  3. Parking Sensor
Parking Sensor
74 Posts 28 Posters 56.2k Views 18 Watching
  • Sander StolkS
    Sander StolkS
    Sander Stolk
    Awesome project but will the led always be on when your car is parked?
    Or is there a timeout after the measurement to switch it of?
    hekH 1 Reply Last reply
    • Sander StolkS Sander Stolk
      @Sander-Stolk
      Ha, yes, didn't think of that little detail.
      Guess you could add a timeout which turns off the leds after a minute when "parked".
      • Lawrence HelmL
        Lawrence HelmL
        Lawrence Helm
        @hek About to make this sensor, very cool! I had already brought a 12v traffic light before I saw this, so now ordered an LED ring, as that makes a lot more sense getting closer to the target area. But could you help out regarding the implementation of the timeout, as I'm pretty terrible at programing :)
        C 1 Reply Last reply
        • R
          R
          ramarro
          Super :+1: :clap:
          • T
            the_iman
            Great! This will be my first project with Arduino!
            Could you, please, post the wiring schematics.
              http://www.mysensors.org/build/parking
              • Lawrence HelmL Lawrence Helm
                C
                C
                chilump
                @hek Great Job. Just wondering if you could point us to instructions on to add the time out feature.
                  My rig is disassembled now.
                  You could add timeout like this (please feedback if it works so I can check it into github):
                   * Version 1.0 - Created by Henrik Ekblad
                   * Parking sensor using a neopixel led ring and distance sensor (HC-SR04).
                   * Configure the digital pins used for distance sensor and neopixels below.
                   * NOTE! Remeber to feed leds and distance sensor serparatly from your Arduino.
                   * It will probably not survive feeding more than a couple of LEDs. You
                   * can also adjust intesity below to reduce the power requirements.
                   * Sends parking status to the controller as a DOOR sensor if SEND_STATUS_TO_CONTROLLER
                   * is defined below. You can also use this _standalone_ without any radio by
                   * removing the SEND_STATUS_TO_CONTROLLER define.
                  #define SEND_STATUS_TO_CONTROLLER  // Put a comment on this line for standalone mode
                  #include <Adafruit_NeoPixel.h>
                  #include <NewPing.h>
                  #ifdef SEND_STATUS_TO_CONTROLLER
                  #define NEO_PIN      4 // NeoPixels input pin
                  #define TRIGGER_PIN  6  // Arduino pin tied to trigger pin on the ultrasonic sensor.
                  #define ECHO_PIN     5  // Arduino pin tied to echo pin on the ultrasonic sensor.
                  #define NUMPIXELS      24 // Number of nexpixels in ring/strip
                  #define MAX_INTESITY   20  // Intesity of leds (in percentage). Remeber more intesity requires more power.
                  // The maximum rated measuring range for the HC-SR04 is about 400-500cm.
                  #define MAX_DISTANCE 100 // Max distance we want to start indicating green (in cm)
                  #define PANIC_DISTANCE 5 // Mix distance we red warning indication should be active (in cm)
                  #define PARKED_DISTANCE 20 // Distance when "parked signal" should be sent to controller (in cm)
                  #define PARK_OFF_TIMEOUT 20000 // Number of milliseconds until turning off light when parked.
                  // Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
                  // example for more information on possible values.
                  Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, NEO_PIN, NEO_GRB + NEO_KHZ400);
                  NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
                  #define CHILD_ID 1
                  unsigned long sendInterval = 5000;  // Send park status at maximum every 5 second.
                  unsigned long lastSend;
                  int oldParkedStatus=-1;
                  unsigned long blinkInterval = 100; // blink interval (milliseconds)
                  unsigned long lastBlinkPeriod;
                  bool blinkColor = true;
                  // To make a fading motion on the led ring/tape we only move one pixel/distDebounce time
                  unsigned long distDebounce = 30;
                  unsigned long lastDebouncePeriod;
                  int numLightPixels=0;
                  int skipZero=0;
                    Serial.println("Starting distance sensor");
                    pixels.begin(); // This initializes the NeoPixel library.
                    Serial.println("Neopixels initialized");
                    gw.begin();
                    gw.sendSketchInfo("Parking Sensor", "1.0");
                    gw.present(CHILD_ID, S_DOOR, "Parking Status");
                    unsigned long now = millis();
                    int fullDist = sonar.ping_cm();
                  //  Serial.println(fullDist);
                    int displayDist = min(fullDist, MAX_DISTANCE);
                    if (displayDist == 0 && skipZero<10) {
                      // Try to filter zero readings
                      skipZero++;
                      return;
                    // Check if it is time to alter the leds
                    if (now-lastDebouncePeriod > distDebounce) {
                      lastDebouncePeriod = now;
                      // Update parked status
                      int parked = displayDist != 0 && displayDist<PARKED_DISTANCE;
                      if (parked != oldParkedStatus && now-lastSend > sendInterval) {
                        if (parked)
                          Serial.println("Car Parked");
                          Serial.println("Car Gone");
                        gw.send(msg.set(parked));
                        oldParkedStatus = parked;
                        lastSend = now;
                      if (parked && now-lastSend > PARK_OFF_TIMEOUT) {
                        // We've been parked for a while now. Turn off all pixels
                        for(int i=0;i<NUMPIXELS;i++){
                          pixels.setPixelColor(i, pixels.Color(0,0,0));
                        if (displayDist == 0) {
                          // No reading from sensor, assume no object found
                          numLightPixels--;
                          skipZero = 0;
                          int newLightPixels = NUMPIXELS - (NUMPIXELS*(displayDist-PANIC_DISTANCE)/MAX_DISTANCE);
                          if (newLightPixels>numLightPixels) {
                            // Fast raise
                            numLightPixels += max((newLightPixels - numLightPixels) / 2, 1);
                          } else if (newLightPixels<numLightPixels) {
                            // Slow decent
                            numLightPixels--;
                        if (numLightPixels>=NUMPIXELS) {
                          // Do some intense red blinking
                          if (now-lastBlinkPeriod > blinkInterval) {
                            blinkColor = !blinkColor;
                            lastBlinkPeriod = now;
                          for(int i=0;i<numLightPixels;i++){
                            pixels.setPixelColor(i, pixels.Color(blinkColor?255*MAX_INTESITY/100:0,0,0));
                            int r = 255 * i/NUMPIXELS;
                            int g = 255 - r;
                            // pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
                            pixels.setPixelColor(i, pixels.Color(r*MAX_INTESITY/100,g*MAX_INTESITY/100,0));
                          // Turn off the rest
                          for(int i=numLightPixels;i<NUMPIXELS;i++){
                      pixels.show(); // This sends the updated pixel color to the hardware.
                  Dan S.D 1 Reply Last reply
                  • C
                    C
                    chilump
                    Definitely, thanks
                    • Andy PepA
                      Andy PepA
                      Andy Pep
                      change the code a little bit and bingo you just made a light thermin .. cool for wearables :)
                        #define CHILD_ID 1
                        int skipZero=0;
                          gw.begin();
                            skipZero++;
                            return;
                              if (parked)
                              lastSend = now;
                                numLightPixels--;
                                skipZero = 0;
                                  // Fast raise
                                  // Slow decent
                                  numLightPixels--;
                                  int g = 255 - r;
                        Dan S.D
                        Dan S.D
                        Dan S.
                        @hek Received my LED ring in the mail over the weekend. Hooked it up and ran your code. Everything looks to be working great, including the timeout code. Now need to mount and test under real world conditions, i.e,. in the garage with the car. Has anyone done that yet?
                        M TD22057T C 3 Replies Last reply
                          Thanks for the feedback, pushed the timeout changes it to github now.
                          • Dan S.D Dan S.
                            msebbe
                            wrote on last edited by msebbe
                            #22
                            @Dan-S. I am going to do this but with a rgb led strip instead of a ring.
                            • Dan S.D Dan S.
                              TD22057T
                              TD22057T
                              TD22057
                              Not yet, but I've got plans, big plans :) - I'm working on a leak detector now but when that board is done, I'm going to build an "ultimate garage" PCB that will have the the parking LED, distance sensor, temp/humidity, garage door location sensors, garage door open/close relay, and will automatically close the garage door after a timeout unless a button is pressed.
                              Here's the way I think about the parking problem: the car moves through 3 different areas: 1) entering garage (not safe), 2) safe to park (far enough in, but not too far), 3) danger - too far. But how do you know what sensor values those correspond to? Especially since mounting the sensor in different areas, at different angles, and with different vehicles will change those values. So if you hold down a button on the sensor, it puts it into config mode. Move the car to the start of the safe area, and push the button to record that sensor reading. Then move the car to the end of the safe parking area and push the button again to record that sensor reading. Then have the software dynamically update the LED ranges to respond to those sensors. Something like: in area 1), illuminate more and more LED's as the car moves through the area. When the car hits area 2), flash the ring green 3 times, then fully illuminate all LED's in green. As the car moves through area 2), decrease the number of LED's illuminated until it hits area 3) where all the LED's flash red.
                              • Dan S.D Dan S.
                                C
                                C
                                chilump
                                @Dan-S. Would you mind providing a little detail on your build? I'm totally new and having problems trying to figure out a few things
                                Do I need a capacitor? If so will 22uf do and where do I hook it up.
                                I really just looking for a few detailed pics so I can hook things up correctly
                                hekH Dan S.D 2 Replies Last reply
                                • F
                                  F
                                  FreakOfNature
                                  My brother just bought a house and I am going to sucker him into taking up this project by building this for him. I want to add some gas sensors and would like advice on best ones to add. I want to monitor CO, LPG, Butane, and fumes you would get off regular old automotive gas.
                                  • C chilump
                                    @chilump
                                    Yes, a cap on the led ring won't hurt. I soldered mine directly on the ring between GND/VCC. 22uF is probably fine.
                                    • C chilump
                                      Dan S.D
                                      Dan S.D
                                      Dan S.
                                      @chilump I am moving from the prototype setup to the garage setup. The first picture shows the LED ring connections. I used solid copper wire because it facilitated what I wanted to do. I squeezed the ends of the wire to flatten them and bent them 90 degrees to make it a bit easier to solder to the solder pads on the led ring. The pads are marked D1,5V,GND and D0. D0 is not used in this application. These are the most difficult connections to make.
                                      Connections.jpg ```
                                      I mounted the ring on a square piece of 1/4 in particle board, drilling holes to feed the wires through. It only has a primer coat on it in the picture.
                                      I will connect a 100uf between the 5v and ground connectors behind the board so it cannot be seen and then mount it on the garage wall.
                                      Hek's 22uf recommendation is probably good enough, but in reading about led ring applications an the internet 100uf was recommended for Adafruit neopixel rings. How much you need is dependent on the led intensity and how rapidly the signal will be changing--for this case 22uf should be ok.
                                      I put the distance sensor in one of the standard cases.
                                      As far as wiring to the Arduino is concerned Hek spells all that out on the mysensor home page if you click on parking sensor. DI of the led ring goes to D4 on Arduino, Trig and echo of the distance sensor got to D6 and D5 of the Arduino respectively. Don't wire the led 5V to the Arduino. It should come directly from the power supply since when the leds are full on they can consume more power than the Arduino can supply. I plugged the Vcc and grnd connections from the distance sensor directly into the Ardouino's pins that were so marked. To be on the safe side I plan on using a 5V 2A DC power supply for this application. All grounds must be common.
                                      C 2 Replies Last reply
                                      • Dan S.D Dan S.
                                        Connections.jpg ```
                                        C
                                        C
                                        chilump
                                        @Dan-S. Thank you very much for taking the time to take pics and write up your project! Can't wait to get home to try.
                                        Thanks!!!!
                                        @hek Thanks for the info on 22uf and thanks for thinking up this project. Great tool for me and my kids.
                                        • Dan S.D Dan S.
                                          Connections.jpg ```
                                          C
                                          C
                                          chilump
                                          @Dan-S. Can a single 5v 2a adapter be used? In that case would everything be wired to the single power adapter?
                                          Dan S.D mjbokM 2 Replies Last reply
