  3. Windows GUI/Controller for MySensors
myscontrollermysbootloader
486 Posts 101 Posters 515.2k Views 73 Watching
  • FrancoisF
    FrancoisF
    Francois
    @tekka do MYSBootloader also work with the RFM69 radios?
    tekkaT 1 Reply Last reply
    • rvendrameR rvendrame
      EDIT: @tekka, @scalz , after so many tries, I don't know why I decided to replace the nRF radio , and guess what?
      Funny thing is that the previous radio is working with regular bootloader. Dam fake chips! But I will sort it out later, now I want to play with my OTA ;-)
      Thanks a lot!
      tekkaT
      tekkaT
      tekka
      @rvendrame excellent :)
      • FrancoisF Francois
        tekkaT
        tekkaT
        tekka
        @Francois No, in it's current stage only nRF24L01+, but porting to RFM69 should not be too difficult...
        • 5546dug5
          5546dug5
          5546dug
          @tekka silly ?
          But still last night changed from serial to Ethernet gw using iboard wiz5100 and the h/w changes.
          No issues but for later problems do I ---use myscontroller by way of FTDI connector>usb or
          -- continue to plug the original serial gw into laptop leaving Ethernet still in use ( plugged in).
          • 5546dug5 5546dug
            @tekka silly ?
            tekkaT
            tekkaT
            tekka
            @5546dug said:
            @tekka silly ?
            I'm not quite sure I understand your question. Are you having issues with the EthernetGW?
            • 5546dug5
              5546dug5
              5546dug
              @tekka No everything is ok now but there will be problems in the future to sort out if history repeats itself.
              So it is just a learning question for troubleshooting later.
              To "see" Ethernet gw in your gui use FDTI>usb>laptop (with gw still connected to the router) or use the serial gw I had from before connected remotely to laptop via usb..
              As of now I use only Ethernet gw plugged into router and the serial gw is no longer plugged into my vera.
              • C cdr
                @tekka I feel really, really, REALLY stupid;
                I changed the channel in the mysensors config.h to 77, this was the reason no node would ever show up since the default mysbootloader uses the default channel 76.
                D'OH
                Thanks for your patience and help, everything is working now and I'm really happy!
                :+1:
                N
                N
                NewFolk
                D'OH
                :+1:
                @tekka is there a way to change the default channel in MYSbootloader ?
                • P
                  P
                  Pendragon
                  What ware the designed values for "type" in the fimware_config.csv?
                  Can I use this variable for my sensor IDs?
                  • rvendrameR
                    rvendrameR
                    rvendrame
                    @tekka, I've being playing with MYSController and MYSBootloader over last days, I'm totally amazed by them ;-) Thank you so much for developing such nice tool!
                    If you allow me, I have only one ask for the santa-claus list: Perhaps it is possible for MYSBootloader capture serial output from a node, allowing OTA Serial monitor via MYSController? I know you guys are doing a miracle within 2KB, but who knows...
                    Again, thanks a lot!
                    ESP8266 GW + mySensors 2.3.2
                    Alexa / Google Home
                    • N NewFolk
                      D'OH
                      :+1:
                      tekkaT
                      tekkaT
                      tekka
                      Yes, but for that you'll have to re-compile it.
                      N 1 Reply Last reply
                      • P Pendragon
                        tekkaT
                        tekkaT
                        tekka
                        Yes, but this is only an internal reference and not being used for AutoFW assignment
                          #198
                          This sounds like a great app! What is the current status? I clicked on the link in the OP expecting it would connect with GitHub (where there might be a ReadMe.txt which tells what the current status is), but instad of that it just downloaded the app right then and there! There are now 197 posts on this thread, which is a bit many to sort through to find the status....
                          Move it to Github?
                            tekkaT
                            tekkaT
                            tekka
                            Thanks, I'm glad you like the tools. :)
                            Unfortunately your suggestion is not possible: bootloader and sketch run sequentially, not in parallel, and thus, cannot communicate with each other.
                              Move it to Github?
                              tekkaT
                              tekkaT
                              tekka
                              @NeverDie said:
                              This sounds like a great app! What is the current status? I clicked on the link in the OP expecting it would connect with GitHub (where there might be a ReadMe.txt which tells what the current status is), but instad of that it just downloaded the app right then and there! There are 197 posts on this thread, which is a bit many to sort through to find the status....
                              Move it to Github?
                              The first post is updated once a new version is released :)
                              • tekkaT tekka
                                Move it to Github?
                                #201
                                @tekka said:
                                Move it to Github?
                                So then, as far as status goes, based on the version number, I guess it's still an unstable alpha release? Am I reading between the lines correctly?
                                I did download it, and I can see that the files are from 7/25/2015, but there's no readme or other indication as to its status.
                                I imagine others probably have the same question....
                                  @tekka said:
                                  Move it to Github?
                                  tekkaT
                                  tekkaT
                                  tekka
                                  @NeverDie No, just never felt to change the major version number...I'll add it to the feature requests :)
                                  • rvendrameR
                                    rvendrameR
                                    rvendrame
                                    Maybe by re-implementing serial.print methods, in order to first checking which FW is installed, and if MYSBootloader, re-direct the output to a internal radio message? Just brainstorming....
                                    Alexa / Google Home
                                    • tekkaT tekka
                                      N
                                      N
                                      NewFolk
                                      @tekka
                                      Could you help me to find where to change channel? It is in MYSBootloaderHW.h ?
                                      • P
                                        P
                                        Pendragon
                                        Du you all connect the controller direct to the gateway?
                                        I have a serial gateway which is connected directly to a raspberry running domoticz. I can rum ser2net and then connect the MYSController via ethernet. While ser2net is running, domoticz does not get any data from the gateway.
                                        Has anyone found a solution to use both, MYSController and a controller software (e.g. domoticz) in parallel?
                                        • N NewFolk
                                          @tekka
                                          tekkaT
                                          tekkaT
                                          tekka
                                          No, it's defined in MyConfig.h (see here)
