  3. Energy harvester
Energy harvester
supercapacitorpower supply
27 Posts 9 Posters 18.3k Views 5 Watching
  • F
    F
    fleinze
    What chip do you use for the solar energy harvester board?
    C 1 Reply Last reply
      How fast do the capacitors self drain at night? I tried some quick measurements a Maxwell super capacitor, and it seemed to lose a lot of its charge just sitting still with nothing connected to it. Are there any super capacitors that are known to hold on to their charge quite well?
      • AnticimexA
        AnticimexA
        Anticimex
        Interesting stuff! Under what license do you work? I an only asking because I think energy harvesters would be a good concept for MYSX daughter boards. You are welcome to consider it for your design, or you can let me have a stab at a reshuffled board for MYSX use. I could not find the boards on github, but I don't have eagle installed either, so they are probably inside one of the other boards there.
        If you are unfamiliar with MYSX, there is a specification.
        C 2 Replies Last reply
        • F fleinze
          C
          C
          ceech
          @fleinze It is a LTC4079
            C
            C
            ceech
            wrote on last edited by ceech
            @NeverDie One of the problems is the charge/discharge curve:
            As you can see the capacitor loses a lot of its charge in the moments right after it starts discharging. It holds the bottom half of the charge better. They are useful for short pulses of energy. But they are not batteries by any means.
            Source: http://www3.ncc.edu/faculty/ens/schoenf/ELT115/UCC.html
            And the other is an improper measurement. The multimeter draws current from capacitor. Anyway here is a graph of self discharge rates by capacitor type:
            Source: http://www.robotroom.com/Capacitor-Self-Discharge-1.html
            • AnticimexA Anticimex
              C
              C
              ceech
              @Anticimex I'm familiar with mysensor boards and the thought had crossed my mind. I'll do it, I just haven't come around to take the time, yet.
                C
                C
                ceech
                @Anticimex I'm trying to create a harvester board with MYSX_1.0 connector on it. I think I got the position requirements figured out but I'm not sure I understand the connections that are supposed to be present. I got the GND and 3,3V, how about the others? Can you point me in the right direction? Here is what i got so far:
                AnticimexA 1 Reply Last reply
                • C ceech
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @ceech well, if you do a board that supplies power, you should use the Vraw signal, because that would be where "motherboards" expect incoming power. 3.3V are typically supplied by the motherboard. So if your subboard is a supplier, it should feed on Vraw. You can see my schematic for a motherboard reference. Also remember when you mount MYSX on a subboard the connector has to go on the reverse side but with the top side footprint to map the pins correctly with the host.
                    C
                    C
                    ceech
                    @Anticimex After looking at the schematic of the board I think its power consumption exceeds the capabilities of a typical harvester power supply and I'm having second thoughts about it. It is probably not appropriate to be used with it. I might just make it for Sensebender Micro.
                    • C ceech
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @ceech I fully understand that your board won't handle that particular board. I only referenced it as an example on how a motherboard would manage the power rails in the MYSX connector. So don't be disencouraged by my specific take on a motherboard :)
                      • C ceech
                        Here are two new boards. Their purpose is to replace batteries in wireless sensor nodes in places where batteries are not appropriate, available or recommended for use.
                        The first one is a Thermal Energy Harvester which uses thermopile or thermoelectric generator as a power source:
                        This board uses a transformer to step-up the voltage and works with voltages as low as 20mV. Here is an intended use:
                        There are three outputs:
                        Vout
                        Vout2 and
                        VLDO
                        Vout and VLDO turn on as soon as the voltage on those pins is within regulation and Vout2 turns on when the Vout2_EN signal receives a high on its pin from a microcontroller, for example.
                        And the second one is a Solar Energy Harvester which is powered by a small 5 - 20V solar cell:
                        The IC can operate with up to 60V of input voltage and has a built-in CC and CV algorithm.
                        There are also some settings available for this one:
                        User can choose output voltage and charge current and also MPPT point of solar cell.
                        This power supply can act as a battery charger as well.
                        Both boards are designed to fit on top of sensor board:
                        to help with connections
                        Frank HerrmannF
                        Frank HerrmannF
                        Frank Herrmann
                        @ceech Nice Design, but you use a chip he is to expensive 4-6 Euro. Hmm, you now a alternative for this LTC4709?
                        • Frank HerrmannF Frank Herrmann
                          C
                          C
                          ceech
                          @Frank-Herrmann Thank you.
                          This chip might seem expensive, but it's very good at what it does. It's voltage range is far wider than any other's, for example. And CC-CV algorithm for battery stacks for up to 60V. That's what caught my attention. Also I had experience with LTC4067, which I also like.
                          • D
                            Dany
                            Since last posts much time has passed. What experiences are related to energy harvesting boards?
                            It can provide an outdoor sensor, for example. BMP180 node supply all night long?
                            • D Dany
                              C
                              C
                              ceech
                              @Dany Yes, it can. While those boards are mostly used for short energy bursts, I made some continuous current draw measurements. I've attached an LED with current draw of 3.5mA. The board provided 20 minutes of power while dropping the voltage from 2.3V to 1.86V.
                              • epierreE
                                epierreE
                                epierre
                                @ceech what thermopiles could be used with your board ? I don't find any reference for it?
                                thanks
                                z-wave - Vera -> Domoticz
                                • epierreE epierre
                                  thanks
                                  C
                                  C
                                  ceech
                                  @epierre You can use a Peltier element to power this board. Like this one:
                                  http://www.ebay.com/itm/TEC1-12706-12V-60W-Heatsink-Thermoelectric-Cooler-Cooling-Peltier-Plate-Module-/121349774916?hash=item1c41029e44:g:mukAAOSwDNdVrg-U
