  3. $8 Lamp (Outlet) "Smart Plug" Module
109 Posts 34 Posters 121.1k Views 13 Watching
  • sundberg84S
    sundberg84S
    #67
    @petewill
    Now i got three working relays thanks to you, so again, great video!
    Wanted to thank you and also show my sollution.
    I hade some 433mhz cheap (not good working) relays with perfect case i could re-use:
    The case had a status-led and a switch i use as well.
    petewillP m26872M D 3 Replies Last reply
    • sundberg84S sundberg84
      @petewill
      petewillP
      petewillP
      petewill
      @sundberg84 Cool! That's nice to have a case like that.
        @petewill
        m26872M
        m26872M
        m26872
        wrote on last edited by m26872
        #69
        @sundberg84
        Nice! That one deserves its own project thread. I think we're many interested in the details.
        • Ivan ZI
          Ivan ZI
          Ivan Z
          This is may realisation
          • petewillP petewill
            @hyla I actually recently did a separate video on how I do this with a little more explanation. If you're interested it's here:
            https://youtu.be/NpMnauHeR7Y
            In summary, I measured the length of the existing antenna on the PCB then added additional wire to get it up to the required length for the 2.4GHz range (4.92 in).
            barduinoB
            barduinoB
            barduino
            Hi @petewill
            I've tried this and had inconclusive results rather then a significant extended rage. Not sure what I'm doing wrong or if it's the quality of my RF module.
            I've used some wire (8.33 cm) I had left over but its not one solid copper wire, its has many "strings" inside. In your experiment did you use one solid copper wire and can this influence this hack?
            petewillP 1 Reply Last reply
            • barduinoB barduino
              Hi @petewill
              petewillP
              petewillP
              petewill
              @barduino I am using solid copper cat5e wire. I don't know much about antennas but it may change the behavior. Do you have any old cat5 that you can cut and test with?
              barduinoB 1 Reply Last reply
                barduinoB
                barduinoB
                barduino
                @petewill
                I'm going to try it.
                I'm also using a capacitor on the RF module, not sure if you did combine both techniques.
                On a last note, I've noticed some power setting on the MyConfig.h (1.5 lib) cant remember the values form 1.4.1
                *  NRF24L01 Driver Defaults
                #define RF24_CE_PIN		   9
                #define RF24_CS_PIN		   10
                So now I'm initializing the gatweway as
                // Instanciate MySersors Gateway
                MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL);
                instead of
                Not sure if there is a significant diference here...
                The results i'm getting now (after removing the antena, but with capacitor and changes on 1.5 MyConfig) are similar to the results I got from lib 1.4.1 with capacitor. I have a repeater about 15 meters from gateway and if i put it 17 meters it doesnt work anymore (there are some walls on the way)
                I'll just add a solid copper antena to see if results change.
                Thanks for the info!
                  @petewill
                  instead of
                  petewillP
                  petewillP
                  petewill
                  @barduino Yes, I always use a capacitor to filter power to my radio. I recently have been using 3.3v Pro Mini Arduinos so I have just been putting a 4.7uf cap very close to the radio.
                  As far as I know the RF24_PA_LEVEL_GW is only used for the gateway. You can change the power level in the config file for the sensors but it looks like you already had it at the MAX. You can play with the power level depending on your radio model used with the gateway. On my gateway I experimented with an external antenna type radio and if it was set on max it completely wrecked my z-wave communication (there must have been interference like crazy since they are different frequencies). If you are using the PCB type antenna you can probably increase the power level to max without any issues. It's been a while since I did anything with my gateway (it's been working great for months) so I don't remember what settings I'm using. I do know I have the antenna hacked radio instead of the external antenna.
                  • Z
                    Z
                    Zeph
                    wrote on last edited by Zeph
                    #75
                    One thing to note is that adding an external antenna extension to the on-PCB antenna moves this into the realm of "RF magic". What I mean is that it becomes a very non-standard sort of hybrid antenna about which we can predict very little. Like receiving television with rabbit ears and aluminum foil, you will mostly have to work by trial and error rather than exact calculations.
                    The on-PCB antenna should already be tuned for the RF wavelength, probably near the middle of the band. We can also calculate the appropriate length for a straight wire used INSTEAD OF the on-PCB. But when we solder a wire onto the PCB antenna, we wind up with a very complex antenna which may or may not work very well (but in general it's far easier to make a random antenna work poorly than to make it work well). There are questions of antenna gain (or attenuation), but also of directionality - adding the wire might make it transmit/receive better in some directions and worse in other directions!
                    Part of my point is that we cannot necessarily predict the best length of wire to solder to the on-PCB antenna by using the calculations that would apply with no PCB antenna. It may depend where on the PCB antenna trace you solder the extra wire, and perhaps on how the wire gets bent (especially if it comes near electrical conductors).
                    So after you have the node placed where you want it (including the orientation), you can try moving the added antenna around in the case for better reception - and you can also try changing the wire length because 8.33 cm is not necessarily optimal for this hybrid antenna. Of course it's easier to shorten a wire by just successively chopping off a little bit at a time; you can solder in a new wire if need be.
                    The length does not have to be super precise by the way - a loose wire antenna is not a highly tuned (Hi-Q) antenna and a slightly suboptimal length doesn't dramatically alter the results. Which is good, since the modules operate over a range of frequencies - and because even without the PCB antenna to really complicate things, even the PCB trace between the chip and the wire is part of the tuning as well, not just the bendable wire.
                    Stranded wire vs solid should not have a large effect, compared to the many other factors involved here.
                    • TheoLT
                      TheoLT
                      TheoL
                      Hi Pete,
                      I'm new to this forum, but I wanted to give you a big thumbs up. I really enjoyed watching your videos and I learned a lot from watching them. It's because of people like you that made me decide to start using MySensors.
                      I have an old 433Mhx power plug that is broken. I see if I can turn it in to a MySensors power plug ;)
                      • petewillP
                        petewillP
                        petewill
                        @Zeph I agree. This is complicated stuff that I don't even begin to grasp. That said it is a cheap and easy hack to try. In my case it has helped every time. Maybe I just got lucky but it helped enough of my nodes that I thought I'd at least tell people about it. If it doesn't work, then just remove the wire and no harm done. Thanks for all your contributions to the site. Your knowledge is helping a lot of people.
                        @TheoL Thanks for the kind words! Although, credit really goes to @hek and the team. They are the geniuses that make this all work! Good luck with "mysensoring" the old power plug. But, be careful, it's addicting. :)
                        TheoLT 1 Reply Last reply
                        • Z
                          Z
                          Zeph
                          #78
                          @petewill just to be clear - I appreciate your posting that adding the loose wire to the on-PCB antenna helped, and I'm not discouraging that. If it works, it works! Mostly I wanted people to understand that it's going to be trial and error, rather than something where they can count on calculating the best length (because it's added to another antenna at an unanticipated point, rather than being a standalone wire antenna). It would not surprise me if somebody found that a 6.5 cm wire worked better than 8.33cm, for their particular case (picking an example length at random). Wiggle those rabbit ears!
                          I love the examples you post and your excellent videos. I have modestly good knowledge here and there, with gaps in other places, and your working examples give me confidence/inspiration to build something I haven't before - along with practical (not just theoretical) advice. You even turn your minor mistakes into lessons - how it should have been done, and how you managed to work around it anyway. Keep them coming!
                          • Z Zeph
                            petewillP
                            petewillP
                            petewill
                            I agree. The more knowledge provided to people the better hopefully it will result in better communicating nodes. Thanks for the posts!
                              TheoLT
                              TheoLT
                              TheoL
                              @petewill Off course I'm very gratefull for what @hek and the team created. I've been playing with mySensors for a week now. And I'm still amazed by it. It's so easy to use. And I haven't had a failure yet. I'm currently promoting MySensors to everyone I know ;-).
                              @hek Do you happen to have some small stickers with the MySensors logo? Ik would love to put them on the sensors I create. Something like "Powered by MySensors"?
                                Good idea. But currently not something we have.
                                • Z
                                  Z
                                  Zeph
                                  I like the idea of logo stickers. Better in some ways than typical swag like t-shirts and coffee cups, because if it goes on the devices we build that provides useful information, not just advertising. Maybe leave a blank section where a node number could optionally be written in with a sharpie, or a version.
                                  Maybe "Networked by MySensors.org" rather than powered? ("Telepathy by MySensors"?)
                                  • Z Zeph
                                    TheoLT
                                    TheoLT
                                    TheoL
                                    @Zeph How about Wired by MySensors ;) Because my experience is that it seems like all sensors and the gateway are wired together because of MySensors.
                                      Dome Stickers would be nice ;)
                                      http://www.aliexpress.com/item/Custom-Made-with-Your-design-Clear-Dome-Resin-Sticker-Epoxy-Stickers-Label-1000pcs-free-shipping/1875126113.html?spm=2114.031010208.3.1.zlyb2B
                                      Just wonder how we should make them cost-effective to buy for the community...
                                        TheoLT
                                        TheoLT
                                        TheoL
                                        @hek they look good to me! Maybe you can start a poll on this forum. Ask the members who would like to buy the stickers. If the majority wants them, we can order them.
                                        • Z
                                          Z
                                          Zeph
                                          The domes are kind of cool for some things, but I think for this purpose I'd actually prefer flat stickers that fit smoothly on any side of a project box, even curved, without protruding and looking like something that should be pressed, or that should light up.
                                          (OTOH domes atop an illuminated button (assuming translucent backing) would be awesome in some cases)
                                          And with flat, (re) distribution in small batches is easier - one could get a lot of them in a minimum-postage conventional letter.
