  3. Motion Sensor, flaky behavior
22 Posts 7 Posters 9.8k Views 1 Watching
    From my experience, the motion sensor sketch works.
    Are you sure you have good radio connectivity?
    N
    N
    naveen
    wrote on last edited by naveen
    That was the first thing I suspected, They are pretty close to each other and have almost direct line of sight...Maybe 7m (21ft) between the gateway and the node. Maybe I need to add a cap to the radio for the gateway?
    • N naveen
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @naveen
      definitely try that next.
      • N
        N
        naveen
        I gave it a go and it doesn't seem to help much. I'm powering the APM with the power supply included in http://www.ebay.ca/itm/131143728672?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649. I have a 12V 2A wall adapter plugged into the power supply that came with the breadboard and I'm using the 5V output into the RAW Arduino pin
        • N naveen
          @naveen Did you check the 5v with a multimeter?
          I have an identical breadboard supply and fried mine with a "12v" adapter. After measuring the output of the adapter it appeared to be around 16v and the onboard voltage converter (ams1117 if I recall right) had it's maximum input set to 15v or so...
          N BulldogLowellB 2 Replies Last reply
          • YveauxY Yveaux
            N
            N
            naveen
            @Yveaux
            Hmm, that's good to know. Apparently my lab has a multimeter lying around so I'll measure the outputs tonight. @hek do you think you could add a reliable power supply vendor to the MySensors store? It is the one thing that I've had trouble choosing - they all look pretty similar its hard to tell the good from the bad.
              Yep, it is hard to tell good from bad. You have to take them apart to be sure. We cannot recommend any special ebay power supply at the moment. But a general tip is to add a few dollars when dealing with AC power. There might be a reason why some stuff is so cheap.
              If anyone has a good supply dealer on ebay or elsewhere, please leave a tip here.
              When we create our own AC MySensors board we will have the possibility to select good stable components.
              • epierreE
                epierreE
                epierre
                I am to say I have the same issue...
                I have a big difference between what the serial displays and what the gw receives... even when adding such to prevent too much radio...
                if (lastValue != tripped) {
                gw.sendVariable(CHILD_ID, V_TRIPPED, tripped?"1":"0");  // Send tripped value to gw
                lastValue=tripped;
                here it is pointing to the ground:
                2014-07-26 20:47:03 4 1 1 0 26.1
                2014-07-26 20:47:04 7 0 1 16 0
                2014-07-26 20:47:04 7 0 1 16 1
                2014-07-26 20:47:05 7 0 1 16 0
                2014-07-26 20:47:08 7 0 1 16 1
                2014-07-26 20:47:11 7 0 1 16 0
                2014-07-26 20:47:14 7 0 1 16 1
                2014-07-26 20:47:16 7 0 1 16 0
                2014-07-26 20:47:20 7 0 1 16 1
                2014-07-26 20:47:24 7 0 1 16 0
                z-wave - Vera -> Domoticz
                epierreE 1 Reply Last reply
                • epierreE epierre
                  lastValue=tripped;
                  epierreE
                  epierreE
                  epierre
                  oooppppssss... wiring error.... @hek always told me to double check...
                  Here some hysteresis could be added, as commercial grade motion sensor, a value the gateway could send to modify how long the presence sensor will not send the "alarm is over", avoiding thus lots of notifications on server side and lot of redundant messages, here one every 2s ...
                  • N
                    N
                    naveen
                    I'm wondering if there is some way to do this:
                    -send tripped command to gw/vera
                    -poll gw/vera for the state of the tripped command (this is the step I have no idea how to do)
                    -if value of tripped which was sent does not match the value in vera, resend command
                    -repeat
                    That way you ensure the message is continually sent until it is received (up to some finite number of times to prevent infinite loops)
                      If you would consider moving your sensor network to 1.4 you can ask for an ack from gateway when you send in your tripped status.
                      This mean the gateway will reply back to you sensor and you can pick up this answer (or choose to resend status again after some timeout if ack never reaches your node).
                      N 1 Reply Last reply
                      • epierreE epierre
                        epierreE
                        epierreE
                        epierre
                        @hek is there a way to make an interrupt with time ?
                        I mean:
                        • if it is tripped and previous status was untripped, send the alarm
                        • if it is untripped but below a certain time don't send anything
                        • after a while, the timer sends an untrip after the amount of time
                        hekH 1 Reply Last reply
                        • epierreE epierre
                          I mean:
                          @epierre
                          Yes, all this should be possible.
                          Untripped should probably still be handled by the motion sensor (you will get an interrupt when state changes and can use the trimpot to change delay).
                            @epierre
                            epierreE
                            epierreE
                            epierre
                            @hek you mean only the hardware way ?
                            Here if under 20s (in arduino time) I get my untrip, I don't send it. If a timer don't occurs, the untrip will never be sent.
                            any idea ?
                            • epierreE epierre
                              any idea ?
                              @epierre
                              How do you keep track of time while sleeping your Arduino?
                                @epierre
                                epierreE
                                epierreE
                                epierre
                                @hek do the millis does it ? else I can add a rtc
                                  N
                                  N
                                  naveen
                                  @hek
                                  Is there any reason I should avoid 1.4? I wouldn't mind upgrading if it'll make my sensors a bit more robust. I'm waiting for 5V power supplies in case the 12V power supply I have is what is causing my issues
                                  • N naveen
                                    @hek
                                    @naveen
                                    No, not really. Go for it. But things might still change (protocol/api) in 1.4. But that does not mean you have to update every day :smiley:
                                    • YveauxY Yveaux
                                      BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      that happened to me once too.
                                      jendrushJ 1 Reply Last reply
                                        jendrushJ
                                        jendrushJ
                                        jendrush
                                        @BulldogLowell I fried my breadbord power supply by connecting broken power adaptor(it have me about 13-14V instead of up to 12V), this fried AMS1117 5V. I replaced it, and it's working proper again.
