  3. ESP8266 WiFi gateway port for MySensors
328 Posts 56 Posters 406.4k Views 39 Watching
  • V vickey
    Hi Friends
    I am having an issue with my NRF24L01+. If I change gw.begin() to anything like below,
    I get an error "radio init fail"
    And I am now trying ESP-8266 12E module along with nrf24L01+ (genuine) transceiver to built wifi gateway, which I'll later use as gateway for openhab. I am having a similar issue, Here is the log I get through serial monitor.
    **Connecting to Ahmed
    ...........Connected!
    IP: 192.168.0.31
    0;0;3;0;9;radio init fail
    ctx: cont
    sp: 3ffebdf0 end: 3ffec010 offset: 01b0
    stack>>>
    3ffebfa0: 0000007f 3ffec03c 40201cac 3ffeaff0
    3ffebfb0: 40202320 00000001 00000000 40201d4f
    3ffebfc0: 1f00a8c0 00ffffff 0100a8c0 3ffec03c
    3ffebfd0: 3ffe9328 3ffead34 3ffec070 402026ef
    3ffebfe0: 3ffe98a8 1f00a8c0 00000000 00000000
    3ffebff0: 3fffdc20 00000000 3ffec034 40201d1f
    3ffec000: 00000000 00000000 3ffeaff0 40100398
    <<<stack<<<
    ets Jan 8 2013,rst cause:1, boot mode:(3,3)
    tail 0
    chksum 0x42
    csum 0x42
    ~ld**
    This information runs in a loop again and again. I am using latest library from https://github.com/mysensors/Arduino/tree/master without editing the sample Esp8266Gateway sktech except user name and password. I have followed the connection instruction specified in sample sketch and sketch was successfully uploaded. I am using 101nf capacitors and 10K resistances as specified by https://www.youtube.com/watch?v=JA-0hs5rpMY.
    Everything is working fine except that error. May anyone help me out?
    @vickey the resets you're experiencing are caused by the failure to init the radio. This will cause the MySensors library to enter an endless loop. This will cause the watchdog to trigger and reset the ESP.
    Please try connecting the radio exactly as stated on the MySensors build page (when using NodeMcu hardware) or connect the same way as I did (see first post in this topic).
    Double check your radio connections.
    • V
      V
      vickey
      wrote on last edited by vickey
      #88
      I have checked all the wires and every thing is according to as par advised. I am using 2 separate 3.3 v voltage regulator to power up ESP-8266 12E and nrf24L01+ having common ground, using ESP-8266 breakout board without voltage regulator and nrf24l01+ breakout board with 3.3 v regulator powered by 5v supply.
      GPIO15 connected via 10K pulldown resistor to GND and also connected with CSN of nrf24l016, is this connection correct?
      Moreover, I am using USB to TTL adapter in place of FTDI and TX of ESP-8266 is connected with RX of TTL serial adapter and vice versa, GND of TTL serial adapter is also connected common GND. It's all the difference from your mentioned procedure.
      • V vickey
        @vickey could the nrf24 be defective?
        Did you obtain the gateway & MySensors code from my github repository or from MySensors repository?
        • V
          V
          vickey
          #90
          Sorry When I investigate the wiring throughly, MOSI and MISO was interchanged. Now it has started working but error has changed
          ESP8266 MySensors Gateway
          Connecting to Ahmed
          .......Connected!
          IP: 192.168.0.31
          0;0;3;0;9;read: 0-0-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
          0;0;3;0;9;ver mismatch
          I obtained the code for gateway & MySensors from MySensors repository on github.
          what would be the problem now?
          • R
            R
            ridge
            wrote on last edited by ridge
            #91
            I would like to use this tutorial for MySensors in the openHAB program:
            http://forum.mysensors.org/topic/1194/tutorial-openhab-with-serial-gateway
            I have the ESP8266 WiFi gateway working over a telnet session in Putty.
            Is there a way to have openHAB communicate over telnet like a hardwired serial interface?
            Has anyone used this yet?
            https://github.com/openhab/openhab/pull/2832
            • R ridge
              @ridge sorry, can't help with that. Everything's MQTT over here :-)
              • R
                R
                ridge
                Thanks! Are you using this gateway with a controller or is it a proof of concept?
                It is fun to watch the states respond in a telnet session. I am having trouble finding any mention on how to use this with a controller.
                • R ridge
                  @ridge its use should be no different then when using the Ethernet gateway (because it is an Ethernet gateway :-) )
                  I'm using it with OpenHab through MQTT and NodeRed through MQTT.
                  • R
                    R
                    ridge
                    Is your setup using this gateway like:
                    MySensors network <=>Gateway <=> Format conversion program <=> MQTT broker <=> openHAB
                    For some reason, I had assumed that the results of the gateway could be used directly in openHAB.
                    hekH YveauxY 2 Replies Last reply
                    • R ridge
                      @ridge
                      Tried this?
                      http://forum.mysensors.org/topic/1598/openhab-2-0-binding
                      • R
                        R
                        ridge
                        Thanks hek, OpenHAB 1.7.1 is stable for me. I will probably wait for openHAB 2.0 to get closer to production status before wading in.
                        I understand serial binding.
                        I understand MQTT binding.
                        I am missing something stupid easy in understanding ethernet binding.
                        Do I include the http binding in the addons folder?
                        A serial connected device is defined in an openHAB items file like:
                        Switch HardwareButton "Bell" (Entrance) { serial="/dev/ttyS0" }
                        I just cannot find an example of what an ethernet connected device would use in place of the "serial" definition.
                        hekH 1 Reply Last reply
                        • R ridge
                          #98
                          Yes. Production gateway is currently (cabled) ethernet gateway, "Format conversion program" is this perl script and MQTT broker is Mosquitto.
                          Perl script, Mosquitto and OpenHab run on Ubuntu 12.04LTS server PC.
                          • R ridge
                            @ridge
                            You could always use ser2net to emulate a serial port connected to the ethernet gateway from you openhab box.
                            • R
                              R
                              ridge
                              Thank you hek and Yveaux. I thought I had missed something obvious. For the present with openHAB 1.7.1, a small piece of the wireless sensor data super highway of the future is still under construction! In that case I will certainly study the MySensors gateway to MQTT broker examples closely.
                              • P
                                P
                                Pseudomizer
                                Hello guys,
                                I am having issues with this installation. I got everything up and running but it simply doesn't connect to my WiFi Netgear router at home.
                                I just enabled my hotspot on my cell phone and the gateway did connect successfully and started the gateway master with IP, etc assigned.
                                When I try to connect to my home WiFi it just keeps on printing dot dot dot in the serial console.
                                My Netgear has two networks with 2.4Ghz and 5Ghz. I tried both and none of them worked. They are configured with WPA2-PSK [AES] encryption for the passphrase and the passphrase has one special character included. The SSID is 5 characters long and the passphrase is 22 characters long which shouldn't be an issue.
                                I don't get any error messages in the serial console and my router doesn't show anything in the logs either like the ESP gateway doesn't even try to connect. I don't know how to troubleshoot this from here.
                                  I also have both 5/2.4Ghz on my router.
                                  When ESP connects is seems to prefer 2,4 GHz / n / WPA2 if that helps.
                                  • P
                                    P
                                    Pseudomizer
                                    This is what I have. 2,4 GHz / n / WPA2 (no TKIP but AES instead so I can go beyond 54Mbit) and it doesn't connect. Just dots coming up.
                                    • P Pseudomizer
                                      @Pseudomizer Esp8266 is 2.4ghz only.
                                      You could try adding the following line just after hw_init() in the sketch:
                                      Serial.setDebugOutput(true);
                                      It will dump a lot of ESP WiFi related data, please post the output here. Maybe some will give a hint of what goes wrong.
                                      • P
                                        P
                                        Pseudomizer
                                        Thanks a lot for this. This helped me troubleshoot the problem and I am surprised why it didn't connect. It couldn't find my SSID name because in the router it is all UPPER case but when I write it on any other machine Windows, Linux, etc to connect to, I always write it lower case with the exception of the first character.
                                        In this case I modified the sketch to have the SSID name all in UPPER case and voila it connected.
                                        Thanks again for the help here. Much appreciated.
                                        • P
                                          P
                                          Pseudomizer
                                          I was very happy when it connected but now it is resetting itself constantly with this error message:
                                          wdt reset
                                          tail 0
                                          chksum 0x42
                                          csum 0x42
                                          ~ld
                                          Any ideas why?
