  3. My Ideal sensor node PCB
pcb
58 Posts 20 Posters 51.3k Views 10 Watching
  • Z Zeph
    @Bandra said:
    I've just sent my PCB off for manufacturing. My design spec was pretty close to your requirements.
    I like your design.
    One newbie question I have (never having done my own boards yet) is about how hard it is to cut apart the PCBs when you panelize them to subunits smaller than the PCB manufacturer separates for you. Do you use shears of some sort, or a band saw, or a dremal saw or what? Seems like you'd need to be very precise to not damage adjacent traces.
    It supports the 3.3v and 5v pro minis, with access to A5 and A6.
    I see holes for A4 and A5. Most APM's also provide A6 and A7 (which are analog in only). I use those for things like the VRAW voltage divider, which will never need to be used as a digital pin.
    One pattern is to place A4+A5 and A6+A7 inside the perimeter pins and offset half a pin, see for example: http://www.ebay.com/itm/191117208428
    Another pattern is to add 4 perimeter pins for A4-A7 at the far end from the serial programming pins, see for example: http://www.ebay.com/itm/271512227109
    I was thinking it would be possible to accommodate either on the sensor board.
    It has a socket for the nRF24L01+. It doesn't hang over the edge, it actually hangs over the APM. My spaghetti board prototype showed no problems with this configuration. It makes it much more compact.
    It does make it more compact so I'd prefer it if is works well, but Nordic's recommendation is not to place the antenna over a ground or power plane or too close. Somebody else posted a reference recently. It may depend on how far above the PCB the nRF24L01+ is mounted. Your milage may vary but it is worth testing on the actual PCB. If we can get solid radio signals without hanging at least the antenna outboard, I'm all for it.
    B
    B
    Bandra
    @Zeph
    For cutting the boards I'll be using a really sharp Stanley knife. I live in an apartment with my young family, so containing the dust is a big consideration for me. A Stanley knife is about the "cleanest" way to cut them. It just takes a little more elbow grease.
    I've left about 3mm between each board (since I have 3 x 3cm boards to fit across 10cm). Plenty of room to cut between :)
    Yeah, I know that Nordic recommend not to run the antenna over a plane. I plan to solder a 2x4 header onto my PCB and slot the nRF into that. My prototype had pretty decent range when I tried it. I'll see how it works when my PCBs come in. I may need a rev 2 yet :)
    Z 1 Reply Last reply
    • T therik
      @Zeph I have a DHT-22 and my pin spacing is 0.1".
      I was thinking of connecting the PIR and DHT-22 directly to the PCB and building a case around it. Of course, I could also use wires to remote the DHT-22 or PIR, but I like the option of direct connecting.
      Oh yea, and where are you getting the DHT22 for $3? I need to use these due to the low humidity here in the desert. The DHT11 only goes to 20% and we a lower than that much of the year.
      Z
      Z
      Zeph
      Cool.
      I understand the desire to go below 20% RH.
      I am using AM2302. Many of the sources for "DHT22" are actually substituting the AM2302 (including the current MySensors store link). Do you have a datasheet for the real DHT-22?
      And I goofed, $3 was based on winning a bid for my first one, they start at $4 w free shipping on eBay for "Buy it Now", tho they can be had for closer to $3 in lots of 5 on AliExpress.
      I got mine before coming to this site; I would now tend to suggest following the links in the MySensors store if you are getting it from eBay - who knows how good the "cheapest offering" on eBay or AliExpress is?
      • B Bandra
        @Zeph
        Z
        Z
        Zeph
        Meaning a box cutter knife? So you probably use a straight edge and score the board with the knife (both sides?) Then just break it on the line? That sounds pretty feasible, other than:
        Ever since SMT, people have new definitions of "plenty of room" :-)
        • Z
          Z
          Zeph
          My overall thinking is that the breadboard area will allow reasonably simple addition of many types of sensors or actuators, so I am suggesting minimizing the dedicated circuitry and maximizing the breadboard area. However it makes sense to have dedicated space on the PCB for sensors and devices which are likely to be commonly used and especially if they do not fit the 0.1" hole grid. For example, a surface mount LDO regulator for the radio.
          There's another candidate which meets this criterion for me, and I've edited it into the Origional Post - onboard external serial Flash. This could be as easy as a SOIC-8 outline (and traces) for the AT24C series, or other serial Flash memory. Optional of course.
          • T
            therik
            Gentlemen,
            For anyone who is interested I have attached a schematic of my proposed "shield". Have a look if you so choose, and if you notice something wrong or incorrect, please let me know. One thing I'm not sure is...does the DHT22 temperature/humidity sensor need an external pull-up resistor?
            • T
              therik
              Oh yea, be nice...it's my first one!
              • T therik
                Gentlemen,
                Z
                Z
                Zeph
                @therik said:
                Very nice. No "mistakes", just some questions.
                This is a base board for the Arduino Pro Mini, right? Are you making use of A6 and A7?
                Why three voltage dividers of this style? Do you anticipate having multiple higher voltages to measure? I would tend to use one for VRAW. I guess you could populate one half with a resistor and jumper the other, then tie something like an LDR between the analog input and VCC or Ground.
                I'm a little unusual, as I want the option to tie the nRF's IRQ to D8 (input capture 1). This is to allow T1 to be used as a high precision timer and capture the time a packet arrives, and I can also use that capture to generate an interrupt based on that - keeping D2 free for INT0.
                I am also using an interrupt driven DHTxx lib, which uses Int0 or Int1 (pin 2 or 3) rather than pin 5.
                Are the PIR and Dallas (one wire) and DHT22 dedicated footprints on the board, or connectors?
                • T
                  therik
                  Indeed, a pro-mini clone. I thought that A6 and A7 might be too much to squeeze in. I'm thinking of a 3x5 cm board.
                  Yea, for the voltage dividers, one for measuring the battery level. And two for something else, possibly an IR-based reflective optical sensor. And anything that has a higher output voltage.
                  Hmm...haven't heard of using nRF's IRQ to D8, can you still wake a sleeping node with this configuration? I guess I just don't have a full grasp on the concept. I just a beginner, so the more I learn the more dangerous I get!
                  Right, the main sensor on this board is the PIR; which is why I want an interrupt pin to that sensor. However I'd like to also use the magnetic-based sensors also as the main sensor and interrupt.
                  The PIR, Dallas, DHT22 are separate from the other 'future-proof' region, this should become clear once the layout is complete.
                  Anyone have a solid answer on whether the DHT22 needs an external pull-up resistor?
                  • T therik
                    Z
                    Z
                    Zeph
                    OK. I like to use one of them for a dedicated measurement of VRAW, since it cannot be used as an additional digital I/O like A0..A5
                    What IR based sensor are you considering that returns analog above VCC? Are you thinking of having 5V power supply and sensors with 3.3v APM?
                    I believe the answer is "yes, but not in the lowest possible power-down mode".
                    Case 1: The nRF is power up and may generate an interrupt. In that case you are using a significant amount of power; you can save battery by nevertheless mostly powering down at ATMega, but keeping timer 1 active so D8 can generate a Input Capture 1 interrupt won't be a big deal.
                    Case 2: You want really minimal power - so the nRF is powered down and isn't generating interrrupts. In that case you don't need D2 or D8, and you can go to the lowest power level (including powering off timer 1); the watchdog may be all you leave running (or some other super low power external device).
                    At least that's my understanding. I'm still learning too.
                    I do not use any pull up resister and I've never seen a circuit which used it.
                    • Z Zeph
                      Z
                      Z
                      Zeph
                      Have a look at this little fella: http://www.digikey.com/product-search/en?mpart=W25X40CLSNIG&vendor=256
                      Isn't anybody willing to create a SOIC-8 home for this cute little chip (with SPI traces of course to keep it happy)?
                      512 KBytes of happiness for logging and OTA programming. Unique ID.
                      Or you can get twice that memory for 2 cents more.
                      (The above is the chip used by the Moteino. The Anarduino uses a heftier 16 MByte chip: http://www.mouser.com/ProductDetail/Spansion/S25FL127SABMFI101/?qs=sGAEpiMZZMtI%252bQ06EiAoG5SEO4xJJ6RlEmMSz7h3HuQ%3D but that too is possible with the same SOIC-8 footprint, I think)
                      (The Moteino and Anarduino use different and incompatible radios compared to MySensors, but nevertheless contain possible inspirations for our corner of this exciting little world).
                      marceltrapmanM T 2 Replies Last reply
                      • B
                        B
                        Bandra
                        Just for completeness, my PCBs came in and I've had a chance to solder them up. The PCBs are really nice. iTead have done a great job. @Zeph, turns out that I didn't need to cut my PCBs because the friendly folk at iTead cut them for me.
                        Here's a photo of a few things soldered on:
                        Underneath the APM I have a 1M and 470K resistors for the battery voltage check. There's also a 4.7K resistor for the Dallas DS18B20 temp sensor. Finally there's a 4.7K resistor for the LDR divider circuit.
                        You can also see the 4x2 header for the radio, the LDR itself, and the 3.3v step-up converter.
                        Here's the (almost) finished package:
                        You can see all the exposed solder pads for my various sensor configurations (motion, humidity, baro pressure, door reed switch, distance and soil moisture).
                        The range on the nRF24 is fine. I put my gateway at one end of the apartment and it easily picked up my sensor at the other end of the apartment (about 10m away through two thick internal walls). So I'm not worried about the nRF24 being parallel to the GND plane.
                        I actually took off the 4.7uF cap. It's probably my PCB (don't think the auto-route did a great job of it) but it made the radio flaky. Works just fine without it.
                        Now to find a box to put it in...
                        hekH RJ_MakeR Q 4 Replies Last reply
                        • B Bandra
                          Nice @Bandra!
                          • Z Zeph
                            marceltrapmanM
                            marceltrapmanM
                            marceltrapman
                            Interesting but even when I am willing to stock them up (50 pcs) the shipment costs exceed the price of them :(
                            Fulltime Servoy Developer
                            bjornhallbergB Z 2 Replies Last reply
                              bjornhallbergB
                              bjornhallbergB
                              bjornhallberg
                              @marceltrapman Have you looked at AliExpress? Seems they had a few sellers offering this chip.
                                marceltrapmanM
                                marceltrapmanM
                                marceltrapman
                                I never considered them. Took the plunge for a little less then 0,19 EU per piece :)
                                  Z
                                  Z
                                  Zeph
                                  Sorry. The problem with 4 Mb chip is that it's so cheap one feels bad about the shipping cost! :-)
                                  I was also looking at some 128Mb (16 MB) flash memories at $2.78, where the shipping would be a smaller part of the order
                                  More seriously, I hope the Ali Express order works well.
                                  • B Bandra
                                    RJ_MakeR
                                    RJ_MakeR
                                    RJ_Make
                                    @Bandra Looks fantastic! I'll take 3 :-)
                                    RJ_Make
                                    B 1 Reply Last reply
                                    • RJ_MakeR RJ_Make
                                      B
                                      B
                                      Bandra
                                      @ServiceXp
                                      Thanks mate! I've soldered up 3 of the boards now and they're all working fine.
                                      So far I've made one just with temp and light. One with temp, light and humidity, and one with temp, light, humidity and pressure. I'll make one more tonight that will just have temp and soil moisture.
                                      I'm not entirely happy with the two caps at the bottom of the board. The auto-route feature of Eagle is good, but I don't think it quite got that right. Seems to run fine without the two caps so the PCBs are not a write-off.
                                      I've got way more boards than I need. So I'm happy to send 3 off to you. PM me your address.
                                      marceltrapmanM RJ_MakeR 2 Replies Last reply
                                      • B Bandra
                                        @ServiceXp
                                        marceltrapmanM
                                        marceltrapmanM
                                        marceltrapman
                                        What is it that you are not happy about?
                                        Trying to learn here because I am still not sure if I will just make my boards myself or keep it with one or two prototypes and use iTead as well...
                                        Talking about iTead, I saw that they can also check your board, did you decide against that?
                                        • B Bandra
                                          @ServiceXp
                                          RJ_MakeR
                                          RJ_MakeR
                                          RJ_Make
                                          @Bandra Thanks, I sent you a PM... I think.. I used the "Chat" system... ;-)
                                          RJ_Make
