  3. SerialGateway can't send to nodes via rules or Serial Monitor
18 Posts 3 Posters 5.0k Views 2 Watching
  • J
    J
    jgporteous
    Hi Hek,
    If you look at this: https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/SerialGateway/SerialGateway.ino
    Line 117 to 123 takes a message and sends it. This is what I'm trying to do, so my code is the same already. :)
    I'm just not sure why it's not working.
    J
      Ah..
      Sure you don't mean to do a msg.setDestination(4)?
      • J
        J
        jgporteous
        let me look that up and try :)
        • J
          J
          jgporteous
          @hek said:
          msg.setDestination
          Here is a silly question, do I need on msg variable per sensor on my arduino node - Currently I only have one, and do a msg.preset for each?
          These are the rules I have (only applicable to this problem):
          //switch function
          val org.eclipse.xtext.xbase.lib.Functions$Function4 switchOperation = [
              org.openhab.core.library.items.SwitchItem relayItem,
              org.openhab.core.library.items.StringItem arduinoItem,
              String arduinoDevMap,
              Integer subType|
              logInfo("Function: switchOperation ","Starting for " + relayItem.name)
              var Integer state = 0
              if (relayItem.state != null)
              {   if (relayItem.state == ON) {
                  state = 1
              else {
                  state = 0
              logInfo("Function: switchOperation ",arduinoDevMap + "1;1;" + subType + ";" + state )
              arduinoItem.sendCommand(arduinoDevMap + "1;0;" + subType + ";" + state + "\n")
          // Mappings
          var HashMap<String, String> sensorToItemsMap = newLinkedHashMap(
              "101;0;"            -> "Balcony_Temperature_Soil"
              ,"Balcony_Temperature_Soil"       -> "101;0;"
              ,"101;1;"            -> "Balcony_Temperature_Air"
              ,"Balcony_Temperature_Air"       -> "101;1;"
              ,"101;2;"            -> "Balcony_Humidity_Air"
              ,"Balcony_Humidity_Air"       -> "101;2;"
              ,"101;3;"            -> "Balcony_Light_Lux"
              ,"Balcony_Light_Lux"       -> "101;3;"
              ,"101;4;"            -> "Balcony_Water_Relay"
              ,"Balcony_Water_Relay"      -> "101;4;"
          rule "Balcony_Water_Relay Switch Rule"
              when
                  Item Balcony_Water_Relay changed
              then
              logInfo("Water Relay","Changing state of Water Relay")
                  switchOperation.apply(Balcony_Water_Relay, Arduino, sensorToItemsMap.get("Balcony_Water_Relay"), V_LIGHT)
          end
            Sorry, I'm not the one to ask for openhab help.
            • J
              J
              jgporteous
              Ok, so if I take a step back and exclude OpenHab.
              Surly I should be able to send data from gateway to a node?
              I can send from node to gateway, and ACK is returned successfully.
              So, If I use a serial interface and send a string, like I did above, should that work with API 1.5?
                The api in 1.5 isn't built for attaching sensors on the gateway itself (when it comes to presenting and sending data to the controller). But if you hack around a bit you can do like the Serial gateway example and send out messages from the gateway to nodes in the radio network.
                In the branch I'm working on now the gateway acts like any other sensor.
                • J
                  J
                  jgporteous
                  Hi Hek,
                  I don't want to add a sensor to the gateway, I want to send a command to a node with the sensor.
                  J
                  • J
                    J
                    jgporteous
                    Hi Everyone,
                    I tried adding the following code to my gateway, to see if it will send the value to the sensor to set it, but it fails with:
                    0;0;3;0;9;send: 0-0-101-101 s=2,c=1,t=2,pt=2,l=2,sg=0,st=fail:1
                    Added to loop():
                      if (!sentSensorValue)
                    	  delay(2500);
                    	  MyMessage message;
                    	  message.setDestination(101);
                    	  message.setSensor(2);
                    	  message.setType(2);
                    	  message.set(1);
                    	  gw.send(message);
                    	  sentSensorValue = true;
                    • rvendrameR
                      rvendrameR
                      rvendrame
                      How are you powering your GW ( arduino and radio)? st=fail:1 usually indicates a problem with power (radio is more sensitive to power noise / fluctuations ).
                      ESP8266 GW + mySensors 2.3.2
                      Alexa / Google Home
                      • J
                        J
                        jgporteous
                        I'm powering the gateway from raspberry pi 2 and has a 10uF Cap.
                        The node is powered from Arduino Nano and has a 22uF Cap.
                        I have tried giving each radio module a separate power supply but that didn't help.
                        What is interesting though, is that the module sends sensor values for 4 sensors and with ACK, the gateway (Arduino) replies successfully. The failure only comes when I try send from parse information from serial input.
                        I think I'm going to try put bigger capacitors on each and see what happens... just not sure how big I can go :)
                        J
                        • J
                          J
                          jgporteous
                          I upgraded the Cap on the gateway to a 47uF and no change...
                          This is the serial monitor of the Node, as you can see, it's successfully transmitting data:
                          send: 101-101-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                          send: 101-101-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                          send: 101-101-0-0 s=2,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                          send: 101-101-0-0 s=3,c=0,t=16,pt=0,l=0,sg=0,st=ok:
                          send: 101-101-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                          send: 101-101-0-0 s=4,c=1,t=0,pt=2,l=2,sg=0,st=ok:0
                          send: 101-101-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:24.73
                          send: 101-101-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:23.00
                          send: 101-101-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,st=ok:39
                          send: 101-101-0-0 s=3,c=1,t=0,pt=7,l=5,sg=0,st=ok:75
                          send: 101-101-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,st=ok:42
                          send: 101-101-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:24.82
                          send: 101-101-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,st=ok:41
                          send: 101-101-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:24.91
                          send: 101-101-0-0 s=3,c=1,t=0,pt=7,l=5,sg=0,st=ok:74
                          send: 101-101-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:24.64
                          This is the serial output of the gateway, where I let it read for a while then send command via serial (101;4;1;0;3;0):
                          0;0;3;0;9;read: 101-101-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.91
                          101;0;1;0;0;24.91
                          0;0;3;0;9;read: 101-101-0 s=3,c=1,t=0,pt=7,l=5,sg=0:74
                          101;3;1;0;0;74
                          0;0;3;0;9;read: 101-101-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.82
                          101;0;1;0;0;24.82
                          101;0;1;0;0;24.91
                          0;0;3;0;9;read: 101-101-0 s=3,c=1,t=0,pt=7,l=5,sg=0:75
                          101;3;1;0;0;75
                          101;0;1;0;0;24.82
                          0;0;3;0;9;read: 101-101-0 s=2,c=1,t=0,pt=7,l=5,sg=0:42
                          101;2;1;0;0;42
                          0;0;3;0;9;read: 101-101-0 s=2,c=1,t=0,pt=7,l=5,sg=0:41
                          101;2;1;0;0;41
                          Sending command from serial input...
                          Destination: 101
                          Sensor: 4
                          sensorType: 0
                          Type: 3
                          Ack: 0
                          Payload: 0
                          0;0;3;0;9;send: 0-0-101-101 s=4,c=1,t=3,pt=4,l=4,sg=0,st=fail:0
                          0;0;3;0;9;read: 101-101-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.73
                          101;0;1;0;0;24.73
                          0;0;3;0;9;read: 101-101-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.64
                          101;0;1;0;0;24.64
                          101;0;1;0;0;24.73
                          101;0;1;0;0;24.64
                          • J
                            J
                            jgporteous
                            wrote on last edited by jgporteous
                            I did another test, I sent all presentation of sensors to request ACK and this below is the output.
                            Although there is only two fails, I think I'm going to have to setup dedicated power for each and try again... unless there is another way?
                            Gateway:
                            0;0;3;0;9;read: 101-101-0 s=255,c=3,t=11,pt=0,l=15,sg=0:Balcony Senso
                            0;0;3;0;9;send: 0-0-101-101 s=255,c=3,t=11,pt=0,l=15,sg=0,st=fail:Bal
                            101;255;3;0;11;Balcony Sensors
                            0;0;3;0;9;read: 101-101-0 s=0,c=0,t=6,pt=0,l=9,sg=0:Soil Temp
                            0;0;3;0;9;send: 0-0-101-101 s=0,c=0,t=6,pt=0,l=9,sg=0,st=ok:Soil Temp
                            101;0;0;0;6;Soil Temp
                            0;0;3;0;9;read: 101-101-0 s=1,c=0,t=6,pt=0,l=8,sg=0:Air Temp
                            0;0;3;0;9;send: 0-0-101-101 s=1,c=0,t=6,pt=0,l=8,sg=0,st=fail:Air Tem
                            101;1;0;0;6;Air Temp
                            0;0;3;0;9;read: 101-101-0 s=2,c=0,t=7,pt=0,l=12,sg=0:Air Humitidy
                            0;0;3;0;9;send: 0-0-101-101 s=2,c=0,t=7,pt=0,l=12,sg=0,st=fail:Air Hu
                            101;2;0;0;7;Air Humitidy
                            0;0;3;0;9;read: 101-101-0 s=4,c=0,t=3,pt=0,l=11,sg=0:Water Relay
                            0;0;3;0;9;send: 0-0-101-101 s=4,c=0,t=3,pt=0,l=11,sg=0,st=ok:Water Re
                            101;4;0;0;3;Water Relay
                            101;0;1;0;0;24.64
                            0;0;3;0;9;read: 101-101-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.00
                            101;1;1;0;0;23.00
                            101;2;1;0;0;41
                            0;0;3;0;9;read: 101-101-0 s=3,c=1,t=0,pt=7,l=5,sg=0:76
                            101;3;1;0;0;76
                            0;0;3;0;9;read: 101-101-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.56
                            101;0;1;0;0;24.56
                            101;2;1;0;0;42
                            Node:
                            send: 101-101-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                            send: 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                            sensor started, id=101, parent=0, distance=1
                            send: 101-101-0-0 s=255,c=3,t=11,pt=0,l=15,sg=0,st=ok:Balcony Sensors
                            send: 101-101-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.1
                            send: 101-101-0-0 s=0,c=0,t=6,pt=0,l=9,sg=0,st=ok:Soil Temp
                            send: 101-101-0-0 s=1,c=0,t=6,pt=0,l=8,sg=0,st=ok:Air Temp
                            send: 101-101-0-0 s=2,c=0,t=7,pt=0,l=12,sg=0,st=ok:Air Humitidy
                            send: 101-101-0-0 s=3,c=0,t=16,pt=0,l=11,sg=0,st=fail:Light Level
                            send: 101-101-0-0 s=4,c=0,t=3,pt=0,l=11,sg=0,st=ok:Water Relay
                            send: 101-101-0-0 s=4,c=1,t=0,pt=2,l=2,sg=0,st=fail:0
                            read: 0-0-101 s=0,c=0,t=6,pt=0,l=9,sg=0:Soil Temp
                            Incoming message: Soil Temp   Sensor: 0
                            Value:
                            Soil Temp
                            send: 101-101-0-0 s=3,c=1,t=0,pt=7,l=5,sg=0,st=ok:76
                            read: 0-0-101 s=4,c=0,t=3,pt=0,l=11,sg=0:Water Relay
                            Incoming message: Water Relay   Sensor: 4
                            Value:
                            Water Relay
                            send: 101-101-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:24.56
                            send: 101-101-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,st=ok:41```
                            • J
                              J
                              jgporteous
                              @jgporteous said:
                              101;4;1;0;3;0
                              Added ACK to one of my senors, node sending values correctly, but ACK failing.
                              I've bumped up the CAP on the gateway to 330uF and no change :(
                              I also dropped bandwidth to 250Kbps and power to low, no change either.
