  3. Safe In-Wall AC to DC Transformers??
431 Posts 71 Posters 590.1k Views 69 Watching
  • SparkmanS Sparkman
    @petewill said:
    How necessary are the .2A fuses? I couldn't find any on ebay at a reasonable price. Is the goal of this fuse to prevent large surges (like lightning) from hitting the MOV, or something else? If it's to prevent large surges would the .75A work ok?
    The fuse serves two purposes, one to protect if the current draw of the power supply exceeds its rated capacity and the other to blow if the varistor starts conducting a large amount of current in a spike situation. A .75A will still provide protection, but will take a longer time to blow. You want to make sure the fuse doesn't blow because of the in-rush current at start-up, which a fast-blow fuse may do. Typically you want the fuse to be sized at about 150% max of the rated capacity so I would not exceed .3A.
    Al
    petewillP
    petewillP
    petewill
    @Sparkman
    As long as you only feed it with 120VAC, there's no issue with that. For those that will feed it with 240VAC, they need to use it with a MOV rated above that.
    I am in the USA so I will only be feeding it with 120VAC, but I will make sure to note that anyone using 240VAC will need a different value varistor.
    the fuse should be after the varistor in the circuit
    Ok, I'm still a little confused. Are you saying it should be 120VAC -> Varistor -> Fuse -> HLK? Or, 120VAC -> Fuse -> Varistor -> HLK? I thought it was the second one but maybe I misunderstood.
    Also, I found some fuses that are rated at 300mA! Not a bad price either!
    http://www.ebay.com/itm/Ceramic-Slow-Blow-Fuse-3-6-x-10mm-Axial-Leads-125V-250V-0-1A-6-3A-10-30pcs-/111433875797?var=&hash=item19f1fa0155
    I think I am almost ready to start ordering parts. I am excited for this build! If anyone else has any feedback please let me know. Thanks!
    SparkmanS 1 Reply Last reply
    • petewillP petewill
      @Sparkman
      SparkmanS
      SparkmanS
      Sparkman
      @petewill said:
      @Sparkman
      Sorry, the wording I used was unclear and was based on the 120VAC being on the right in your diagram :-). Yes, it is 120VAC -> Fuse -> Varistor -> HLK.
      Al
      petewillP 1 Reply Last reply
        @petewill said:
        @Sparkman
        Al
        petewillP
        petewillP
        petewill
        @Sparkman Great, thanks! The parts have been ordered. Can't wait!
        • C ceech
          This one is not "safe", but it is an In-Wall AC to DC converter. Transformerless. With a 3A Solid state relay:
          The converter output is 3.3V at 100mA and the solid state relay is a Triac.
          F
          F
          Fabien
          Do you have some shcematic of this board ? I'd like to adapt it for 2 relays
          C 1 Reply Last reply
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            Can anyone give me ebay-links to the parts I need to order to use the HLK with 230V.
            I am getting a little confused about all the links.
            • rvendrameR
              rvendrameR
              rvendrame
              wrote on last edited by rvendrame
              #233
              This is the one I sent to be reviewed:
              http://www.aliexpress.com/item/Free-Shipping-1pcs-lot-HLK-PM01-AC-DC-220V-to-5V-mini-power-supply-module-intelligent/32408565688.html
              ESP8266 GW + mySensors 2.3.2
              Alexa / Google Home
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                Ok thanks, but I meant the fuses, varistors and stuff.
                  petewillP
                  petewillP
                  petewill
                  @Cliff-Karlsson
                  I haven't tested any of these parts yet but this is what I ordered. I am in the USA so this is spec'd for 120 VAC. If you're using 240 you will need to change the size of the Varistor but everything else should be fine for 240.
                  Varistor for 120VAC - http://www.ebay.com/itm/321024816822?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                  73°C Thermal Fuse - http://www.ebay.com/itm/221560426284?_trksid=p2057872.m2749.l2649&var=520415979885&ssPageName=STRK%3AMEBIDX%3AIT
                  250V 300mA Slow Blow Fuse - http://www.ebay.com/itm/111433875797?_trksid=p2057872.m2749.l2649&var=410420838583&ssPageName=STRK%3AMEBIDX%3AIT
                  HLK-PM01 - http://www.ebay.com/itm/351418782712?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                  • F Fabien
                    C
                    C
                    ceech
                    @Fabien @DrJeff Here is a link to board and schematic files for the transformerless AC-DC converter:
                    https://github.com/ceech/AC_SR087
                    DrJeffD 1 Reply Last reply
                      MartinP
                      Would this varistor work with 240v?
                      http://www.ebay.com/itm/10-x-Zinc-Oxide-Varistor-250VAC-60J-2500A-10mm-/260848704608?hash=item3cbbcb5c60
                      • C ceech
                        DrJeffD
                        DrJeffD
                        DrJeff
                        @ceech can't look at the files right now is this a dimmer switch that is transformerless?
                        • DrJeffD DrJeff
                          C
                          C
                          ceech
                          @DrJeff Yes
                          • C ceech
                            @DrJeff Yes
                            DrJeffD
                            DrJeffD
                            DrJeff
                            @ceech Thanks yet again!
                            • M MartinP
                              petewillP
                              petewillP
                              petewill
                              @MartinP Based on my limited knowledge, yes, that should work. Maybe someone else can chime in to confirm?
                              • F
                                F
                                Fabien
                                thank you @ceech
                                  SparkmanS
                                  SparkmanS
                                  Sparkman
                                  I would personally go with a higher voltage rating. Something like 15-20% higher than your normal voltage otherwise you may get regular nuisance trips. So for a 240 VAC system, I would use something close to 290V.
                                  Al
                                    Al
                                    petewillP
                                    petewillP
                                    petewill
                                    @Sparkman Thanks!
                                    • RJ_MakeR
                                      RJ_MakeR
                                      RJ_Make
                                      20150929_193752.jpg :stuck_out_tongue:
                                      RJ_Make
                                      YveauxY petewillP 2 Replies Last reply
                                      • RJ_MakeR RJ_Make
                                        @ServiceXp :+1: long evening ahead :satisfied:
                                        • Steve CasterS
                                          Steve CasterS
                                          Steve Caster
                                          Hi all,
                                          I was wondering, I want to be able to adress my blinds using mysensors. Using the relay, radio etc works fine, yet I am still wondering on this power supply. So using the above component I basically prevent fire by using the thermal fuse and an overload by using a regular fuse, the varistor and the HLK.
                                          Now, I am using a Nano (I have still 15 of those) which appear to be using 230mA, the radio itself and a relay. The relay (from the spec sheet) uses 180mA. This should be ok to be used with the HLK shown above. Now, my main concern is, how do you make a all sit together nicely? Is there a PCB type of board you are using? Any pointers welcome :)
                                          Kind regards
                                          Steve
