  3. SerialGateway can't send to nodes via rules or Serial Monitor
18 Posts 3 Posters 5.0k Views 2 Watching
  • J
    J
    jgporteous
    @hek said:
    msg.setDestination
    Here is a silly question, do I need on msg variable per sensor on my arduino node - Currently I only have one, and do a msg.preset for each?
    These are the rules I have (only applicable to this problem):
    //switch function
    val org.eclipse.xtext.xbase.lib.Functions$Function4 switchOperation = [
        org.openhab.core.library.items.SwitchItem relayItem,
        org.openhab.core.library.items.StringItem arduinoItem,
        String arduinoDevMap,
        Integer subType|
        logInfo("Function: switchOperation ","Starting for " + relayItem.name)
        var Integer state = 0
        if (relayItem.state != null)
        {   if (relayItem.state == ON) {
            state = 1
        else {
            state = 0
        logInfo("Function: switchOperation ",arduinoDevMap + "1;1;" + subType + ";" + state )
        arduinoItem.sendCommand(arduinoDevMap + "1;0;" + subType + ";" + state + "\n")
    // Mappings
    var HashMap<String, String> sensorToItemsMap = newLinkedHashMap(
        "101;0;"            -> "Balcony_Temperature_Soil"
        ,"Balcony_Temperature_Soil"       -> "101;0;"
        ,"101;1;"            -> "Balcony_Temperature_Air"
        ,"Balcony_Temperature_Air"       -> "101;1;"
        ,"101;2;"            -> "Balcony_Humidity_Air"
        ,"Balcony_Humidity_Air"       -> "101;2;"
        ,"101;3;"            -> "Balcony_Light_Lux"
        ,"Balcony_Light_Lux"       -> "101;3;"
        ,"101;4;"            -> "Balcony_Water_Relay"
        ,"Balcony_Water_Relay"      -> "101;4;"
    rule "Balcony_Water_Relay Switch Rule"
        when
            Item Balcony_Water_Relay changed
        then
        logInfo("Water Relay","Changing state of Water Relay")
            switchOperation.apply(Balcony_Water_Relay, Arduino, sensorToItemsMap.get("Balcony_Water_Relay"), V_LIGHT)
    end
      Sorry, I'm not the one to ask for openhab help.
      • J
        J
        jgporteous
        Ok, so if I take a step back and exclude OpenHab.
        Surly I should be able to send data from gateway to a node?
        I can send from node to gateway, and ACK is returned successfully.
        So, If I use a serial interface and send a string, like I did above, should that work with API 1.5?
          The api in 1.5 isn't built for attaching sensors on the gateway itself (when it comes to presenting and sending data to the controller). But if you hack around a bit you can do like the Serial gateway example and send out messages from the gateway to nodes in the radio network.
          In the branch I'm working on now the gateway acts like any other sensor.
          • J
            J
            jgporteous
            Hi Hek,
            I don't want to add a sensor to the gateway, I want to send a command to a node with the sensor.
            J
            • J
              J
              jgporteous
              Hi Everyone,
              I tried adding the following code to my gateway, to see if it will send the value to the sensor to set it, but it fails with:
              0;0;3;0;9;send: 0-0-101-101 s=2,c=1,t=2,pt=2,l=2,sg=0,st=fail:1
              Added to loop():
                if (!sentSensorValue)
              	  delay(2500);
              	  MyMessage message;
              	  message.setDestination(101);
              	  message.setSensor(2);
              	  message.setType(2);
              	  message.set(1);
              	  gw.send(message);
              	  sentSensorValue = true;
              • rvendrameR
                rvendrameR
                rvendrame
                How are you powering your GW ( arduino and radio)? st=fail:1 usually indicates a problem with power (radio is more sensitive to power noise / fluctuations ).
                ESP8266 GW + mySensors 2.3.2
                Alexa / Google Home
                • J
                  J
                  jgporteous
                  I'm powering the gateway from raspberry pi 2 and has a 10uF Cap.
                  The node is powered from Arduino Nano and has a 22uF Cap.
                  I have tried giving each radio module a separate power supply but that didn't help.
                  What is interesting though, is that the module sends sensor values for 4 sensors and with ACK, the gateway (Arduino) replies successfully. The failure only comes when I try send from parse information from serial input.
                  I think I'm going to try put bigger capacitors on each and see what happens... just not sure how big I can go :)
                  J
                  • J
                    J
                    jgporteous
                    I upgraded the Cap on the gateway to a 47uF and no change...
                    This is the serial monitor of the Node, as you can see, it's successfully transmitting data:
                    send: 101-101-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                    send: 101-101-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                    send: 101-101-0-0 s=2,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                    send: 101-101-0-0 s=3,c=0,t=16,pt=0,l=0,sg=0,st=ok:
                    send: 101-101-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
                    send: 101-101-0-0 s=4,c=1,t=0,pt=2,l=2,sg=0,st=ok:0
                    send: 101-101-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:24.73
                    send: 101-101-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:23.00
                    send: 101-101-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,st=ok:39
                    send: 101-101-0-0 s=3,c=1,t=0,pt=7,l=5,sg=0,st=ok:75
                    send: 101-101-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,st=ok:42
                    send: 101-101-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:24.82
                    send: 101-101-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,st=ok:41
                    send: 101-101-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:24.91
                    send: 101-101-0-0 s=3,c=1,t=0,pt=7,l=5,sg=0,st=ok:74
                    send: 101-101-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:24.64
                    This is the serial output of the gateway, where I let it read for a while then send command via serial (101;4;1;0;3;0):
                    0;0;3;0;9;read: 101-101-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.91
                    101;0;1;0;0;24.91
                    0;0;3;0;9;read: 101-101-0 s=3,c=1,t=0,pt=7,l=5,sg=0:74
                    101;3;1;0;0;74
                    0;0;3;0;9;read: 101-101-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.82
                    101;0;1;0;0;24.82
                    101;0;1;0;0;24.91
                    0;0;3;0;9;read: 101-101-0 s=3,c=1,t=0,pt=7,l=5,sg=0:75
                    101;3;1;0;0;75
                    101;0;1;0;0;24.82
                    0;0;3;0;9;read: 101-101-0 s=2,c=1,t=0,pt=7,l=5,sg=0:42
                    101;2;1;0;0;42
                    0;0;3;0;9;read: 101-101-0 s=2,c=1,t=0,pt=7,l=5,sg=0:41
                    101;2;1;0;0;41
                    Sending command from serial input...
                    Destination: 101
                    Sensor: 4
                    sensorType: 0
                    Type: 3
                    Ack: 0
                    Payload: 0
                    0;0;3;0;9;send: 0-0-101-101 s=4,c=1,t=3,pt=4,l=4,sg=0,st=fail:0
                    0;0;3;0;9;read: 101-101-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.73
                    101;0;1;0;0;24.73
                    0;0;3;0;9;read: 101-101-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.64
                    101;0;1;0;0;24.64
                    101;0;1;0;0;24.73
                    101;0;1;0;0;24.64
                    • J
                      J
                      jgporteous
                      wrote on last edited by jgporteous
                      I did another test, I sent all presentation of sensors to request ACK and this below is the output.
                      Although there is only two fails, I think I'm going to have to setup dedicated power for each and try again... unless there is another way?
                      Gateway:
                      0;0;3;0;9;read: 101-101-0 s=255,c=3,t=11,pt=0,l=15,sg=0:Balcony Senso
                      0;0;3;0;9;send: 0-0-101-101 s=255,c=3,t=11,pt=0,l=15,sg=0,st=fail:Bal
                      101;255;3;0;11;Balcony Sensors
                      0;0;3;0;9;read: 101-101-0 s=0,c=0,t=6,pt=0,l=9,sg=0:Soil Temp
                      0;0;3;0;9;send: 0-0-101-101 s=0,c=0,t=6,pt=0,l=9,sg=0,st=ok:Soil Temp
                      101;0;0;0;6;Soil Temp
                      0;0;3;0;9;read: 101-101-0 s=1,c=0,t=6,pt=0,l=8,sg=0:Air Temp
                      0;0;3;0;9;send: 0-0-101-101 s=1,c=0,t=6,pt=0,l=8,sg=0,st=fail:Air Tem
                      101;1;0;0;6;Air Temp
                      0;0;3;0;9;read: 101-101-0 s=2,c=0,t=7,pt=0,l=12,sg=0:Air Humitidy
                      0;0;3;0;9;send: 0-0-101-101 s=2,c=0,t=7,pt=0,l=12,sg=0,st=fail:Air Hu
                      101;2;0;0;7;Air Humitidy
                      0;0;3;0;9;read: 101-101-0 s=4,c=0,t=3,pt=0,l=11,sg=0:Water Relay
                      0;0;3;0;9;send: 0-0-101-101 s=4,c=0,t=3,pt=0,l=11,sg=0,st=ok:Water Re
                      101;4;0;0;3;Water Relay
                      101;0;1;0;0;24.64
                      0;0;3;0;9;read: 101-101-0 s=1,c=1,t=0,pt=7,l=5,sg=0:23.00
                      101;1;1;0;0;23.00
                      101;2;1;0;0;41
                      0;0;3;0;9;read: 101-101-0 s=3,c=1,t=0,pt=7,l=5,sg=0:76
                      101;3;1;0;0;76
                      0;0;3;0;9;read: 101-101-0 s=0,c=1,t=0,pt=7,l=5,sg=0:24.56
                      101;0;1;0;0;24.56
                      101;2;1;0;0;42
                      Node:
                      send: 101-101-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                      send: 101-101-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                      sensor started, id=101, parent=0, distance=1
                      send: 101-101-0-0 s=255,c=3,t=11,pt=0,l=15,sg=0,st=ok:Balcony Sensors
                      send: 101-101-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:1.1
                      send: 101-101-0-0 s=0,c=0,t=6,pt=0,l=9,sg=0,st=ok:Soil Temp
                      send: 101-101-0-0 s=1,c=0,t=6,pt=0,l=8,sg=0,st=ok:Air Temp
                      send: 101-101-0-0 s=2,c=0,t=7,pt=0,l=12,sg=0,st=ok:Air Humitidy
                      send: 101-101-0-0 s=3,c=0,t=16,pt=0,l=11,sg=0,st=fail:Light Level
                      send: 101-101-0-0 s=4,c=0,t=3,pt=0,l=11,sg=0,st=ok:Water Relay
                      send: 101-101-0-0 s=4,c=1,t=0,pt=2,l=2,sg=0,st=fail:0
                      read: 0-0-101 s=0,c=0,t=6,pt=0,l=9,sg=0:Soil Temp
                      Incoming message: Soil Temp   Sensor: 0
                      Value:
                      Soil Temp
                      send: 101-101-0-0 s=3,c=1,t=0,pt=7,l=5,sg=0,st=ok:76
                      read: 0-0-101 s=4,c=0,t=3,pt=0,l=11,sg=0:Water Relay
                      Incoming message: Water Relay   Sensor: 4
                      Value:
                      Water Relay
                      send: 101-101-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:24.56
                      send: 101-101-0-0 s=2,c=1,t=0,pt=7,l=5,sg=0,st=ok:41```
                      • J
                        J
                        jgporteous
                        @jgporteous said:
                        101;4;1;0;3;0
                        Added ACK to one of my senors, node sending values correctly, but ACK failing.
                        I've bumped up the CAP on the gateway to 330uF and no change :(
                        I also dropped bandwidth to 250Kbps and power to low, no change either.
