  3. My Ideal sensor node PCB
pcb
58 Posts 20 Posters 51.2k Views 10 Watching
  • T therik
    Gentlemen,
    For anyone who is interested I have attached a schematic of my proposed "shield". Have a look if you so choose, and if you notice something wrong or incorrect, please let me know. One thing I'm not sure is...does the DHT22 temperature/humidity sensor need an external pull-up resistor?
    Z
    Z
    Zeph
    @therik said:
    Very nice. No "mistakes", just some questions.
    This is a base board for the Arduino Pro Mini, right? Are you making use of A6 and A7?
    Why three voltage dividers of this style? Do you anticipate having multiple higher voltages to measure? I would tend to use one for VRAW. I guess you could populate one half with a resistor and jumper the other, then tie something like an LDR between the analog input and VCC or Ground.
    I'm a little unusual, as I want the option to tie the nRF's IRQ to D8 (input capture 1). This is to allow T1 to be used as a high precision timer and capture the time a packet arrives, and I can also use that capture to generate an interrupt based on that - keeping D2 free for INT0.
    I am also using an interrupt driven DHTxx lib, which uses Int0 or Int1 (pin 2 or 3) rather than pin 5.
    Are the PIR and Dallas (one wire) and DHT22 dedicated footprints on the board, or connectors?
    • T
      therik
      Indeed, a pro-mini clone. I thought that A6 and A7 might be too much to squeeze in. I'm thinking of a 3x5 cm board.
      Yea, for the voltage dividers, one for measuring the battery level. And two for something else, possibly an IR-based reflective optical sensor. And anything that has a higher output voltage.
      Hmm...haven't heard of using nRF's IRQ to D8, can you still wake a sleeping node with this configuration? I guess I just don't have a full grasp on the concept. I just a beginner, so the more I learn the more dangerous I get!
      Right, the main sensor on this board is the PIR; which is why I want an interrupt pin to that sensor. However I'd like to also use the magnetic-based sensors also as the main sensor and interrupt.
      The PIR, Dallas, DHT22 are separate from the other 'future-proof' region, this should become clear once the layout is complete.
      Anyone have a solid answer on whether the DHT22 needs an external pull-up resistor?
      Z 1 Reply Last reply
      • T therik
        Z
        Z
        Zeph
        OK. I like to use one of them for a dedicated measurement of VRAW, since it cannot be used as an additional digital I/O like A0..A5
        What IR based sensor are you considering that returns analog above VCC? Are you thinking of having 5V power supply and sensors with 3.3v APM?
        I believe the answer is "yes, but not in the lowest possible power-down mode".
        Case 1: The nRF is power up and may generate an interrupt. In that case you are using a significant amount of power; you can save battery by nevertheless mostly powering down at ATMega, but keeping timer 1 active so D8 can generate a Input Capture 1 interrupt won't be a big deal.
        Case 2: You want really minimal power - so the nRF is powered down and isn't generating interrrupts. In that case you don't need D2 or D8, and you can go to the lowest power level (including powering off timer 1); the watchdog may be all you leave running (or some other super low power external device).
        At least that's my understanding. I'm still learning too.
        I do not use any pull up resister and I've never seen a circuit which used it.
        • Z Zeph
          My overall thinking is that the breadboard area will allow reasonably simple addition of many types of sensors or actuators, so I am suggesting minimizing the dedicated circuitry and maximizing the breadboard area. However it makes sense to have dedicated space on the PCB for sensors and devices which are likely to be commonly used and especially if they do not fit the 0.1" hole grid. For example, a surface mount LDO regulator for the radio.
          There's another candidate which meets this criterion for me, and I've edited it into the Origional Post - onboard external serial Flash. This could be as easy as a SOIC-8 outline (and traces) for the AT24C series, or other serial Flash memory. Optional of course.
          Z
          Z
          Zeph
          Have a look at this little fella: http://www.digikey.com/product-search/en?mpart=W25X40CLSNIG&vendor=256
          Isn't anybody willing to create a SOIC-8 home for this cute little chip (with SPI traces of course to keep it happy)?
          512 KBytes of happiness for logging and OTA programming. Unique ID.
          Or you can get twice that memory for 2 cents more.
          (The above is the chip used by the Moteino. The Anarduino uses a heftier 16 MByte chip: http://www.mouser.com/ProductDetail/Spansion/S25FL127SABMFI101/?qs=sGAEpiMZZMtI%252bQ06EiAoG5SEO4xJJ6RlEmMSz7h3HuQ%3D but that too is possible with the same SOIC-8 footprint, I think)
          (The Moteino and Anarduino use different and incompatible radios compared to MySensors, but nevertheless contain possible inspirations for our corner of this exciting little world).
          marceltrapmanM T 2 Replies Last reply
          • B
            B
            Bandra
            Just for completeness, my PCBs came in and I've had a chance to solder them up. The PCBs are really nice. iTead have done a great job. @Zeph, turns out that I didn't need to cut my PCBs because the friendly folk at iTead cut them for me.
            Here's a photo of a few things soldered on:
            Underneath the APM I have a 1M and 470K resistors for the battery voltage check. There's also a 4.7K resistor for the Dallas DS18B20 temp sensor. Finally there's a 4.7K resistor for the LDR divider circuit.
            You can also see the 4x2 header for the radio, the LDR itself, and the 3.3v step-up converter.
            Here's the (almost) finished package:
            You can see all the exposed solder pads for my various sensor configurations (motion, humidity, baro pressure, door reed switch, distance and soil moisture).
            The range on the nRF24 is fine. I put my gateway at one end of the apartment and it easily picked up my sensor at the other end of the apartment (about 10m away through two thick internal walls). So I'm not worried about the nRF24 being parallel to the GND plane.
            I actually took off the 4.7uF cap. It's probably my PCB (don't think the auto-route did a great job of it) but it made the radio flaky. Works just fine without it.
            Now to find a box to put it in...
            hekH RJ_MakeR Q 4 Replies Last reply
            • B Bandra
              Nice @Bandra!
              • Z Zeph
                marceltrapmanM
                marceltrapmanM
                marceltrapman
                Interesting but even when I am willing to stock them up (50 pcs) the shipment costs exceed the price of them :(
                Fulltime Servoy Developer
                bjornhallbergB Z 2 Replies Last reply
                  bjornhallbergB
                  bjornhallbergB
                  bjornhallberg
                  @marceltrapman Have you looked at AliExpress? Seems they had a few sellers offering this chip.
                    marceltrapmanM
                    marceltrapmanM
                    marceltrapman
                    I never considered them. Took the plunge for a little less then 0,19 EU per piece :)
                      Z
                      Z
                      Zeph
                      Sorry. The problem with 4 Mb chip is that it's so cheap one feels bad about the shipping cost! :-)
                      I was also looking at some 128Mb (16 MB) flash memories at $2.78, where the shipping would be a smaller part of the order
                      More seriously, I hope the Ali Express order works well.
                      • B Bandra
                        RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        @Bandra Looks fantastic! I'll take 3 :-)
                        RJ_Make
                        B 1 Reply Last reply
                        • RJ_MakeR RJ_Make
                          B
                          B
                          Bandra
                          @ServiceXp
                          Thanks mate! I've soldered up 3 of the boards now and they're all working fine.
                          So far I've made one just with temp and light. One with temp, light and humidity, and one with temp, light, humidity and pressure. I'll make one more tonight that will just have temp and soil moisture.
                          I'm not entirely happy with the two caps at the bottom of the board. The auto-route feature of Eagle is good, but I don't think it quite got that right. Seems to run fine without the two caps so the PCBs are not a write-off.
                          I've got way more boards than I need. So I'm happy to send 3 off to you. PM me your address.
                          marceltrapmanM RJ_MakeR 2 Replies Last reply
                          • B Bandra
                            @ServiceXp
                            marceltrapmanM
                            marceltrapmanM
                            marceltrapman
                            What is it that you are not happy about?
                            Trying to learn here because I am still not sure if I will just make my boards myself or keep it with one or two prototypes and use iTead as well...
                            Talking about iTead, I saw that they can also check your board, did you decide against that?
                            • B Bandra
                              @ServiceXp
                              RJ_MakeR
                              RJ_MakeR
                              RJ_Make
                              @Bandra Thanks, I sent you a PM... I think.. I used the "Chat" system... ;-)
                              RJ_Make
                                B
                                B
                                Bandra
                                @marceltrapman
                                The auto-route feature in Eagle attempts to make the most efficient board layout it can. To do that, it seems to join the traces where ever it can. When you click on the rats nest button, it will combine any GND traces that it can. Since the cap sits on GND, for example, it assumes it can put it anywhere on a GND trace, and physically dislocates it from the radio pins. I just noticed that on my board, for example, the nRF24 cap doesn't sit directly across + and -.
                                So my next go I would manually route those traces first then auto-route the rest.
                                It's no big deal, because if I get bad reception then I can always solder the decoupling cap directly onto the radio.
                                I did choose the option to check my board. It's my very first PCB (which is why I didn't pick up the problem) so I was expecting for them to find lots of problems. But it turns out that technically my board is correct. It's the "logic" of the board that's wrong, so iTead could not have picked this up.
                                Lesson learned!
                                • B Bandra
                                  @marceltrapman
                                  Lesson learned!
                                  marceltrapmanM
                                  marceltrapmanM
                                  marceltrapman
                                  @Bandra Aha. Thank you for the explanation.
                                  I don't use auto-route at all. Sometimes I check it out, when I am tempted to try to avoid my brains doing overtime at finding a new route for yet another trace, but I always undo it.
                                  • J
                                    J
                                    jribera
                                    Is anyone with a tested and working sensors PCB willing to share the design files ? This way people can order directly from oshpark, iteed etc. I'm sure these will make a great addition to the mysensors.org website.
                                    • DvbitD
                                      DvbitD
                                      Dvbit
                                      Hi
                                      I would also benefit from the sharing on OSHPark or similar sites as I am a total newbie.
                                      Btw thanks to all the pros for their great work ;-)
                                      Bandra your design is for now the one that gets closer to my desires. Really nice compact and flexible
                                      • Z Zeph
                                        ToSa
                                        Code Contributor
                                        Any proposals for DIP-8 flash to use for breadboard testing that are compatible to avoid surprises when switching to the SOT-8 ones later-on? Do all of these SPIflash chips use the same "protocol"?
                                        • Z
                                          Z
                                          Zeph
                                          @ToSa
                                          Here's a dip version of the next larger brother from adafruit:for $1.95 https://www.adafruit.com/products/1564
                                          Then digikey has the soic for $0.43
                                          http://www.digikey.com/product-search/en?x=0&y=0&lang=en&site=us&keywords=W25Q80BV
                                          (Digikey has listings for the dip version but 0 stock)
                                          I have not used these so I don't have any first hand recommendation. I cued in on this line because Felix uses the 4Mbit version on the Moteino, so I looked it up and thought it looked good.
                                          (The Anarduino uses a 128 Mbit spi flash chip from a different line).
