  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 590.3k Views 69 Watching
  • M mvdarend
    @rvendrame said:
    Some more thoughts from the guy who analyzed it:
    "Hi Ricardo
    *It looks safe enough to me, except I want a fuse or fusible resistor before it. The purpose of the fuse is to blow when the module is worn down and maybe shorts.
    Would something like this be OK?
    http://www.aliexpress.com/store/product/100pcs-LOT-PTC-Resettable-Fuses-TRF250-080-250V-0-08A-80MA-PPTC-Polymeric-PTC-PolySwitch-DIP/1653204_32267664975.html
    rvendrameR
    rvendrameR
    rvendrame
    @mvdarend , I don't have experience to evaluate that. These ones are current-driven, I think it would be nice some fuse that is temperature-driven (despite I don't know even if that exist or what would be the parameters for that...)
    ESP8266 GW + mySensors 2.3.2
    Alexa / Google Home
    • Z Zeph
      The wiring is easy to describe.
      Put a fuse in line between the "hot" mains AC input and the power supply module input (the "neutral" can go directly to the power supply). Put a MOV across the power supply input (on the PS side of the fuse).
      For small spikes, the MOV would protect the PS by absorbing most of it. For longer surges, the MOV would cause the fuse to blow, probably sacrificing itself in the process.
      Maybe others can help with component selection (for 120v and 240v mains). I see that in the case of Littelfuse, the fuse is rated by RMS AC voltage, so a 140v MOV would work for a nominal 120VAC mains). http://www.littelfuse.com/~/media/electronics_technical/application_notes/varistors/littelfuse_selecting_a_littelfuse_varistor_application_note.pdf
      I don't know if RMS rating is standard, or if some are rated by their DC voltage conduction threshold, but one would want to be sure of that for the brand they are getting.
      petewillP
      petewillP
      petewill
      @Zeph Thanks.
      Do you all think a 150v MOV is ok for USA? I found some cheaper than the 140v on ebay but I' like to do it right :)
      http://www.ebay.com/itm/LOT-of-10-MAIDA-METAL-OXIDE-VARISTOR-RADIAL-MOV-8mm-Disk-150V-D68ZOV151RA03-/390095815756?hash=item5ad385c44c
      I found these fuses but they are 250v. Do you think that would be OK for 120v normal power or do I need to find 150v fuses?
      http://www.ebay.com/itm/Through-Hole-T5A-5A-250V-Radial-Leads-Miniature-Micro-Fuse-20-Pcs-SP-/181623867749?hash=item2a49a04965
      Something like this for the temperature fuse?
      http://www.ebay.com/itm/3-pcs-New-KSD-9700-70-C-250V-5A-Thermostat-Temperature-BiMetal-Switch-NC-Close-/141752004726?hash=item210113f076
      Is there anything else I'm missing that should be included in the circuit? Like others, I was also thinking that adding a temp sensor to the Arduino would be good so I could tell how hot it is in the box at any time.
      • rvendrameR
        rvendrameR
        rvendrame
        wrote on last edited by rvendrame
        #220
        More from the 'guru'
        "There is no input fuse, that is the reason I recommend one and it has to be a real fuse that blows, not a fuse that will automatic recover. The only time it is supposed to blow is if the converter blows and then you want the mains permanently disconnected. Probably a 0.2A slow fuse will work."
        Alexa / Google Home
        • rvendrameR rvendrame
          mvdarend
          @rvendrame Thanks for the clarification.
          • Z
            Z
            Zeph
            And a 250VAC fuse is fine to use on 120VAC (and in fact quite common).
            • petewillP
              petewillP
              petewill
              Ok, how does this look for parts?
              70 degree (Celsius) fuses - http://www.ebay.com/itm/10pcs-Thermal-Cutoffs-SEFUSE-Microtemp-Thermal-TF-Cutoff-NEC-Fuses-73-C-240-C-/221560426284?var=&hash=item339607cf2c
              .75A fuse - They are fast blow not slow like specified above. Does that matter?? http://www.ebay.com/itm/40Pcs-ELECTRIC-FUSE-FAST-BLOW-0-75A-250VAC-35A-IR-THROUGH-HOLE-/271902224922?hash=item3f4ea2b21a
              Same MOVs http://www.ebay.com/itm/LOT-of-10-MAIDA-METAL-OXIDE-VARISTOR-RADIAL-MOV-8mm-Disk-150V-D68ZOV151RA03-/390095815756?hash=item5ad385c44c
              Is there anything else I'm missing? The goal with all this is to make another "how to" video so I want to make sure I'm not giving people bad advice.
              So, it would look something like this (ignore power to radio, didn't have time to wire it):
              • rvendrameR
                rvendrameR
                rvendrame
                @petewill . the MOV goes in parallel with HLK input (and not in series like you did).
                It was suggested to use .2A fuses (instead the .75A). And the Thermal fuse should be glued on HLK top (my guess).
                Alexa / Google Home
                • petewillP
                  petewillP
                  petewill
                  Dang, totally forgot about all that in my rush to finish the diagram before lunch ended... That's why you guys design the electronics and I make the videos ;)
                  How necessary are the .2A fuses? I couldn't find any on ebay at a reasonable price. Is the goal of this fuse to prevent large surges (like lightning) from hitting the MOV, or something else? If it's to prevent large surges would the .75A work ok?
                  Also, I was able to find cheaper varistors. I'm thinking 150VAC should work ok because the HLK is designed to handle 240VAC but maybe I'm off on that?
                  http://www.ebay.com/itm/5-x-Zinc-Oxide-Varistor-150VAC-15J-1200A-7mm-FREE-SHIPPING-/321024816822?hash=item4abe91f6b6
                  How does this look?
                  SparkmanS 2 Replies Last reply
                  • petewillP petewill
                    How does this look?
                    SparkmanS
                    SparkmanS
                    Sparkman
                    wrote on last edited by Sparkman
                    #226
                    As long as you only feed it with 120VAC, there's no issue with that. For those that will feed it with 240VAC, they need to use it with a MOV rated above that.
                    Al
                    PS Here's an option from Digikey: http://www.digikey.com/product-detail/en/MOV-10D241K/MOV-10D241K-ND/2407562
                      How does this look?
                      SparkmanS
                      SparkmanS
                      Sparkman
                      #227
                      The fuse serves two purposes, one to protect if the current draw of the power supply exceeds its rated capacity and the other to blow if the varistor starts conducting a large amount of current in a spike situation. A .75A will still provide protection, but will take a longer time to blow. You want to make sure the fuse doesn't blow because of the in-rush current at start-up, which a fast-blow fuse may do. Typically you want the fuse to be sized at about 150% max of the rated capacity so I would not exceed .3A.
                      Al
                      petewillP 1 Reply Last reply
                      • SparkmanS Sparkman
                        Al
                        petewillP
                        petewillP
                        petewill
                        @Sparkman
                        I am in the USA so I will only be feeding it with 120VAC, but I will make sure to note that anyone using 240VAC will need a different value varistor.
                        the fuse should be after the varistor in the circuit
                        Ok, I'm still a little confused. Are you saying it should be 120VAC -> Varistor -> Fuse -> HLK? Or, 120VAC -> Fuse -> Varistor -> HLK? I thought it was the second one but maybe I misunderstood.
                        Also, I found some fuses that are rated at 300mA! Not a bad price either!
                        http://www.ebay.com/itm/Ceramic-Slow-Blow-Fuse-3-6-x-10mm-Axial-Leads-125V-250V-0-1A-6-3A-10-30pcs-/111433875797?var=&hash=item19f1fa0155
                        I think I am almost ready to start ordering parts. I am excited for this build! If anyone else has any feedback please let me know. Thanks!
                        SparkmanS 1 Reply Last reply
                          @Sparkman
                          SparkmanS
                          SparkmanS
                          Sparkman
                          @petewill said:
                          @Sparkman
                          Sorry, the wording I used was unclear and was based on the 120VAC being on the right in your diagram :-). Yes, it is 120VAC -> Fuse -> Varistor -> HLK.
                          Al
                            @petewill said:
                            @Sparkman
                            Al
                            petewillP
                            petewillP
                            petewill
                            @Sparkman Great, thanks! The parts have been ordered. Can't wait!
                            • C ceech
                              This one is not "safe", but it is an In-Wall AC to DC converter. Transformerless. With a 3A Solid state relay:
                              The converter output is 3.3V at 100mA and the solid state relay is a Triac.
                              F
                              F
                              Fabien
                              Do you have some shcematic of this board ? I'd like to adapt it for 2 relays
                              C 1 Reply Last reply
                              • Cliff KarlssonC
                                Cliff KarlssonC
                                Cliff Karlsson
                                Can anyone give me ebay-links to the parts I need to order to use the HLK with 230V.
                                I am getting a little confused about all the links.
                                • rvendrameR
                                  rvendrameR
                                  rvendrame
                                  #233
                                  This is the one I sent to be reviewed:
                                  http://www.aliexpress.com/item/Free-Shipping-1pcs-lot-HLK-PM01-AC-DC-220V-to-5V-mini-power-supply-module-intelligent/32408565688.html
                                  Alexa / Google Home
                                  • Cliff KarlssonC
                                    Cliff KarlssonC
                                    Cliff Karlsson
                                    Ok thanks, but I meant the fuses, varistors and stuff.
                                      petewillP
                                      petewillP
                                      petewill
                                      @Cliff-Karlsson
                                      I haven't tested any of these parts yet but this is what I ordered. I am in the USA so this is spec'd for 120 VAC. If you're using 240 you will need to change the size of the Varistor but everything else should be fine for 240.
                                      Varistor for 120VAC - http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                      73°C Thermal Fuse - http://www.ebay.com/itm/221560426284?_trksid=p2057872.m2749.l2649&var=520415979885&ssPageName=STRK%3AMEBIDX%3AIT
                                      250V 300mA Slow Blow Fuse - http://www.ebay.com/itm/111433875797?_trksid=p2057872.m2749.l2649&var=410420838583&ssPageName=STRK%3AMEBIDX%3AIT
                                      HLK-PM01 - http://www.ebay.com/itm/351418782712?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                                      • F Fabien
                                        C
                                        C
                                        ceech
                                        @Fabien @DrJeff Here is a link to board and schematic files for the transformerless AC-DC converter:
                                        https://github.com/ceech/AC_SR087
                                        DrJeffD 1 Reply Last reply
                                          MartinP
                                          Would this varistor work with 240v?
                                          http://www.ebay.com/itm/10-x-Zinc-Oxide-Varistor-250VAC-60J-2500A-10mm-/260848704608?hash=item3cbbcb5c60
