboot should work fine. Uploads becomes faster and you can use watchdogs.
            Just bought a couple of these ISPs to be able to change bootloader. Will probably add them to the shop.
            AVR ISP programmer for Arduino bootloader
            • Z Zeph
              @Zeph Yeah, on my harddrive in Dutch...
              I can give you a very short description on how I did it for Arduino Pro Mini, 3v3 @ 8MHz, though.
              • Download https://code.google.com/p/optiboot/downloads/detail?name=optiboot-v5.0a.zip
              • Extract to c:\Arduino_1.5.5\hardware\arduino\avr\ (rename existing optiboot dir, when required)
              • Edit bootloaders\optiboot\Makefile to change baudrate (line 562)
                  atmega328_pro8:
                  	$(MAKE) $(CHIP) AVR_FREQ=8000000L LED_START_FLASHES=3 BAUD_RATE=76800
              • Start cmd shell in c:\Arduino_1.5.5\hardware\arduino\avr\bootloaders\optiboot
              • make clean
              • make atmega328_pro8
              • flash optiboot_atmega328_pro_8MHz.hex using your favourite ISP
              • Fuses: Low = 0xFF, High = 0xDE, Extended = 0xFE
              • Close any active Arduino windows.
              • Edit c:\Arduino_1.5.5\hardware\arduino\avr\boards.txt
              • Add (based on Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328):
                  ## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328 - Optiboot 76k8
                  pro.menu.cpu.8MHzatmega328ob=ATmega328 (3.3V, 8 MHz, Optiboot 76k8)
                  pro.menu.cpu.8MHzatmega328ob.upload.maximum_size=30720
                  pro.menu.cpu.8MHzatmega328ob.upload.maximum_data_size=2048
                  pro.menu.cpu.8MHzatmega328ob.upload.speed=76800
                  pro.menu.cpu.8MHzatmega328ob.bootloader.low_fuses=0xFF
                  pro.menu.cpu.8MHzatmega328ob.bootloader.high_fuses=0xDA
                  pro.menu.cpu.8MHzatmega328ob.bootloader.extended_fuses=0x05
                  pro.menu.cpu.8MHzatmega328ob.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                  pro.menu.cpu.8MHzatmega328ob.build.mcu=atmega328p
                  pro.menu.cpu.8MHzatmega328ob.build.f_cpu=8000000L
              • Start Arduino IDE
              • Select Board -> Arduino Pro or Pro Mini
              • Select Processor -> ATmega328 (3.3V, 8 MHz, Optiboot 76k8)
              • File->Upload
              That's it :+1:
              hekH Z 2 Replies Last reply
              • YveauxY Yveaux
                    atmega328_pro8:
                • make clean
                • Start Arduino IDE
                • File->Upload
                That's it :+1:
                @Yveaux
                Could you perhaps post this separately? Candidate for stickie.
                • YveauxY Yveaux
                      atmega328_pro8:
                  • make clean
                  • Start Arduino IDE
                  • File->Upload
                  That's it :+1:
                  Z
                  Z
                  Zeph
                  @Yveaux
                  Thanks! Very helpful.
                  There's something I've been considering for a while. I'd like a unique ID on each Arduino. A short number would be fine if I'm assigning my own.
                  My thought is that there seems to be a few unused bytes at the top of OptiBoot (not specified in the .hex, and remaining the unprogrammed FF value when read). I was thinking I could put my unique unit number there. Unlike eeprom or application flash, it would remain stable (until and unless I reflashed the boot flash). The fuses have to be programmed to make the boot flash readable by application code of course.
                  I was thinking to use about 3 bytes, with a 2 byte ID number and a checksum. The checksum doesn't have to be very robust, it's mainly just to confirm that there is indeed a unit ID there (would be all FF otherwise, or other values if fuses don't let you read it).
                  Then I could have a very tiny utility routine which allows me to ask a node which Arduino it's running on (the system corresponding to the ID would be described in a row of a Google spreadsheet so I don't misplace it)
                  I was thinking that this could be perhaps done by editing the.hex file before programming the bootloader (with some code, or by hand if neccessary - I don't have THAT many ardu's) There is a simple per row checksum in the .hex file, but I'm not aware of a overall checksum on the whole image to be adjusted.
                  How feasible / difficult does this sound? Any ideas on how to implement it?
                  • Z Zeph
                    @Yveaux
                    @Zeph sound feasible and useful.
                    Google for hex file format (I know there are many variants so be careful) or tools to modify them.
                    You could also just decode (or take the binary file generated by the linker) the hex file, change it and then convert to hex again.
                      @Yveaux
                      Moved it to my blog: http://yveaux.blogspot.nl/2014/07/changing-arduino-bootloader-to-optiboot.html
                      • YveauxY Yveaux
                        Z
                        Z
                        Zeph
                        @Yveaux I was about to ask about using 31.5 KiB for application code with optiboot, but I'll put the comment on your blog instead.
                        • YveauxY Yveaux
                          Z
                          Z
                          Zeph
                          That makes sense - 115k2 is kind of marginal anyway in terms of bit rate accuracy for async serial on the ATMega @16 MHz, and many Arduino Pro Micros have ceramic resonators with +/- 0.5% (vs more accurate crystals for the Uno). I see that 76k8 is actually a pretty good match even with an 8 MHz F_CPU. (0.2% error)
                          I had not noticed that there was a good match for 76k8, so thanks for that indirect "tip" as well.
                          • Z Zeph
                            @Zeph Yeah, I know, but I didn't want to devote a whole article on baudrate calculation!
