  3. Motion Sensor, flaky behavior
22 Posts 7 Posters 9.4k Views 1 Watching
  • N Offline
    N Offline
    naveen
    I recently build a motion sensor and it doesn't have robust behavior. It seems to work most of the time but not all of the time. Does the motion sensor only send a command once when its state change? e.g. once when it detects motion and then once when the motion stops? If so, I think if the first motion command is not sent, it will not detect motion again until the motion sensor turns off and then back on again. Does this make sense?
    How reliable should the sent commands be? I wired the capacitor across the motion sensor ground/3.3V but I didn't do it for my hub - should I put a cap there too??
    • D Offline
      daulagari
      Why don't you add a LED or serial console to the motion sensor and add some code that activates them if motion is detected or when data is published. Then check things against the log of the gateway.
      • B Offline
        B Offline
        BulldogLowell
        From my experience, the motion sensor sketch works.
        Are you sure you have good radio connectivity?
        N 1 Reply Last reply
        • B BulldogLowell
          N Offline
          N Offline
          naveen
          wrote on last edited by naveen
          That was the first thing I suspected, They are pretty close to each other and have almost direct line of sight...Maybe 7m (21ft) between the gateway and the node. Maybe I need to add a cap to the radio for the gateway?
          B 1 Reply Last reply
          • N naveen
            B Offline
            B Offline
            BulldogLowell
            @naveen
            definitely try that next.
            • N Offline
              N Offline
              naveen
              I gave it a go and it doesn't seem to help much. I'm powering the APM with the power supply included in http://www.ebay.ca/itm/131143728672?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649. I have a 12V 2A wall adapter plugged into the power supply that came with the breadboard and I'm using the 5V output into the RAW Arduino pin
              Y 1 Reply Last reply
              • N naveen
                Y Offline
                Y Offline
                @naveen Did you check the 5v with a multimeter?
                I have an identical breadboard supply and fried mine with a "12v" adapter. After measuring the output of the adapter it appeared to be around 16v and the onboard voltage converter (ams1117 if I recall right) had it's maximum input set to 15v or so...
                N B 2 Replies Last reply
                • Y Yveaux
                  N Offline
                  N Offline
                  naveen
                  @Yveaux
                  Hmm, that's good to know. Apparently my lab has a multimeter lying around so I'll measure the outputs tonight. @hek do you think you could add a reliable power supply vendor to the MySensors store? It is the one thing that I've had trouble choosing - they all look pretty similar its hard to tell the good from the bad.
                  • hekH Offline
                    hekH Offline
                    Yep, it is hard to tell good from bad. You have to take them apart to be sure. We cannot recommend any special ebay power supply at the moment. But a general tip is to add a few dollars when dealing with AC power. There might be a reason why some stuff is so cheap.
                    If anyone has a good supply dealer on ebay or elsewhere, please leave a tip here.
                    When we create our own AC MySensors board we will have the possibility to select good stable components.
                    • E Offline
                      E Offline
                      epierre
                      I am to say I have the same issue...
                      I have a big difference between what the serial displays and what the gw receives... even when adding such to prevent too much radio...
                      if (lastValue != tripped) {
                      gw.sendVariable(CHILD_ID, V_TRIPPED, tripped?"1":"0");  // Send tripped value to gw
                      lastValue=tripped;
                      here it is pointing to the ground:
                      2014-07-26 20:47:03 4 1 1 0 26.1
                      2014-07-26 20:47:04 7 0 1 16 0
                      2014-07-26 20:47:04 7 0 1 16 1
                      2014-07-26 20:47:05 7 0 1 16 0
                      2014-07-26 20:47:08 7 0 1 16 1
                      2014-07-26 20:47:11 7 0 1 16 0
                      2014-07-26 20:47:14 7 0 1 16 1
                      2014-07-26 20:47:16 7 0 1 16 0
                      2014-07-26 20:47:20 7 0 1 16 1
                      2014-07-26 20:47:24 7 0 1 16 0
                      z-wave - Vera -> Domoticz
                      E 1 Reply Last reply
                      • E epierre
                        lastValue=tripped;
                        E Offline
                        E Offline
                        epierre
                        oooppppssss... wiring error.... @hek always told me to double check...
                        Here some hysteresis could be added, as commercial grade motion sensor, a value the gateway could send to modify how long the presence sensor will not send the "alarm is over", avoiding thus lots of notifications on server side and lot of redundant messages, here one every 2s ...
                        • N Offline
                          N Offline
                          naveen
                          I'm wondering if there is some way to do this:
                          -send tripped command to gw/vera
                          -poll gw/vera for the state of the tripped command (this is the step I have no idea how to do)
                          -if value of tripped which was sent does not match the value in vera, resend command
                          -repeat
                          That way you ensure the message is continually sent until it is received (up to some finite number of times to prevent infinite loops)
                          • hekH Offline
                            hekH Offline
                            If you would consider moving your sensor network to 1.4 you can ask for an ack from gateway when you send in your tripped status.
                            This mean the gateway will reply back to you sensor and you can pick up this answer (or choose to resend status again after some timeout if ack never reaches your node).
                            • E epierre
                              E Offline
                              E Offline
                              epierre
                              @hek is there a way to make an interrupt with time ?
                              I mean:
                              • if it is tripped and previous status was untripped, send the alarm
                              • if it is untripped but below a certain time don't send anything
                              • after a while, the timer sends an untrip after the amount of time
                              hekH 1 Reply Last reply
                              • E epierre
                                I mean:
                                hekH Offline
                                hekH Offline
                                @epierre
                                Yes, all this should be possible.
                                Untripped should probably still be handled by the motion sensor (you will get an interrupt when state changes and can use the trimpot to change delay).
                                  @epierre
                                  E Offline
                                  E Offline
                                  epierre
                                  @hek you mean only the hardware way ?
                                  Here if under 20s (in arduino time) I get my untrip, I don't send it. If a timer don't occurs, the untrip will never be sent.
                                  any idea ?
                                  • E epierre
                                    any idea ?
                                    hekH Offline
                                    hekH Offline
                                    @epierre
                                    How do you keep track of time while sleeping your Arduino?
                                      @epierre
                                      E Offline
                                      E Offline
                                      epierre
                                      @hek do the millis does it ? else I can add a rtc
                                        N Offline
                                        N Offline
                                        naveen
                                        @hek
                                        Is there any reason I should avoid 1.4? I wouldn't mind upgrading if it'll make my sensors a bit more robust. I'm waiting for 5V power supplies in case the 12V power supply I have is what is causing my issues
                                        • N naveen
                                          @hek
                                          hekH Offline
                                          hekH Offline
                                          @naveen
                                          No, not really. Go for it. But things might still change (protocol/api) in 1.4. But that does not mean you have to update every day :smiley:
