  3. Energy harvester
Energy harvester
supercapacitorpower supply
27 Posts 9 Posters 18.3k Views 5 Watching
  • epierreE epierre
    Just an idea, an interresting boardd would be the one to have an efficient management of battery and solar panel for arduino projects, such as the one on the ceech board but for arduini.
    I would say it would be most helpful for Particle.io projects too for they propose something to small IMHO.
    C
    C
    ceech
    @epierre I'm working on it. The board is finished, just needs a test.Untitled.png
    epierreE 1 Reply Last reply
    • SparkmanS Sparkman
      @ceech They look great Roman. Are you offering them for sale?
      Al
      C
      C
      ceech
      wrote on last edited by ceech
      @Sparkman Take a look at my eBay listings.
      SparkmanS 1 Reply Last reply
      • C
        C
        ceech
        Here is the link to design files: https://github.com/ceech
        • F
          F
          Fabien
          Amazing product. We can have sensors like enocean with mysensors !
          With Sensebender, can we send data every minutes with your energy harvester ?
          C 1 Reply Last reply
          • C ceech
            SparkmanS
            SparkmanS
            Sparkman
            Great, thanks!
            • F Fabien
              C
              C
              ceech
              @Fabien Thank you. Yes, it's possible. It depends on the input power source.
              • C ceech
                epierreE
                epierreE
                epierre
                Here is a link to the particle one: https://docs.particle.io/datasheets/photon-shields/#power-shield
                certainly a solar panel is quite big, but if it would fit in the solar lamp shown elsewhere, it would be very useful to provide an exterior packaging with solar panel.
                z-wave - Vera -> Domoticz
                • epierreE epierre
                  C
                  C
                  ceech
                  @epierre It's finished as well and tested working.
                  Next will be the particle one.
                  • F
                    F
                    fleinze
                    What chip do you use for the solar energy harvester board?
                      How fast do the capacitors self drain at night? I tried some quick measurements a Maxwell super capacitor, and it seemed to lose a lot of its charge just sitting still with nothing connected to it. Are there any super capacitors that are known to hold on to their charge quite well?
                      • AnticimexA
                        AnticimexA
                        Anticimex
                        Interesting stuff! Under what license do you work? I an only asking because I think energy harvesters would be a good concept for MYSX daughter boards. You are welcome to consider it for your design, or you can let me have a stab at a reshuffled board for MYSX use. I could not find the boards on github, but I don't have eagle installed either, so they are probably inside one of the other boards there.
                        If you are unfamiliar with MYSX, there is a specification.
                        C 2 Replies Last reply
                        • F fleinze
                          C
                          C
                          ceech
                          @fleinze It is a LTC4079
                            C
                            C
                            ceech
                            @NeverDie One of the problems is the charge/discharge curve:
                            As you can see the capacitor loses a lot of its charge in the moments right after it starts discharging. It holds the bottom half of the charge better. They are useful for short pulses of energy. But they are not batteries by any means.
                            Source: http://www3.ncc.edu/faculty/ens/schoenf/ELT115/UCC.html
                            And the other is an improper measurement. The multimeter draws current from capacitor. Anyway here is a graph of self discharge rates by capacitor type:
                            Source: http://www.robotroom.com/Capacitor-Self-Discharge-1.html
                            • AnticimexA Anticimex
                              C
                              C
                              ceech
                              @Anticimex I'm familiar with mysensor boards and the thought had crossed my mind. I'll do it, I just haven't come around to take the time, yet.
                                C
                                C
                                ceech
                                @Anticimex I'm trying to create a harvester board with MYSX_1.0 connector on it. I think I got the position requirements figured out but I'm not sure I understand the connections that are supposed to be present. I got the GND and 3,3V, how about the others? Can you point me in the right direction? Here is what i got so far:
                                AnticimexA 1 Reply Last reply
                                • C ceech
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @ceech well, if you do a board that supplies power, you should use the Vraw signal, because that would be where "motherboards" expect incoming power. 3.3V are typically supplied by the motherboard. So if your subboard is a supplier, it should feed on Vraw. You can see my schematic for a motherboard reference. Also remember when you mount MYSX on a subboard the connector has to go on the reverse side but with the top side footprint to map the pins correctly with the host.
                                    C
                                    C
                                    ceech
                                    @Anticimex After looking at the schematic of the board I think its power consumption exceeds the capabilities of a typical harvester power supply and I'm having second thoughts about it. It is probably not appropriate to be used with it. I might just make it for Sensebender Micro.
                                    • C ceech
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @ceech I fully understand that your board won't handle that particular board. I only referenced it as an example on how a motherboard would manage the power rails in the MYSX connector. So don't be disencouraged by my specific take on a motherboard :)
                                      • C ceech
                                        Here are two new boards. Their purpose is to replace batteries in wireless sensor nodes in places where batteries are not appropriate, available or recommended for use.
                                        The first one is a Thermal Energy Harvester which uses thermopile or thermoelectric generator as a power source:
                                        This board uses a transformer to step-up the voltage and works with voltages as low as 20mV. Here is an intended use:
                                        There are three outputs:
                                        Vout
                                        Vout2 and
                                        VLDO
                                        Vout and VLDO turn on as soon as the voltage on those pins is within regulation and Vout2 turns on when the Vout2_EN signal receives a high on its pin from a microcontroller, for example.
                                        And the second one is a Solar Energy Harvester which is powered by a small 5 - 20V solar cell:
                                        The IC can operate with up to 60V of input voltage and has a built-in CC and CV algorithm.
                                        There are also some settings available for this one:
                                        User can choose output voltage and charge current and also MPPT point of solar cell.
                                        This power supply can act as a battery charger as well.
                                        Both boards are designed to fit on top of sensor board:
                                        to help with connections
                                        Frank HerrmannF
                                        Frank HerrmannF
                                        Frank Herrmann
                                        @ceech Nice Design, but you use a chip he is to expensive 4-6 Euro. Hmm, you now a alternative for this LTC4709?
                                        • Frank HerrmannF Frank Herrmann
                                          C
                                          C
                                          ceech
                                          @Frank-Herrmann Thank you.
                                          This chip might seem expensive, but it's very good at what it does. It's voltage range is far wider than any other's, for example. And CC-CV algorithm for battery stacks for up to 60V. That's what caught my attention. Also I had experience with LTC4067, which I also like.
