  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 590.5k Views 69 Watching
  • petewillP petewill
    @rvendrame said:
    @petewill . the MOV goes in parallel with HLK input (and not in series like you did).
    It was suggested to use .2A fuses (instead the .75A). And the Thermal fuse should be glued on HLK top (my guess).
    Dang, totally forgot about all that in my rush to finish the diagram before lunch ended... That's why you guys design the electronics and I make the videos ;)
    How necessary are the .2A fuses? I couldn't find any on ebay at a reasonable price. Is the goal of this fuse to prevent large surges (like lightning) from hitting the MOV, or something else? If it's to prevent large surges would the .75A work ok?
    Also, I was able to find cheaper varistors. I'm thinking 150VAC should work ok because the HLK is designed to handle 240VAC but maybe I'm off on that?
    http://www.ebay.com/itm/5-x-Zinc-Oxide-Varistor-150VAC-15J-1200A-7mm-FREE-SHIPPING-/321024816822?hash=item4abe91f6b6
    How does this look?
    SparkmanS
    SparkmanS
    Sparkman
    wrote on last edited by Sparkman
    #226
    As long as you only feed it with 120VAC, there's no issue with that. For those that will feed it with 240VAC, they need to use it with a MOV rated above that.
    Al
    PS Here's an option from Digikey: http://www.digikey.com/product-detail/en/MOV-10D241K/MOV-10D241K-ND/2407562
      How does this look?
      SparkmanS
      SparkmanS
      Sparkman
      #227
      The fuse serves two purposes, one to protect if the current draw of the power supply exceeds its rated capacity and the other to blow if the varistor starts conducting a large amount of current in a spike situation. A .75A will still provide protection, but will take a longer time to blow. You want to make sure the fuse doesn't blow because of the in-rush current at start-up, which a fast-blow fuse may do. Typically you want the fuse to be sized at about 150% max of the rated capacity so I would not exceed .3A.
      Al
      petewillP 1 Reply Last reply
      • SparkmanS Sparkman
        Al
        petewillP
        petewillP
        petewill
        @Sparkman
        I am in the USA so I will only be feeding it with 120VAC, but I will make sure to note that anyone using 240VAC will need a different value varistor.
        the fuse should be after the varistor in the circuit
        Ok, I'm still a little confused. Are you saying it should be 120VAC -> Varistor -> Fuse -> HLK? Or, 120VAC -> Fuse -> Varistor -> HLK? I thought it was the second one but maybe I misunderstood.
        Also, I found some fuses that are rated at 300mA! Not a bad price either!
        http://www.ebay.com/itm/Ceramic-Slow-Blow-Fuse-3-6-x-10mm-Axial-Leads-125V-250V-0-1A-6-3A-10-30pcs-/111433875797?var=&hash=item19f1fa0155
        I think I am almost ready to start ordering parts. I am excited for this build! If anyone else has any feedback please let me know. Thanks!
        SparkmanS 1 Reply Last reply
          @Sparkman
          SparkmanS
          SparkmanS
          Sparkman
          @petewill said:
          @Sparkman
          Sorry, the wording I used was unclear and was based on the 120VAC being on the right in your diagram :-). Yes, it is 120VAC -> Fuse -> Varistor -> HLK.
          Al
            @petewill said:
            @Sparkman
            Al
            petewillP
            petewillP
            petewill
            @Sparkman Great, thanks! The parts have been ordered. Can't wait!
            • C ceech
              This one is not "safe", but it is an In-Wall AC to DC converter. Transformerless. With a 3A Solid state relay:
              The converter output is 3.3V at 100mA and the solid state relay is a Triac.
              F
              F
              Fabien
              Do you have some shcematic of this board ? I'd like to adapt it for 2 relays
              C 1 Reply Last reply
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                Can anyone give me ebay-links to the parts I need to order to use the HLK with 230V.
                I am getting a little confused about all the links.
                • rvendrameR
                  rvendrameR
                  rvendrame
                  wrote on last edited by rvendrame
                  #233
                  This is the one I sent to be reviewed:
                  http://www.aliexpress.com/item/Free-Shipping-1pcs-lot-HLK-PM01-AC-DC-220V-to-5V-mini-power-supply-module-intelligent/32408565688.html
                  ESP8266 GW + mySensors 2.3.2
                  Alexa / Google Home
                  • Cliff KarlssonC
                    Cliff KarlssonC
                    Cliff Karlsson
                    Ok thanks, but I meant the fuses, varistors and stuff.
                      petewillP
                      petewillP
                      petewill
                      @Cliff-Karlsson
                      I haven't tested any of these parts yet but this is what I ordered. I am in the USA so this is spec'd for 120 VAC. If you're using 240 you will need to change the size of the Varistor but everything else should be fine for 240.
                      Varistor for 120VAC - http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                      73°C Thermal Fuse - http://www.ebay.com/itm/221560426284?_trksid=p2057872.m2749.l2649&var=520415979885&ssPageName=STRK%3AMEBIDX%3AIT
                      250V 300mA Slow Blow Fuse - http://www.ebay.com/itm/111433875797?_trksid=p2057872.m2749.l2649&var=410420838583&ssPageName=STRK%3AMEBIDX%3AIT
                      HLK-PM01 - http://www.ebay.com/itm/351418782712?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                      • F Fabien
                        C
                        C
                        ceech
                        @Fabien @DrJeff Here is a link to board and schematic files for the transformerless AC-DC converter:
                        https://github.com/ceech/AC_SR087
                        DrJeffD 1 Reply Last reply
                          MartinP
                          Would this varistor work with 240v?
                          http://www.ebay.com/itm/10-x-Zinc-Oxide-Varistor-250VAC-60J-2500A-10mm-/260848704608?hash=item3cbbcb5c60
                          • C ceech
                            DrJeffD
                            DrJeffD
                            DrJeff
                            @ceech can't look at the files right now is this a dimmer switch that is transformerless?
                            • DrJeffD DrJeff
                              C
                              C
                              ceech
                              @DrJeff Yes
                              • C ceech
                                @DrJeff Yes
                                DrJeffD
                                DrJeffD
                                DrJeff
                                @ceech Thanks yet again!
                                • M MartinP
                                  petewillP
                                  petewillP
                                  petewill
                                  @MartinP Based on my limited knowledge, yes, that should work. Maybe someone else can chime in to confirm?
                                  • F
                                    F
                                    Fabien
                                    thank you @ceech
                                      SparkmanS
                                      SparkmanS
                                      Sparkman
                                      I would personally go with a higher voltage rating. Something like 15-20% higher than your normal voltage otherwise you may get regular nuisance trips. So for a 240 VAC system, I would use something close to 290V.
                                      Al
                                        Al
                                        petewillP
                                        petewillP
                                        petewill
                                        @Sparkman Thanks!
                                        • RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          20150929_193752.jpg :stuck_out_tongue:
                                          RJ_Make
                                          YveauxY petewillP 2 Replies Last reply
